  4. Kann VIS Editor nicht mehr aufrufen
37 Beiträge 7 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • T TimoWald
    2024-01-21 11:56:30.559 - info: admin.0 (304) ==> Connected system.user.admin from ::ffff:192.168.9.50
    2024-01-21 11:56:36.859 - info: web.0 (34611) ==> Connected system.user.admin from ::ffff:192.168.9.50
    2024-01-21 11:56:52.265 - error: roborock.0 (COMPACT) MQTT connection error: Error: client disconnecting
    2024-01-21 11:56:52.283 - warn: roborock.0 (COMPACT) MQTT connection close.
    2024-01-21 11:56:52.283 - warn: roborock.0 (COMPACT) MQTT connection reconnect.
    2024-01-21 11:56:53.258 - info: synology.0 (703) Connecting to Synology 192.168.9.13:5000
    2024-01-21 11:56:53.585 - info: web.0 (34611) <== Disconnect system.user.admin from ::ffff:192.168.9.50 vis.0
    2024-01-21 11:56:53.820 - info: web.0 (34611) ==> Connected system.user.admin from ::ffff:192.168.9.50
    2024-01-21 11:57:02.424 - warn: roborock.0 (COMPACT) Failed to execute get_room_mapping on robot YoRCVECj19KNDwRd5jgz1 Error: Request with id 6131 timed out after 10 seconds for response.102
    2024-01-21 11:57:26.886 - info: synology.0 (703) Connecting to Synology 192.168.9.13:5000
    2024-01-21 11:57:55.785 - info: web.0 (34611) ==> Connected system.user.admin from ::ffff:192.168.9.50
    2024-01-21 11:58:00.998 - info: synology.0 (703) Connecting to Synology 192.168.9.13:5000
    2024-01-21 11:58:04.113 - info: web.0 (34611) <== Disconnect system.user.admin from ::ffff:192.168.9.50 vis.0
    @timowald
    Das ist nicht die Ausgabe von 'iob diag'.
      @timowald
      TimoWald
      @thomas-braun Ist das das hier?
      Skript v.2023-10-25
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.5.11-7-pve
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:24:28 up 1 day, 12:31,  1 user,  load average: 1.28, 1.05, 0.89
      CPU threads: 4
      *** Time and Time Zones ***
      x               Local time: Sun 2024-01-21 12:24:28 CET
                 Universal time: Sun 2024-01-21 11:24:28 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.8G        3.4G        4.1G        0.0K        366M        4.4G
      Swap:           7.0G        1.4G        5.6G
      Total:           14G        4.8G        9.7G
               7828 M total memory
               3381 M used memory
               1913 M active memory
               1536 M inactive memory
               4080 M free memory
                  0 M buffer memory
                366 M swap cache
               7039 M total swap
               1448 M used swap
               5591 M free swap
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--254--disk--0 ext4       16G  8.0G  6.8G  54% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      /dev/mapper/pve-root             ext4       24G   15G  7.9G  65% /dev/ttyACM0
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  100K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Check not possible in LXC or Docker
      Show mounted filesystems:
      TARGET                                SOURCE                                             FSTYPE     OPTIONS
      /                                     /dev/mapper/pve-vm--254--disk--0                   ext4       rw,relatime,stripe=16
      |-/run                                tmpfs                                              tmpfs      rw,nosuid,nodev,size=1603352k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | `-/run/lock                         tmpfs                                              tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      |-/dev                                none                                               tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                          tmpfs                                              tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                       mqueue                                             mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/ttyACM0                      /dev/mapper/pve-root[/var/lib/lxc/254/devices/ttyACM0]
      | |        ext4       rw,relatime,errors=remount-ro
      | |-/dev/.lxc/proc                    proc                                               proc       rw,relatime
      | |-/dev/.lxc/sys                     sys                                                sysfs      rw,relatime
      | |-/dev/full                         udev[/full]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/null                         udev[/null]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/random                       udev[/random]                                      devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/tty                          udev[/tty]                                         devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/urandom                      udev[/urandom]                                     devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/zero                         udev[/zero]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
      | |-/dev/pts                          devpts                                             devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                         devpts[/ptmx]                                      devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                      devpts[/0]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                         devpts[/1]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                         devpts[/2]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                               proc                                               proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                         proc[/sys]                                         proc       ro,relatime
      | | |-/proc/sys/net                   proc[/sys/net]                                     proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]                                tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger               proc[/sysrq-trigger]                               proc       ro,relatime
      | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                   lxcfs[/proc/diskstats]                             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                     lxcfs[/proc/loadavg]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                     lxcfs[/proc/meminfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]                              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                        lxcfs[/proc/stat]                                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                       lxcfs[/proc/swaps]                                 fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                      lxcfs[/proc/uptime]                                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                sysfs                                              sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections          fusectl                                            fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]                        sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                    none                                               cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      712M    /var/
      317M    /var/cache
      313M    /var/cache/apt
      258M    /var/log
      247M    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
      Archived and active journals take up 246.6M in the file system.
      /opt/iobroker/backups:
      493M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      i1.4G   /opt/iobroker/iobroker-data/
      842M    /opt/iobroker/iobroker-data/files
      267M    /opt/iobroker/iobroker-data/backup-objects
      177M    /opt/iobroker/iobroker-data/files/vis-2
      155M    /opt/iobroker/iobroker-data/node-red
      38M     /opt/iobroker/iobroker-data/states.jsonl
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
      *** NodeJS-Installation ***
      ./iob_diag: line 283: nodejs: command not found
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      ./iob_diag: line 294: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      Run ob nodejs-update to fix it.
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   12
      Adapter State
      + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
      + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
        system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled, compact disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
        system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
      + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
        system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled, compact disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
        system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled, compact disabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled, compact disabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
      + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
        system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker                                 - disabled, compact disabled, port: 8089, bind: 0.0.0.0
      + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
        system.adapter.innogy-smarthome.0       : innogy-smarthome      : iobroker                                 - disabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
      + system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
      + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, compact disabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled, compact disabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
      + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
      + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, compact disabled, port: 0
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled, compact disabled
      + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled, compact disabled
      + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
        system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled, compact disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
      + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
      + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 5050
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      ^AAdapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "gira-iot"     : 0.4.0    , installed 0.4.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
      Adapter    "hmip"         : 1.21.0   , installed 1.21.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "knx"          : 2.0.24   , installed 2.0.24
      Adapter    "lg-thinq"     : 0.3.2    , installed 0.3.2
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "modbus"       : 6.0.1    , installed 6.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "openknx"      : 0.6.3    , installed 0.6.3
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "solax"        : 0.8.0    , installed 0.8.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-2"        : 2.9.11   , installed 2.9.17
      Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
      Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-jaeger-design": 1.1.5, installed 1.1.5
      Adapter    "vis-2-widgets-material": 1.3.17, installed 1.3.17
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects:        24409
      States:         20018
      Hit:1 http://ftp.debian.org/debian bullseye InRelease
      Hit:2 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org bullseye-security InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists... Done
      • T TimoWald
        Skript v.2023-10-25
        *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
                 7828 M total memory
                 3381 M used memory
                 4080 M free memory
                    0 M buffer memory
                  366 M swap cache
                 7039 M total swap
                 1448 M used swap
                 5591 M free swap
        *** FILESYSTEM ***
        /var:
        712M    /var/
        317M    /var/cache
        313M    /var/cache/apt
        258M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        24409
        States:         20018
        @timowald
        Auch im Container wird NICHT als root herumgehampelt.
          @timowald
          TimoWald
          @thomas-braun das heist ich sollte einen Benutzer anlegen und über diesen die Adapter installieren?
          • T TimoWald
            @timowald sagte in Kann VIS Editor nicht mehr aufrufen:
            Grundsätzlich macht man das als aller erstes.
              TimoWald
              @thomas-braun ok. Aber worin liegt das Problem das der VIS Editor nicht mehr geht?
              Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
              • T TimoWald
                Keine Ahnung. Ich schau mir iob diag immer nur bis root an. Stell es richtig und dann rückst du mit einer frischen Ausgabe von
                iob diag
                an. In sauberen CodeTags, die Ausgabe beinhaltet die schon.
                • T TimoWald
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @timowald vis 1 oder vis 2 ?
                  Bei Dir scheint ja viel Beta installiert zu sein 🤔
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    TimoWald
                    @djmarc75 viel Beta eigentlich nicht. Die VIS 2 funktioniert aber bei der VIS 1 funktioniert der editor nicht.
                    Thomas BraunT FeuersturmF 2 Antworten Letzte Antwort
                    • T TimoWald
                      @timowald
                      Nee, nur
                      • T TimoWald
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        Hast du mal den Browsercache gelöscht?
                        • FeuersturmF Feuersturm
                          TimoWald
                          @feuersturm ja habe ich auch. Auch auf mehreren PCs probiert. Überall das selbe.
                          • T TimoWald
                            @timowald
                            User angelegt?
                            Als dieser user dann:
                            iob nodejs-update
                            iob diag
                            • T TimoWald
                              Skript v.2023-10-25
                              *** BASE SYSTEM ***
                                         Chassis: container
                                  Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              root
                              /root
                              root
                              X-Server:       false
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                                       7828 M total memory
                                       3381 M used memory
                                       4080 M free memory
                                          0 M buffer memory
                                        366 M swap cache
                                       7039 M total swap
                                       1448 M used swap
                                       5591 M free swap
                              *** FILESYSTEM ***
                              /var:
                              712M    /var/
                              317M    /var/cache
                              313M    /var/cache/apt
                              258M    /var/log
                              USB-Devices by-id:
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        24409
                              States:         20018
                              @timowald da fehlt die Hälfte!
                              mehr Geduld!
                                mehr Geduld!
                                TimoWald
                                @homoran Habe jetzt noch einen dritten Rechner genommen und da kann ich alles noch normal aufrufen. Am Handy habe ich es auch mal versucht. Das geht auch. Was haben die beiden PCs für ein Problem? Egal welchen Browser ich nutze, der Editor öffnet sich nicht. (Chrome, Firefox, Edge)
                                HomoranH wendy2702W 2 Antworten Letzte Antwort
                                • T TimoWald
                                  das sollte im vollständigen Output von iob diag zu sehen sein.
                                    TimoWald
                                    @homoran mit dem erstellen von dem iob diag bin ich glaube überfordert. Sorry.
                                    liv-in-skyL HomoranH 2 Antworten Letzte Antwort
                                    • T TimoWald
                                      wendy2702W Online
                                      wendy2702W Online
                                      @timowald möglicherweise:
                                      Firewall
                                      Antivirus
                                      As blocker
                                      Irgendwelche browser Erweiterungen
                                      Scheint ja jedenfalls ein Problem der PCs zu sein und nicht iobroker
                                      • T TimoWald
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @timowald
                                        probier mal (chrome):
                                        • vis aufrufen - dann irgendwo auf der seite mit rechter maustaste auf "untersuchen" gehen - es öffnet sich ein fenster, darin den tab: console waählen - dann refresh der seite und in dem console tab nachkucken, was da kommt
                                        oder
                                        eine erweiterung eines virenscanners oder ein blocker für scripte installiert
                                        • liv-in-skyL liv-in-sky
                                          @timowald
                                          oder
                                          TimoWald
                                          @liv-in-sky da kommt das wenn ich den Editor lade.
