  4. Router gewechselt, kein Zugriff auf Weboberfläche mehr
94 Beiträge 10 Kommentatoren 6.5k Aufrufe 8 Beobachtet
  • fiedlesF Offline
    fiedlesF Offline
    fiedles
    könnt ihr aus meinen logs noch weitere Probleme sehen bzw. auswerten?
    hab noch so viele Baustellen, wüsste garnicht wo ich anfangen soll 😰
    • fiedlesF fiedles
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       20:17:50 up 19:48,  1 user,  load average: 1.32, 1.07, 0.93
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-22 20:17:50 CET
                 Universal time: Mon 2024-01-22 19:17:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.7G        5.4G        8.0M        887M        6.0G
      Swap:           99M          0B         99M
      Total:         8.0G        1.7G        5.5G
               7898 M total memory
               1654 M used memory
                533 M active memory
               1788 M inactive memory
               5356 M free memory
                241 M buffer memory
                646 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      117G   13G  100G  12% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Mon Jan 22 00:28:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:F9:AF:43 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c5b1c200-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Jan 22 00:28:55 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Jan 22 00:28:57 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      347M    /var/
      151M    /var/cache
      145M    /var/cache/apt
      93M     /var/lib
      86M     /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      5.5G    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      707M    /opt/iobroker/iobroker-data/
      552M    /opt/iobroker/iobroker-data/files
      116M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: homebridge-fibaro-hc2@^2.4.3, required by iobroker.ham@5.3.1
      npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-22T19_17_59_433Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.15
      javascript:     7.7.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.28, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
      + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.13.15  , installed 6.13.15
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.10.5   , installed 2.10.5
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.7.0    , installed 7.7.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "onvif"        : 1.1.2    , installed 1.1.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "speedport"    : 0.0.3    , installed 0.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
      Adapter    "tado"         : 0.5.1    , installed 0.5.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram-menu": 1.6.2    , installed 1.6.2
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        9671
      States:         7613
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       47151      5047/io.jarvis.0
      tcp        0      0 192.168.178.28:8081     0.0.0.0:*               LISTEN      1001       38575      4099/io.admin.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17293      635/sshd
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       41311      4288/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40312      4081/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40305      4081/iobroker.js-co
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45338      4697/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17295      635/sshd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       45176      4641/io.simple-api.
      tcp6       0      0 :::39319                :::*                    LISTEN      1001       38762      4261/io.ham.0
      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       38666      4200/io.geofency.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15973      627/dhcpcd
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       45685      4869/io.broadlink2.
      udp        0      0 0.0.0.0:34980           0.0.0.0:*                           108        16898      405/avahi-daemon: r
      udp        0      0 0.0.0.0:52438           0.0.0.0:*                           1001       45768      4869/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       38763      4261/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16896      405/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14830      627/dhcpcd
      udp6       0      0 :::51405                :::*                                108        16899      405/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        16897      405/avahi-daemon: r
      2024-01-22 20:17:26.135  - error: tr-064.0 (16095) ~
      2024-01-22 20:17:26.137  - warn: tr-064.0 (16095) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:17:26.796  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:17:26.797  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:17:56.934  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16300
      2024-01-22 20:18:00.803  - info: tr-064.0 (16300) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
      2024-01-22 20:18:01.139  - error: tr-064.0 (16300) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
      2024-01-22 20:18:01.140  - error: tr-064.0 (16300) ~
      2024-01-22 20:18:01.141  - error: tr-064.0 (16300) ~~ Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:01.142  - error: tr-064.0 (16300) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      2024-01-22 20:18:01.143  - error: tr-064.0 (16300) ~
      2024-01-22 20:18:01.145  - warn: tr-064.0 (16300) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:01.812  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:18:01.813  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:18:31.936  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16451
      2024-01-22 20:18:35.612  - info: tr-064.0 (16451) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
      2024-01-22 20:18:35.943  - error: tr-064.0 (16451) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
      2024-01-22 20:18:35.944  - error: tr-064.0 (16451) ~
      2024-01-22 20:18:35.945  - error: tr-064.0 (16451) ~~ Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:35.946  - error: tr-064.0 (16451) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      2024-01-22 20:18:35.947  - error: tr-064.0 (16451) ~
      2024-01-22 20:18:35.949  - warn: tr-064.0 (16451) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:36.586  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:18:36.586  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:19:06.786  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16847
      GlasfaserG Offline
      GlasfaserG Offline
      @sebastian-fiedler sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
      Ist alt ...
      • fiedlesF fiedles
        warum bist du im beta Repo unterwegs?
        und den tr64 kannst du wohl mit dem Speedport nicht mehr nutzen
        • fiedlesF Offline
          fiedlesF Offline
          fiedles
          schrieb am zuletzt editiert von fiedles
          ähm, wie bereits erwähnt. mit mir bitte im Noobmodus sprechen.
          @Homoran Ich hab ein update gemacht, so bin ich wohl auf diese Version gekommen.
          und ja den tr-64 kann ich anscheinend leider nicht mehr benutzen.
          @Glasfaser bitte genauer spezifizieren. was muss ich machen um den Zustand zu verbessern?
          GlasfaserG HomoranH 2 Antworten Letzte Antwort
          • fiedlesF fiedles
            GlasfaserG Offline
            GlasfaserG Offline
            auf Bookworm wechseln
            Edit:
            Beispiel was ich meine
            https://kofler.info/raspberry-pi-os-bookworm/
            fiedlesF 1 Antwort Letzte Antwort
            • fiedlesF fiedles
              und dann vergessen zurück auf stable zu gehen?
              jetzt sind alle Adapter auf neuestem Beta Stand.
                fiedlesF Offline
                fiedlesF Offline
                fiedles
                @homoran ja anscheinend. wie gesagt ich bin hier leider mehr oder weniger im Blindflug unterwegs was Programmierung etc. angeht. Ich habe mich bisher mit Youtube etc in das ganze Thema informiert. Dafür habe ich schon vieles hinbekommen. Aber sobald Probleme auftreten bin ich lost.
                wie komme ich zurück auf stable?
                HomoranH GlasfaserG 2 Antworten Letzte Antwort
                • fiedlesF fiedles
                  indem du es in den Systemeinstellungeen unter Repositories wieder umstellst
                  • fiedlesF fiedles
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Repositories
                    https://www.iobroker.net/#de/documentation/admin/settings.md
                    • GlasfaserG Glasfaser
                      Edit:
                      fiedlesF Offline
                      fiedlesF Offline
                      fiedles
                      @glasfaser scheint als würde das mehr oder weniger Sinn zu machen, da ich wie gesagt zur meisten Zeit eher blind fliege, habe ich bei der Beschreibung eher große Bauchschmerzen mein System umzubauen.
                      Sicherung etc ist bei mir auch ein Thema. Den Backitup bekomme ich auch nicht zum laufen. Wenn ich hier mal ein sicheres Backup hätte wäre ich sicher auch nochmal etwas experimentierfreudiger.
                      • fiedlesF fiedles
                        wieso das denn nicht?
                        gehört zwar nicht zum Thema, aber backitup ist sehr pflegeleicht.
                        Und wenn du erst einmal nur lokal speicherst und dann die Backups auf den PC runterziehst.
                        • fiedlesF fiedles
                          GlasfaserG Offline
                          GlasfaserG Offline
                          ist doch ordentlich was drin
                            @glasfaser sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
                            Sollte aber wahrscheinlich woanders hin
                            • fiedlesF Offline
                              fiedlesF Offline
                              fiedles
                              habe mehrere Updates über ein Tool aus dem Netz erstellen können.
                              Den backitup bekomme ich aber irgendwie nicht wirklich zum laufen.
                              erklärt mal bitte kurz wie ich die Backups von der SD Karte sichere. Einfach drag and drop auf Synology und gut? würde das mit einer neuen Installation kompatibel sein?
                              Geht das nicht auch komfortabler? der Backitup müsste doch auch direkt parallel auf der Synology sichern können?
                              • fiedlesF fiedles
                                bitte nicht das, was ich befürchte!
                                • fiedlesF fiedles
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : armhf
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           99M          0B         99M
                                           7898 M total memory
                                           1654 M used memory
                                            533 M active memory
                                           5356 M free memory
                                            241 M buffer memory
                                            646 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  347M    /var/
                                  151M    /var/cache
                                  145M    /var/cache/apt
                                  93M     /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.15
                                  javascript:     7.7.0
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        9671
                                  States:         7613
                                  Pending Updates: 0
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  ... der auch Redis sichert ... dein Tool ... obwohl du es nicht hast !?
                                    fiedlesF Offline
                                    fiedlesF Offline
                                    fiedles
                                    @homoran wahrscheinlich genau das was du befürchtest, wenn du schon so schreibst... elzershark 💩 bitte nicht lünchen 🙏 🤐
                                    • fiedlesF fiedles
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @sebastian-fiedler
                                      Jipp ... wo sind die Ste...
                                      • fiedlesF fiedles
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @sebastian-fiedler
                                        Und was hast du da drin .. im 5.5G Ordner
                                        zeige :
                                        ls -lh /opt/iobroker/backups
                                          @sebastian-fiedler
                                          @sebastian-fiedler
                                          sie war's, ähm er, er!
                                          @Sebastian-Fiedler
                                          ja! wenn die Elsterforelle da nicht mittlerweile massiv nachgebessert hat, verbiegt dir das "Tool" dein gesamtes System.
                                          Da wundern mich deine Baustellen kein bischen.
