  4. Error Log Controller Iobroker *GELÖST*
32 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
    @nicoloma
    Die lange Fassung.
    NicolomaN Offline
    NicolomaN Offline
    Nicoloma
    @thomas-braun ```
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-19-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:26:26 up  1:34,  2 users,  load average: 1.49, 1.36, 1.13
    CPU threads: 3
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-24 21:26:26 CET
               Universal time: Fri 2023-11-24 20:26:26 UTC
                     RTC time: n/a
                    Time zone: CET (CET, +0100)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    nicolas
    /home/nicolas
    nicolas sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.0G        3.5G        4.4G        1.0M        117M        4.5G
    Swap:           2.0G         25M        2.0G
    Total:           10G        3.5G        6.4G
             8000 M total memory
             3504 M used memory
              101 M active memory
             3356 M inactive memory
             4377 M free memory
                0 M buffer memory
              117 M swap cache
             2000 M total swap
               25 M used swap
             1974 M free swap
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * media-FREIGABE.mount                 loaded failed failed /media/FREIGABE
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * bluetooth.service                    loaded failed failed Bluetooth service
    * motioneye.service                    loaded failed failed motionEye Server
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    5 loaded units listed.
    *** FILESYSTEM ***
    Filesystem            Type   Size  Used Avail Use% Mounted on
    ssd/subvol-103-disk-0 zfs     39G   18G   22G  45% /
    none                  tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                 tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                 tmpfs  3.1G  1.7M  3.1G   1% /run
    tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                 tmpfs  1.6G  4.0K  1.6G   1% /run/user/1002
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                FSTYPE OPTIONS
    /      ssd/subvol-103-disk-0 zfs    rw,xattr,posixacl
    /var:
    6.5G    /var/
    4.3G    /var/lib
    2.8G    /var/lib/influxdb
    2.7G    /var/lib/influxdb/data
    2.3G    /var/lib/influxdb/data/iobroker/global
    Archived and active journals take up 168.5K in the file system.
    /opt/iobroker/backups:
    6.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    339M    /opt/iobroker/iobroker-data/
    226M    /opt/iobroker/iobroker-data/files
    97M     /opt/iobroker/iobroker-data/backup-objects
    32M     /opt/iobroker/iobroker-data/files/echarts.admin
    26M     /opt/iobroker/iobroker-data/files/javascript.admin
    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    8.2M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3.2 500
            500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   4
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      system.adapter.material.0               : material              : iobroker                                 - disabled
      system.adapter.mbus.0                   : mbus                  : iobroker                                 - disabled, port: 1502
    + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.103
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
    + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
      system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1887, bind: 192.168.178.103
    + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
      system.adapter.solarviewdatareader.0    : solarviewdatareader   : iobroker                                 - disabled, port: 15000
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.50
    + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8090, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.5.4    , installed 1.5.4
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.4    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mbus"         : 2.5.0    , installed 2.4.0  [Updatable]
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "onvif"        : 1.1.1    , installed 1.1.1
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "radar2"       : 2.0.8    , installed 2.0.8
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "statistics"   : 2.4.0    , installed 2.3.0  [Updatable]
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        22399
    States:         18080
    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:34759         0.0.0.0:*               LISTEN      0          1332094785 228/containerd
    tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      112        1332094765 234/mosquitto
    tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          1332119484 1175/docker-proxy
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1332093500 182/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1332115025 540/master
    tcp        0      0 192.168.178.103:8081    0.0.0.0:*               LISTEN      1000       1333518017 7209/io.admin.0
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          1332104159 548/perl
    tcp        0      0 127.0.0.1:45009         0.0.0.0:*               LISTEN      113        1333808462 9856/plugin_start_l
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1333517165 7191/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1333517169 7191/iobroker.js-co
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1332112977 389/smbd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1332112978 389/smbd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1332093146 1/init
    tcp        0      0 192.168.178.103:1885    0.0.0.0:*               LISTEN      1000       1333610677 7354/io.mqtt.0
    tcp        0      0 192.168.178.103:1884    0.0.0.0:*               LISTEN      1000       1333610676 7354/io.mqtt.0
    tcp        0      0 192.168.178.103:1887    0.0.0.0:*               LISTEN      1000       1333610764 7385/io.shelly.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1332112931 291/influxd
    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      115        1332097086 231/motion
    tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      115        1332097085 231/motion
    tcp6       0      0 :::3001                 :::*                    LISTEN      0          1332119490 1182/docker-proxy
    tcp6       0      0 :::3000                 :::*                    LISTEN      113        1333803505 9714/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1332115026 540/master
    tcp6       0      0 ::1:1883                :::*                    LISTEN      112        1332094766 234/mosquitto
    tcp6       0      0 :::445                  :::*                    LISTEN      0          1332112975 389/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          1332112976 389/smbd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1332093148 1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1332094457 1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1333754449 8820/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        1332113042 291/influxd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1333661282 7418/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1333661283 7418/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1332093499 182/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1332093147 1/init
    udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          1332348842 282/nmbd
    udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          1332348841 282/nmbd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1332112921 282/nmbd
    udp        0      0 192.168.178.103:137     0.0.0.0:*                           0          1332112920 282/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1332112908 282/nmbd
    udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          1332348844 282/nmbd
    udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          1332348843 282/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1332112923 282/nmbd
    udp        0      0 192.168.178.103:138     0.0.0.0:*                           0          1332112922 282/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1332112909 282/nmbd
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          1332104160 548/perl
    udp6       0      0 :::111                  :::*                                0          1332093149 1/init
    2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[10]: 13: 0x12f933d v8::internal::Runtime_StringCharCodeAt(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
    2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[11]: 14: 0x1705b39  [/usr/bin/node]
    2023-11-24 21:25:58.464  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
    2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
    2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
    2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: [33518:0x5e306c0]      720 ms: Mark-sweep (reduce) 19.1 (20.8) -> 18.4 (21.3) MB, 4.4 / 0.0 ms  (+ 0.4 ms in 30 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 31 ms) (average mu = 0.901, current mu = 0.877) allocation f[33518:0x5e306c0]      739 ms: Mark-sweep (reduce) 19.9 (21.3) -> 18.5 (21.5) MB, 4.3 / 0.0 ms  (+ 0.3 ms in 15 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 18 ms) (average mu = 0.862, current mu = 0.757) allocation f
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[2]:  1: 0xb85bc0 node::Abort() [/usr/bin/node]
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[3]:  2: 0xa94834  [/usr/bin/node]
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[4]:  3: 0xd66d10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[5]:  4: 0xd670b7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[6]:  5: 0xf447c5  [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[7]:  6: 0xf56cad v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[8]:  7: 0xf313ae v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[9]:  8: 0xf32777 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[10]:  9: 0xf1394a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[11]: 10: 0x12d8caf v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
    2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[12]: 11: 0x1705b39  [/usr/bin/node]
    2023-11-24 21:26:29.331  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
    2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
    2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
    2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
    NicolomaN 1 Antwort Letzte Antwort
    • NicolomaN Nicoloma
      @thomas-braun ```
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 3
                       RTC time: n/a
                RTC in local TZ: no
      nicolas
      /home/nicolas
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G         25M        2.0G
               8000 M total memory
               3504 M used memory
                101 M active memory
               4377 M free memory
                  0 M buffer memory
                117 M swap cache
               2000 M total swap
                 25 M used swap
               1974 M free swap
      *** FILESYSTEM ***
      /var:
      6.5G    /var/
      4.3G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        22399
      States:         18080
      Pending Updates: 0
      NicolomaN Offline
      NicolomaN Offline
      Nicoloma
      @Thomas-Braun Hallo, hast du eine Idee?
        @nicoloma
        Nein
          @nicoloma
          Nein
          NicolomaN Offline
          NicolomaN Offline
          Nicoloma
          Hallo Jungs und Mädels,
          ich habe immer noch das gleiche Problem.
          Kann bitte mir einer versuchen nochmal zu helfen. Mein Web adapter bzw VIS funktioniert nicht. Er zeigt keine fehlermeldung im Log an aber ich kann es nicht aufrufen.
          Ich wäre euch sehr verbunden
          Skript v.2023-10-25
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
                    Kernel: Linux 6.5.11-7-pve
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           11:43:02 up 21:41,  1 user,  load average: 2.66, 3.07, 2.94
          CPU threads: 4
                         Local time: Wed 2024-01-03 11:43:02 CET
                     Universal time: Wed 2024-01-03 10:43:02 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          nicolo
          /home/nicolo
          nicolo sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.0G        4.5G        3.1G        0.0K        336M        3.5G
          Swap:           100M         99M        0.0K
          Total:          8.1G        4.6G        3.1G
                   8000 M total memory
                   4543 M used memory
                   1839 M active memory
                   2869 M inactive memory
                   3119 M free memory
                      0 M buffer memory
                    337 M swap cache
                    100 M total swap
                     99 M used swap
                      0 M free swap
          3 loaded units listed.
          *** FILESYSTEM ***
          /dev/mapper/Save-vm--103--disk--1 ext4       39G   15G   23G  40% /
          efivarfs                          efivarfs  128K   72K   52K  59% /sys/firmware/efi/efivars
          tmpfs                             tmpfs     3.1G  1.6M  3.1G   1% /run
          Check not possible in LXC or Docker
          Show mounted filesystems:
          /                                             /dev/mapper/Save-vm--103--disk--1 ext4        rw,relatime,stripe=16
          |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,size=3246552k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
          | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
          | |-/run/credentials/systemd-sysusers.service ramfs                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/user/1002                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=1623276k,nr_inodes=405819,mode=700,uid=101002,gid=101002,inode64
          |-/dev                                        none                              tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
          | |-/dev/mqueue                               mqueue                            mqueue      rw,relatime
          | |-/dev/ttyACM0                              udev[/ttyACM0]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/.lxc/proc                            proc                              proc        rw,relatime
          | |-/dev/.lxc/sys                             sys                               sysfs       rw,relatime
          | |-/dev/full                                 udev[/full]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/null                                 udev[/null]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/random                               udev[/random]                     devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/tty                                  udev[/tty]                        devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/urandom                              udev[/urandom]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/zero                                 udev[/zero]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
          | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/ptmx                                 devpts[/ptmx]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/console                              devpts[/0]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/tty1                                 devpts[/1]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | `-/dev/tty2                                 devpts[/2]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys                                 proc[/sys]                        proc        ro,relatime
          | | |-/proc/sys/net                           proc[/sys/net]                    proc        rw,nosuid,nodev,noexec,relatime
          | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
          | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]               tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]              proc        ro,relatime
          | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/diskstats                           lxcfs[/proc/diskstats]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/loadavg                             lxcfs[/proc/loadavg]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/meminfo                             lxcfs[/proc/meminfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/stat                                lxcfs[/proc/stat]                 fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/swaps                               lxcfs[/proc/swaps]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | `-/proc/uptime                              lxcfs[/proc/uptime]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys                                        sysfs                             sysfs       ro,nosuid,nodev,noexec,relatime
            |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
            |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]       sysfs       rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
            |-/sys/firmware/efi/efivars                 efivarfs                          efivarfs    rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/cgroup                            none                              cgroup2     rw,nosuid,nodev,noexec,relatime
            `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]    fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          6.9G    /var/
          4.5G    /var/lib
          3.8G    /var/lib/influxdb/data
          3.3G    /var/lib/influxdb/data/iobroker
          Archived and active journals take up 24.0M in the file system.
          83M     /opt/iobroker/backups/
          747M    /opt/iobroker/iobroker-data/
          588M    /opt/iobroker/iobroker-data/files
          126M    /opt/iobroker/iobroker-data/files/vis-2
          105M    /opt/iobroker/iobroker-data/backup-objects
          90M     /opt/iobroker/iobroker-data/files/echarts.admin
          48M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220810141742-if00
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   5
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
            system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
            system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.103
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
          + instance is alive
          Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
          Adapter    "acme"         : 0.1.2    , installed 0.1.2
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mbus"         : 2.6.1    , installed 2.6.1
          Adapter    "meross"       : 1.16.1   , installed 1.16.1
          Adapter    "modbus"       : 6.0.1    , installed 6.0.1
          Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
          Adapter    "radar2"       : 2.1.0    , installed 2.1.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "vis"          : 1.5.4    , installed 1.5.4
          Adapter    "welcome"      : 0.1.0    , installed 0.1.0
          Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
          Objects and States
          Objects:        23550
          States:         19971
          Hit:1 https://repos.influxdata.com/debian stable InRelease
          Hit:2 https://packages.grafana.com/oss/deb stable InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:6 http://archive.ubuntu.com/ubuntu jammy-security InRelease
          Pending Updates: 0
          Netid                  State                   Recv-Q                   Send-Q                                       Local Address:Port                                      Peer Address:Port                  Process
          udp                    UNCONN                  0                        0                                                  0.0.0.0:6666                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=41))
          udp                    UNCONN                  0                        0                                                  0.0.0.0:6667                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=42))
          udp                    UNCONN                  0                        0                                            127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=13))
          udp                    UNCONN                  0                        0                                                  0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=5),("systemd",pid=1,fd=28))
          udp                    UNCONN                  0                        0                                          192.168.178.255:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=16))
          udp                    UNCONN                  0                        0                                          192.168.178.103:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=15))
          udp                    UNCONN                  0                        0                                                  0.0.0.0:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=13))
          udp                    UNCONN                  0                        0                                          192.168.178.255:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=18))
          udp                    UNCONN                  0                        0                                          192.168.178.103:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=17))
          udp                    UNCONN                  0                        0                                                  0.0.0.0:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=14))
          udp                    UNCONN                  0                        0                                                  0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=6))
          udp                    UNCONN                  0                        0                                                     [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=7),("systemd",pid=1,fd=30))
          tcp                    LISTEN                  0                        511                                        192.168.178.103:8081                                           0.0.0.0:*                      users:(("io.admin.0",pid=257225,fd=29))
          tcp                    LISTEN                  0                        100                                              127.0.0.1:25                                             0.0.0.0:*                      users:(("master",pid=459,fd=13))
          tcp                    LISTEN                  0                        100                                              127.0.0.1:1883                                           0.0.0.0:*                      users:(("mosquitto",pid=192,fd=5))
          tcp                    LISTEN                  0                        4096                                               0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=5))
          tcp                    LISTEN                  0                        511                                              127.0.0.1:43317                                          0.0.0.0:*                      users:(("plugin_start_li",pid=744,fd=19))
          tcp                    LISTEN                  0                        50                                                 0.0.0.0:445                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=46))
          tcp                    LISTEN                  0                        4096                                         127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=14))
          tcp                    LISTEN                  0                        4096                                               0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=4),("systemd",pid=1,fd=27))
          tcp                    LISTEN                  0                        50                                                 0.0.0.0:139                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=47))
          tcp                    LISTEN                  0                        511                                                0.0.0.0:9001                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=21))
          tcp                    LISTEN                  0                        511                                                0.0.0.0:9000                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=27))
          tcp                    LISTEN                  0                        511                                        192.168.178.103:1887                                           0.0.0.0:*                      users:(("io.shelly.0",pid=846,fd=32))
          tcp                    LISTEN                  0                        511                                        192.168.178.103:1884                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=29))
          tcp                    LISTEN                  0                        511                                        192.168.178.103:1885                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=30))
          tcp                    LISTEN                  0                        511                                        192.168.178.103:1880                                           0.0.0.0:*                      users:(("io.sonoff.0",pid=864,fd=34))
          tcp                    LISTEN                  0                        4096                                             127.0.0.1:8088                                           0.0.0.0:*                      users:(("influxd",pid=330,fd=3))
          tcp                    LISTEN                  0                        4096                                             127.0.0.1:8080                                           0.0.0.0:*                      users:(("motion",pid=190,fd=7))
          tcp                    LISTEN                  0                        4096                                             127.0.0.1:8081                                           0.0.0.0:*                      users:(("motion",pid=190,fd=5))
          tcp                    LISTEN                  0                        4096                                                     *:3000                                                 *:*                      users:(("grafana",pid=601,fd=9))
          tcp                    LISTEN                  0                        50                                                    [::]:445                                               [::]:*                      users:(("smbd",pid=477,fd=44))
          tcp                    LISTEN                  0                        4096                                                     *:22                                                   *:*                      users:(("systemd",pid=1,fd=43))
          tcp                    LISTEN                  0                        4096                                                  [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=6),("systemd",pid=1,fd=29))
          tcp                    LISTEN                  0                        50                                                    [::]:139                                               [::]:*                      users:(("smbd",pid=477,fd=45))
          tcp                    LISTEN                  0                        511                                                      *:8082                                                 *:*                      users:(("io.web.0",pid=8598,fd=28))
          tcp                    LISTEN                  0                        4096                                                     *:8086                                                 *:*                      users:(("influxd",pid=330,fd=179))
          tcp                    LISTEN                  0                        100                                                  [::1]:1883                                              [::]:*                      users:(("mosquitto",pid=192,fd=6))
          tcp                    LISTEN                  0                        100                                                  [::1]:25                                                [::]:*                      users:(("master",pid=459,fd=14))
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[15]: 14: 0xd8c7f9 v8::ScriptCompiler::CompileFunctionInternal(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason, v8::Local<v8::ScriptOrModule>*) [/usr/bin/node]
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[16]: 15: 0xd8cbc7 v8::ScriptCompiler::CompileFunction(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) [/usr/bin/node]
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[17]: 16: 0xb875f8 node::contextify::ContextifyContext::CompileFunction(v8::FunctionCallbackInfo<v8::Value> const&) [/usr/bin/node]
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[18]: 17: 0xdcd3e0  [/usr/bin/node]
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[19]: 18: 0xdce91f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
          2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[20]: 19: 0x170dfb9  [/usr/bin/node]
          2024-01-03 11:43:25.443  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
          2024-01-03 11:43:38.840  - error: host.iobroker cannot call visUtils: Not exists
          2024-01-03 11:43:38.842  - error: host.iobroker cannot call visUtils: Not exists
          2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
          2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: n [262346:0x64c0870]      883 ms: Mark-sweep (reduce) 18.9 (21.0) -> 18.3 (21.3) MB, 2.9 / 0.0 ms  (+ 1.0 ms in 10 steps since start of marking, biggest step 0.2 ms, walltime since start of marking 16 ms) (average mu = 0.669, current mu = 0.768) finalize in[262346:0x64c0870]      902 ms: Mark-sweep (reduce) 19.1 (21.6) -> 18.6 (21.6) MB, 6.2 / 0.0 ms  (+ 0.2 ms in 4 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 17 ms) (average mu = 0.669, current mu = 0.669) finalize inc
          2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
          2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
          2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[1]:  1: 0xb95b60 node::Abort() [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[2]:  2: 0xa9a7f8  [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[3]:  3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[4]:  4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[5]:  5: 0xf4cba5  [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[6]:  6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[7]:  7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[8]:  8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[9]:  9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
          2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[10]: 10: 0x170deb9  [/usr/bin/node]
          2024-01-03 11:43:56.509  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
          2024-01-03 11:43:57.345  - info: iot.0 (8971) Connection changed: disconnect
          iob diag has finished.
          Copy text starting here:
                                  v.2023-10-25
                   Chassis: container
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               CET (CET, +0100)
          User-ID:                1002
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          MEMORY:
          Mem:            8.0G        4.5G        2.8G        0.0K        707M        3.5G
          Swap:           100M         99M        0.0K
          Total:          8.1G        4.6G        2.8G
          Active iob-Instances:   33
          ioBroker Core:          js-controller           5.0.17
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                23550
          States:                 19971
          Size of iob-Database:
          56M     /opt/iobroker/iobroker-data/objects.jsonl
          10M     /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
            Skript v.2023-10-25
            *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            nicolo
            /home/nicolo
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           100M         99M        0.0K
                     8000 M total memory
                     4543 M used memory
                     3119 M free memory
                        0 M buffer memory
                      337 M swap cache
                      100 M total swap
                       99 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            6.9G    /var/
            4.5G    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        23550
            States:         19971
            Pending Updates: 0
                                    v.2023-10-25
                     Chassis: container
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                1002
            X-Server:               false
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            MEMORY:
            Swap:           100M         99M        0.0K
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                23550
            States:                 19971
            arteckA Offline
            arteckA Offline
            arteck
            @nicoloma
            gesehen..bestimmt nicht..
            da läuft in deinen Javscripten was schief
            NicolomaN 2 Antworten Letzte Antwort
            • arteckA arteck
              @nicoloma
              NicolomaN Offline
              NicolomaN Offline
              Nicoloma
              @arteck doch, ich habe den den Adapter sogar schon komplett deaktiviert, die Meldung bleibt gleich.
              • arteckA arteck
                @nicoloma
                NicolomaN Offline
                NicolomaN Offline
                Nicoloma
                schrieb am zuletzt editiert von Nicoloma
                @arteck
                host.iobroker
                2024-01-03 12:15:34.137	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[11]: 10: 0x170deb9 [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[10]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[9]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[8]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[7]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[6]: 5: 0xf4cba5 [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[5]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[4]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[3]: 2: 0xa9a7f8 [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[2]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[1]: <--- JS stacktrace --->
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[0]: nc[269268:0x6440870] 24816 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.7 (21.3) MB, 6.7 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 52 ms) (average mu = 0.937, current mu = 0.874) finalize inc[269268:0x6440870] 24903 ms: Mark-sweep (reduce) 19.0 (21.3) -> 18.8 (21.6) MB, 5.9 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 86 ms) (average mu = 0.934, current mu = 0.931) finalize inc
                host.iobroker
                2024-01-03 12:15:34.137	error	Caught by controller[0]: <--- Last few GCs --->
                javascript.0
                2024-01-03 12:15:03.964	info	terminating
                javascript.0
                2024-01-03 12:15:03.469	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                javascript.0
                2024-01-03 12:15:03.468	info	terminating
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.PV-Heizstab_aktiv
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.Fußboden
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.aquarium_per_pv
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.telegramm1
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.nullsteller
                javascript.0
                2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.überschuss1_b
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_OG
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_Fb
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaszahler
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gasslbst
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaskhwverbrauch
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.Gas_kwheuro
                javascript.0
                2024-01-03 12:15:03.466	info	Stop script script.js.common.Alexa.Müllrausbringen
                javascript.0
                2024-01-03 12:15:03.465	info	Stop script script.js.Skript_1ss
                javascript.0
                2024-01-03 12:15:03.463	info	Got terminate signal TERMINATE_YOURSELF
                • NicolomaN Offline
                  NicolomaN Offline
                  Nicoloma
                  LÖSUNG: DOWNGRADE VON Node.js18 auf NODE 16...
                    @nicoloma
                    Das ist keine Lösung, nodejs@16 ist im Upstream abgekündigt.
                      @nicoloma
                      NicolomaN Offline
                      NicolomaN Offline
                      Nicoloma
                      @thomas-braun Ja, aber ich kann es nicht lösen und keiner von euch weiß weiter.
                        NicolomaN Offline
                        NicolomaN Offline
                        Nicoloma
                        War doch keine lösung habe wieder auf 18 upgedatet!
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @nicoloma setzt die kiste mal neu auf...
                          wechsel auf debian.. probeweise..warum auch immer
                          • arteckA arteck
                            @arteck sagte in Error Log Controller Iobroker:
                            Den exakt gleichen Gedanken hatte ich auch! :-)
                            • NicolomaN Offline
                              NicolomaN Offline
                              Nicoloma
                              Kann man mit den Fehlermeldungen den nichts anfangen?
                              host.iobroker
                              2024-01-04 10:36:18.491	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[10]: 10: 0x170deb9 [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[9]: 9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[8]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[7]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[6]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[5]: 5: 0xf4cba5 [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[4]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[3]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[2]: 2: 0xa9a7f8 [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[1]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                              host.iobroker
                              2024-01-04 10:36:18.491	error	Caught by controller[0]: <--- JS stacktrace --->
                              host.iobroker
                              2024-01-04 10:36:18.490	error	Caught by controller[0]: nc[269575:0x689a870] 693 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.3 (21.3) MB, 2.9 / 0.0 ms (+ 0.4 ms in 9 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 10 ms) (average mu = 0.772, current mu = 0.708) allocation f[269575:0x689a870] 714 ms: Mark-sweep (reduce) 19.7 (21.6) -> 19.1 (22.1) MB, 5.9 / 0.0 ms (+ 0.7 ms in 12 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 19 ms) (average mu = 0.717, current mu = 0.681) finalize in
                              host.iobroker
                              2024-01-04 10:36:18.490	error	Caught by controller[0]: <--- Last few GCs --->
                              Boah das system neu aufzusetzten ist, da stecken für mich LAIE, ewig viel Arbeit....
                              influx.. die ganzen config.... :-/
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                @nicoloma sagte in Error Log Controller Iobroker:
                                Ich nicht. Ich sehe da nur, das 'irgendwas' den Speicher im Heap auffrisst.
                                Kannst ja mal durch deine Skripte gehen.
                                  NicolomaN Offline
                                  NicolomaN Offline
                                  Nicoloma
                                  Ich bin dir für jeden Vorschlag dankbar! Aber wenn ich den Javascript-Adapter stoppe sollen doch alle Skripte auch nicht mehr laufen?
                                  Oder laufen Sie vielleicht im Hintergrund weiter?
                                    NicolomaN Offline
                                    NicolomaN Offline
                                    Nicoloma
                                    Ich habe schon den Node Option auf
                                    Node: -max_old_space_size=8192 erhöt.
                                    dan habe ich
                                    npm install -g increase-memory-limit
                                    durchgeführt..
                                    Hat auch nichts gebraucht
                                    @Thomas-Braun kennst du eine gute Anleitung für einen evetuellen Umzug?
                                      dan habe ich
                                      durchgeführt..
                                      NicolomaN Offline
                                      NicolomaN Offline
                                      Nicoloma
                                      OCH LEUTE * Ich bin stink sauer*
                                      Ich glaube ich habe es jetzt.
                                      Aus unerklärlichen Gründen, hatte der Trashsheduleadapater eine limitierung von 20MB!
                                      JUHU!!!!!
                                      Trotzdem allen vielen dank. Jetzt muss ich nur noch schauen, warum VIS bei mir nicht funktioniert!
