  4. Sonoff mit iobroker
    5.2k
Sonoff mit iobroker
240 Beiträge 33 Kommentatoren 98.8k Aufrufe 2 Beobachtet
    speedy78
    #202
    Du musst die Werte noch Justieren, steige da auch noch nicht so ganz durch.
    Habe mal ein Messgerät angeschlossen und habe jetzt erstmal die hoffe genauen Werte und passe die mal die Tage an.
    Hier der Link fast ganz unten:
    https://github.com/arendst/Sonoff-Tasmota/wiki/Commands
    Für jede Hilfe bin ich dankbar.
    Sonoff Pow
    Command	Payload	Description
    AmpRes		Show current Current Resolution
    AmpRes	0..3	Set Current Resolution
    CurrentHigh		Show current current high threshold value
    CurrentHigh	0 / off	(default) Disable current high threshold
    CurrentHigh	 <milliamps>Set current high threshold value
    CurrentLow		Show current current low threshold value
    CurrentLow	0 / off	(default) Disable current low threshold
    CurrentLow	 <milliamps>Set current low threshold value
    EnergyRes		Show current Energy Resolution
    EnergyRes	0..5	Set Energy Resolution
    EnergyReset		Show Energy Total, Yesterday and Today
    EnergyReset	1	Reset Energy Today
    EnergyReset	2	Reset Energy Yesterday
    EnergyReset	3	Reset Energy Total to value of Energy Today
    EnergyReset1	0..42500	((P)Re)Set Energy Today in Wh
    EnergyReset2	0..42500	((P)Re)Set Energy Yesterday in Wh
    EnergyReset3	0..42500000	((P)Re)Set Energy Total in Wh
    HlwIcal		Show calibration value for Current
    HlwIcal	1	Set default calibration value for Current to 3500
    HlwIcal	 <value>Set user calibration value for Current starting from 1100
    HlwIset	 <milliamps>Auto-calibrate current to a target value
    HlwPcal		Show calibration value for Power
    HlwPcal	1	Set default calibration value for Power to 12530
    HlwPcal	 <value>Set user calibration value for Power starting from 4000
    HlwPset	 <watts>Auto-calibrate power to a target value
    HlwUcal		Show calibration value for Voltage
    HlwUcal	1	Set default calibration value for Voltage to 1950
    HlwUcal	 <value>Set user calibration value for Voltage starting from 1000
    HlwUset	 <volts>Auto-calibrate voltage to a target value
    MaxPower		Show current maximum power allowed setting
    MaxPower	0 / off	Disable use maximum power monitoring
    MaxPower	 <watt>Set maximum allowed power
    MaxPowerHold		Show current time in seconds to stay over MaxPower before power off
    MaxPowerHold	1	Set default time to 10 seconds to stay over MaxPower before power off
    MaxPowerHold	 <seconds>Set time in seconds to stay over MaxPower before power off
    MaxPowerWindow		Show current time in seconds to stay power off before re-applying power up to 5 times
    MaxPowerWindow	1	Set default time to 30 seconds to stay power off before re-applying power up to 5 times
    MaxPowerWindow	 <seconds>Set time in seconds to stay power off before re-applying power up to 5 times
    PowerHigh		Show current power high threshold value
    PowerHigh	0 / off	(default) Disable power high threshold
    PowerHigh	 <watt>Set power high threshold value
    PowerLow		Show current power low threshold value
    PowerLow	0 / off	(default) Disable power low threshold
    PowerLow	 <watt>Set power low threshold value
    SetOption33		Show Sonoff Pow Max_Power_Retry value
    SetOption33	1..250	Set Sonoff Pow Max_Power_Retry from 1 to 250
    Status	8	Show Power usage
    Status	9	Show Power thresholds
    VoltageHigh		Show current voltage high threshold value
    VoltageHigh	0 / off	(default) Disable voltage high threshold
    VoltageHigh	 <voltage>Set voltage high threshold value
    VoltageLow		Show current voltage low threshold value
    VoltageLow	0 / off	(default) Disable voltage low threshold
    VoltageLow	 <voltage>Set voltage low threshold value
    VoltRes		Show current Voltage Resolution
    VoltRes	0..3	Set Voltage Resolution
    WattRes		Show current Power Resolution
    WattRes	0..3	Set Power Resolution</voltage></voltage></watt></watt></seconds></seconds></watt></volts></value></watts></value></milliamps></value></milliamps></milliamps>
    • SchubiS Offline
      SchubiS Offline
      Schubi
      #203
      1.) Zeitintervall
      Schau mal unter TelePeriod
      https://github.com/arendst/Sonoff-Tasmo … t-specific
      Das Kommando einfach über die Konsole im WEBIF des Moduls eingeben.
      2.) Ein Kommando (und davon gibt es wahnsinnig viele) kann man im WEBIF des Moduls unter dem Punkt Console eingeben.
      Es ist auch möglich Kommandos via MQTT zu senden! D.h. auch direkt aus ioBroker (hab ich auch noch nicht getestet)
      / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
        Bohr
        #204
        @kmxak:
        Adapter auf debug. Wenn im Log alle Schalter auftauchen die Logs als git hub issue
        Gesendet von meinem SM-G930F mit Tapatalk `
        habe einen Fehler entdeckt. Hatte sowohl den Sonoff- als auch MQTT-Adapter auf dem selben Port laufen. Die vertragen sich nicht.
        Jetzt erscheint zwar die RF Bridge unter MQTT bzw Sonoff, aber die 16 möglichen Datenpunkte werden nicht erstellt :roll:
        Bei mir sieht das so aus:
        • kmxakK Offline
          kmxakK Offline
          kmxak
          #205
          stell den adapter mal auf debug mit dem du das gerät benutzt und kopier mal die ausgabe vom log hier rein.
          Die Bridge ist ja schon wieder ein spezieller sonoff. Hat wohl noch niemand.
          Gruß Alex
            Bohr
            #206
            @kmxak:
            Die Bridge ist ja schon wieder ein spezieller sonoff. Hat wohl noch niemand. `
            Habe jetzt jeweils immer nur einen Adapter für die Logs laufen lassen.
            Sonoff-Adapter
            MQTT-Adapter
              dondaik
              #207
              mir ist zu mqtt bekannt das das der sonoff-adapter "mitbring" bzw der mqtt adapter nicht vor dem sonoff-adapter installiert werden sollte .. da war was mit das sie den gleichen port nutzen ( war aber nur ein kurzes "im treppenhaus gespräch" mit einem ITler der iobroker gerade entdeckt hat .. da war es der grund warum sonoff erst nicht funzte … inzwischen ist er mehr als begeister über iobrocker ! )
              ggf ist da auch was neues ...
              https://www.youtube.com/watch?v=pMOhqDl ... 1500324519
              wer Schreibfehler findet darf sie behalten … :-(
              Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
              • kmxakK Offline
                kmxakK Offline
                kmxak
                #208
                Debug aktivieren unter adapter
                Gruß Alex
                  Bohr
                  #209
                  Sonoff Adapter:
                  MQTT-Adapter:
                    Bohr
                    #210
                    mir ist schon klar, dass ich nur einen Adapter (entweder Sonoff oder MQTT) laufen lassen kann. Egal welchen ich nehme, wird mir aber nur Power als Switch angeboten, obwohl ich 16 verschiedene Signale in der Bridge anlernen kann.
                    • SchubiS Offline
                      SchubiS Offline
                      Schubi
                      #211
                      Ich hab das Teil auch nicht, aber du musst sicher die Datenpunkte manuell erstellen.
                      (Link siehe vorher - gibt einen eigen Abschnitt über die Bridge).
                      Probier mal unter cmnd/SonoffBridge/RfKey1
                        Bohr
                        #212
                        habe jetzt diverse Datenpunkte als angelegt (POWER,POWER1 … POWERx, RfKey, RfKey1 ... RfKeyx) ... bringt alles nichts. Der Sonoffadapter legt selber POWER als Switch an. Selbst der will nichts tun, wenn man ihn auslöst. Es würde ja auch nur ein Trigger reichen, der veranlasst, dass die in der Bridge gespeicherten RfKeys abgesendet werden.
                        • kmxakK Offline
                          kmxakK Offline
                          kmxak
                          #213
                          Hast du ein Gerät angemeldet? Wenn ja was sagt der sonoff Log auf der tasmota weboberfläche? Mach mal ein screen wie du überhaupt damit schaltest
                          Gruß Alex
                          • SchubiS Offline
                            SchubiS Offline
                            Schubi
                            #214
                            @Bohr:
                            Hast du die Datenpunkte im Sonoff oder Mqtt Adapter angelegt?
                            Ich glaube nämlich im Sonoff-Adapter funktioniert das nicht -
                            oder sagen wir anders - im Mqtt-Adapter weiß ich, dass es funktioniert :D
                              Bohr
                              #215
                              So nach langem hin und her: Dockerimage angehalten und neugestartet, Sonoffadapter und MQTTadapter de- und neuinstalliert. aktuelle Tasmotaversion auf die RF Bridge geflasht. Unter CMND die Datenpunkte RfKey(x) angelegt und aus irgendeinem Grund geht es jetzt. Ich werkel jetzt seit 3 Nächten an dem sch… Teil rum und habe bisher nichts anderes gemacht als jetzt auch ... scheinbar hat das neuinstallieren der Adapter geholfen.
                              Nachtrag: Mittlerweile steuer ich hier die komplette Weihnachtsbeleuchtung. Geht einwandfrei. Bis auf die Tatsache, dass man manche Signale mehrfach absetzen muss.
                                Bohr
                                #216
                                @Schubi:
                                @Bohr:
                                oder sagen wir anders - im Mqtt-Adapter weiß ich, dass es funktioniert :D `
                                Hast recht, im Sonoff-Adapter geht es nicht!
                                  Torsten07
                                  #217
                                  Servus bin neu hier und muss gleich mal eine blöde Frage absetzen. Der MQTT Adapter funktioniert aus Serverdienst, also quasi als mosquito Alternative richtig?
                                  Gesendet von meinem MI 6 mit Tapatalk
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #218
                                    @Torsten07:
                                    Servus bin neu hier und muss gleich mal eine blöde Frage absetzen. Der MQTT Adapter funktioniert aus Serverdienst, also quasi als mosquito Alternative richtig? `
                                    richtig, wobei man den adapter als "nur" client oder auch server configurieren kan !
                                    Wen als server konfiguriert brauch man kein mosquitto oder dergleichen das laeuft dan als adapter in iobroker und die empfagenden daten werden in ein object wiedergegeben.
                                    (welche man dan in script usw benutzen kan fuer weitere logic)
                                    ~Dutch
                                      sveni_lee
                                      #219
                                      ich habe hier einen SONOFF S20_EU_V1.3 2017-2-16 1741
                                      leider bekomme ich diesen nicht geflascht mit EASYPEASY… Ich habe es jetzt mit allen möglichen
                                      Versionen versucht, zuletzt mit ESPEasy_v2.0.0-dev12 alles ohne erfolg. es wird zwar immer angezeigt, dasss erfolgreich geflascht wurde aber in meinen WLAN taucht esp_0 nicht auf...
                                      • kmxakK Offline
                                        kmxakK Offline
                                        kmxak
                                        #220
                                        du musst meine ich die taste ein paar mal drücken um den wlan ap anzumachen.
                                        steht aber in der wiki
                                        Gruß Alex
                                          sveni_lee
                                          #221
                                          hat bis jetzt leider nicht funktioniert…
                                          Welche Wiki meinst Du?
