  4. jarvis v3.2.x - just another remarkable vis
    apollon77A
969 Beiträge 48 Kommentatoren 397.9k Aufrufe 45 Beobachtet
  • ZefauZ Zefau
    @intruder7 Du verwendest kein https, richtig? Adapter ist richtig geuploaded im ioBroker Backend? Also korrekte Versionsnummer in den Instanzen? Kannst du die Instanz mal auf debug stellen und schauen, ob du was im ioBroker Log bekommst?
    I
    I
    intruder7
    @zefau ja, ja und ja :-)
    Log nach restart der instanz
    jarvis.0
    2023-10-30 21:13:08.663	info	State value to set for "jarvis.0.settings.pageHomeReturn" has to be type "number" but received type "string"
    jarvis.0
    2023-10-30 21:13:08.473	info	Found Backups for devices.
    jarvis.0
    2023-10-30 21:13:08.471	error	Error opening web socket: Cannot read properties of null (reading 'on')
    jarvis.0
    2023-10-30 21:13:08.471	error	WebSocketServer is not a constructor
    jarvis.0
    2023-10-30 21:13:08.470	debug	Connection: Using options: {}
    jarvis.0
    2023-10-30 21:13:08.470	debug	Connection: Using non-secure HTTP-Server
    jarvis.0
    2023-10-30 21:13:08.468	debug	Connection: ioBroker host detected with NUC-ioBroker (IP: 192.168.100.85).
    jarvis.0
    2023-10-30 21:13:08.466	debug	Web Configuration: {"port":8082,"auth":false,"secure":false,"bind":"0.0.0.0","cache":false,"socketio":"","simpleapi":false,"defaultUser":"admin","ttl":3600,"certPublic":"","certPrivate":"","certChained":"","addUserName":false,"forceWebSockets":false,"whiteListEnabled":false,"leEnabled":false,"leUpdate":false,"leCheckPort":80,"loginBackgroundColor":"","loginBackgroundImage":false,"basicAuth":false,"disableExtensions":false,"disableStates":false,"disableFilesObjects":false,"defaultRedirect":"","usePureWebSockets":false,"compatibilityV2":true,"staticAssetCacheMaxAge":60,"language":"","startDisabledExtensions":false,"showFolderIndex":false,"whiteListSettings":{"default":{"user":"admin"}}}
    jarvis.0
    2023-10-30 21:13:08.457	info	Found Backups for styles.
    jarvis.0
    2023-10-30 21:13:08.455	info	Found Backups for scripts.
    jarvis.0
    2023-10-30 21:13:08.455	info	Found Backups for settings.
    jarvis.0
    2023-10-30 21:13:08.451	info	Found Backups for widgets.
    jarvis.0
    2023-10-30 21:13:08.450	info	Found Backups for layout.
    jarvis.0
    2023-10-30 21:13:08.412	debug	Scheduled for 10:24
    jarvis.0
    2023-10-30 21:13:08.368	info	starting. Version 3.2.0-alpha.3 (non-npm: Zefau/ioBroker.jarvis#62ba80dc2f5de2dd821c5226c786799629bd9950) in /opt/iobroker/node_modules/iobroker.jarvis, node: v18.17.1, js-controller: 5.0.15
    • M MCU
      @intruder7
      http://192.168.100.85:8400/jarvis/index.html#/home0
      sigi234S
      sigi234S
      @mcu
      wie komme ich von Alpha 13 zurück auf 12?
      • sigi234S sigi234
        @mcu
        M
        M
        MCU
        @sigi234
        https://github.com/Zefau/ioBroker.jarvis/tree/38ec42822d9580a7f2b6b9885413376da9631866
        • M MCU
          @sigi234
          sigi234S
          sigi234S
          @mcu sagte in jarvis v3.2.x - just another remarkable vis (alpha-testing):
          @sigi234
          Ok, geht zwar aber Fehler in 12 , denke ich hatte zuletzt die v3.2.0-alpha.7
          Bitte Link zu 7
          • sigi234S sigi234
            @sigi234
            Bitte Link zu 7
            M
            M
            MCU
            @sigi234
            https://github.com/Zefau/ioBroker.jarvis/tree/6ba08dd71c92340d880a37555d96ca795f13f3ee
            hotspot_2H 1 Antwort Letzte Antwort
            • M MCU
              @sigi234
              hotspot_2H
              hotspot_2H
              hotspot_2
              @mcu Hallo zusammen, ich habe auch auf die 3.2.0 alpha 49 per Github ein Update gemacht. Gefällt mir sehr gut und funktioniert auch soweit alles.
              Ich habe aktuell nur das kleinere Problem das bei mir im Bereich CSS nichts angezeigt wird. Jarvis aber trotzdem das was in der alten Version funktioniert anwendet aber eben nicht alles. Ich habe z.B. Anpassungen gemacht das die SwitchActions in rot und grün angezeigt werden je nach Zustand, nun bleiben mit der 3.2.0 alpha die Buttons immer weiß die Fläche im Hintergrund (wo der Button drauf hin und herspringt) ändert sich aber in der Farbe.
              Ich würde gerne mal den aktuellen Zustand sehen und z.B. einfach erstmal rausnehmen oder so. Aufgrund eines Tipps von MCU im anderen Jarvis Thread habe ich schon mal ein Upload gemacht und den Web Adapter neugestartet. Das bringt aber leider nichts, der CSS Reiter in der Konfiguration von Jarvis bleibt leer.
              Vielleicht gibt es ja noch was, was ich tun kann.
              Grüße...
              • hotspot_2H hotspot_2
                Grüße...
                M
                M
                MCU
                @hotspot_2 Ist denn im DP jarvis.0.css was drin?
                Bitte den Inhalt als Objekt kopieren und in CodeTags hier einfügen
                • M MCU
                  hotspot_2H
                  hotspot_2H
                  hotspot_2
                  @mcu Anbei der Inhalt von jarvis.0.css.
                     "version": 3.2,
                     "signature": 4889882263576557,
                     "css": "/* Abfallkalender Widget */\n\n.jarvis-widget-d9e3b00f-a014-4004-9aeb-747f80d977ef .jarvis-iFrame-Container {\n\tposition: absolute;\n\tleft: 30px;\n}\n\n/* Farbige Slider Temperatur */\n\n.jarvis-widget-be0b1d30-14d3-48ef-8293-629517e56d42 .q-slider .q-slider__track {\n\tbackground: linear-gradient( to right, #009fff 0%, #00cfff 33%, #ffffff 50%, #fff000 83%, #ff5000 100% );\n}\n\n.jarvis-widget-be0b1d30-14d3-48ef-8293-629517e56d42 .q-slider__track {\n\tcolor: transparent;\n}\n\n/* Anderer Hintergrund */\n\n.jarvis-page-container {\n\tbackground-image: url(\"https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg\");\n}\n\n.body--dark .jarvis-header {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.jarvis-tabs-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.jarvis-widget-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.body--dark .jarvis-widget {\n\tbackground: rgba(0,0,0,0.45);\n}\n\n.body--light .jarvis-widget {\n\tbackground: rgba(255,255,255,1);\n}\n\n.body--dark .jarvis-tabs-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n/* für JsonTable ergänzt @mcu */\n\n.q-table__container {\n\tbackground-color: transparent !important;\n}\n\n/* für Trennstrich für TABs ergänzt @mcu */\n\n.q-header--bordered {\n\tborder: 1px solid transparent !important;\n}\n\n/* transparents Icon im Widget-Header @mcu */\n\n.jarvis-widget-icon {\n\tbackground: rgba(0,0,0,0.45);\n}\n\n/* MediaControl in transparentem Design @mcu */\n\n.cover {\n\tbackground-color: transparent !important;\n}\n\n.controls {\n\tbackground-color: transparent !important;\n}\n\n.track-information {\n\tbackground: rgba(25, 118, 210, 0) !important;\n}\n\n.track-duration {\n\tbackground-color: white;\n}\n\n.track-progress {\n\tbackground-color: blue;\n}\n\n.controls .jarvis-icon svg {\n\tcolor: white;\n}\n\n.controls .controlsLeft .q-btn__wrapper {\n\tbackground-color: transparent !important;\n}\n\n.controls .q-btn-group >.q-btn-item {\n\tbackground-color: transparent !important;\n}\n\n/* Bei JsonTable in Vergrößerung anderer Hintergrund nicht transparent @MCU */\n\n.fullscreen.scroll.jarvis-JsonTable.sticky-table-header {\n\tbackground-image: url(\"https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg\") !important;\n}\n\n/* Anpassungen Widgets */\n\n.jarvis-widget-c1a9b0d4-192d-4eb5-ba7f-10239c84a817 .q-table__bottom {\n\tdisplay: none !important;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n/* Temperatur Pufferspeicher */\n\n.disHTML {\n\tdisplay: table;\n\tmargin: 0px !important;\n\twidth: 100%;\n}\n\n.disHTMLimg {\n\twidth: 200px;\n\theight: auto;\n\t/* alternativ */\n\t/* width: 200px; */\n\t/* height: auto; */\n}\n\n.disHTMLcell {\n\tdisplay: table-cell;\n\tvertical-align: middle;\n\tpadding: 20px;\n\t/*Abstand der Zellen */\n}\n\n.disHTMLtemp {\n\tfont-size: 25px;\n\ttext-align: right;\n\tpadding-top: 30px;\n\tpadding-bottom: 30px;\n\t/* Abstand zwischen den Temperaturen */\n\tmargin: 0px;\n}\n\n/* fehlt die Einheit kann eine anhängen (nur einheitlich für alle Temp-Werte) */\n\n.disHTMLtemp.disHTMLUnit:after {\n\tcontent: ' °C';\n}\n\n/* Mit Umrahmung vom Image */\n\n.q-card.q-card--dark.q-dark .disHTMLimg {\n\tborder: 3px solid white;\n}\n\n.q-card .disHTMLimg {\n\tborder: 3px solid black;\n}"
                  • M
                    M
                    MCU
                    @hotspot_2
                    Ändere mal ein Zeichen in css und speicher dann.
                    • M MCU
                      @hotspot_2
                      hotspot_2H
                      hotspot_2H
                      hotspot_2
                      @mcu Das hat keine Besserung gebracht.
                        M
                        M
                        MCU
                        @hotspot_2 Das Problem ist doch, das in der Jarvis Konfiguration kein Eintrag in den Styles ist, oder?
                        Geh mal bitte auf die letzte Version alpha.50. Damit wir den gleichen Stand haben.
                        • M MCU
                          hotspot_2H
                          hotspot_2H
                          hotspot_2
                          @mcu Ich bin jetzt auch auf der .50 und es sieht gleich aus weiterhin.
                          Mein Problem ist das in der Konfiguration die Styles so aussehen:
                          Es wird aber etwas angewendet sonst wären ja vermutlich die Buttons nicht teilweise rot und grün usw.
                            M
                            M
                            MCU
                            @hotspot_2 Kannst du bitte ein Issue erstellen, damit zefau sich das anschaut. Danke.
                            https://github.com/Zefau/ioBroker.jarvis/issues
                            Wenn du F12 drückst irgendwelche Fehler?
                            • M MCU
                              hotspot_2H
                              hotspot_2H
                              hotspot_2
                              schrieb am zuletzt editiert von hotspot_2
                              @mcu Ein paar Fehler wurden angezeigt, zu verschiedenen Kategorien. Ich habe den issue erstellt und ein Screenshot der Fehler eingefügt.
                                M
                                M
                                MCU
                                @hotspot_2 Füge den Inhalt von dem CS-Dp hinzu und ein Bild von den ioBroker-Objekten, damit er sieht, dass es drin ist
                                     "version": 3.2,
                                  M
                                  M
                                  MCU
                                  @hotspot_2 Ändere mal css -> styles
                                  • M MCU
                                    hotspot_2H
                                    hotspot_2H
                                    hotspot_2
                                    @mcu Jupp, damit hat es dann geklappt.
                                    • teletapiT
                                      teletapiT
                                      teletapi
                                      schrieb am zuletzt editiert von teletapi
                                      Nabend, ich hab die letzten tage mal probiert die neue Alpha Version von Jarvis zu installieren aber immer ab der Alpha 11 hatte ich Probleme heute hab ich dann zum einen den Ical Kalender updaten können (Wurde angeboten) sowohl die letzte Alpha57 installiert der auf Anhieb funktionierte mit meiner jarvis visu. Einzige Fehler sind zig warnungen was den Müllkalender angeht.
                                      Zu sehen im aktuellen IOB Diag.
                                      Das ist ein RPI5 8Gb den ich in nächster zukunft nutzen möchte und meinen RPI 4 8Gb ablösen soll Ich warte derzeit nur noch auf die auslieferung des Argon one V3
                                      Daher hab ich das mit der Alpha Version hier schön testen können.
                                      Vielleicht fällt ja jemanden noch ein wo ich selbst vielleicht noch was machen kann was die warnungen auflöst
                                      Nachdem starten von Jarvis kommt ansich keine Warnung aber sobald ich den kalender anklicke kommen sofort 99 Warnungen.
                                      IOB Diag
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                       Static hostname: Raspberrypi5
                                             Icon name: computer
                                                Kernel: Linux 6.1.0-rpi8-rpi-2712
                                          Architecture: arm64
                                      Model           : Raspberry Pi 5 Model B Rev 1.0
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : arm64
                                      Systemuptime and Load:
                                       01:10:36 up 16 min,  2 users,  load average: 0.10, 0.21, 0.20
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Tue 2024-01-30 01:10:36 CET
                                                 Universal time: Tue 2024-01-30 00:10:36 UTC
                                                       RTC time: Tue 2024-01-30 00:10:36
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      pi
                                      /home/pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      *** X-Server-Setup ***
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      Boot Target:    multi-user.target
                                      *** MEMORY ***
                                      Mem:            8.4G        2.6G        4.5G        5.4M        1.4G        5.8G
                                      Swap:           104M          0B        104M
                                      Total:          8.5G        2.6G        4.6G
                                               8053 M total memory
                                               2524 M used memory
                                               2426 M active memory
                                                946 M inactive memory
                                               4268 M free memory
                                                 66 M buffer memory
                                               1295 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      vc_gencmd_read_response returned -1
                                      error=1 error_msg="Command not registered"
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.8G     0  3.8G   0% /dev
                                      tmpfs          tmpfs     806M  5.2M  801M   1% /run
                                      /dev/sda2      ext4       59G  7.6G   48G  14% /
                                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                      /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
                                      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                      [Tue Jan 30 00:54:20 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                      [Tue Jan 30 00:54:22 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Tue Jan 30 00:54:23 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                      TARGET           SOURCE    FSTYPE OPTIONS
                                      /                /dev/sda2 ext4   rw,noatime
                                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      1.3G    /var/
                                      614M    /var/lib
                                      425M    /var/lib/influxdb
                                      424M    /var/lib/influxdb/engine/data/1c84edc534c2a24a/autogen
                                      Archived and active journals take up 168.0M in the file system.
                                      /opt/iobroker/backups:
                                      1.6G    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      348M    /opt/iobroker/iobroker-data/
                                      181M    /opt/iobroker/iobroker-data/files
                                      72M     /opt/iobroker/iobroker-data/node-red
                                      71M     /opt/iobroker/iobroker-data/node-red/node_modules
                                      62M     /opt/iobroker/iobroker-data/node-red.0
                                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                      17M     /opt/iobroker/iobroker-data/objects.jsonl
                                      12M     /opt/iobroker/iobroker-data/states.jsonl
                                      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                                      USB-Devices by-id:
                                      find: '/dev/serial/by-id/': No such file or directory
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.19.0
                                      /usr/bin/node           v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      /usr/bin/corepack       0.22.0
                                      nodejs:
                                        Installed: 18.19.0-1nodesource1
                                        Candidate: 18.19.0-1nodesource1
                                        Version table:
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                       *** 18.19.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  5.0.17
                                      admin:          6.13.15
                                      javascript:     7.8.0
                                      Adapters from github:   2
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
                                        system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
                                      + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
                                      + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
                                      + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12001
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12010
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
                                      + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 443
                                        system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
                                      + system.adapter.info.0                   : info                  : Raspberrypi5                             -  enabled
                                      + system.adapter.iot.0                    : iot                   : Raspberrypi5                             -  enabled
                                      + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
                                        system.adapter.node-red.0               : node-red              : Raspberrypi5                             - disabled, port: 1880, bind: 0.0.0.0
                                      + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
                                      + system.adapter.opendtu.0                : opendtu               : Raspberrypi5                             -  enabled
                                      + system.adapter.philips-tv.0             : philips-tv            : Raspberrypi5                             -  enabled
                                      + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
                                      + system.adapter.shelly.0                 : shelly                : Raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.sourceanalytix.0         : sourceanalytix        : Raspberrypi5                             -  enabled
                                      + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
                                      + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): beta
                                      Installed ioBroker-Instances
                                      Used repository: beta
                                      Adapter    "admin"        : 6.13.15  , installed 6.13.15
                                      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                      Adapter    "backitup"     : 2.10.7   , installed 2.10.7
                                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                      Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                      Adapter    "ical"         : 1.14.2   , installed 1.14.2
                                      Adapter    "info"         : 2.0.0    , installed 2.0.0
                                      Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                      Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-alpha.57
                                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                      Controller "js-controller": 5.0.17   , installed 5.0.17
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "net-tools"    : 1.0.4    , installed 0.2.0  [Updatable]
                                      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                                      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                      Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                                      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                      Adapter    "shelly"       : 6.7.0    , installed 6.7.0
                                      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                      Adapter    "web"          : 6.2.3    , installed 6.2.3
                                      Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                      Objects and States
                                      Objects:        9938
                                      States:         10154
                                      Hit:2 https://repos.influxdata.com/debian stable InRelease
                                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:6 https://apt.grafana.com stable InRelease
                                      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       15882      1172/io.hm-rpc.3
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14142      972/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16596      972/iobroker.js-con
                                      tcp        0      0 192.168.178.121:9092    0.0.0.0:*               LISTEN      1001       23898      2089/io.nuki.0
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       17159      1300/io.sonoff.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        17467      802/mosquitto
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17123      1279/io.shelly.0
                                      tcp        0      0 192.168.178.121:12010   0.0.0.0:*               LISTEN      1001       15848      1157/io.hm-rpc.2
                                      tcp        0      0 192.168.178.121:12001   0.0.0.0:*               LISTEN      1001       17814      1142/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39489      3072/io.jarvis.0
                                      tcp        0      0 192.168.178.121:18701   0.0.0.0:*               LISTEN      1001       18467      1127/io.hm-rpc.0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17479      804/sshd: /usr/sbin
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22819      2209/io.socketio.0
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22083      2184/io.simple-api.
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15546      897/influxd
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14179      1007/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25123      2245/io.web.0
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      107        17621      971/grafana
                                      tcp6       0      0 :::1883                 :::*                    LISTEN      106        17468      802/mosquitto
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          17481      804/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13832      676/avahi-daemon: r
                                      udp        0      0 0.0.0.0:44133           0.0.0.0:*                           104        13834      676/avahi-daemon: r
                                      udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          16587      738/NetworkManager
                                      udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          15506      738/NetworkManager
                                      udp6       0      0 :::5353                 :::*                                104        13833      676/avahi-daemon: r
                                      udp6       0      0 :::56242                :::*                                104        13835      676/avahi-daemon: r
                                      2024-01-30 01:10:00.857  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      2024-01-30 01:10:00.858  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      2024-01-30 01:10:00.859  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      2024-01-30 01:10:00.860  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      2024-01-30 01:10:00.861  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      2024-01-30 01:10:00.862  - warn: jarvis.0 (3072) Failed parsing an event of calendar Müllkalender: Cannot read properties of undefined (reading 'preprocessor')
                                      Außerdem tauchen folgende Fehler immer wieder auf
                                      jarvis.0 2024-01-30 01:19:05.861	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.819	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.818	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.817	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.816	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.814	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.229	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.185	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.181	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.179	error	192.168.178.63 (Firefox) - {"code":17}
                                      jarvis.0 2024-01-30 01:19:05.176	error	192.168.178.63 (Firefox) - {"code":17}
                                      • teletapiT teletapi
                                        IOB Diag
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                        CPU threads: 4
                                        Current issues:
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           104M          0B        104M
                                                 8053 M total memory
                                                 2524 M used memory
                                                 4268 M free memory
                                                   66 M buffer memory
                                                 1295 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        *** FILESYSTEM ***
                                        /var:
                                        1.3G    /var/
                                        614M    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.15
                                        javascript:     7.8.0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        9938
                                        States:         10154
                                        Pending Updates: 0
                                        M
                                        M
                                        MCU
                                        @teletapi Bitte direkt als Issue unter github erstellen.
                                        Die Meldungen unter kommen von der Umleitung von F12-consolen LOG auf ioBroker.log?
                                        Wie ist der DP jarvis.0.clients.allBrowserConsoleInLog eingestellt? -> off
                                        Besonderer Müllkalender? Er kann einen Termin nicht parsen.
                                        teletapiT 1 Antwort Letzte Antwort
                                        • M MCU
                                          teletapiT
                                          teletapiT
                                          teletapi
                                          @mcu said in jarvis v3.2.x - just another remarkable vis (alpha-testing):
                                          jarvis.0.clients.allBrowserConsoleInLog steht auf "warn
                                          Es sind mehere kalender aus Google erstellt und enthält derzeit 6 Kalender
                                          Issue´erstellen ist so garnicht mein Ding, könnte das nicht jemand machen der sich damit auskennt.... ;-)
                                          teletapiT M 2 Antworten Letzte Antwort
                                          84.1k
