  4. LOG anschauen , ständige Internet ausfälle
21 Beiträge 7 Kommentatoren 2.5k Aufrufe 6 Beobachtet
    maik5066
    Hallo Leute, ich bin neu im Iobroker space, ich habe ständig Adapterprobleme , die Verbindungsprobleme melden, könnt ihr bitte mal meinen LOG ansehen ?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.15.83-1-pve
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     08:56:02 up 111 days, 18:13,  1 user,  load average: 0.28, 0.47, 0.39
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Fri 2024-01-12 08:56:02 CET
               Universal time: Fri 2024-01-12 07:56:02 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: yes
    Warning: The system is configured to read the RTC time in the local time zone.
             This mode cannot be fully supported. It will create various problems
             with time zone changes and daylight saving time adjustments. The RTC
             time is never updated, it relies on external facilities to maintain it.
             If at all possible, use RTC in UTC by calling
             'timedatectl set-local-rtc 0'.
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout audio video
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           8.1G        4.7G        2.1G        0.0K        1.2G        3.3G
    Swap:          4.1G        1.1G        3.0G
    Total:          12G        5.8G        5.2G
             8064 M total memory
             4720 M used memory
             2441 M active memory
             3219 M inactive memory
             2133 M free memory
                0 M buffer memory
             1210 M swap cache
             4096 M total swap
             1056 M used swap
             3039 M free swap
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * apparmor.service loaded failed failed Load AppArmor profiles
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/loop1     ext4       30G   11G   18G  38% /
    none           tmpfs     492K  4.0K  488K   1% /dev
    udev           devtmpfs   32G     0   32G   0% /dev/fuse
    tmpfs          tmpfs      32G     0   32G   0% /dev/shm
    tmpfs          tmpfs     6.3G  144K  6.3G   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
    [Wed Jan 10 21:07:18 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Jan 10 21:07:42 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Jan 10 21:08:34 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Jan 10 21:08:49 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Jan 11 21:07:17 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Jan 11 21:07:42 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Jan 11 21:08:34 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Jan 11 21:08:50 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET                      SOURCE                         FSTYPE     OPTIONS
    /                           /dev/loop1                     ext4       rw,relatime
    |-/proc/cpuinfo             lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats           lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg             lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo             lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo            lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat                lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps               lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime              lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/sys/kernel/debug/tracing tracefs                        tracefs    rw,nosuid,nodev,noexec,relatime
    `-/sys/devices/system/cpu   lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    2.7G    /var/
    2.1G    /var/log/journal/7caaddd5c28f42b48434096facca95f9
    2.1G    /var/log
    336M    /var/lib
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    497M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    659M    /opt/iobroker/iobroker-data/
    461M    /opt/iobroker/iobroker-data/files
    140M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    find: Failed to change directory: /root: Permission denied
    find: Failed to restore initial working directory: /root: Permission denied
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_be3ff669ce12ec119e5c23c7bd930c07-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.19.0~dfsg-3ubuntu1.3 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: simple-ssh@^1.1.1, required by iobroker.javascript@7.1.6
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-12T07_56_03_957Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   7
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 192.168.0.18, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.bydhvs.0                 : bydhvs                : ioBroker                                 -  enabled
      system.adapter.canbus.0                 : canbus                : ioBroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.ebus.0                   : ebus                  : ioBroker                                 - disabled
      system.adapter.echarts.0                : echarts               : ioBroker                                 - disabled
    + system.adapter.esphome.0                : esphome               : ioBroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
      system.adapter.hass.0                   : hass                  : ioBroker                                 - disabled, port: 8123
    + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
      system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 -  enabled
      system.adapter.hyperion_ng.0            : hyperion_ng           : ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
      system.adapter.lovelace.0               : lovelace              : ioBroker                                 - disabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.omada.0                  : omada                 : ioBroker                                 -  enabled, port: 443
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      system.adapter.radar2.0                 : radar2                : ioBroker                                 - disabled
    + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
    + system.adapter.roomba.0                 : roomba                : ioBroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
    + system.adapter.scheppach-roboticmower.0 : scheppach-roboticmower: ioBroker                                 -  enabled
    + system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
    + system.adapter.sma-em.0                 : sma-em                : ioBroker                                 -  enabled
      system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 - disabled
    + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : ioBroker                                 -  enabled, port: 8088, bind: 192.168.0.18, run as: admin
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 - disabled
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.xterm.0                  : xterm                 : ioBroker                                 -  enabled, port: 8099, bind: 0.0.0.0
      system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
    Adapter    "canbus"       : 1.3.1    , installed 1.3.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "ebus"         : 3.2.4    , installed 3.2.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "heizungssteuerung": 1.7.0, installed 1.7.0
    Adapter    "heos"         : 2.1.0    , installed 2.1.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
    Adapter    "reolink"      : 1.0.2    , installed 1.0.2
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "semp"         : 1.3.13   , installed 1.3.13
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
    Adapter    "smappee"      : 0.2.6    , installed 0.2.6
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "tapo"         : 0.0.8    , installed 0.2.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wireless-mbus": 0.9.1    , installed 0.9.1
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "xterm"        : 2.0.1    , installed 2.0.1
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
    Objects and States
    Objects:        25545
    States:         20470
    Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 https://dl.yarnpkg.com/debian stable InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 192.168.0.18:8081       0.0.0.0:*               LISTEN      1000       1335626639 3783566/io.admin.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          601716640  332/master
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1335625579 3783548/iobroker.js
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1335628103 3783548/iobroker.js
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       1335637211 3784454/io.jarvis.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        601716336  99/systemd-resolved
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       1335643422 3784780/python3
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1335631018 3783803/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1335632443 3784304/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1507922602 1640561/sshd: /usr/
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          601710293  1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          601716641  332/master
    tcp6       0      0 :::9765                 :::*                    LISTEN      1000       1556454454 2013116/io.semp.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       1335640408 3784560/io.terminal
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1517818547 1755329/io.web.0
    tcp6       0      0 :::8099                 :::*                    LISTEN      1000       1335632253 3784210/io.xterm.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1507922604 1640561/sshd: /usr/
    tcp6       0      0 :::111                  :::*                    LISTEN      0          601714828  1/init
    udp        0      0 0.0.0.0:52164           0.0.0.0:*                           1000       1335632544 3784349/io.broadlin
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1335628409 3784131/io.mihome-v
    udp        0      0 0.0.0.0:60660           0.0.0.0:*                           1000       1335632542 3784349/io.broadlin
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        601716335  99/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          601710294  1/init
    udp        0      0 0.0.0.0:33222           0.0.0.0:*                           1000       1335631562 3784349/io.broadlin
    udp        0      0 0.0.0.0:33524           0.0.0.0:*                           1000       1335628769 3784349/io.broadlin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1556454456 2013116/io.semp.0
    udp        0      0 0.0.0.0:35282           0.0.0.0:*                           1000       1335631590 3784349/io.broadlin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1429471422 707657/io.wled.0
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       1335645296 3784780/python3
    udp        0      0 192.168.0.18:5353       0.0.0.0:*                           1000       1335645295 3784780/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1335645290 3784780/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1335643410 3784760/io.esphome.
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1475426065 1260070/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1475426066 1260070/io.tuya.0
    udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1000       1491545917 1448238/io.sma-em.0
    udp        0      0 0.0.0.0:46458           0.0.0.0:*                           1000       1335632545 3784349/io.broadlin
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       1335632520 3784349/io.broadlin
    udp        0      0 0.0.0.0:48623           0.0.0.0:*                           1000       1335632521 3784349/io.broadlin
    udp6       0      0 :::111                  :::*                                0          601710297  1/init
    iob diag has finished.
    Press any key for a summary
    • M maik5066
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
      iobroker
      /home/iobroker
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               8064 M total memory
               4720 M used memory
               2133 M free memory
                  0 M buffer memory
               1210 M swap cache
               4096 M total swap
               1056 M used swap
               3039 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      2.1G    /var/log
      336M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        25545
      States:         20470
      Pending Updates: 2
      @maik5066 sagte in LOG anschauen , ständige Internet ausfälle:
      und warum schneidest du es dann ab?
      • M maik5066
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
        iobroker
        /home/iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 8064 M total memory
                 4720 M used memory
                 2133 M free memory
                    0 M buffer memory
                 1210 M swap cache
                 4096 M total swap
                 1056 M used swap
                 3039 M free swap
        *** FILESYSTEM ***
        /var:
        2.7G    /var/
        2.1G    /var/log
        336M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        25545
        States:         20470
        Pending Updates: 2
        @maik5066
        Deine Echtzeituhr steht auf der lokalen Zeitzone, die sollte aber auf Z-Zeit stehen.
        Boot Target: graphical.target
        sudo systemctl set-default multi-host.target
        Du verwendest einen falschen User. Leg dir einen neuen an, der dann 'maik 5066' oder so heißt. Und den setzt du dann u. a. in die Gruppen adm und iobroker rein.
        Du stehst vermutlich in /root herum. Da hast du aber nix verloren, stell dich in das /home des neuen users.
        Da fehlt ein Modul, vermutlich manuell im javascript-Adapter einzutragen.
        Für meinen Geschmack / für ein stabiles System deutlich zu viel Zeuch von GitHub installiert.
        Kann vermutlich rausgekickt werden. Braucht man im Allgemeinen nicht.
          @maik5066
          maik5066
          schrieb am zuletzt editiert von maik5066
          @thomas-braun said in LOG anschauen , ständige Internet ausfälle:
          Sorry hier nochmal der Gesamte LOG:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                           RTC time: n/a
          iobroker
          /home/iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   8064 M total memory
                   4720 M used memory
                   2133 M free memory
                      0 M buffer memory
                   1210 M swap cache
                   4096 M total swap
                   1056 M used swap
                   3039 M free swap
          *** FILESYSTEM ***
          /var:
          2.7G    /var/
          2.1G    /var/log
          336M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        25545
          States:         20470
          Pending Updates: 2
          iobroker@ioBroker:/root$ apt policy nodejs
          nodejs:
            Version table:
          Failed to set default target: Access denied
          • M maik5066
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: container
                Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                             RTC time: n/a
            iobroker
            /home/iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     8064 M total memory
                     4720 M used memory
                     2133 M free memory
                        0 M buffer memory
                     1210 M swap cache
                     4096 M total swap
                     1056 M used swap
                     3039 M free swap
            *** FILESYSTEM ***
            /var:
            2.7G    /var/
            2.1G    /var/log
            336M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        25545
            States:         20470
            Pending Updates: 2
            nodejs:
              Version table:
            und wo genau?
            ist abgeschnitten
            Da steht kein log
              und wo genau?
              ist abgeschnitten
              Da steht kein log
              maik5066
              Entschuldige wenn ich Ihn einfüge schneidet er ihn immer ab
              LOG.txt
              CodierknechtC MartinPM 2 Antworten Letzte Antwort
              • M maik5066
                LOG.txt
                CodierknechtC Offline
                Codierknecht
                @maik5066
                Da steht auch nix drin :-(
                Hast Du die von @Thomas-Braun genannten Probleme gelöst?
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • M maik5066
                  LOG.txt
                  MartinPM Online
                  MartinPM Online
                  MartinP
                  @maik5066 Schau doch mal, ob Du über die Zwischenablage des Browsers die Loggings bekommst ...
                  • MartinPM MartinP
                    maik5066
                    @martinp
                    Ich habe den Befehl iob diag über Putty ausgeführt, er bringt auf den Fehler/Hinweis Log File - Last 25 Lines ***
                    in meiner Console, was kann ich machen das er alles anzeigt ?
                    Die Fehler habe ich leider nicht richtig verstanden, sorry aber ich bin ein Anfänger.
                    **Ich habe den befehl eingeben es kommt aber die Antwort; Failed to set default target: Unit file multi-host.target does not exist. Ich habe ein User SU angelegt mit dem Namen maik5066 , wie kann ich den den Gruppen zuweisen **
                    Da fehlt ein Modul, vermutlich manuell im javascript-Adapter einzutragen.[LOG.txt](/assets/uploads/files/
                    **Welches Modul muss ich installieren ? ich habe in den Adaptern noch nichts manuell eingetragen **
                    HomoranH MartinPM 4 Antworten Letzte Antwort
                    • M maik5066
                      @martinp
                      @maik5066 bitte immer alles zeigen!
                      input und output als Text in code-tags!
                      logs genauso
                      • M maik5066
                        @martinp
                        Diesmal war es vollständig, aber enthielt persönliche Daten.
                        Diese bitte entfernen und nochmal senden
                        • M maik5066
                          @martinp
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          @maik5066 said in LOG anschauen , ständige Internet ausfälle:
                          Es geht um diese Zeile im diag:
                          Weiß aber nicht, wie relevant das ist ... bei mir und auch bei Dir gibt es gar keine "RTC-Time" von der Echtzeituhr (da steht N/A), da LXC-Container...
                                         Local time: Fri 2024-01-12 10:05:26 CET
                                     Universal time: Fri 2024-01-12 09:05:26 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          • MartinPM MartinP
                                             RTC time: n/a
                                      RTC in local TZ: no
                            @martinp sagte in LOG anschauen , ständige Internet ausfälle:
                            da LXC-Container...
                            Ja, aber die Meldung zur RTC taucht in anderen Containern in der Form nicht auf. Da ist also irgendwas anders eingestellt.
                            Da ich aber von Containern keine Ahnung habe halte ich mich im weiteren dann hier raus.
                              da LXC-Container...
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              @thomas-braun Definitiv - bei mir steht bei RTC in local TZ: no...
                              @maik5066 steht denn da etwas in der Konsole wenn Du Dir den Abschnitt des diag outputs anschaust?
                              Die Abhilfe gegen das Problem ist ja in der diag-ausgabe zu finden...
                              • wendy2702W Online
                                wendy2702W Online
                                Schau mal in ein iobroker log, zu finden unter
                                /opt/iobroker/log
                                wahrscheinlich am einfachsten wenn du es per z.B. per FTP auf deinen Arbeitsrechner kopierst, dann mit Notepad++ öffnen und nach dem "fehler" suchen den du meinst.
                                Den vollständigen relevanten Teil dann mal hier posten.
                                • wendy2702W wendy2702
                                  /opt/iobroker/log
                                  @wendy2702 sagte in LOG anschauen , ständige Internet ausfälle:
                                  hatte er ja zumindest aus der Diag gemacht, musste ich aber wegen privater Daten entfernen.
                                  seitdem kommt nichts mehr
                                  • M maik5066
                                    @martinp
                                    MartinPM Online
                                    MartinPM Online
                                    MartinP
                                    @maik5066 wie hast Du es geschafft "iob diag"aus "/root" auszuführen?
                                    • MartinPM MartinP
                                      maik5066
                                      @martinp
                                      Hallo, nein aus root kann ich ihn nicht ausführen, ich gehe über den Nutzer Iobroker
                                      024-01-12 09:58:36.188 - info: homeconnect.0 (1260020) Keep Alive failed Reconnect EventStream
                                      2024-01-12 09:58:39.043 - error: iot.0 (348511) Error by device connection: "read ECONNRESET"
                                      2024-01-12 09:58:39.044 - info: iot.0 (348511) Connection changed: disconnect
                                      2024-01-12 09:58:39.044 - info: iot.0 (348511) Connection lost
                                      2024-01-12 09:58:44.293 - info: iot.0 (348511) Connection changed: connect "maik5_66_gmail_com"
                                      2024-01-12 09:59:22.166 - info: alexa2.0 (1785240) Alexa-Push-Connection Error: read ECONNRESET
                                      2024-01-12 09:59:22.166 - info: alexa2.0 (1785240) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                      2024-01-12 09:59:23.365 - info: alexa2.0 (1785240) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                      2024-01-12 10:07:19.762 - info: omada.0 (3784702) Omada cID:
                                      2024-01-12 10:07:20.263 - info: omada.0 (3784702) Login successful
                                      2024-01-12 10:14:07.517 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                      2024-01-12 11:12:59.397 - info: tuya.0 (1260070) 65302272c45bbeda2ea3: Connect locally to device
                                      2024-01-12 11:12:59.397 - info: tuya.0 (1260070) 65302272c45bbeda2ea3 Init with IP=192.168.0.8, Key=75ec761dbbb96fe3, Version=3.3
                                      2024-01-12 11:14:07.572 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                      2024-01-12 11:44:58.611 - info: homeconnect.0 (1260020) BOSCH-PXV975DV1E-68A40E7A3D63/programs/active/options: There is no program active.
                                      2024-01-12 12:04:11.331 - info: alexa2.0 (1785240) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                      2024-01-12 12:04:12.722 - info: alexa2.0 (1785240) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                      2024-01-12 12:06:58.901 - info: homeconnect.0 (1260020) BOSCH-PXV975DV1E-68A40E7A3D63/programs/active/options: There is no program active.
                                      2024-01-12 12:14:07.558 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                      2024-01-12 13:02:24.485 - info: tuya.0 (1260070) 80444028a4e57cb6dd9e: Connect locally to device
                                      2024-01-12 13:02:24.485 - info: tuya.0 (1260070) 80444028a4e57cb6dd9e Init with IP=192.168.0.25, Key=cDU:/7yogI_ss_87, Version=3.3
                                      2024-01-12 13:09:54.416 - error: alexa2.0 (1785240) G0911X03149400LD Error getting aux controller state: Error: Timeout
                                      2024-01-12 13:11:57.321 - error: spotify-premium.0 (2020970) spotify status polling stopped with error Error: connect ETIMEDOUT 35.186.224.25:443
                                      2024-01-12 13:14:07.759 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                      DJMarc75D MartinPM 2 Antworten Letzte Antwort
                                      • M maik5066
                                        @martinp
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @maik5066
                                        Bitte Text in CODETAGS setzen und BITTE entferne persönliche Daten !
                                        Lehrling seit 1975 !!!
                                        • M maik5066
                                          @martinp
                                          MartinPM Online
                                          MartinPM Online
                                          MartinP
                                          Doppelpost
