  3. Off Topic
  4. Grafana
  5. Hintergrund von Grafana Dashboard in VIS entfernen
    6.6k
Geplant Angeheftet Gesperrt Verschoben Grafana
vis
148 Beiträge 33 Kommentatoren 42.7k Aufrufe 40 Beobachtet
  • B bloop
    @saeft_2003
    Besteht lediglich aus:
    @charset "UTF-8";
     :root {
    	color-scheme: none !important;
    .panel-container {
        background-color: transparent !important;
    index.html:
    <!doctype html><html lang="en"><head>[[ if and .CSPEnabled .IsDevelopmentEnv ]]<meta http-equiv="Content-Security-Policy" content="[[.CSPContent]]"/>[[ end ]]<meta charset="utf-8"/><meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1"/><meta name="viewport" content="width=device-width"/><meta name="theme-color" content="#000"/><title>[[.AppTitle]]</title><base href="[[.AppSubUrl]]/"/><link rel="icon" type="image/png" href="[[.FavIcon]]"/><link rel="apple-touch-icon" sizes="180x180" href="[[.AppleTouchIcon]]"/><link rel="mask-icon" href="[[.ContentDeliveryURL]]public/img/grafana_mask_icon.svg" color="#F05A28"/>[[ if eq .ThemeType "light" ]]<link rel="stylesheet" href="[[.ContentDeliveryURL]]public/build/grafana.light.469af479381f2d6cb442.css"/>[[ else if eq .ThemeType "dark" ]]<link rel="stylesheet" href="[[.ContentDeliveryURL]]public/build/grafana.dark.886efb710af4d17a895d.css"/>[[ end ]]<script nonce="[[.Nonce]]">performance.mark('frontend_boot_css_time_seconds');</script><meta name="apple-mobile-web-app-capable" content="yes"/><meta name="apple-mobile-web-app-status-bar-style" content="black"/><meta name="msapplication-TileColor" content="#2b5797"/><meta name="msapplication-config" content="public/img/browserconfig.xml"/>
    <link rel="stylesheet" href="http://IPAdresse/vis.0/mygrafana4.css" type="text/css">
    </head>
    <body class="theme-[[ .ThemeType ]] [[.AppNameBodyClass]]"><style>
    body.dashboard-solo { background: none !important; }
    .preloader__enter {
            opacity: 0;
            animation-name: preloader-fade-in;
            animation-iteration-count: 1;
            animation-duration: 0.9s;
            animation-delay: 1.35s;
            animation-fill-mode: forwards;
          .preloader__bounce {
            text-align: center;
            animation-name: preloader-bounce;
            animation-iteration-count: infinite;
    usw.
    saeft_2003
    #119
    @bloop
    bei mir will es nicht funktionieren. Wenn ich die index datei von dir übernehme zerhaut es mir die ganzen charts... Wenn ich den head abschnitt von meiner grafana 8 index datei nehme startet grafna 10 nicht mehr.
    So hab ich es jetzt aber der Hintergrund beibt der originale,
    Index:
    <!DOCTYPE html>
    <html lang="[[.User.Language]]">
      <head>
        <!-- Cypress overwrites CSP headers in HTTP requests, so this is required for e2e tests-->
        [[ end ]]
        <meta charset="utf-8" />
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
        <meta name="viewport" content="width=device-width" />
        <meta name="theme-color" content="#000" />
        <base href="[[.AppSubUrl]]/" />
        <link rel="icon" type="image/png" href="[[.FavIcon]]" />
        <link rel="apple-touch-icon" sizes="180x180" href="[[.AppleTouchIcon]]" />
        <link rel="mask-icon" href="[[.ContentDeliveryURL]]public/img/grafana_mask_icon.svg" color="#F05A28" />
        <!-- If theme is "system", we inject the stylesheets with javascript further down the page -->
        <link rel="stylesheet" href="[[.ContentDeliveryURL]][[.Assets.CSSLight]]" />
        <link rel="stylesheet" href="[[.ContentDeliveryURL]][[.Assets.CSSDark]]" />
        [[ end ]]
        </script>
        <meta name="apple-mobile-web-app-capable" content="yes" />
        <meta name="apple-mobile-web-app-status-bar-style" content="black" />
        <meta name="msapplication-TileColor" content="#2b5797" />
        <meta name="msapplication-config" content="public/img/browserconfig.xml" />
        <link rel="stylesheet" href="http://192.168.178.90:8082/vis.0/mygrafana2.css" type="text/css">
      </head>
    CSS:
    @charset "UTF-8";
     :root {
    .panel-container {
    Hast du noch eine Idee was ich probieren kann?
    • S saeft_2003
      @bloop
      Index:
      <!DOCTYPE html>
        <head>
          [[ end ]]
          [[ end ]]
          </script>
        </head>
      CSS:
      @charset "UTF-8";
       :root {
      .panel-container {
      bloop
      #120
      @saeft_2003
      Hast du mal versucht
      unter Style einzufügen?
      .preloader__enter {
              opacity: 0;
      Ebenfalls würde ich die mygrafana.css komplett löschen. Vis neu starten anschließend neu hochladen und Grafana neu starten.
      S 2 Antworten Letzte Antwort
      • B bloop
        @saeft_2003
        .preloader__enter {
                opacity: 0;
        saeft_2003
        #121
        @bloop
        Danke probiere ich heute Abend mal aus.
        • B bloop
          @saeft_2003
          .preloader__enter {
                  opacity: 0;
          saeft_2003
          #122
          @bloop sagte in Hintergrund von Grafana Dashboard in VIS entfernen:
          Ich habs jetzt so gemacht und grafana neu gestartet (hab ich immer gemacht) und geht auch nicht...
              <style>
                .preloader {
                  height: 100%;
                  flex-direction: column;
                  display: flex;
                  justify-content: center;
                  align-items: center;
          • S saeft_2003
                <style>
                  .preloader {
                    height: 100%;
                    display: flex;
            bloop
            #123
            @saeft_2003
            Welche Grafana Version läuft bei dir?
            Ich habe die 10.1.5 am laufen.
            Anderer Ansatz:
            Ich habe für jedes in der VIS eingebettete Diagramm ein eigenes Dashboard erstellt (um die Größe richtig anpassen zu können) und die Visualization via Embed als iframe eingebettet. Hier würden sich auch unterschiedliche Themes auswählen lassen.
            Hast du hier eventuell nicht das Default Theme ausgewählt? bzw. was ist in den Grundeinstellungen als Default definiert? In der config unter users / default_theme zu finden. - Bei mir dark
            • B bloop
              @saeft_2003
              Anderer Ansatz:
              saeft_2003
              #124
              @bloop
              Ich hab 10.2.3 installiert. Als theme war dark gewählt das habe ich auf default gestellt. Später probiere ich es nochmal ob sich was geändert hat.
              Meine charts sind auch über iframe in der VIS
              • S saeft_2003
                @bloop
                Kail
                #125
                @saeft_2003
                habt ihr eine funktionierende Lösung für die Version 10.2.3 gefunden?
                Nach einem Systemupdate geht es bei mir auch nicht mehr.
                Grüße Kail
                • K Kail
                  @saeft_2003
                  Grüße Kail
                  saeft_2003
                  #126
                  @kail
                  Nein hab leider keine Lösung gefunden. Von welcher Version hast du das Update gemacht, also mit welcher ging es bei dir noch?
                  • S saeft_2003
                    @kail
                    Kail
                    #127
                    @saeft_2003
                    Der Vorgänger hatte höchstens eine 9 vorne in der Versionsnummer. Die genaue, kann ich Dir erst am Wochenende nennen.
                    • K Kail
                      @saeft_2003
                      saeft_2003
                      #128
                      @kail
                      Sag bitte Bescheid falls du eine Lösung findest…
                        Kail
                        schrieb am zuletzt editiert von Kail
                        #129
                        @saeft_2003
                        Bescheid
                        Habe mal analysiert und romprobiert. Folge Einträge entfernen bei mir den Hintergrund
                        in der 10.2.3. In meiner Vis stelle ich im iframe nur einzelne Diagramme dar und keine kompletten Dashboards.
                            :root {
                               color-scheme: none;
                              [class*="panel-container"] {
                                 background: transparent !important;
                        Grüße Kail
                        • K Kail
                          @saeft_2003
                          Bescheid
                              :root {
                                 color-scheme: none;
                          Grüße Kail
                          saeft_2003
                          #130
                          @kail
                          Ich bekomms nicht hin. Kannst du bitte mal deine index.html posten wo auf die grafana.css verwiesen wird.
                          • S saeft_2003
                            @kail
                            Kail
                            #131
                            @saeft_2003
                            Meine Einträge sind direkt in der index.html.
                            index.html
                            • K Kail
                              @saeft_2003
                              index.html
                              saeft_2003
                              #132
                              @kail
                              Alles klar danke ich probiere es nachher aus.
                              • K Kail
                                @saeft_2003
                                index.html
                                saeft_2003
                                #133
                                @kail
                                Perfekt jetzt geht es!!! Großes danke schön 👍
                                Ich hab erst nicht verstanden das du das direkt in der index Datei eingibst, aber jetzt läuft das. Jetzt kann ich endlich von der grafana 8 VM auf den grafana 10 LXC umsteigen 😎
                                • S saeft_2003
                                  @kail
                                  Kail
                                  #134
                                  @saeft_2003
                                  Das freut mich. In dem Stand, den ich hochgeladen habe, ist auch der äußere Rand deaktiviert. Wenn Du den haben möchtest, musst Du die Zeile mit border löschen.
                                  Grüße Kail
                                  R 1 Antwort Letzte Antwort
                                  • K Kail
                                    @saeft_2003
                                    Grüße Kail
                                    RkcCorian
                                    schrieb am zuletzt editiert von RkcCorian
                                    #135
                                    @kail Moin! Ich habe großes Interesse an Deiner index.html. Allerdings startet bei mir der Container mit Grafana v10.3.1 nicht mehr, wenn ich die index.html mit Deiner austausche.
                                    Bei jedem Verbindungsversuch über den Browser bekommen ich jeweils einmal die folgende Fehlermeldung...
                                    INFO [01-31|20:38:57] Shutdown started                         logger=server reason="System signal: terminated"
                                    INFO [01-31|20:38:57] Closing tracing                          logger=tracing
                                    INFO [01-31|20:38:57] stopped                                  logger=ticker last_tick=2024-01-31T20:38:50Z
                                    INFO [01-31|20:39:13] Starting Grafana                         logger=settings version=10.3.1 commit=00a22ff8b28550d593ec369ba3da1b25780f0a4a branch=HEAD compiled=2024-01-22T18:40:42Z
                                    INFO [01-31|20:39:13] Config loaded from                       logger=settings file=/usr/share/grafana/conf/defaults.ini
                                    INFO [01-31|20:39:13] Config loaded from                       logger=settings file=/etc/grafana/grafana.ini
                                    INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.data=/var/lib/grafana"
                                    INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.logs=/var/log/grafana"
                                    INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
                                    INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
                                    INFO [01-31|20:39:13] Config overridden from command line      logger=settings arg="default.log.mode=console"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_DATA=/var/lib/grafana"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_LOGS=/var/log/grafana"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_SERVER_PROTOCOL=http"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_SECURITY_ALLOW_EMBEDDING=true"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_AUTH_ANONYMOUS_ENABLED=true"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_FULL_DATE=DD.MM.YY HH:mm:ss"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_HOUR=DD.MM HH:mm"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_DAY=DD.MM"
                                    INFO [01-31|20:39:13] Config overridden from Environment variable logger=settings var="GF_DATE_FORMATS_INTERVAL_MONTH=MM.YY"
                                    INFO [01-31|20:39:13] Target                                   logger=settings target=[all]
                                    INFO [01-31|20:39:13] Path Home                                logger=settings path=/usr/share/grafana
                                    INFO [01-31|20:39:13] Path Data                                logger=settings path=/var/lib/grafana
                                    INFO [01-31|20:39:13] Path Logs                                logger=settings path=/var/log/grafana
                                    INFO [01-31|20:39:13] Path Plugins                             logger=settings path=/var/lib/grafana/plugins
                                    INFO [01-31|20:39:13] Path Provisioning                        logger=settings path=/etc/grafana/provisioning
                                    INFO [01-31|20:39:13] App mode production                      logger=settings
                                    INFO [01-31|20:39:13] Connecting to DB                         logger=sqlstore dbtype=sqlite3
                                    WARN [01-31|20:39:13] SQLite database file has broader permissions than it should logger=sqlstore path=/var/lib/grafana/grafana.db mode=-rwxrwxr-x expected=-rw-r-----
                                    INFO [01-31|20:39:13] Starting DB migrations                   logger=migrator
                                    INFO [01-31|20:39:13] migrations completed                     logger=migrator performed=0 skipped=526 duration=2.883611ms
                                    INFO [01-31|20:39:13] Envelope encryption state                logger=secrets enabled=true current provider=secretKey.v1
                                    INFO [01-31|20:39:13] Loading plugins...                       logger=plugin.store
                                    WARN [01-31|20:39:13] Skipping finding plugins as directory does not exist logger=local.finder path=/usr/share/grafana/plugins-bundled
                                    INFO [01-31|20:39:13] Plugins loaded                           logger=plugin.store count=55 duration=43.891667ms
                                    INFO [01-31|20:39:13] Query Service initialization             logger=query_data
                                    INFO [01-31|20:39:13] Live Push Gateway initialization         logger=live.push_http
                                    INFO [01-31|20:39:14] Starting                                 logger=ngalert.migration
                                    INFO [01-31|20:39:14] Migration already complete               logger=ngalert.migration CurrentType=UnifiedAlerting DesiredType=UnifiedAlerting CleanOnDowngrade=false CleanOnUpgrade=false
                                    WARN [01-31|20:39:14] Unexpected number of rows updating alert configuration history logger=ngalert rows=0 org=1 hash=not-yet-calculated
                                    INFO [01-31|20:39:14] registering usage stat providers         logger=infra.usagestats.collector usageStatsProvidersLen=2
                                    INFO [01-31|20:39:14] starting to provision alerting           logger=provisioning.alerting
                                    INFO [01-31|20:39:14] finished to provision alerting           logger=provisioning.alerting
                                    INFO [01-31|20:39:14] Warming state cache for startup          logger=ngalert.state.manager
                                    INFO [01-31|20:39:14] HTTP Server Listen                       logger=http.server address=[::]:3000 protocol=http subUrl= socket=
                                    INFO [01-31|20:39:14] Storage starting                         logger=grafanaStorageLogger
                                    INFO [01-31|20:39:14] Starting MultiOrg Alertmanager           logger=ngalert.multiorg.alertmanager
                                    INFO [01-31|20:39:14] Authentication is disabled               logger=grafana-apiserver
                                    INFO [01-31|20:39:14] Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager logger=grafana-apiserver
                                    INFO [01-31|20:39:15] Update check succeeded                   logger=grafana.update.checker duration=159.940755ms
                                    INFO [01-31|20:39:15] Update check succeeded                   logger=plugins.update.checker duration=245.34633ms
                                    INFO [01-31|20:39:16] State cache has been initialized         logger=ngalert.state.manager states=0 duration=1.244056524s
                                    INFO [01-31|20:39:16] Starting scheduler                       logger=ngalert.scheduler tickInterval=10s
                                    INFO [01-31|20:39:16] starting                                 logger=ticker first_tick=2024-01-31T20:39:20Z
                                    ERROR[01-31|20:39:29] Request error                            logger=context userId=0 orgId=1 uname= error="Context.HTML - Error rendering template: index. You may need to build frontend assets \n template: index:19:34: executing \"index\" at <.ContentDeliveryURL>: can't evaluate field ContentDeliveryURL in type *dtos.IndexViewData" stack="github.com/grafana/grafana/pkg/web/context.go:112 (0x61c0106)\ngithub.com/grafana/grafana/pkg/api/index.go:231 (0x88ae1cb)\ngithub.com/grafana/grafana/pkg/api/response/web_hack.go:40 (0x61ce5ef)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:131 (0x61c106e)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/services/contexthandler/contexthandler.go:144 (0x88d01c9)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/render.go:44 (0x61c1bfd)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/macaron.go:137 (0x61c1112)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/csrf/csrf.go:66 (0x7ef039a)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/recovery.go:180 (0x88aa63d)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/loggermw/logger.go:72 (0x7ef13b6)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/request_metrics.go:83 (0x67b9975)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/request_tracing.go:88 (0x88ab315)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/middleware/requestmeta/request_metadata.go:66 (0x88cf275)\nnet/http/server.go:2136 (0x5407728)\ngithub.com/grafana/grafana/pkg/web/context.go:52 (0x61bfb56)\ngithub.com/grafana/grafana/pkg/web/router.go:155 (0x61c32cd)\ngithub.com/grafana/grafana/pkg/web/router.go:211 (0x61c3e34)\ngithub.com/grafana/grafana/pkg/web/macaron.go:163 (0x61c153c)\nnet/http/server.go:2938 (0x540a40d)\nnet/http/server.go:2009 (0x54062f3)\nruntime/asm_amd64.s:1650 (0x50cdfc0)\n"
                                    INFO [01-31|20:40:30] Usage stats are ready to report          logger=infra.usagestats
                                    Hast Du eine Idee was das Problem sein könnte? Vielen Dank im Voraus!!!
                                    • R RkcCorian
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #136
                                      @rkccorian Was ist denn DAS für ein Screenshot ????
                                      Was soll man daraus lesen / interpretieren ?
                                      Hammer 😰
                                      Text bitte immer hier in Codetags posten ;)
                                      Lehrling seit 1975 !!!
                                      • DJMarc75D DJMarc75
                                        Hammer 😰
                                        RkcCorian
                                        #137
                                        @djmarc75 Stimmt 🙈 Bin glaub zu müde, sorry! Hab den Post angepasst
                                        • R RkcCorian
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #138
                                          @rkccorian sagte in Hintergrund von Grafana Dashboard in VIS entfernen:
                                          jo, so ists besser lesbar ;)
