  4. Kann VIS Editor nicht mehr aufrufen
37 Beiträge 7 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • T TimoWald
    @thomas-braun Ist das das hier?
    Skript v.2023-10-25
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.5.11-7-pve
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:24:28 up 1 day, 12:31,  1 user,  load average: 1.28, 1.05, 0.89
    CPU threads: 4
    *** Time and Time Zones ***
    x               Local time: Sun 2024-01-21 12:24:28 CET
               Universal time: Sun 2024-01-21 11:24:28 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            7.8G        3.4G        4.1G        0.0K        366M        4.4G
    Swap:           7.0G        1.4G        5.6G
    Total:           14G        4.8G        9.7G
             7828 M total memory
             3381 M used memory
             1913 M active memory
             1536 M inactive memory
             4080 M free memory
                0 M buffer memory
              366 M swap cache
             7039 M total swap
             1448 M used swap
             5591 M free swap
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--254--disk--0 ext4       16G  8.0G  6.8G  54% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       24G   15G  7.9G  65% /dev/ttyACM0
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  100K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Check not possible in LXC or Docker
    Show mounted filesystems:
    TARGET                                SOURCE                                             FSTYPE     OPTIONS
    /                                     /dev/mapper/pve-vm--254--disk--0                   ext4       rw,relatime,stripe=16
    |-/run                                tmpfs                                              tmpfs      rw,nosuid,nodev,size=1603352k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | `-/run/lock                         tmpfs                                              tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    |-/dev                                none                                               tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                          tmpfs                                              tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                       mqueue                                             mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/ttyACM0                      /dev/mapper/pve-root[/var/lib/lxc/254/devices/ttyACM0]
    | |        ext4       rw,relatime,errors=remount-ro
    | |-/dev/.lxc/proc                    proc                                               proc       rw,relatime
    | |-/dev/.lxc/sys                     sys                                                sysfs      rw,relatime
    | |-/dev/full                         udev[/full]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/null                         udev[/null]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/random                       udev[/random]                                      devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/tty                          udev[/tty]                                         devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/urandom                      udev[/urandom]                                     devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/zero                         udev[/zero]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
    | |-/dev/pts                          devpts                                             devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                         devpts[/ptmx]                                      devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                      devpts[/0]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                         devpts[/1]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                         devpts[/2]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                               proc                                               proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                         proc[/sys]                                         proc       ro,relatime
    | | |-/proc/sys/net                   proc[/sys/net]                                     proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]                                tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger               proc[/sysrq-trigger]                               proc       ro,relatime
    | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                   lxcfs[/proc/diskstats]                             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                     lxcfs[/proc/loadavg]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                     lxcfs[/proc/meminfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]                              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                        lxcfs[/proc/stat]                                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                       lxcfs[/proc/swaps]                                 fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                      lxcfs[/proc/uptime]                                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                sysfs                                              sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections          fusectl                                            fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]                        sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                    none                                               cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    712M    /var/
    317M    /var/cache
    313M    /var/cache/apt
    258M    /var/log
    247M    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
    Archived and active journals take up 246.6M in the file system.
    /opt/iobroker/backups:
    493M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    i1.4G   /opt/iobroker/iobroker-data/
    842M    /opt/iobroker/iobroker-data/files
    267M    /opt/iobroker/iobroker-data/backup-objects
    177M    /opt/iobroker/iobroker-data/files/vis-2
    155M    /opt/iobroker/iobroker-data/node-red
    38M     /opt/iobroker/iobroker-data/states.jsonl
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
    *** NodeJS-Installation ***
    ./iob_diag: line 283: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    ./iob_diag: line 294: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    Run ob nodejs-update to fix it.
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   12
    Adapter State
    + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
    + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
      system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
      system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
    + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
      system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled, compact disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled, compact disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled, compact disabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
    + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
      system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker                                 - disabled, compact disabled, port: 8089, bind: 0.0.0.0
    + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
      system.adapter.innogy-smarthome.0       : innogy-smarthome      : iobroker                                 - disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
      system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
    + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, compact disabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled, compact disabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
    + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, compact disabled, port: 0
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled, compact disabled
    + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled, compact disabled
    + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
      system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled, compact disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
    + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
    + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 5050
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    ^AAdapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "firetv"       : 2.0.2    , installed 2.0.2
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
    Adapter    "gira-iot"     : 0.4.0    , installed 0.4.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
    Adapter    "hmip"         : 1.21.0   , installed 1.21.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "knx"          : 2.0.24   , installed 2.0.24
    Adapter    "lg-thinq"     : 0.3.2    , installed 0.3.2
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openknx"      : 0.6.3    , installed 0.6.3
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "roborock"     : 0.4.4    , installed 0.4.4
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solax"        : 0.8.0    , installed 0.8.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.17
    Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
    Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-jaeger-design": 1.1.5, installed 1.1.5
    Adapter    "vis-2-widgets-material": 1.3.17, installed 1.3.17
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:        24409
    States:         20018
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Hit:2 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists... Done
    @timowald
    Auch im Container wird NICHT als root herumgehampelt.
      @timowald
      TimoWald
      @thomas-braun das heist ich sollte einen Benutzer anlegen und über diesen die Adapter installieren?
      • T TimoWald
        @timowald sagte in Kann VIS Editor nicht mehr aufrufen:
        Grundsätzlich macht man das als aller erstes.
          TimoWald
          @thomas-braun ok. Aber worin liegt das Problem das der VIS Editor nicht mehr geht?
          Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
          • T TimoWald
            Keine Ahnung. Ich schau mir iob diag immer nur bis root an. Stell es richtig und dann rückst du mit einer frischen Ausgabe von
            iob diag
            an. In sauberen CodeTags, die Ausgabe beinhaltet die schon.
            • T TimoWald
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @timowald vis 1 oder vis 2 ?
              Bei Dir scheint ja viel Beta installiert zu sein 🤔
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                TimoWald
                @djmarc75 viel Beta eigentlich nicht. Die VIS 2 funktioniert aber bei der VIS 1 funktioniert der editor nicht.
                Thomas BraunT FeuersturmF 2 Antworten Letzte Antwort
                • T TimoWald
                  @timowald
                  Nee, nur
                  • T TimoWald
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    Hast du mal den Browsercache gelöscht?
                    • FeuersturmF Feuersturm
                      TimoWald
                      @feuersturm ja habe ich auch. Auch auf mehreren PCs probiert. Überall das selbe.
                      • T TimoWald
                        @timowald
                        User angelegt?
                        Als dieser user dann:
                        iob nodejs-update
                        iob diag
                        • T TimoWald
                          Skript v.2023-10-25
                          *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                                   7828 M total memory
                                   3381 M used memory
                                   4080 M free memory
                                      0 M buffer memory
                                    366 M swap cache
                                   7039 M total swap
                                   1448 M used swap
                                   5591 M free swap
                          *** FILESYSTEM ***
                          /var:
                          712M    /var/
                          317M    /var/cache
                          313M    /var/cache/apt
                          258M    /var/log
                          USB-Devices by-id:
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        24409
                          States:         20018
                          @timowald da fehlt die Hälfte!
                          mehr Geduld!
                            mehr Geduld!
                            TimoWald
                            @homoran Habe jetzt noch einen dritten Rechner genommen und da kann ich alles noch normal aufrufen. Am Handy habe ich es auch mal versucht. Das geht auch. Was haben die beiden PCs für ein Problem? Egal welchen Browser ich nutze, der Editor öffnet sich nicht. (Chrome, Firefox, Edge)
                            HomoranH wendy2702W 2 Antworten Letzte Antwort
                            • T TimoWald
                              das sollte im vollständigen Output von iob diag zu sehen sein.
                                TimoWald
                                @homoran mit dem erstellen von dem iob diag bin ich glaube überfordert. Sorry.
                                liv-in-skyL HomoranH 2 Antworten Letzte Antwort
                                • T TimoWald
                                  wendy2702W Online
                                  wendy2702W Online
                                  @timowald möglicherweise:
                                  Firewall
                                  Antivirus
                                  As blocker
                                  Irgendwelche browser Erweiterungen
                                  Scheint ja jedenfalls ein Problem der PCs zu sein und nicht iobroker
                                  • T TimoWald
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @timowald
                                    probier mal (chrome):
                                    • vis aufrufen - dann irgendwo auf der seite mit rechter maustaste auf "untersuchen" gehen - es öffnet sich ein fenster, darin den tab: console waählen - dann refresh der seite und in dem console tab nachkucken, was da kommt
                                    oder
                                    eine erweiterung eines virenscanners oder ein blocker für scripte installiert
                                    • liv-in-skyL liv-in-sky
                                      @timowald
                                      oder
                                      TimoWald
                                      @liv-in-sky da kommt das wenn ich den Editor lade.
                                      • T TimoWald
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @timowald hast du zufällig noch ein zweites project in der vis, welches du mal aufrufen könntest - nehme an, du willst immer das selbe vis-project öffnen
                                        bin mir bei dieser meldung nicht sicher, ob es nur ein defektes widget oder das vis-views.json file ist. anscheinend gibt es irgendwo ein json, welches nicht lesbar ist
                                          TimoWald
                                          schrieb am zuletzt editiert von TimoWald
                                          @liv-in-sky ja die werkseitig drauf ist. (DemoView) Aber selbst die geht nicht auf.
