  4. Start aus Backup *gelöst*
51 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • G gluecksmann
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:37:57 up 15 min,  4 users,  load average: 0.54, 1.05, 1.02
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-01-17 19:37:57 CET
               Universal time: Wed 2024-01-17 18:37:57 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.2G        2.3G        5.0G         16M        1.1G        5.9G
    Swap:           104M          0B        104M
    Total:          8.3G        2.3G        5.1G
             7811 M total memory
             2148 M used memory
             2222 M active memory
              522 M inactive memory
             4780 M free memory
              100 M buffer memory
              919 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.3M  780M   1% /run
    /dev/mmcblk0p2 ext4       58G  6.7G   49G  13% /
    tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     782M   36K  782M   1% /run/user/1000
    [Wed Jan 17 19:22:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e5696c9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Wed Jan 17 19:22:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Jan 17 19:22:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    567M    /var/
    191M    /var/lib
    186M    /var/cache
    173M    /var/cache/apt
    132M    /var/lib/apt/lists
    Archived and active journals take up 87.9M in the file system.
    /opt/iobroker/backups:
    22M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    434M    /opt/iobroker/iobroker-data/
    335M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
      system.adapter.philips-air.1            : philips-air           : raspberrypi                              - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: ls -l /dev/serial/by-id
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
    Objects and States
    Objects:        11303
    States:         9421
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       41201      8877/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16825      793/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35809      8663/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       35802      8663/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15771      774/cupsd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15770      774/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16827      793/sshd: /usr/sbin
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       39057      8737/io.sonos.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41344      8984/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       38253      8683/io.admin.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       41952      10042/io.fullybrows
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       39692      9179/io.musiccast.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18248      1323/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        11898      521/avahi-daemon: r
    udp        0      0 0.0.0.0:54831           0.0.0.0:*                           104        11900      521/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       38531      8862/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40342      8892/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40343      8892/io.tuya.0
    udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       40286      8847/io.philips-air
    udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          17321      660/NetworkManager
    udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          17225      660/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        11899      521/avahi-daemon: r
    udp6       0      0 :::43656                :::*                                104        11901      521/avahi-daemon: r
    2024-01-17 19:36:26.646  - info: zigbee.0 (21674) Installed Version: iobroker.zigbee@1.9.7
    2024-01-17 19:36:50.317  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-01-17 19:36:50.322  - info: zigbee.0 (21674) Got terminate signal TERMINATE_YOURSELF
    2024-01-17 19:36:50.363  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-01-17 19:36:50.324  - info: zigbee.0 (21674) cleaned everything up...
    2024-01-17 19:36:50.542  - info: zigbee.0 (21674) Zigbee: disabling joining new devices.
    2024-01-17 19:36:50.633  - warn: zigbee.0 (21674) Failed to stop zigbee during startup
    2024-01-17 19:36:50.635  - info: zigbee.0 (21674) terminating
    2024-01-17 19:36:50.637  - info: zigbee.0 (21674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-17 19:36:50.773  - info: zigbee.0 (21674) debug devices set to []
    2024-01-17 19:36:50.825  - info: zigbee.0 (21674) terminating
    2024-01-17 19:36:51.266  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-17 19:36:53.513  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23114
    2024-01-17 19:36:58.857  - info: zigbee.0 (23114) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-17 19:36:58.970  - info: zigbee.0 (23114) Starting Zigbee  npm ...
    2024-01-17 19:36:59.349  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
    2024-01-17 19:36:59.350  - error: zigbee.0 (23114) Failed to start Zigbee
    2024-01-17 19:36:59.351  - error: zigbee.0 (23114) Error herdsman start
    2024-01-17 19:36:59.355  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
    2024-01-17 19:37:09.355  - info: zigbee.0 (23114) Try to reconnect. 1 attempts left
    2024-01-17 19:37:09.356  - info: zigbee.0 (23114) Starting Zigbee  npm ...
    2024-01-17 19:37:09.374  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
    2024-01-17 19:37:09.375  - error: zigbee.0 (23114) Failed to start Zigbee
    2024-01-17 19:37:09.376  - error: zigbee.0 (23114) Error herdsman start
    2024-01-17 19:37:09.385  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
    GlasfaserG Offline
    GlasfaserG Offline
    @gluecksmann sagte in Start aus Backup:
    Steht in den Instanzeinstellung Zigbee zum Stick
    G 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      gluecksmann
      @glasfaser
      Ja, das stand so in der Anleitung....
      https://www.elzershark.com/forum/index.php?thread/137-zigbee-richtig-aufbauen-mit-dem-zigbee-adapter-von-iobroker/
      evtl habe ich da was falsch verstanden...
      • G gluecksmann
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @glasfaser
        Damit wird im Putty geprüft ..
        • G gluecksmann
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           104M          0B        104M
                   7811 M total memory
                   2148 M used memory
                   4780 M free memory
                    100 M buffer memory
                    919 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          567M    /var/
          191M    /var/lib
          186M    /var/cache
          173M    /var/cache/apt
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11303
          States:         9421
          Pending Updates: 0
          Boot Target: graphical.target
          Würde ich ändern auf
          sudo systemctl set-default multi-user.target
          Du hast ja auch Quatsch in den Com-Port eingetragen....
          Statt
          gehört da das rein:
            wieso? Sind da Fehler drin?
            weiss ich nicht in dem speziellen Fall.
            Aber hier melden sich immer wieder welche, die sich mit den Toolz von dem genannten einiges zerschossen haben.
            GlasfaserG Offline
            GlasfaserG Offline
            @gluecksmann
            @homoran sagte in Start aus Backup:
            da ... die hier bei iobroker.net den besten Support bekommen ;)
              @gluecksmann dein /dev/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
              Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
              @gluecksmann dein /dev/serial/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
              wie ich schon vor Tagen sagte
              @glasfaser sagte in Start aus Backup:
                @gluecksmann
                gluecksmann
                @glasfaser
                Habe die andere Anleitung genutzt, weil die ...zumindest teilweise an Stellen funktioniert hat und bebildert war... im Gegensatz zu der hier verlinkten...
                Aber mal sehen... ging mir ja darum die garäte zu behalten...zwischendurch habe ich die auch kurz gesehen...
                • G gluecksmann
                  @glasfaser
                  gluecksmann
                  @gluecksmann
                  ist nicht besser geworden..
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   19:56:43 up 33 min,  4 users,  load average: 0.97, 0.69, 0.75
                  CPU threads: 4
                  Current issues:
                                 Local time: Wed 2024-01-17 19:56:44 CET
                             Universal time: Wed 2024-01-17 18:56:44 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M          0B        104M
                           7811 M total memory
                           2170 M used memory
                           2244 M active memory
                            527 M inactive memory
                           4751 M free memory
                            100 M buffer memory
                            925 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  567M    /var/
                  191M    /var/lib
                  186M    /var/cache
                  173M    /var/cache/apt
                  439M    /opt/iobroker/iobroker-data/
                  9.5M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
                  + instance is alive
                  Objects and States
                  Objects:        11553
                  States:         9447
                  Pending Updates: 0
                  2024-01-17 19:54:13.273  - error: gruenbeck.0 (9111) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.C/BS00072047/realtime/enter?api-version=2020-08-03
                  2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) AxiosError: Request failed with status code 404
                  2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) Failed enter SD
                  2024-01-17 19:54:13.275  - info: gruenbeck.0 (9111) Relogin
                  2024-01-17 19:54:13.595  - info: gruenbeck.0 (9111) Login step 1
                  2024-01-17 19:54:14.002  - info: gruenbeck.0 (9111) Login step 2
                  2024-01-17 19:54:14.577  - info: gruenbeck.0 (9111) Login successful
                  2024-01-17 19:54:17.758  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:54:21.746  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:54:26.256  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:54:39.079  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:54:50.090  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:54:55.889  - info: admin.0 (8683) <== Disconnect system.user.admin from ::ffff:192.168.2.61
                  2024-01-17 19:54:57.812  - info: admin.0 (8683) ==> Connected system.user.admin from ::ffff:192.168.2.61
                  2024-01-17 19:54:58.315  - error: zigbee.0 (59735) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2024-01-17 19:54:58.561  - info: zigbee.0 (59735) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"34337ce2ac9ded11ab46cfa5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                  2024-01-17 19:55:00.026  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 62862
                  2024-01-17 19:55:00.519  - warn: sonos.0 (8737) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
                  2024-01-17 19:55:00.696  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:55:02.665  - info: dwd.0 (62862) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                  2024-01-17 19:55:07.202  - info: dwd.0 (62862) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-01-17 19:55:07.970  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-01-17 19:55:08.055  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:55:24.744  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  2024-01-17 19:55:30.910  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                  • G gluecksmann
                    @gluecksmann
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             7811 M total memory
                             2170 M used memory
                             4751 M free memory
                              100 M buffer memory
                              925 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    567M    /var/
                    191M    /var/lib
                    186M    /var/cache
                    173M    /var/cache/apt
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        11553
                    States:         9447
                    Pending Updates: 0
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Hast du jetzt einen neuen Stick ...
                    das ist der alte hier im Thread !?
                    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
                    EDIT :
                    OK
                    überlesen :
                    So, neuer Stick.
                      EDIT :
                      OK
                      überlesen :
                      So, neuer Stick.
                      gluecksmann
                      @glasfaser
                      Ja, habe einen neuen Stick... wurde mir ja in diesem Threat empfohen einen neuen zu verwenden...
                      • G gluecksmann
                        @gluecksmann
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 7811 M total memory
                                 2170 M used memory
                                 4751 M free memory
                                  100 M buffer memory
                                  925 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        567M    /var/
                        191M    /var/lib
                        186M    /var/cache
                        173M    /var/cache/apt
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        11553
                        States:         9447
                        Pending Updates: 0
                        @gluecksmann
                        Starte die Kiste mal komplett sauber durch.
                        sudo reboot
                          @gluecksmann
                          sudo reboot
                          gluecksmann
                          @thomas-braun sagte in Start aus Backup:
                          sudo reboot
                          wenn ich Geräte koppeln will kommt das...
                          Error: Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 '". undefined
                          • G gluecksmann
                            sudo reboot
                            @gluecksmann
                            Du hast vermutlich ein Leerzeichen hintendran.
                              @gluecksmann
                              gluecksmann
                              Alter! Ich muß mal ein ganz großes Lob aussprechen...im Leben wäre ich nicht auf so etwas gekommen... jetzt läuft es, sogar die alten Geräte sind da... mal sehen ob ich jetzt die Aquara Komponenten angemeldet bekomme...
                              • G gluecksmann
                                warum nicht?
                                zwischen port0 und dem abschließenden ' ist es ganz deutlich zu sehen.
                                  warum nicht?
                                  gluecksmann
                                  für den Wissenden bestimmt...ich glaueb ich habe gut unter Beweis gestellt das ich nicht dazu gehöre;-)
