  4. Start aus Backup *gelöst*
51 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • G gluecksmann
    @glasfaser
    Ja, das stand so in der Anleitung....
    https://www.elzershark.com/forum/index.php?thread/137-zigbee-richtig-aufbauen-mit-dem-zigbee-adapter-von-iobroker/
    evtl habe ich da was falsch verstanden...
    GlasfaserG Offline
    GlasfaserG Offline
    @gluecksmann sagte in Start aus Backup:
    @glasfaser
    Damit wird im Putty geprüft ..
    • G gluecksmann
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:37:57 up 15 min,  4 users,  load average: 0.54, 1.05, 1.02
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-01-17 19:37:57 CET
                 Universal time: Wed 2024-01-17 18:37:57 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        2.3G        5.0G         16M        1.1G        5.9G
      Swap:           104M          0B        104M
      Total:          8.3G        2.3G        5.1G
               7811 M total memory
               2148 M used memory
               2222 M active memory
                522 M inactive memory
               4780 M free memory
                100 M buffer memory
                919 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  1.3M  780M   1% /run
      /dev/mmcblk0p2 ext4       58G  6.7G   49G  13% /
      tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     782M   36K  782M   1% /run/user/1000
      [Wed Jan 17 19:22:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e5696c9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Wed Jan 17 19:22:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jan 17 19:22:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      567M    /var/
      191M    /var/lib
      186M    /var/cache
      173M    /var/cache/apt
      132M    /var/lib/apt/lists
      Archived and active journals take up 87.9M in the file system.
      /opt/iobroker/backups:
      22M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      434M    /opt/iobroker/iobroker-data/
      335M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
      + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
        system.adapter.philips-air.1            : philips-air           : raspberrypi                              - disabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: ls -l /dev/serial/by-id
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
      Objects and States
      Objects:        11303
      States:         9421
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       41201      8877/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16825      793/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35809      8663/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       35802      8663/iobroker.js-co
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15771      774/cupsd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15770      774/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16827      793/sshd: /usr/sbin
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       39057      8737/io.sonos.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41344      8984/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       38253      8683/io.admin.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       41952      10042/io.fullybrows
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       39692      9179/io.musiccast.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18248      1323/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        11898      521/avahi-daemon: r
      udp        0      0 0.0.0.0:54831           0.0.0.0:*                           104        11900      521/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       38531      8862/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40342      8892/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40343      8892/io.tuya.0
      udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       40286      8847/io.philips-air
      udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          17321      660/NetworkManager
      udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          17225      660/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        11899      521/avahi-daemon: r
      udp6       0      0 :::43656                :::*                                104        11901      521/avahi-daemon: r
      2024-01-17 19:36:26.646  - info: zigbee.0 (21674) Installed Version: iobroker.zigbee@1.9.7
      2024-01-17 19:36:50.317  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-01-17 19:36:50.322  - info: zigbee.0 (21674) Got terminate signal TERMINATE_YOURSELF
      2024-01-17 19:36:50.363  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2024-01-17 19:36:50.324  - info: zigbee.0 (21674) cleaned everything up...
      2024-01-17 19:36:50.542  - info: zigbee.0 (21674) Zigbee: disabling joining new devices.
      2024-01-17 19:36:50.633  - warn: zigbee.0 (21674) Failed to stop zigbee during startup
      2024-01-17 19:36:50.635  - info: zigbee.0 (21674) terminating
      2024-01-17 19:36:50.637  - info: zigbee.0 (21674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-17 19:36:50.773  - info: zigbee.0 (21674) debug devices set to []
      2024-01-17 19:36:50.825  - info: zigbee.0 (21674) terminating
      2024-01-17 19:36:51.266  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-17 19:36:53.513  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23114
      2024-01-17 19:36:58.857  - info: zigbee.0 (23114) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-01-17 19:36:58.970  - info: zigbee.0 (23114) Starting Zigbee  npm ...
      2024-01-17 19:36:59.349  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
      2024-01-17 19:36:59.350  - error: zigbee.0 (23114) Failed to start Zigbee
      2024-01-17 19:36:59.351  - error: zigbee.0 (23114) Error herdsman start
      2024-01-17 19:36:59.355  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
      2024-01-17 19:37:09.355  - info: zigbee.0 (23114) Try to reconnect. 1 attempts left
      2024-01-17 19:37:09.356  - info: zigbee.0 (23114) Starting Zigbee  npm ...
      2024-01-17 19:37:09.374  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
      2024-01-17 19:37:09.375  - error: zigbee.0 (23114) Failed to start Zigbee
      2024-01-17 19:37:09.376  - error: zigbee.0 (23114) Error herdsman start
      2024-01-17 19:37:09.385  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
      Boot Target: graphical.target
      Würde ich ändern auf
      sudo systemctl set-default multi-user.target
      Du hast ja auch Quatsch in den Com-Port eingetragen....
      Statt
      gehört da das rein:
        wieso? Sind da Fehler drin?
        weiss ich nicht in dem speziellen Fall.
        Aber hier melden sich immer wieder welche, die sich mit den Toolz von dem genannten einiges zerschossen haben.
        GlasfaserG Offline
        GlasfaserG Offline
        @gluecksmann
        @homoran sagte in Start aus Backup:
        da ... die hier bei iobroker.net den besten Support bekommen ;)
        G 1 Antwort Letzte Antwort
          @gluecksmann dein /dev/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
          Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
          @gluecksmann dein /dev/serial/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
          wie ich schon vor Tagen sagte
          @glasfaser sagte in Start aus Backup:
          Steht in den Instanzeinstellung Zigbee zum Stick
          • GlasfaserG Glasfaser
            @gluecksmann
            gluecksmann
            @glasfaser
            Habe die andere Anleitung genutzt, weil die ...zumindest teilweise an Stellen funktioniert hat und bebildert war... im Gegensatz zu der hier verlinkten...
            Aber mal sehen... ging mir ja darum die garäte zu behalten...zwischendurch habe ich die auch kurz gesehen...
            • G gluecksmann
              @glasfaser
              gluecksmann
              @gluecksmann
              ist nicht besser geworden..
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               19:56:43 up 33 min,  4 users,  load average: 0.97, 0.69, 0.75
              CPU threads: 4
              Current issues:
                             Local time: Wed 2024-01-17 19:56:44 CET
                         Universal time: Wed 2024-01-17 18:56:44 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           104M          0B        104M
                       7811 M total memory
                       2170 M used memory
                       2244 M active memory
                        527 M inactive memory
                       4751 M free memory
                        100 M buffer memory
                        925 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              567M    /var/
              191M    /var/lib
              186M    /var/cache
              173M    /var/cache/apt
              439M    /opt/iobroker/iobroker-data/
              9.5M    /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
              + instance is alive
              Objects and States
              Objects:        11553
              States:         9447
              Pending Updates: 0
              2024-01-17 19:54:13.273  - error: gruenbeck.0 (9111) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.C/BS00072047/realtime/enter?api-version=2020-08-03
              2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) AxiosError: Request failed with status code 404
              2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) Failed enter SD
              2024-01-17 19:54:13.275  - info: gruenbeck.0 (9111) Relogin
              2024-01-17 19:54:13.595  - info: gruenbeck.0 (9111) Login step 1
              2024-01-17 19:54:14.002  - info: gruenbeck.0 (9111) Login step 2
              2024-01-17 19:54:14.577  - info: gruenbeck.0 (9111) Login successful
              2024-01-17 19:54:17.758  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:54:21.746  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:54:26.256  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:54:39.079  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:54:50.090  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:54:55.889  - info: admin.0 (8683) <== Disconnect system.user.admin from ::ffff:192.168.2.61
              2024-01-17 19:54:57.812  - info: admin.0 (8683) ==> Connected system.user.admin from ::ffff:192.168.2.61
              2024-01-17 19:54:58.315  - error: zigbee.0 (59735) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2024-01-17 19:54:58.561  - info: zigbee.0 (59735) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"34337ce2ac9ded11ab46cfa5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
              2024-01-17 19:55:00.026  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 62862
              2024-01-17 19:55:00.519  - warn: sonos.0 (8737) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
              2024-01-17 19:55:00.696  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:55:02.665  - info: dwd.0 (62862) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
              2024-01-17 19:55:07.202  - info: dwd.0 (62862) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-17 19:55:07.970  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-17 19:55:08.055  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:55:24.744  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              2024-01-17 19:55:30.910  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
              GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
              • G gluecksmann
                @gluecksmann
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M          0B        104M
                         7811 M total memory
                         2170 M used memory
                         4751 M free memory
                          100 M buffer memory
                          925 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                567M    /var/
                191M    /var/lib
                186M    /var/cache
                173M    /var/cache/apt
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        11553
                States:         9447
                Pending Updates: 0
                GlasfaserG Offline
                GlasfaserG Offline
                Hast du jetzt einen neuen Stick ...
                das ist der alte hier im Thread !?
                /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
                EDIT :
                OK
                überlesen :
                So, neuer Stick.
                  EDIT :
                  OK
                  überlesen :
                  So, neuer Stick.
                  gluecksmann
                  @glasfaser
                  Ja, habe einen neuen Stick... wurde mir ja in diesem Threat empfohen einen neuen zu verwenden...
                  • G gluecksmann
                    @gluecksmann
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             7811 M total memory
                             2170 M used memory
                             4751 M free memory
                              100 M buffer memory
                              925 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    567M    /var/
                    191M    /var/lib
                    186M    /var/cache
                    173M    /var/cache/apt
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        11553
                    States:         9447
                    Pending Updates: 0
                    @gluecksmann
                    Starte die Kiste mal komplett sauber durch.
                    sudo reboot
                      @gluecksmann
                      sudo reboot
                      gluecksmann
                      @thomas-braun sagte in Start aus Backup:
                      sudo reboot
                      wenn ich Geräte koppeln will kommt das...
                      Error: Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 '". undefined
                      • G gluecksmann
                        sudo reboot
                        @gluecksmann
                        Du hast vermutlich ein Leerzeichen hintendran.
                          @gluecksmann
                          gluecksmann
                          Alter! Ich muß mal ein ganz großes Lob aussprechen...im Leben wäre ich nicht auf so etwas gekommen... jetzt läuft es, sogar die alten Geräte sind da... mal sehen ob ich jetzt die Aquara Komponenten angemeldet bekomme...
                          • G gluecksmann
                            warum nicht?
                            zwischen port0 und dem abschließenden ' ist es ganz deutlich zu sehen.
                              warum nicht?
                              gluecksmann
                              für den Wissenden bestimmt...ich glaueb ich habe gut unter Beweis gestellt das ich nicht dazu gehöre;-)
