  4. Error Log Controller Iobroker *GELÖST*
32 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
    @nicoloma
    Und der hat kein Heimverzeichnis? Warum stehst du da in / herum?
    NicolomaN Offline
    NicolomaN Offline
    Nicoloma
    @thomas-braun ```
    Copy text starting here:
                            v.2023-10-10
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-19-pve
        Architecture: x86-64
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               CET (CET, +0100)
    User-ID:                1003
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            8.0G        3.5G        4.4G        1.0M        117M        4.5G
    Swap:           2.0G         25M        2.0G
    Total:           10G        3.5G        6.4G
    Active iob-Instances:   31
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    Objects:                22399
    States:                 18080
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    1.1M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    • NicolomaN Nicoloma
      @thomas-braun ```
                              v.2023-10-10
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1003
      X-Server:               false
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      MEMORY:
      Swap:           2.0G         25M        2.0G
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                22399
      States:                 18080
      @nicoloma
      Die lange Fassung.
      NicolomaN 1 Antwort Letzte Antwort
        @nicoloma
        Die lange Fassung.
        NicolomaN Offline
        NicolomaN Offline
        Nicoloma
        @thomas-braun ```
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
        model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         21:26:26 up  1:34,  2 users,  load average: 1.49, 1.36, 1.13
        CPU threads: 3
        *** Time and Time Zones ***
                       Local time: Fri 2023-11-24 21:26:26 CET
                   Universal time: Fri 2023-11-24 20:26:26 UTC
                         RTC time: n/a
                        Time zone: CET (CET, +0100)
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        nicolas
        /home/nicolas
        nicolas sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G         25M        2.0G
                 8000 M total memory
                 3504 M used memory
                  101 M active memory
                 3356 M inactive memory
                 4377 M free memory
                    0 M buffer memory
                  117 M swap cache
                 2000 M total swap
                   25 M used swap
                 1974 M free swap
        *** FAILED SERVICES ***
          UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
        * media-FREIGABE.mount                 loaded failed failed /media/FREIGABE
        * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
        * bluetooth.service                    loaded failed failed Bluetooth service
        * motioneye.service                    loaded failed failed motionEye Server
        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
        5 loaded units listed.
        *** FILESYSTEM ***
        Filesystem            Type   Size  Used Avail Use% Mounted on
        ssd/subvol-103-disk-0 zfs     39G   18G   22G  45% /
        none                  tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                 tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs                 tmpfs  3.1G  1.7M  3.1G   1% /run
        tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs                 tmpfs  1.6G  4.0K  1.6G   1% /run/user/1002
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                FSTYPE OPTIONS
        /      ssd/subvol-103-disk-0 zfs    rw,xattr,posixacl
        /var:
        6.5G    /var/
        4.3G    /var/lib
        2.8G    /var/lib/influxdb
        2.7G    /var/lib/influxdb/data
        2.3G    /var/lib/influxdb/data/iobroker/global
        Archived and active journals take up 168.5K in the file system.
        /opt/iobroker/backups:
        6.4G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        339M    /opt/iobroker/iobroker-data/
        226M    /opt/iobroker/iobroker-data/files
        97M     /opt/iobroker/iobroker-data/backup-objects
        32M     /opt/iobroker/iobroker-data/files/echarts.admin
        26M     /opt/iobroker/iobroker-data/files/javascript.admin
        18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        13M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        8.2M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.2 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   4
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
          system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
          system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
          system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          system.adapter.material.0               : material              : iobroker                                 - disabled
          system.adapter.mbus.0                   : mbus                  : iobroker                                 - disabled, port: 1502
        + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
          system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.103
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
        + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
          system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
        + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
          system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
          system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
        + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1887, bind: 192.168.178.103
        + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
        + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
          system.adapter.solarviewdatareader.0    : solarviewdatareader   : iobroker                                 - disabled, port: 15000
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.50
        + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8090, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
          system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "echarts"      : 1.5.4    , installed 1.5.4
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.4    , installed 7.1.6
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mbus"         : 2.5.0    , installed 2.4.0  [Updatable]
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "onvif"        : 1.1.1    , installed 1.1.1
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
        Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "radar2"       : 2.0.8    , installed 2.0.8
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "statistics"   : 2.4.0    , installed 2.3.0  [Updatable]
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        22399
        States:         18080
        W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 https://repos.influxdata.com/debian stable InRelease
        Hit:4 https://packages.grafana.com/oss/deb stable InRelease
        Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:34759         0.0.0.0:*               LISTEN      0          1332094785 228/containerd
        tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      112        1332094765 234/mosquitto
        tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          1332119484 1175/docker-proxy
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1332093500 182/systemd-resolve
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1332115025 540/master
        tcp        0      0 192.168.178.103:8081    0.0.0.0:*               LISTEN      1000       1333518017 7209/io.admin.0
        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          1332104159 548/perl
        tcp        0      0 127.0.0.1:45009         0.0.0.0:*               LISTEN      113        1333808462 9856/plugin_start_l
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1333517165 7191/iobroker.js-co
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1333517169 7191/iobroker.js-co
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1332112977 389/smbd
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1332112978 389/smbd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1332093146 1/init
        tcp        0      0 192.168.178.103:1885    0.0.0.0:*               LISTEN      1000       1333610677 7354/io.mqtt.0
        tcp        0      0 192.168.178.103:1884    0.0.0.0:*               LISTEN      1000       1333610676 7354/io.mqtt.0
        tcp        0      0 192.168.178.103:1887    0.0.0.0:*               LISTEN      1000       1333610764 7385/io.shelly.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1332112931 291/influxd
        tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      115        1332097086 231/motion
        tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      115        1332097085 231/motion
        tcp6       0      0 :::3001                 :::*                    LISTEN      0          1332119490 1182/docker-proxy
        tcp6       0      0 :::3000                 :::*                    LISTEN      113        1333803505 9714/grafana
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1332115026 540/master
        tcp6       0      0 ::1:1883                :::*                    LISTEN      112        1332094766 234/mosquitto
        tcp6       0      0 :::445                  :::*                    LISTEN      0          1332112975 389/smbd
        tcp6       0      0 :::139                  :::*                    LISTEN      0          1332112976 389/smbd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          1332093148 1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1332094457 1/init
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1333754449 8820/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        1332113042 291/influxd
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1333661282 7418/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1333661283 7418/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1332093499 182/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1332093147 1/init
        udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          1332348842 282/nmbd
        udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          1332348841 282/nmbd
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1332112921 282/nmbd
        udp        0      0 192.168.178.103:137     0.0.0.0:*                           0          1332112920 282/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1332112908 282/nmbd
        udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          1332348844 282/nmbd
        udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          1332348843 282/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1332112923 282/nmbd
        udp        0      0 192.168.178.103:138     0.0.0.0:*                           0          1332112922 282/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1332112909 282/nmbd
        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          1332104160 548/perl
        udp6       0      0 :::111                  :::*                                0          1332093149 1/init
        2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[10]: 13: 0x12f933d v8::internal::Runtime_StringCharCodeAt(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
        2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[11]: 14: 0x1705b39  [/usr/bin/node]
        2023-11-24 21:25:58.464  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
        2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
        2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
        2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: [33518:0x5e306c0]      720 ms: Mark-sweep (reduce) 19.1 (20.8) -> 18.4 (21.3) MB, 4.4 / 0.0 ms  (+ 0.4 ms in 30 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 31 ms) (average mu = 0.901, current mu = 0.877) allocation f[33518:0x5e306c0]      739 ms: Mark-sweep (reduce) 19.9 (21.3) -> 18.5 (21.5) MB, 4.3 / 0.0 ms  (+ 0.3 ms in 15 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 18 ms) (average mu = 0.862, current mu = 0.757) allocation f
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[2]:  1: 0xb85bc0 node::Abort() [/usr/bin/node]
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[3]:  2: 0xa94834  [/usr/bin/node]
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[4]:  3: 0xd66d10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[5]:  4: 0xd670b7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
        2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[6]:  5: 0xf447c5  [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[7]:  6: 0xf56cad v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[8]:  7: 0xf313ae v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[9]:  8: 0xf32777 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[10]:  9: 0xf1394a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[11]: 10: 0x12d8caf v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
        2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[12]: 11: 0x1705b39  [/usr/bin/node]
        2023-11-24 21:26:29.331  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
        2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
        2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
        2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
          @thomas-braun ```
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 3
                           RTC time: n/a
                    RTC in local TZ: no
          nicolas
          /home/nicolas
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           2.0G         25M        2.0G
                   8000 M total memory
                   3504 M used memory
                    101 M active memory
                   4377 M free memory
                      0 M buffer memory
                    117 M swap cache
                   2000 M total swap
                     25 M used swap
                   1974 M free swap
          *** FILESYSTEM ***
          /var:
          6.5G    /var/
          4.3G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        22399
          States:         18080
          Pending Updates: 0
          NicolomaN Offline
          NicolomaN Offline
          Nicoloma
          @Thomas-Braun Hallo, hast du eine Idee?
            @nicoloma
            Nein
              @nicoloma
              Nein
              NicolomaN Offline
              NicolomaN Offline
              Nicoloma
              Hallo Jungs und Mädels,
              ich habe immer noch das gleiche Problem.
              Kann bitte mir einer versuchen nochmal zu helfen. Mein Web adapter bzw VIS funktioniert nicht. Er zeigt keine fehlermeldung im Log an aber ich kann es nicht aufrufen.
              Ich wäre euch sehr verbunden
              Skript v.2023-10-25
              *** BASE SYSTEM ***
                       Chassis: container
                Virtualization: lxc
                        Kernel: Linux 6.5.11-7-pve
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               11:43:02 up 21:41,  1 user,  load average: 2.66, 3.07, 2.94
              CPU threads: 4
                             Local time: Wed 2024-01-03 11:43:02 CET
                         Universal time: Wed 2024-01-03 10:43:02 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              nicolo
              /home/nicolo
              nicolo sudo iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.0G        4.5G        3.1G        0.0K        336M        3.5G
              Swap:           100M         99M        0.0K
              Total:          8.1G        4.6G        3.1G
                       8000 M total memory
                       4543 M used memory
                       1839 M active memory
                       2869 M inactive memory
                       3119 M free memory
                          0 M buffer memory
                        337 M swap cache
                        100 M total swap
                         99 M used swap
                          0 M free swap
              3 loaded units listed.
              *** FILESYSTEM ***
              /dev/mapper/Save-vm--103--disk--1 ext4       39G   15G   23G  40% /
              efivarfs                          efivarfs  128K   72K   52K  59% /sys/firmware/efi/efivars
              tmpfs                             tmpfs     3.1G  1.6M  3.1G   1% /run
              Check not possible in LXC or Docker
              Show mounted filesystems:
              /                                             /dev/mapper/Save-vm--103--disk--1 ext4        rw,relatime,stripe=16
              |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,size=3246552k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
              | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
              | |-/run/credentials/systemd-sysusers.service ramfs                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
              | `-/run/user/1002                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=1623276k,nr_inodes=405819,mode=700,uid=101002,gid=101002,inode64
              |-/dev                                        none                              tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
              | |-/dev/mqueue                               mqueue                            mqueue      rw,relatime
              | |-/dev/ttyACM0                              udev[/ttyACM0]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/.lxc/proc                            proc                              proc        rw,relatime
              | |-/dev/.lxc/sys                             sys                               sysfs       rw,relatime
              | |-/dev/full                                 udev[/full]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/null                                 udev[/null]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/random                               udev[/random]                     devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/tty                                  udev[/tty]                        devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/urandom                              udev[/urandom]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/zero                                 udev[/zero]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
              | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/ptmx                                 devpts[/ptmx]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/console                              devpts[/0]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/tty1                                 devpts[/1]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | `-/dev/tty2                                 devpts[/2]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
              | |-/proc/sys                                 proc[/sys]                        proc        ro,relatime
              | | |-/proc/sys/net                           proc[/sys/net]                    proc        rw,nosuid,nodev,noexec,relatime
              | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
              | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]               tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]              proc        ro,relatime
              | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/diskstats                           lxcfs[/proc/diskstats]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/loadavg                             lxcfs[/proc/loadavg]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/meminfo                             lxcfs[/proc/meminfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/stat                                lxcfs[/proc/stat]                 fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/swaps                               lxcfs[/proc/swaps]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | `-/proc/uptime                              lxcfs[/proc/uptime]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              `-/sys                                        sysfs                             sysfs       ro,nosuid,nodev,noexec,relatime
                |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
                |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]       sysfs       rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
                |-/sys/firmware/efi/efivars                 efivarfs                          efivarfs    rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/cgroup                            none                              cgroup2     rw,nosuid,nodev,noexec,relatime
                `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]    fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              /var:
              6.9G    /var/
              4.5G    /var/lib
              3.8G    /var/lib/influxdb/data
              3.3G    /var/lib/influxdb/data/iobroker
              Archived and active journals take up 24.0M in the file system.
              83M     /opt/iobroker/backups/
              747M    /opt/iobroker/iobroker-data/
              588M    /opt/iobroker/iobroker-data/files
              126M    /opt/iobroker/iobroker-data/files/vis-2
              105M    /opt/iobroker/iobroker-data/backup-objects
              90M     /opt/iobroker/iobroker-data/files/echarts.admin
              48M     /opt/iobroker/iobroker-data/objects.jsonl
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220810141742-if00
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 1001
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   5
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
                system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
              + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.103
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              + instance is alive
              Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
              Adapter    "acme"         : 0.1.2    , installed 0.1.2
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "mbus"         : 2.6.1    , installed 2.6.1
              Adapter    "meross"       : 1.16.1   , installed 1.16.1
              Adapter    "modbus"       : 6.0.1    , installed 6.0.1
              Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
              Adapter    "radar2"       : 2.1.0    , installed 2.1.0
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "telegram"     : 3.0.1    , installed 3.0.1
              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
              Adapter    "vis"          : 1.5.4    , installed 1.5.4
              Adapter    "welcome"      : 0.1.0    , installed 0.1.0
              Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
              Objects and States
              Objects:        23550
              States:         19971
              Hit:1 https://repos.influxdata.com/debian stable InRelease
              Hit:2 https://packages.grafana.com/oss/deb stable InRelease
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
              Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:6 http://archive.ubuntu.com/ubuntu jammy-security InRelease
              Pending Updates: 0
              Netid                  State                   Recv-Q                   Send-Q                                       Local Address:Port                                      Peer Address:Port                  Process
              udp                    UNCONN                  0                        0                                                  0.0.0.0:6666                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=41))
              udp                    UNCONN                  0                        0                                                  0.0.0.0:6667                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=42))
              udp                    UNCONN                  0                        0                                            127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=13))
              udp                    UNCONN                  0                        0                                                  0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=5),("systemd",pid=1,fd=28))
              udp                    UNCONN                  0                        0                                          192.168.178.255:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=16))
              udp                    UNCONN                  0                        0                                          192.168.178.103:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=15))
              udp                    UNCONN                  0                        0                                                  0.0.0.0:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=13))
              udp                    UNCONN                  0                        0                                          192.168.178.255:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=18))
              udp                    UNCONN                  0                        0                                          192.168.178.103:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=17))
              udp                    UNCONN                  0                        0                                                  0.0.0.0:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=14))
              udp                    UNCONN                  0                        0                                                  0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=6))
              udp                    UNCONN                  0                        0                                                     [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=7),("systemd",pid=1,fd=30))
              tcp                    LISTEN                  0                        511                                        192.168.178.103:8081                                           0.0.0.0:*                      users:(("io.admin.0",pid=257225,fd=29))
              tcp                    LISTEN                  0                        100                                              127.0.0.1:25                                             0.0.0.0:*                      users:(("master",pid=459,fd=13))
              tcp                    LISTEN                  0                        100                                              127.0.0.1:1883                                           0.0.0.0:*                      users:(("mosquitto",pid=192,fd=5))
              tcp                    LISTEN                  0                        4096                                               0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=5))
              tcp                    LISTEN                  0                        511                                              127.0.0.1:43317                                          0.0.0.0:*                      users:(("plugin_start_li",pid=744,fd=19))
              tcp                    LISTEN                  0                        50                                                 0.0.0.0:445                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=46))
              tcp                    LISTEN                  0                        4096                                         127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=14))
              tcp                    LISTEN                  0                        4096                                               0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=4),("systemd",pid=1,fd=27))
              tcp                    LISTEN                  0                        50                                                 0.0.0.0:139                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=47))
              tcp                    LISTEN                  0                        511                                                0.0.0.0:9001                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=21))
              tcp                    LISTEN                  0                        511                                                0.0.0.0:9000                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=27))
              tcp                    LISTEN                  0                        511                                        192.168.178.103:1887                                           0.0.0.0:*                      users:(("io.shelly.0",pid=846,fd=32))
              tcp                    LISTEN                  0                        511                                        192.168.178.103:1884                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=29))
              tcp                    LISTEN                  0                        511                                        192.168.178.103:1885                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=30))
              tcp                    LISTEN                  0                        511                                        192.168.178.103:1880                                           0.0.0.0:*                      users:(("io.sonoff.0",pid=864,fd=34))
              tcp                    LISTEN                  0                        4096                                             127.0.0.1:8088                                           0.0.0.0:*                      users:(("influxd",pid=330,fd=3))
              tcp                    LISTEN                  0                        4096                                             127.0.0.1:8080                                           0.0.0.0:*                      users:(("motion",pid=190,fd=7))
              tcp                    LISTEN                  0                        4096                                             127.0.0.1:8081                                           0.0.0.0:*                      users:(("motion",pid=190,fd=5))
              tcp                    LISTEN                  0                        4096                                                     *:3000                                                 *:*                      users:(("grafana",pid=601,fd=9))
              tcp                    LISTEN                  0                        50                                                    [::]:445                                               [::]:*                      users:(("smbd",pid=477,fd=44))
              tcp                    LISTEN                  0                        4096                                                     *:22                                                   *:*                      users:(("systemd",pid=1,fd=43))
              tcp                    LISTEN                  0                        4096                                                  [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=6),("systemd",pid=1,fd=29))
              tcp                    LISTEN                  0                        50                                                    [::]:139                                               [::]:*                      users:(("smbd",pid=477,fd=45))
              tcp                    LISTEN                  0                        511                                                      *:8082                                                 *:*                      users:(("io.web.0",pid=8598,fd=28))
              tcp                    LISTEN                  0                        4096                                                     *:8086                                                 *:*                      users:(("influxd",pid=330,fd=179))
              tcp                    LISTEN                  0                        100                                                  [::1]:1883                                              [::]:*                      users:(("mosquitto",pid=192,fd=6))
              tcp                    LISTEN                  0                        100                                                  [::1]:25                                                [::]:*                      users:(("master",pid=459,fd=14))
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[15]: 14: 0xd8c7f9 v8::ScriptCompiler::CompileFunctionInternal(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason, v8::Local<v8::ScriptOrModule>*) [/usr/bin/node]
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[16]: 15: 0xd8cbc7 v8::ScriptCompiler::CompileFunction(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) [/usr/bin/node]
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[17]: 16: 0xb875f8 node::contextify::ContextifyContext::CompileFunction(v8::FunctionCallbackInfo<v8::Value> const&) [/usr/bin/node]
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[18]: 17: 0xdcd3e0  [/usr/bin/node]
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[19]: 18: 0xdce91f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
              2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[20]: 19: 0x170dfb9  [/usr/bin/node]
              2024-01-03 11:43:25.443  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
              2024-01-03 11:43:38.840  - error: host.iobroker cannot call visUtils: Not exists
              2024-01-03 11:43:38.842  - error: host.iobroker cannot call visUtils: Not exists
              2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
              2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: n [262346:0x64c0870]      883 ms: Mark-sweep (reduce) 18.9 (21.0) -> 18.3 (21.3) MB, 2.9 / 0.0 ms  (+ 1.0 ms in 10 steps since start of marking, biggest step 0.2 ms, walltime since start of marking 16 ms) (average mu = 0.669, current mu = 0.768) finalize in[262346:0x64c0870]      902 ms: Mark-sweep (reduce) 19.1 (21.6) -> 18.6 (21.6) MB, 6.2 / 0.0 ms  (+ 0.2 ms in 4 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 17 ms) (average mu = 0.669, current mu = 0.669) finalize inc
              2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
              2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
              2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[1]:  1: 0xb95b60 node::Abort() [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[2]:  2: 0xa9a7f8  [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[3]:  3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[4]:  4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[5]:  5: 0xf4cba5  [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[6]:  6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[7]:  7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[8]:  8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[9]:  9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
              2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[10]: 10: 0x170deb9  [/usr/bin/node]
              2024-01-03 11:43:56.509  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
              2024-01-03 11:43:57.345  - info: iot.0 (8971) Connection changed: disconnect
              iob diag has finished.
                                      v.2023-10-25
                       Chassis: container
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               amd64
              User-ID:                1002
              X-Server:               false
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              MEMORY:
              Mem:            8.0G        4.5G        2.8G        0.0K        707M        3.5G
              Swap:           100M         99M        0.0K
              Total:          8.1G        4.6G        2.8G
              Active iob-Instances:   33
              ioBroker Core:          js-controller           5.0.17
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                23550
              States:                 19971
              56M     /opt/iobroker/iobroker-data/objects.jsonl
              10M     /opt/iobroker/iobroker-data/states.jsonl
                Skript v.2023-10-25
                *** BASE SYSTEM ***
                         Chassis: container
                  Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                                 RTC time: n/a
                          RTC in local TZ: no
                nicolo
                /home/nicolo
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           100M         99M        0.0K
                         8000 M total memory
                         4543 M used memory
                         3119 M free memory
                            0 M buffer memory
                          337 M swap cache
                          100 M total swap
                           99 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                6.9G    /var/
                4.5G    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        23550
                States:         19971
                Pending Updates: 0
                                        v.2023-10-25
                         Chassis: container
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                1002
                X-Server:               false
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                MEMORY:
                Swap:           100M         99M        0.0K
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                23550
                States:                 19971
                arteckA Offline
                arteckA Offline
                arteck
                @nicoloma
                gesehen..bestimmt nicht..
                da läuft in deinen Javscripten was schief
                NicolomaN 2 Antworten Letzte Antwort
                • arteckA arteck
                  @nicoloma
                  NicolomaN Offline
                  NicolomaN Offline
                  Nicoloma
                  @arteck doch, ich habe den den Adapter sogar schon komplett deaktiviert, die Meldung bleibt gleich.
                  • arteckA arteck
                    @nicoloma
                    NicolomaN Offline
                    NicolomaN Offline
                    Nicoloma
                    schrieb am zuletzt editiert von Nicoloma
                    @arteck
                    host.iobroker
                    2024-01-03 12:15:34.137	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[11]: 10: 0x170deb9 [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[10]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[9]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[8]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[7]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[6]: 5: 0xf4cba5 [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[5]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[4]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[3]: 2: 0xa9a7f8 [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[2]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[1]: <--- JS stacktrace --->
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[0]: nc[269268:0x6440870] 24816 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.7 (21.3) MB, 6.7 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 52 ms) (average mu = 0.937, current mu = 0.874) finalize inc[269268:0x6440870] 24903 ms: Mark-sweep (reduce) 19.0 (21.3) -> 18.8 (21.6) MB, 5.9 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 86 ms) (average mu = 0.934, current mu = 0.931) finalize inc
                    host.iobroker
                    2024-01-03 12:15:34.137	error	Caught by controller[0]: <--- Last few GCs --->
                    javascript.0
                    2024-01-03 12:15:03.964	info	terminating
                    javascript.0
                    2024-01-03 12:15:03.469	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    javascript.0
                    2024-01-03 12:15:03.468	info	terminating
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.PV-Heizstab_aktiv
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.Fußboden
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.aquarium_per_pv
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.telegramm1
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.nullsteller
                    javascript.0
                    2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.überschuss1_b
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_OG
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_Fb
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaszahler
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gasslbst
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaskhwverbrauch
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.Gas_kwheuro
                    javascript.0
                    2024-01-03 12:15:03.466	info	Stop script script.js.common.Alexa.Müllrausbringen
                    javascript.0
                    2024-01-03 12:15:03.465	info	Stop script script.js.Skript_1ss
                    javascript.0
                    2024-01-03 12:15:03.463	info	Got terminate signal TERMINATE_YOURSELF
                    • NicolomaN Offline
                      NicolomaN Offline
                      Nicoloma
                      LÖSUNG: DOWNGRADE VON Node.js18 auf NODE 16...
                        @nicoloma
                        Das ist keine Lösung, nodejs@16 ist im Upstream abgekündigt.
                          @nicoloma
                          NicolomaN Offline
                          NicolomaN Offline
                          Nicoloma
                          @thomas-braun Ja, aber ich kann es nicht lösen und keiner von euch weiß weiter.
                            NicolomaN Offline
                            NicolomaN Offline
                            Nicoloma
                            War doch keine lösung habe wieder auf 18 upgedatet!
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @nicoloma setzt die kiste mal neu auf...
                              wechsel auf debian.. probeweise..warum auch immer
                              • arteckA arteck
                                @arteck sagte in Error Log Controller Iobroker:
                                Den exakt gleichen Gedanken hatte ich auch! :-)
                                • NicolomaN Offline
                                  NicolomaN Offline
                                  Nicoloma
                                  Kann man mit den Fehlermeldungen den nichts anfangen?
                                  host.iobroker
                                  2024-01-04 10:36:18.491	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[10]: 10: 0x170deb9 [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[9]: 9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[8]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[7]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[6]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[5]: 5: 0xf4cba5 [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[4]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[3]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[2]: 2: 0xa9a7f8 [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[1]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                  host.iobroker
                                  2024-01-04 10:36:18.491	error	Caught by controller[0]: <--- JS stacktrace --->
                                  host.iobroker
                                  2024-01-04 10:36:18.490	error	Caught by controller[0]: nc[269575:0x689a870] 693 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.3 (21.3) MB, 2.9 / 0.0 ms (+ 0.4 ms in 9 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 10 ms) (average mu = 0.772, current mu = 0.708) allocation f[269575:0x689a870] 714 ms: Mark-sweep (reduce) 19.7 (21.6) -> 19.1 (22.1) MB, 5.9 / 0.0 ms (+ 0.7 ms in 12 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 19 ms) (average mu = 0.717, current mu = 0.681) finalize in
                                  host.iobroker
                                  2024-01-04 10:36:18.490	error	Caught by controller[0]: <--- Last few GCs --->
                                  Boah das system neu aufzusetzten ist, da stecken für mich LAIE, ewig viel Arbeit....
                                  influx.. die ganzen config.... :-/
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    host.iobroker
                                    @nicoloma sagte in Error Log Controller Iobroker:
                                    Ich nicht. Ich sehe da nur, das 'irgendwas' den Speicher im Heap auffrisst.
                                    Kannst ja mal durch deine Skripte gehen.
                                      NicolomaN Offline
                                      NicolomaN Offline
                                      Nicoloma
                                      Ich bin dir für jeden Vorschlag dankbar! Aber wenn ich den Javascript-Adapter stoppe sollen doch alle Skripte auch nicht mehr laufen?
                                      Oder laufen Sie vielleicht im Hintergrund weiter?
                                        NicolomaN Offline
                                        NicolomaN Offline
                                        Nicoloma
                                        Ich habe schon den Node Option auf
                                        Node: -max_old_space_size=8192 erhöt.
                                        dan habe ich
                                        npm install -g increase-memory-limit
                                        durchgeführt..
                                        Hat auch nichts gebraucht
                                        @Thomas-Braun kennst du eine gute Anleitung für einen evetuellen Umzug?
                                          dan habe ich
                                          durchgeführt..
                                          NicolomaN Offline
                                          NicolomaN Offline
                                          Nicoloma
                                          OCH LEUTE * Ich bin stink sauer*
                                          Ich glaube ich habe es jetzt.
                                          Aus unerklärlichen Gründen, hatte der Trashsheduleadapater eine limitierung von 20MB!
                                          JUHU!!!!!
                                          Trotzdem allen vielen dank. Jetzt muss ich nur noch schauen, warum VIS bei mir nicht funktioniert!
