  4. Admin startet nicht - buanet image[gelöst]
55 Beiträge 2 Kommentatoren 6.3k Aufrufe 3 Beobachtet
  • H HMuser
    @glasfaser
    Hier das Ergebnis von Diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : Intel Corporation
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.0.1
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:28:34 up 3 days,  6:55,  0 user,  load average: 2.40, 2.10, 1.88
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Jan 22 20:28:34 UTC 2024
    Mon Jan 22 21:28:34 CET 2024
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            1.0G        914M        122M        2.7M        250M        122M
    Swap:           2.8G        699M        2.1G
    Total:          3.8G        1.6G        2.2G
              988 M total memory
              871 M used memory
              197 M active memory
              257 M inactive memory
              116 M free memory
               13 M buffer memory
              225 M swap cache
             2641 M total swap
              667 M used swap
             1974 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    none                   aufs   3.6T  1.7T  2.0T  47% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  495M     0  495M   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 ext4   3.6T  1.7T  2.0T  47% /opt/iobroker
    tmpfs                  tmpfs  495M     0  495M   0% /proc/acpi
    tmpfs                  tmpfs  495M     0  495M   0% /proc/scsi
    tmpfs                  tmpfs  495M     0  495M   0% /sys/firmware
    [Fri Jan 19 14:34:06 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:08 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:08 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:13 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:14 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Fri Jan 19 14:34:34 2024] EXT4-fs (dm-0): barriers disabled
    [Fri Jan 19 14:34:35 2024] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,oldalloc
    [Fri Jan 19 14:34:49 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  none        aufs   rw,relatime,si=e20874a76f97f35,dio,dirperm1
    |-/opt/iobroker    /dev/mapper/cachedev_0[/docker/iobroker_data]        ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@docker/containers/fc8a2d4a9b91b0684e008a4d386fa591d0ba1fc92d86287615aa9ec6f7ba5ff4/resolv.conf] ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/hostname    /dev/mapper/cachedev_0[/@docker/containers/fc8a2d4a9b91b0684e008a4d386fa591d0ba1fc92d86287615aa9ec6f7ba5ff4/hostname]    ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    `-/etc/hosts       /dev/mapper/cachedev_0[/@docker/containers/fc8a2d4a9b91b0684e008a4d386fa591d0ba1fc92d86287615aa9ec6f7ba5ff4/hosts]       ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    /var:
    34M     /var/
    32M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    54M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    109M    /opt/iobroker/iobroker-data/
    62M     /opt/iobroker/iobroker-data/files
    33M     /opt/iobroker/iobroker-data/backup-objects
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    8.2M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.9M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        299
    States:         279
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       13473077   -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       13475539   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       13475621   -
    udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          13470984   -
    2024-01-22 16:07:27.139  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2024-01-22 16:07:27.142  - info: host.iobroker 10 instances found
    2024-01-22 16:07:27.186  - info: host.iobroker starting 2 instances
    2024-01-22 16:07:27.303  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2024-01-22 16:07:27.332  - info: host.iobroker instance system.adapter.admin.1 started with pid 184
    2024-01-22 16:07:27.355  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2024-01-22 16:07:27.369  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2024-01-22 16:07:27.384  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2024-01-22 16:07:27.399  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2024-01-22 16:07:27.413  - info: host.iobroker Some obsolete host states deleted.
    2024-01-22 16:07:31.285  - info: host.iobroker instance system.adapter.discovery.0 started with pid 191
    2024-01-22 16:07:33.257  - info: admin.1 (184) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
    2024-01-22 16:07:33.351  - info: admin.1 (184) requesting all objects
    2024-01-22 16:07:34.689  - info: admin.1 (184) received all objects
    2024-01-22 16:07:35.573  - info: discovery.0 (191) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
    2024-01-22 16:07:36.683  - info: admin.1 (184) socket.io server listening on port 8081
    2024-01-22 16:07:36.689  - info: admin.1 (184) http server listening on port 8081
    2024-01-22 16:07:36.690  - info: admin.1 (184) Use link "http://127.0.0.1:8081" to configure.
    2024-01-22 21:24:48.076  - info: admin.1 (184) ==> Connected system.user.admin from ::ffff:172.17.0.1
    2024-01-22 21:24:50.064  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-22 21:25:03.083  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-22 21:26:22.491  - info: admin.1 (184) ==> Connected system.user.admin from ::ffff:172.17.0.1
    2024-01-22 21:26:23.290  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-22 21:26:24.364  - info: admin.1 (184) <== Disconnect system.user.admin from ::ffff:172.17.0.1 admin
    und hier die summary:
                            v.2023-10-10
    model name      : Intel(R) Atom(TM) CPU D2701   @ 2.13GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.0.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            1.0G        901M        134M        2.8M        248M        134M
    Swap:           2.8G        710M        2.1G
    Active iob-Instances:   3
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                299
    States:                 279
    Size of iob-Database:
    GlasfaserG Offline
    GlasfaserG Offline
    @hmuser sagte in Admin startet nicht - buanet image:
    • system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Admin ist da ... und auch an !?
    H 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      Der Admin Adapter ist disabled, lässt sich aber in der Konsole nicht starten
      und was kommt dann in der Konsole wenn du
      iob start admin
      machst !?
      Was steht sonst im Log !?
      In Portainer steht der iobroker Container auf "healthy", nicht auf "running"
      healthy ist richtig !
      Zeige mal was du so hast :
      Full Ausgabe von
      iob diag
      aber bitte in Code-Tags </>
      HMuser
      @glasfaser
      Das Ergebnis von Job start admin:
      root@iobroker:/opt/iobroker# iob start admin
      The execution of this command is blocked as your ioBroker is running inside a Docker container!
      For more details see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/) or use the maintenance script 'maintenance --help'.
      Synology 713+
      IOBroker im Dockerumfeld auf Synology
      Raspimatic
      • H HMuser
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @hmuser
        Das ist ein bekannter Fehler im Image 9.0.1 ,Issuses ist vorhanden
        und auch schon im Image 9.1.0 behoben
        H 1 Antwort Letzte Antwort
          HMuser
          @glasfaser
          Hatte zusätzlich admin.1 installiert. Ist aber auch nicht erreichbar über 8081 bzw. 8089 (so gemapt)
          Synology 713+
          Raspimatic
          • GlasfaserG Offline
            GlasfaserG Offline
            @hmuser
            zeige
            docker ps
            und
            docker exec iobroker env
              HMuser
              @glasfaser
              admin.1 ist jetzt erreichbar über 8081, obwohl gemapt auf 8089, verstehe ich nicht. aber immerhin läuft er jetzt.
              Also jetzt noch das neue image ziehen und dann müsste admin start auch wieder funktionieren, korrekt?
              Danke für Deine Hilfe!
              Synology 713+
              Raspimatic
              • H HMuser
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Richtig :)
                ... sehr gerne
                  @hmuser
                  zeige
                  docker ps
                  und
                  HMuser
                  @glasfaser
                  Anfängerfrage: in welcher Konsole/ welchem Verzeichnis sind die Befehle auszuführen?
                  Synology 713+
                  Raspimatic
                  • H HMuser
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    in welcher Konsole/
                    in der Synology Ebene / ( über Putty auf die Synology , also nicht zum Container )
                      in welcher Konsole/
                      HMuser
                      schrieb am zuletzt editiert von HMuser
                      @glasfaser
                      Also über ssl auf der Syno einloggen? oder geht das im Docker Paket?
                      Synology 713+
                      Raspimatic
                      • H HMuser
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Nein ... siehe oben
                          Nein ... siehe oben
                          HMuser
                          @glasfaser
                          adminle@DS_backup:~$ docker ps
                          Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/json": dial unix /var/run/docker.sock: connect: permission denied
                          adminle@DS_backup:~$ docker exec iobroker env
                          Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/iobroker/json": dial unix /var/run/docker.sock: connect: permission denied
                          Synology 713+
                          Raspimatic
                          • H HMuser
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @hmuser
                            sudo docker ps
                            sudo docker exec iobroker env
                              @hmuser
                              sudo docker ps
                              HMuser
                              @glasfaser
                              adminle@DS_backup:~$ sudo docker exec iobroker env
                              Password:
                              PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                              HOSTNAME=iobroker
                              DEBIAN_FRONTEND=teletype
                              LANG=de_DE.UTF-8
                              LANGUAGE=de_DE:de
                              LC_ALL=de_DE.UTF-8
                              SETGID=1000
                              SETUID=1000
                              TZ=Europe/Berlin
                              HOME=/root
                              adminle@DS_backup:~$ sudo docker ps
                              CONTAINER ID   IMAGE                    COMMAND                  CREATED      STATUS                 PORTS        NAMES
                              fc8a2d4a9b91   buanet/iobroker:latest   "/bin/bash -c /opt/s…"   5 days ago   Up 6 hours (healthy)   0.0.0.0:2001->2001/tcp, 0.0.0.0:2010->2010/tcp, 0.0.0.0:3307->3307/tcp, 0.0.0.0:8081-8082->8081-8082/tcp   iobroker
                              4697a92fbc3b   portainer/portainer-ce   "/portainer"             8 days ago   Up 3 days              8000/tcp, 9443/tcp, 0.0.0.0:8889->9000/tcp        portainer
                              Synology 713+
                              Raspimatic
                              • H HMuser
                                @glasfaser
                                Password:
                                HOSTNAME=iobroker
                                LANG=de_DE.UTF-8
                                LANGUAGE=de_DE:de
                                LC_ALL=de_DE.UTF-8
                                SETGID=1000
                                SETUID=1000
                                TZ=Europe/Berlin
                                HOME=/root
                                GlasfaserG Offline
                                GlasfaserG Offline
                                8081-8082
                                Kann man machen .... von bis , bin aber kein Freund davon, lieber einzeln
                                8081 : 8081
                                8082 : 8082
                                  8081-8082
                                  8081 : 8081
                                  8082 : 8082
                                  HMuser
                                  @glasfaser
                                  Das kann ich noch ändern wenn ich das neue image ziehe.
                                  Habe das hier noch im Log:
                                  Cannot get NPM version: timeout
                                  Muss ich da noch etwas verändern?
                                  Synology 713+
                                  Raspimatic
                                  • H HMuser
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @hmuser
                                    Hiermit :
                                    https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                                      @hmuser
                                      Hiermit :
                                      HMuser
                                      @glasfaser
                                      Hm, wollte jetzt mit der Vorgehensweise des obigen Threads weitermachen, aber jetzt funktioniert iobroker stop etc. wieder nicht. hatte vermeintlich das neueste Image gezogen mit "recreate". muss ich eine spezielle Version fordern?
                                      Synology 713+
                                      Raspimatic
                                        @hmuser
                                        HMuser
                                        @glasfaser
                                        Inzwischen ist 9.1.0 installiert, aber iob start/ stop funktioniert trotzdem nicht.
                                        Gibt es vielleicht noch eine andere Ursache?
                                        Synology 713+
                                        Raspimatic
                                        • H HMuser
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Was meinst du damit .
                                          Es ging hier um die Instanz
                                          iob start admin.0
