  4. [gelöst] Scenes Adapter geht immer auf rot
17 Beiträge 4 Kommentatoren 448 Aufrufe 2 Beobachtet
    Beowolf
    Es mag ja unglaubwürdig klingen, aber bis zum 31.12.2023 hat es problemlos funktioniert.
    • B Beowolf
      host.ioBroker-Master
      	2024-01-03 11:18:45.714	warn	Do not restart adapter system.adapter.scenes.0 because restart loop detected
      	2024-01-03 11:18:45.713	info	Restart adapter system.adapter.scenes.0 because enabled
      	2024-01-03 11:18:45.713	error	instance system.adapter.scenes.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      	2024-01-03 11:18:45.713	error	Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
      	2024-01-03 11:18:45.713	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8524:38)
      	2024-01-03 11:18:45.713	error	Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
      	2024-01-03 11:18:45.712	error	Caught by controller[1]: Error: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target
      	2024-01-03 11:18:45.712	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      scenes.0
      	2024-01-03 11:18:45.251	info	terminating
      scenes.0
      	2024-01-03 11:18:44.748	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      scenes.0
      	2024-01-03 11:18:44.747	debug	Plugin sentry destroyed
      scenes.0
      	2024-01-03 11:18:44.746	info	terminating
      scenes.0
      	2024-01-03 11:18:44.714	error	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target
      scenes.0
      	2024-01-03 11:18:44.713	error	Error: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8524:38) at processImmediate (node:internal/timers:478:21)
      scenes.0
      	2024-01-03 11:18:44.388	error	unhandled promise rejection: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target
      scenes.0
      	2024-01-03 11:18:44.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      scenes.0
      	2024-01-03 11:18:44.386	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 5
      scenes.0
      	2024-01-03 11:18:44.383	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8
      scenes.0
      	2024-01-03 11:18:41.378	debug	activateScene: execute for "scene.0.Schmucklampen" (false)
      scenes.0
      	2024-01-03 11:18:27.610	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.610	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.609	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.608	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.608	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.607	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.602	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.602	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.601	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.601	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.600	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.600	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.599	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.598	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.598	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.597	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.597	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8
      scenes.0
      	2024-01-03 11:18:27.596	warn	Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8
      scenes.0
      	2024-01-03 11:18:27.544	debug	initScenes: subscribe on all
      scenes.0
      	2024-01-03 11:18:27.372	info	starting. Version 2.3.9 in /opt/iobroker/node_modules/iobroker.scenes, node: v18.19.0, js-controller: 5.0.17
      scenes.0
      	2024-01-03 11:18:26.609	debug	Plugin sentry Initialize Plugin (enabled=true)
      	2024-01-03 11:18:24.094	info	instance system.adapter.scenes.0 started with pid 15539
      @beowolf sagte in Scenes Adapter geht immer auf rot:
      der referenzierte DP im alias existiert noch?
        Beowolf
        Alle DP existieren und sind auch bei iqontrol eingetragen und auch schaltbar.
        Alle DP haben auch kein Leerzeichen.
        HomoranH FredFF 2 Antworten Letzte Antwort
        • B Beowolf
          Alle DP existieren
          dann zeig sie mal bitte!
          die Alias Definition und den darin referenzierten Datenpunkt
            Alle DP existieren
            Beowolf
            @homoran sagte in Scenes Adapter geht immer auf rot:
            Zeigt das nicht das Bild?
            • B Beowolf
              nein!
              sonst würde ich nicht fragen
                nein!
                Beowolf
                Meinst du dieses?
                • B Beowolf
                  Meinst du dieses?
                  Meinst du dieses?
                  auch!
                  aber vom angemeckerten Alias ...-links-oben
                  und dann den darin eingstellten Datenpunkt
                  der soll laut log nicht mehr existieren
                    Meinst du dieses?
                    auch!
                    Beowolf
                    das meinst du?
                    • B Beowolf
                      das meinst du?
                      das meinst du?
                      auch! aber das entscheidende feht.
                      existiert der dort eingegebene Ikea Datenpunkt.
                      Laut log fehlt der
                      • B Beowolf
                        FredFF Online
                        FredFF Online
                        FredF
                        Most Active Forum Testing
                        Hier haben die DPs alle einen Bindestrich in der Bezeichnung.
                        Lt. Log von scenes Adapter allerdings nicht 🤔
                        • FredFF FredF
                          Beowolf
                          Das mit dem Bindestrich war es.
                          Wie immer sitzt der Fehler VOR dem Bildschirm. Ich habe am 31.12.2023 aus Langweile die DP bearbeitet.
                          Deshalb ging es auch bis zu dem Datum.
                          Alle DP die ich geändert habe neu unter Scenes eingetragen.
                          Was soll ich sagen - kaum macht man es richtig - funktioniert es.
                          Danke für die Hilfe
                          • B Beowolf
                            Danke für die Hilfe
                            @beowolf sagte in [gelöst] Scenes Adapter geht immer auf rot:
                            Danke für die Hilfe
                            Ach was!??
                            genau so etwas stand ja auch im log
                              Beowolf
                              Ja, ja. Das mit dem Sehen - Lesen - Verstehen ist nicht immer einfach. 😊
