  4. Zigbee: Resource temporarily unavailable Cannot lock port
29 Beiträge 4 Kommentatoren 5.8k Aufrufe 4 Beobachtet
  • R roughestboy
                         v.2023-01-02
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Installation:           Native
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     54
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                            /usr/bin/node           v16.19.1
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.6
    Objects type: jsonl
    States  type: redis
    Status admin:
    + system.adapter.admin.0                  : admin                 : pi4iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Pending iob updates:    0
    Active repo(s): beta
    Objects:                4090
    States:                 2820
    Size of iob-Database:
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    552K    /opt/iobroker/iobroker-data/states.jsonl
    @roughestboy
    Updaten...
    R 1 Antwort Letzte Antwort
    • R roughestboy
      @crunchip
      Ja, die alte nvbackup.json is ja auch noch da. Wenn ich die wieder einsetze, sehen die Fehlermeldungen anders aus, Instanz bleibt aber auf gelb:
      zigbee.0
      2023-02-26 18:00:06.605	error	Error herdsman start
      zigbee.0
      2023-02-26 18:00:06.604	error	Failed to start Zigbee
      zigbee.0
      2023-02-26 18:00:06.598	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2023-02-26 18:00:06.199	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0
      2023-02-26 18:00:06.131	info	Starting Zigbee npm ...
      zigbee.0
      2023-02-26 18:00:06.128	info	Try to reconnect. 1 attempts left
      zigbee.0
      2023-02-26 17:59:56.121	error	Error herdsman start
      zigbee.0
      2023-02-26 17:59:56.120	error	Failed to start Zigbee
      zigbee.0
      2023-02-26 17:59:56.117	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
      zigbee.0
      2023-02-26 17:59:46.937	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0
      2023-02-26 17:59:46.246	info	Starting Zigbee npm ...
      zigbee.0
      2023-02-26 17:59:46.242	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-02-26 17:59:46.102	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
      crunchipC Offline
      crunchipC Offline
      @roughestboy und wenn du den Stick mal kurz absteckst?
        roughestboy
        @crunchip ändert nichts.
          @roughestboy
          Updaten...
          roughestboy
          Habe jetzt Pending OS-Updates auf Null. Zwischendurch Kabel zum Stick getauscht, den Stick gegen einen identischen gewechselt, und ein Backitup vom 2.2. eingespielt, da war das Problem noch nicht. Auch noch eine neue, 2te Instanz angelegt. Es bleibt immer bei einem 'zigbee-herdsman Problem,' "Cannot read properties of undefined (reading 'payload')" und "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'". Letztes log:
          zigbee.0
          	2023-03-04 11:48:47.327	error	Error herdsman start
          zigbee.0
          	2023-03-04 11:48:47.325	error	Failed to start Zigbee
          zigbee.0
          	2023-03-04 11:48:47.324	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          	2023-03-04 11:48:47.127	info	Installed Version: iobroker.zigbee@1.8.10
          zigbee.0
          	2023-03-04 11:48:47.103	info	Starting Zigbee npm ...
          zigbee.0
          	2023-03-04 11:48:47.102	info	Try to reconnect. 1 attempts left
          zigbee.0
          	2023-03-04 11:48:37.083	error	Error herdsman start
          zigbee.0
          	2023-03-04 11:48:37.083	error	Failed to start Zigbee
          zigbee.0
          	2023-03-04 11:48:37.081	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
          zigbee.0
          	2023-03-04 11:48:28.346	info	Installed Version: iobroker.zigbee@1.8.10
          zigbee.0
          	2023-03-04 11:48:27.652	info	Starting Zigbee npm ...
          zigbee.0
          	2023-03-04 11:48:27.483	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
          • R Offline
            roughestboy
            Frage: gibts in iobroker irgendetwas oder einen anderen Adapter, der sich den Zigbee Stick schnappt, in etwa sowas wie hier:
            502 - Bad Gateway =>TypeError: Cannot read property 'payload' of undefined
            • R Offline
              roughestboy
              So, um das hier noch abzuschließen. Habe mich wegen eines anderen 'Großprojekts' lange nicht kümmern können und erstmal ohne Zigbee leben müssen.
              Nun ist raus, es war ein 'schlechtes' udev-Paket. Siehe auch
              zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
              Für mich war es dann die Möglichkeit 2.
                micw42
                schrieb am zuletzt editiert von micw42
                ich habe heute den js-controller aktualisiert und danach node.js und den zigbee-Adapter. Sonst habe ich nichts verändert!
                Leider bekomme ich nun auch die Meldung und der Adapter startet nicht mehr:
                zigbee.0
                2024-01-03 23:02:48.184	error	Error herdsman start
                zigbee.0
                2024-01-03 23:02:48.183	error	Failed to start Zigbee
                zigbee.0
                2024-01-03 23:02:48.182	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                zigbee.0
                2024-01-03 23:02:47.835	info	Installed Version: iobroker.zigbee@1.9.5
                zigbee.0
                2024-01-03 23:02:47.802	info	Starting Zigbee npm ...
                zigbee.0
                2024-01-03 23:02:47.801	info	Try to reconnect. 1 attempts left
                zigbee.0
                2024-01-03 23:02:37.795	error	Error herdsman start
                zigbee.0
                2024-01-03 23:02:37.794	error	Failed to start Zigbee
                zigbee.0
                2024-01-03 23:02:37.793	error	Starting zigbee-herdsman problem : undefined
                zigbee.0
                2024-01-03 23:02:26.289	info	Installed Version: iobroker.zigbee@1.9.5
                zigbee.0
                2024-01-03 23:02:25.619	info	Starting Zigbee npm ...
                zigbee.0
                2024-01-03 23:02:25.616	info	delete old Backup files. keep only last 10
                zigbee.0
                2024-01-03 23:02:25.317	info	starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                • M micw42
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  @micw42
                  iob diag
                  in der Langfassung anschauen.
                    @micw42
                    iob diag
                    micw42
                    Ich muss wohl noch dazu sagen, dass ich einen RaspBee II Stick habe.
                    • M micw42
                      @micw42 sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
                      Was davon ist denn interessant?
                      Alles. Im gesamten gibt es ein Bild.
                        micw42
                        Habe es in dem vorigen Beitrag reingepackt.
                        • M micw42
                          @micw42
                          Besser CodeTags statt Spoiler verwenden.
                          • M micw42
                            @micw42
                            Ich brauche aber gar nicht weiterlesen.
                            Buster ist tot, installier da NEU das aktuelle Release 'Bookworm'. In der 64Bit Lite-Version.
                              @micw42
                              micw42
                              Ich weiß, aber daran kann es doch nicht liegen?
                              Das hat vor zwei Stunden unter buster alles funktioniert ...
                              • M micw42
                                @micw42 Irrelevant. Buster ist tot. Zeit von dem Gaul abzusteigen.
