  4. jarvis v3.2.x - just another remarkable vis
961 Beiträge 46 Kommentatoren 344.1k Aufrufe 43 Beobachtet
  • ZefauZ Zefau
    @intruder7 verbinde dich mal auf den jarvis Port 8400
    I Offline
    I Offline
    intruder7
    @zefau Also jetzt nochmal die Alpha installiert und dann
    jarvis so aufgerufen http://192.168.100.85:8400/#/home0
    damit kommt das
    und mit 8082
      MCU
      @intruder7
      http://192.168.100.85:8400/jarvis/index.html#/home0
      I sigi234S 2 Antworten Letzte Antwort
      • M MCU
        @intruder7
        I Offline
        I Offline
        intruder7
        @mcu sagte in jarvis v3.2.x - just another remarkable vis (alpha-testing):
        kommt das erste Bild vom letzten Post
        mit
        kommt
        Error: xhr poll error
        Connecting to http://192.168.100.85:8400 (#1)...
        30.10.2023, 20:16:26 | INFO | CONNECTION
        Connecting to http://192.168.100.85:8400 unsuccessful.
        30.10.2023, 20:16:26 | WARN | SOCKET
        Failed connecting to http://192.168.100.85:8400 (#1)!
        30.10.2023, 20:16:26 | ERROR | CONNECTION
        Connecting to https://192.168.100.85:8400 (#2)...
        Connecting to https://192.168.100.85:8400 unsuccessful.
        30.10.2023, 20:16:29 | WARN | SOCKET
        Failed connecting to https://192.168.100.85:8400 (#2)!
        30.10.2023, 20:16:29 | ERROR | CONNECTION
        Connecting to https://192.168.100.85:443 (#3)...
        30.10.2023, 20:16:29 | INFO | CONNECTION
        30.10.2023, 20:16:30 | WARN | SOCKET
        Connecting to https://192.168.100.85:443 unsuccessful.
        30.10.2023, 20:16:31 | WARN | SOCKET
        Failed connecting to https://192.168.100.85:443 (#3)!
        30.10.2023, 20:16:31 | ERROR | CONNECTION
        Connecting to http://192.168.100.85:80 (#4)...
        30.10.2023, 20:16:31 | INFO | CONNECTION
        30.10.2023, 20:16:32 | WARN | SOCKET
        Connecting to http://192.168.100.85:80 unsuccessful.
        30.10.2023, 20:16:33 | WARN | SOCKET
        Failed connecting to http://192.168.100.85:80 (#4)!
        30.10.2023, 20:16:33 | ERROR | CONNECTION
        30.10.2023, 20:16:34 | WARN | SOCKET
        30.10.2023, 20:16:35 | WARN | SOCKET
        30.10.2023, 20:16:36 | WARN | SOCKET
        30.10.2023, 20:16:39 | WARN | SOCKET
        30.10.2023, 20:16:41 | WARN | SOCKET
        30.10.2023, 20:16:43 | WARN | SOCKET
        30.10.2023, 20:16:46 | WARN | SOCKET
        30.10.2023, 20:16:48 | WARN | SOCKET
        30.10.2023, 20:16:50 | WARN | SOCKET
        30.10.2023, 20:16:54 | WARN | SOCKET
        30.10.2023, 20:16:55 | WARN | SOCKET
        30.10.2023, 20:16:57 | WARN | SOCKET
        30.10.2023, 20:16:58 | WARN | SOCKET
        30.10.2023, 20:17:01 | WARN | SOCKET
        30.10.2023, 20:17:02 | WARN | SOCKET
        30.10.2023, 20:17:04 | WARN | SOCKET
        30.10.2023, 20:17:05 | WARN | SOCKET
        30.10.2023, 20:17:08 | WARN | SOCKET
        30.10.2023, 20:17:09 | WARN | SOCKET
        30.10.2023, 20:17:11 | WARN | SOCKET
        30.10.2023, 20:17:12 | WARN | SOCKET
        30.10.2023, 20:17:16 | WARN | SOCKET
        30.10.2023, 20:17:17 | WARN | SOCKET
        30.10.2023, 20:17:19 | WARN | SOCKET
        30.10.2023, 20:17:20 | WARN | SOCKET
        30.10.2023, 20:17:24 | WARN | SOCKET
        30.10.2023, 20:17:25 | WARN | SOCKET
        30.10.2023, 20:17:27 | WARN | SOCKET
        30.10.2023, 20:17:28 | WARN | SOCKET
        30.10.2023, 20:17:32 | WARN | SOCKET
        30.10.2023, 20:17:33 | WARN | SOCKET
        30.10.2023, 20:17:34 | WARN | SOCKET
        30.10.2023, 20:17:45 | WARN | SOCKET
        30.10.2023, 20:17:52 | WARN | SOCKET
        • I intruder7
          mit
          kommt
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          @intruder7 Du verwendest kein https, richtig? Adapter ist richtig geuploaded im ioBroker Backend? Also korrekte Versionsnummer in den Instanzen? Kannst du die Instanz mal auf debug stellen und schauen, ob du was im ioBroker Log bekommst?
          I 1 Antwort Letzte Antwort
          • ZefauZ Zefau
            I Offline
            I Offline
            intruder7
            @zefau ja, ja und ja :-)
            Log nach restart der instanz
            jarvis.0
            2023-10-30 21:13:08.663	info	State value to set for "jarvis.0.settings.pageHomeReturn" has to be type "number" but received type "string"
            jarvis.0
            2023-10-30 21:13:08.473	info	Found Backups for devices.
            jarvis.0
            2023-10-30 21:13:08.471	error	Error opening web socket: Cannot read properties of null (reading 'on')
            jarvis.0
            2023-10-30 21:13:08.471	error	WebSocketServer is not a constructor
            jarvis.0
            2023-10-30 21:13:08.470	debug	Connection: Using options: {}
            jarvis.0
            2023-10-30 21:13:08.470	debug	Connection: Using non-secure HTTP-Server
            jarvis.0
            2023-10-30 21:13:08.468	debug	Connection: ioBroker host detected with NUC-ioBroker (IP: 192.168.100.85).
            jarvis.0
            2023-10-30 21:13:08.466	debug	Web Configuration: {"port":8082,"auth":false,"secure":false,"bind":"0.0.0.0","cache":false,"socketio":"","simpleapi":false,"defaultUser":"admin","ttl":3600,"certPublic":"","certPrivate":"","certChained":"","addUserName":false,"forceWebSockets":false,"whiteListEnabled":false,"leEnabled":false,"leUpdate":false,"leCheckPort":80,"loginBackgroundColor":"","loginBackgroundImage":false,"basicAuth":false,"disableExtensions":false,"disableStates":false,"disableFilesObjects":false,"defaultRedirect":"","usePureWebSockets":false,"compatibilityV2":true,"staticAssetCacheMaxAge":60,"language":"","startDisabledExtensions":false,"showFolderIndex":false,"whiteListSettings":{"default":{"user":"admin"}}}
            jarvis.0
            2023-10-30 21:13:08.457	info	Found Backups for styles.
            jarvis.0
            2023-10-30 21:13:08.455	info	Found Backups for scripts.
            jarvis.0
            2023-10-30 21:13:08.455	info	Found Backups for settings.
            jarvis.0
            2023-10-30 21:13:08.451	info	Found Backups for widgets.
            jarvis.0
            2023-10-30 21:13:08.450	info	Found Backups for layout.
            jarvis.0
            2023-10-30 21:13:08.412	debug	Scheduled for 10:24
            jarvis.0
            2023-10-30 21:13:08.368	info	starting. Version 3.2.0-alpha.3 (non-npm: Zefau/ioBroker.jarvis#62ba80dc2f5de2dd821c5226c786799629bd9950) in /opt/iobroker/node_modules/iobroker.jarvis, node: v18.17.1, js-controller: 5.0.15
            • M MCU
              @intruder7
              sigi234S Online
              sigi234S Online
              @mcu
              wie komme ich von Alpha 13 zurück auf 12?
              • sigi234S sigi234
                @mcu
                MCU
                @sigi234
                https://github.com/Zefau/ioBroker.jarvis/tree/38ec42822d9580a7f2b6b9885413376da9631866
                • M MCU
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @sigi234
                  Ok, geht zwar aber Fehler in 12 , denke ich hatte zuletzt die v3.2.0-alpha.7
                  Bitte Link zu 7
                  • sigi234S sigi234
                    @sigi234
                    Bitte Link zu 7
                    MCU
                    @sigi234
                    https://github.com/Zefau/ioBroker.jarvis/tree/6ba08dd71c92340d880a37555d96ca795f13f3ee
                    hotspot_2H 1 Antwort Letzte Antwort
                    • M MCU
                      @sigi234
                      hotspot_2H Offline
                      hotspot_2H Offline
                      hotspot_2
                      @mcu Hallo zusammen, ich habe auch auf die 3.2.0 alpha 49 per Github ein Update gemacht. Gefällt mir sehr gut und funktioniert auch soweit alles.
                      Ich habe aktuell nur das kleinere Problem das bei mir im Bereich CSS nichts angezeigt wird. Jarvis aber trotzdem das was in der alten Version funktioniert anwendet aber eben nicht alles. Ich habe z.B. Anpassungen gemacht das die SwitchActions in rot und grün angezeigt werden je nach Zustand, nun bleiben mit der 3.2.0 alpha die Buttons immer weiß die Fläche im Hintergrund (wo der Button drauf hin und herspringt) ändert sich aber in der Farbe.
                      Ich würde gerne mal den aktuellen Zustand sehen und z.B. einfach erstmal rausnehmen oder so. Aufgrund eines Tipps von MCU im anderen Jarvis Thread habe ich schon mal ein Upload gemacht und den Web Adapter neugestartet. Das bringt aber leider nichts, der CSS Reiter in der Konfiguration von Jarvis bleibt leer.
                      Vielleicht gibt es ja noch was, was ich tun kann.
                      Grüße...
                      • hotspot_2H hotspot_2
                        Grüße...
                        MCU
                        @hotspot_2 Ist denn im DP jarvis.0.css was drin?
                        Bitte den Inhalt als Objekt kopieren und in CodeTags hier einfügen
                        • M MCU
                          hotspot_2H Offline
                          hotspot_2H Offline
                          hotspot_2
                          @mcu Anbei der Inhalt von jarvis.0.css.
                             "version": 3.2,
                             "signature": 4889882263576557,
                             "css": "/* Abfallkalender Widget */\n\n.jarvis-widget-d9e3b00f-a014-4004-9aeb-747f80d977ef .jarvis-iFrame-Container {\n\tposition: absolute;\n\tleft: 30px;\n}\n\n/* Farbige Slider Temperatur */\n\n.jarvis-widget-be0b1d30-14d3-48ef-8293-629517e56d42 .q-slider .q-slider__track {\n\tbackground: linear-gradient( to right, #009fff 0%, #00cfff 33%, #ffffff 50%, #fff000 83%, #ff5000 100% );\n}\n\n.jarvis-widget-be0b1d30-14d3-48ef-8293-629517e56d42 .q-slider__track {\n\tcolor: transparent;\n}\n\n/* Anderer Hintergrund */\n\n.jarvis-page-container {\n\tbackground-image: url(\"https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg\");\n}\n\n.body--dark .jarvis-header {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.jarvis-tabs-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.jarvis-widget-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n.body--dark .jarvis-widget {\n\tbackground: rgba(0,0,0,0.45);\n}\n\n.body--light .jarvis-widget {\n\tbackground: rgba(255,255,255,1);\n}\n\n.body--dark .jarvis-tabs-container {\n\tbackground-color: rgba(0,0,0,0.45) !important;\n}\n\n/* für JsonTable ergänzt @mcu */\n\n.q-table__container {\n\tbackground-color: transparent !important;\n}\n\n/* für Trennstrich für TABs ergänzt @mcu */\n\n.q-header--bordered {\n\tborder: 1px solid transparent !important;\n}\n\n/* transparents Icon im Widget-Header @mcu */\n\n.jarvis-widget-icon {\n\tbackground: rgba(0,0,0,0.45);\n}\n\n/* MediaControl in transparentem Design @mcu */\n\n.cover {\n\tbackground-color: transparent !important;\n}\n\n.controls {\n\tbackground-color: transparent !important;\n}\n\n.track-information {\n\tbackground: rgba(25, 118, 210, 0) !important;\n}\n\n.track-duration {\n\tbackground-color: white;\n}\n\n.track-progress {\n\tbackground-color: blue;\n}\n\n.controls .jarvis-icon svg {\n\tcolor: white;\n}\n\n.controls .controlsLeft .q-btn__wrapper {\n\tbackground-color: transparent !important;\n}\n\n.controls .q-btn-group >.q-btn-item {\n\tbackground-color: transparent !important;\n}\n\n/* Bei JsonTable in Vergrößerung anderer Hintergrund nicht transparent @MCU */\n\n.fullscreen.scroll.jarvis-JsonTable.sticky-table-header {\n\tbackground-image: url(\"https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg\") !important;\n}\n\n/* Anpassungen Widgets */\n\n.jarvis-widget-c1a9b0d4-192d-4eb5-ba7f-10239c84a817 .q-table__bottom {\n\tdisplay: none !important;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-28759d3b-e57f-4698-a1f2-35f45db074ba .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-0c044607-d8f9-40b1-a118-19ebc517e3d6 .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-0ce48d89-371c-4dae-b6f9-d26bb413eefa .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--truthy .q-toggle__track {\n\tcolor: green;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--truthy .q-toggle__thumb::after {\n\tcolor: green;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--falsy .q-toggle__track {\n\tcolor: red;\n}\n\n.jarvis-widget-92c3317f-0748-433b-97d2-049ead36699d .q-toggle__inner--falsy .q-toggle__thumb::after {\n\tbackground-color: red;\n}\n\n/* Temperatur Pufferspeicher */\n\n.disHTML {\n\tdisplay: table;\n\tmargin: 0px !important;\n\twidth: 100%;\n}\n\n.disHTMLimg {\n\twidth: 200px;\n\theight: auto;\n\t/* alternativ */\n\t/* width: 200px; */\n\t/* height: auto; */\n}\n\n.disHTMLcell {\n\tdisplay: table-cell;\n\tvertical-align: middle;\n\tpadding: 20px;\n\t/*Abstand der Zellen */\n}\n\n.disHTMLtemp {\n\tfont-size: 25px;\n\ttext-align: right;\n\tpadding-top: 30px;\n\tpadding-bottom: 30px;\n\t/* Abstand zwischen den Temperaturen */\n\tmargin: 0px;\n}\n\n/* fehlt die Einheit kann eine anhängen (nur einheitlich für alle Temp-Werte) */\n\n.disHTMLtemp.disHTMLUnit:after {\n\tcontent: ' °C';\n}\n\n/* Mit Umrahmung vom Image */\n\n.q-card.q-card--dark.q-dark .disHTMLimg {\n\tborder: 3px solid white;\n}\n\n.q-card .disHTMLimg {\n\tborder: 3px solid black;\n}"
                            MCU
                            @hotspot_2
                            Ändere mal ein Zeichen in css und speicher dann.
                            • M MCU
                              @hotspot_2
                              hotspot_2H Offline
                              hotspot_2H Offline
                              hotspot_2
                              @mcu Das hat keine Besserung gebracht.
                                MCU
                                @hotspot_2 Das Problem ist doch, das in der Jarvis Konfiguration kein Eintrag in den Styles ist, oder?
                                Geh mal bitte auf die letzte Version alpha.50. Damit wir den gleichen Stand haben.
                                • M MCU
                                  hotspot_2H Offline
                                  hotspot_2H Offline
                                  hotspot_2
                                  @mcu Ich bin jetzt auch auf der .50 und es sieht gleich aus weiterhin.
                                  Mein Problem ist das in der Konfiguration die Styles so aussehen:
                                  Es wird aber etwas angewendet sonst wären ja vermutlich die Buttons nicht teilweise rot und grün usw.
                                    MCU
                                    @hotspot_2 Kannst du bitte ein Issue erstellen, damit zefau sich das anschaut. Danke.
                                    https://github.com/Zefau/ioBroker.jarvis/issues
                                    Wenn du F12 drückst irgendwelche Fehler?
                                    • M MCU
                                      hotspot_2H Offline
                                      hotspot_2H Offline
                                      hotspot_2
                                      schrieb am zuletzt editiert von hotspot_2
                                      @mcu Ein paar Fehler wurden angezeigt, zu verschiedenen Kategorien. Ich habe den issue erstellt und ein Screenshot der Fehler eingefügt.
                                        MCU
                                        @hotspot_2 Füge den Inhalt von dem CS-Dp hinzu und ein Bild von den ioBroker-Objekten, damit er sieht, dass es drin ist
                                             "version": 3.2,
                                          MCU
                                          @hotspot_2 Ändere mal css -> styles
