  4. Test Adapter telegram-menu v.1.6.x
    6.3k
1.9k Beiträge 65 Kommentatoren 987.4k Aufrufe 63 Beobachtet
  • Michael RolingM Michael Roling
    @segway evtl. Über die console updaten
    SegwayS Offline
    SegwayS Offline
    Segway
    schrieb am zuletzt editiert von Segway
    #1210
    @michael-roling
    Auch darüber siehts komisch aus :-(
    iob upgrade telegram-menu@1.6.1
    Would you like to upgrade telegram-menu from @1.5.1 to @1.6.1 now? [(y)es, (n)o]: y
    Update telegram-menu from @1.5.1 to @1.6.1
    NPM version: 10.2.3
    Installing iobroker.telegram-menu@1.6.1... (System call)
    removed 104 packages, and changed 1 package in 8s
    295 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.telegram-menu.0"
    upload [17] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/build/index.js build/index.js application/javascript
    upload [16] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/build/index.js.map build/index.js.map application/json
     Objects database error: read ECONNRESET
     Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    upload [15] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [14] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [13] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [12] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [11] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [10] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [9] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [8] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [6] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [5] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [4] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/img/info-big.png img/info-big.png image/png
    upload [3] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/index_m.html index_m.html text/html
    upload [2] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/src/style.css src/style.css text/css
    upload [1] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/telegram-menu.png telegram-menu.png image/png
    upload [0] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/words.js words.js application/javascript
    Speicher ist auch wieder voll gelaufen und stop/start ausgeführt :-(
    Gruß Dirk
    Michael RolingM 1 Antwort Letzte Antwort
    • SegwayS Segway
      @michael-roling
      NPM version: 10.2.3
      Michael RolingM Offline
      Michael Roling
      #1211
      @segway du nutzt doch anscheinend proxmox. Kannst du dem Container nicht etwas mehr ram zuteilen
      SegwayS 1 Antwort Letzte Antwort
        SegwayS Offline
        SegwayS Offline
        Segway
        #1212
        @michael-roling
        Sollten 5Gb nicht ausreichen ?
        Selbst mit 6,5Gb ist dergleichen Effekt :-(
        Gruß Dirk
        • SegwayS Segway
          @michael-roling
          Michael Roling
          #1213
          @segway das ist nicht so schön. Dann musst du evtl die 0.8.5 installieren und warten bis bei dem js-Controller dieses Issue gefixt wurde
          Rene55R SegwayS 2 Antworten Letzte Antwort
            Rene55R Offline
            Rene55R Offline
            Rene55
            #1214
            @michael-roling Ich habe im Bereich der Navigation keinen Scrollbalken. Liegt das am Adapter oder am Admin?
            • Rene55R Rene55
              Michael Roling
              #1215
              @rene55 kann am Adapter liegen. Müsste ich mal nachschauen die Tage. Erstellst du bitte ein Issue
                Rene55R Offline
                Rene55R Offline
                Rene55
                #1216
                @michael-roling Wenn du das so möchtest.
                • Rene55R Rene55
                  Michael Roling
                  #1217
                  @rene55 ja sonst verliere ich das aus den Augen
                    Rene55R Offline
                    Rene55R Offline
                    Rene55
                    #1218
                    @michael-roling Kann ja auch nur an mir liegen. Haben das die anderen Mitstreiter evtl. auch? Dann mach ich ein Issue.
                    Michael RolingM liv-in-skyL B 3 Antworten Letzte Antwort
                    • Rene55R Rene55
                      Michael Roling
                      #1219
                      @rene55 mach einfach und ich schaue nach
                      • Rene55R Rene55
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #1220
                        @rene55
                        ja , habe ich auch - der ramverbrauch steigt um ca 1,5 GB - da ich aber 6 gb frei habe ist das kein thema bei mir
                        • Rene55R Rene55
                          BobBruni
                          #1221
                          @rene55 said in Test Adapter telegram-menu v.0.9.x:
                          Ich kann auch nicht mehr Scrollen, wenn ich einen Datenpunkt auswählen möchte (setstate sowie getstate).
                            abuzze
                            #1222
                            Guten Abend.Ich habe eine Frage zum Adapter. Wie kann ich eine Chat ID einer Gruppe hinzufügen ? Mache ich das über diesen Adapter oder im Telegram Adapter ? Würde gerne die Tastatur im Gruppenchat laden. Danke
                            W Michael RolingM 2 Antworten Letzte Antwort
                            • A abuzze
                              W Offline
                              W Offline
                              Willi-Wunder
                              #1223
                              @abuzze
                              Das wirst du im Telegram Adapter selbst tun müssen. Hier wird das Menü erstellt.
                              W 1 Antwort Letzte Antwort
                              • W Willi-Wunder
                                @abuzze
                                W Offline
                                W Offline
                                Willi-Wunder
                                #1224
                                Hallo Michael,
                                was haben die drei roten Kreuze bei "Par" zu sagen? Kann diese bei Aufruf auch nicht an- oder abwählen.
                                • SegwayS Segway
                                  @michael-roling sagte in Test Adapter telegram-menu v.0.9.x:
                                  @segway ja das mit dem update ist richtig das jetzt erst eins auftaucht , welches im STABLE Repo ist. Mit dem anderen weiss ich , das liegt am js-controller, der hat einen bug. Dazu gibt es auch schon ein Issue, da kann ich leider so nichts machen. Es geht kurzzeitig der RAM- Verbrauch extrem hoch
                                  Mhhh, leider kann ich den Adapter nun gar nicht mehr aufrufen :-( Anscheinend wegen der abgebrochenen Installation ? Nix geht mehr. :-(
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  #1225
                                  @segway
                                  Habe einen Rasp 4 mit 4GB. Mit den ganzen Adapter die Laufen sind aktuell 50-60% verbraucht. Update klappt aber dennoch, braucht halt 2-4 Minuten.
                                  System
                                  Debian 12 "bookworm"
                                  Node.js 18.19.0
                                  NPM 10.2.3
                                  Vielleicht bringen dir die Infos etwas.
                                  • W Willi-Wunder
                                    Hallo Michael,
                                    Michael Roling
                                    #1226
                                    @willi-wunder das ist nicht so gewollt. Aber sollte keine Auswirkungen haben. Sagt nur das der parse Mode aus ist. Ich meine eigentlich sollten alle ein Kreuz haben. Aktiviere evtl. Mal den parsemode speichern und dann wieder entfernen. Ich meine das ich da schon etwas dran geändert habe. Dürfte dann bei neu erstellten Zeilen nicht mehr auftauchen. Bzw gleichmäßig logisch.
                                    • A abuzze
                                      Michael Roling
                                      #1227
                                      @abuzze im Gruppenchat kann es meiner Meinung nach nicht funktionieren , denn das Menu beruht auf der Kommunikation mit einem bot. Ich weiß aber nicht ob man einen bot der Gruppe hinzufügen kann.
                                        Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        schrieb am zuletzt editiert von Rene55
                                        #1228
                                        @michael-roling Nachtrag zu gestern 'Scrollbalken': @Willi-Wunder hat den Scrollbalken drin.
                                        Version ist 1.6.1
                                        EDIT: hier ist das Erstell-Fenster zu sehen. Ich meinte eine Ebene früher in der Übersicht.
                                        • stefu87_CHS Offline
                                          stefu87_CHS Offline
                                          stefu87_CH
                                          #1229
                                          Ich habe heute zum 1. Mal den Adapter heruntergeladen und versuche mich mal mit einarbeiten. Habe schon zum testen mal einen Statusabfrage eingebunden, aber bei mir kommt immer eine Fehlermeldung bei Telegram. Auch nach dem ausführen des Befehls, kommt bei mir die Tastatur unten und nicht mehr die Übersicht. Was mache ich alles falsch?
                                          Cores: 1 × 8 = 8 cores
                                          Threads: 16
                                          mit Proxmox
                                          LXC Container mit Iobroker
