  4. Test ioBroker unter Windows installieren - 2023 Edition
    6.8k
installation iobrokerwindowswindows installation
405 Beiträge 25 Kommentatoren 120.8k Aufrufe 22 Beobachtet
  • K klassisch
    @homoran Vielen Dank!
    Aber eigentlich habe ich keine Probleme mit ioBroker an sich. Lediglich der Fixer, welcher durch den Installer/Updater automatisch ausgeführt wid, läuft auf ein Problem. Ist für mich eher ein Luxusproblem solange alles läuft .....
    Ansonsten:
    C:\ioBroker>iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    C:\ioBroker>npm -v
    10.2.3
    C:\ioBroker>node -v
    v18.19.0
    C:\ioBroker>
    npm ist da und die node-Version sieht auch gut aus. Kein +dfsg-6~deb12u1 sichtbar. Kam ja mit dem Installer mit. Und ich bin ja zurückhaltend und update nicht gleich auf jede neu aufblitzende Version :-)
    Info sagt das auch:
    System-Betriebszeit
    02:40:09
    Node.js
    v18.19.0
    time
    1704219201213
    timeOffset
    -60
    NPM
    10.2.3
    Die Adapter, die ich brauche laufen - Ausser RFLink. Das könnte aber andere Gründe haben.
    #185
    @klassisch sagte in Test ioBroker unter Windows installieren - 2023 Edition:
    :\ioBroker>iob diag
    gibbet nicht für Windows.
    dann ist gut!
    Ich war nur durch diese npm Meldungen verunsichert!
    ist RF Link überhaupt WIN fähig?
    PS natürlich noch ein gutes neues Jahr!
    • K klassisch
      Ansonsten:
      iobroker [command]
      Commands:
      Options:
      C:\ioBroker>npm -v
      10.2.3
      C:\ioBroker>node -v
      v18.19.0
      C:\ioBroker>
      Info sagt das auch:
      System-Betriebszeit
      02:40:09
      Node.js
      v18.19.0
      time
      1704219201213
      timeOffset
      -60
      NPM
      10.2.3
      GaspodeG Online
      GaspodeG Online
      Gaspode
      #186
      @klassisch
      iob diag
      Gibt es unter Windows leider nicht.
      Irgendwo wird unter bestimmten Umständen ein npm Aufruf zu einer alten Version verbogen, was zu dem Fehler führt. Die Kunst ist jetzt, raus zu bekommen, wo das krumm ist.
        @klassisch ähm, könnte das hier
        https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
        zutreffen?
        #187
        Das Thema 'dfsg-Version' ist exklusive für Debian 12 'Bookworm'. Und auch dort nur bei einem Teil der Installationen.
          :\ioBroker>iob diag
          dann ist gut!
          klassisch
          #188
          [OT]
          @homoran sagte in Test ioBroker unter Windows installieren - 2023 Edition:
          Danke, und selbstverständlich die besten Wünsche zurück!
          Das lief jahrelang bis zu einem Umzug von ioBroker mit nodejs update, python update etc..
          Da gab es wohl Problem mit einem seriellen Schnittstellen-Modul und der Adapter wurde nicht maschinell zusammengebaut. Ich habe mich dann durch die Fehlermeldungen gefressen und solange rumgemacht, bis es wieder lief. Das ist dort dokumentiert https://forum.iobroker.net/topic/60173/rflink-auf-win-rechner-cannot-find-adapter-rflink-2-1-6
          Ich habe einen ordentlichen Zoo von 433MHz Sensoren, eine schöne Groundplane Antenne dafür und komme durch das ganze Haus. RFLink ist für mich wichtig.
          Habe nach den vielen Updates, Stops, Starts etc. heute jetzt mal alles wieder frisch gebootet und der Schluckauf scheint weg zu sein.
          Habe auch noch eine Sonderkonfiguration über eine Virtuelle COM weil ich das RFLink umgebastelt habe. Der RFLink Arduino wird ja normalerweise über USB angeschlossen. Mag ich aber nicht und habe einen USRIOT serial <-> LAN Konverter dazwischen geschaltet. Da der RFLink Adapter - anders als z.B. Smartmeter oder Zigbee - kein Ethernet einbinden kann, brauche ich auch noch eine virtuelle COM.
          • GaspodeG Online
            GaspodeG Online
            Gaspode
            schrieb am zuletzt editiert von Gaspode
            #189
            @klassisch
            Wie gesagt, du scheinst noch irgendwo (aus alten Zeiten?) eine alte Version von npm auf deinem Rechner zu haben, evtl. auch in irgendeinem npm cache. Ich würde dem gerne auf den Grund gehen, evtl. kann man einen entsprechenden Check in den Installer einbauen, wenn man das Problem versteht.
            Kannst du bei Gelegenheit bitte mal im ioBroker Cmd Window die folgenden Befehle absetzen und den Output posten:
            npm -v
            node -v
            where npm
            Und könntest du dann noch das kleine Script aus dem Anhang in dein ioBroker root Verzeichnis legen (also wahrscheinlich bei dir c:\ioBroker) und es dann ausführen mit
            node test.js
            Was wird da ausgegeben?
            Schon mal vielen Dank.
            test.js
            K 2 Antworten Letzte Antwort
            • GaspodeG Gaspode
              @klassisch
              npm -v
              node -v
              where npm
              node test.js
              test.js
              klassisch
              schrieb am zuletzt editiert von klassisch
              #190
              @gaspode
              Vielen Dank! sieht bei mir so aus:
              C:\ioBroker>npm -v
              10.2.3
              C:\ioBroker>
              C:\ioBroker>node -v
              v18.19.0
              C:\ioBroker>
              C:\ioBroker>where npm
              C:\Program Files\nodejs\npm
              C:\Program Files\nodejs\npm.cmd
              C:\ioBroker>node testnpm.js
              10.2.3
              C:\ioBroker>
              Was ich nicht verstehe ist das:
              EDIT: Ich finde npm files noch unter Visual Studio.
              Ich kann man die Platte scannen. Nach welchen Dateien soll ich suchen?
              GaspodeG 1 Antwort Letzte Antwort
              • GaspodeG Gaspode
                @klassisch
                npm -v
                node -v
                where npm
                node test.js
                test.js
                klassisch
                #191
                @gaspode
                Habe jetzt mal nach node.cmd gesucht:
                c:\ioBroker\node_modules\.bin\npm.cmd
                c:\Program Files\nodejs\node_modules\corepack\shims\nodewin\npm.cmd
                c:\Program Files\nodejs\node_modules\corepack\shims\npm.cmd
                c:\Program Files\nodejs\node_modules\npm\bin\npm.cmd
                c:\Program Files\nodejs\npm.cmd
                c:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\NodeJs\npm.cmd
                c:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\NodeJs\node_modules\npm\bin\npm.cmd
                c:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\NodeJs\node_modules\.bin\npm.cmd
                c:\ioBroker\node_modules\npm\bin\npm.cmd
                c:\Users\JS\AppData\Local\npm-cache\_npx\df100e174afb6ecd\node_modules\npx\node_modules\.bin\npm.cmd
                c:\Users\JS\AppData\Local\npm-cache\_npx\df100e174afb6ecd\node_modules\npx\node_modules\npm\bin\npm.cmd
                • K klassisch
                  @gaspode
                  C:\ioBroker>npm -v
                  10.2.3
                  C:\ioBroker>
                  C:\ioBroker>node -v
                  v18.19.0
                  C:\ioBroker>
                  10.2.3
                  C:\ioBroker>
                  GaspodeG Online
                  GaspodeG Online
                  Gaspode
                  #192
                  @klassisch said in Test ioBroker unter Windows installieren - 2023 Edition:
                  Das sieht unter Windows immer so aus, ist also OK.
                  Das muss wieder mal irgend was mit dem npx Aufruf zu tun haben. Irgendwo wird da was verbogen. Der legt da an den unmöglichsten Stellen gecachte Daten ab. Du kannst mal versuchen, den Cache aufzuräumen:
                  npm cache verify
                  Oder die Hardcore Variante
                  npm cache clean --force
                  Ich befürchte nur, das wird auch nix nützen. Ich muss heute Abend mal Google anwerfen. ;)
                  • GaspodeG Gaspode
                    npm cache verify
                    klassisch
                    #193
                    @gaspode sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                    npm cache verify
                    Vielen Dank, sieht so aus:
                    C:\ioBroker>npm cache verify
                    Cache verified and compressed (~\AppData\Local\npm-cache\_cacache)
                    Content verified: 1625 (120608749 bytes)
                    Content garbage-collected: 251 (33744871 bytes)
                    Index entries: 1625
                    Finished in 15.391s
                    • K klassisch
                      npm cache verify
                      Index entries: 1625
                      Finished in 15.391s
                      GaspodeG Online
                      GaspodeG Online
                      Gaspode
                      #194
                      Das Problem ist, man sieht dem Ergebnis nicht wirklich an, welche Auswirkungen das hat.
                      Du kannst ja nochmal ein Fix probieren.
                      • GaspodeG Gaspode
                        klassisch
                        #195
                        @gaspode
                        C:\ioBroker>iob fix
                        Windows installation starting... (fixing = true)
                        NPM version: 10.2.3
                        Usage: npm <command>
                        where <command> is one of:
                            access, adduser, audit, bin, bugs, c, cache, ci, cit,
                            clean-install, clean-install-test, completion, config,
                            create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
                            edit, explore, fund, get, help, help-search, hook, i, init,
                            install, install-ci-test, install-test, it, link, list, ln,
                            login, logout, ls, org, outdated, owner, pack, ping, prefix,
                            profile, prune, publish, rb, rebuild, repo, restart, root,
                            run, run-script, s, se, search, set, shrinkwrap, star,
                            stars, start, stop, t, team, test, token, tst, un,
                            uninstall, unpublish, unstar, up, update, v, version, view,
                            whoami
                        npm <command> -h  quick help on <command>
                        npm -l            display full usage info
                        npm help <term>   search for help on <term>
                        npm help npm      involved overview
                        Specify configs in the ini-formatted file:
                            C:\Users\JS\.npmrc
                        or on the command line via: npm <command> --key value
                        Config info can be viewed via: npm help config
                        npm@6.14.17 C:\ioBroker\node_modules\npm
                        node:child_process:965
                            throw err;
                        Error: Command failed: npm x --yes @iobroker/jsonltool@latest
                            at checkExecSyncError (node:child_process:890:11)
                            at execSync (node:child_process:962:15)
                            at Object.<anonymous> (C:\Users\JS\AppData\Local\npm-cache\_npx\19d197aa1f8fa98c\node_modules\@iobroker\fix\lib-npx\install.js:71:17)
                            at Module._compile (node:internal/modules/cjs/loader:1356:14)
                            at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                            at Module.load (node:internal/modules/cjs/loader:1197:32)
                            at Module._load (node:internal/modules/cjs/loader:1013:12)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                            at node:internal/main/run_main_module:28:49 {
                          status: 1,
                          signal: null,
                          output: [ null, null, null ],
                          pid: 11992,
                          stdout: null,
                          stderr: null
                        Node.js v18.19.0
                        Auch nach dem Bereinigen des Chaches:
                        C:\ioBroker>npm cache clean --force
                        npm WARN using --force Recommended protections disabled.
                        C:\ioBroker>iob fix
                        NPM version: 10.2.3
                            whoami
                            C:\Users\JS\.npmrc
                            throw err;
                          status: 1,
                          signal: null,
                          pid: 1972,
                          stdout: null,
                          stderr: null
                        Node.js v18.19.0
                        C:\ioBroker>
                        • K klassisch
                          @gaspode
                          C:\ioBroker>iob fix
                          NPM version: 10.2.3
                              whoami
                              C:\Users\JS\.npmrc
                              throw err;
                            status: 1,
                            signal: null,
                            pid: 11992,
                            stdout: null,
                            stderr: null
                          Node.js v18.19.0
                          C:\ioBroker>iob fix
                          NPM version: 10.2.3
                              whoami
                              C:\Users\JS\.npmrc
                              throw err;
                            status: 1,
                            signal: null,
                            pid: 1972,
                            stdout: null,
                            stderr: null
                          Node.js v18.19.0
                          C:\ioBroker>
                          GaspodeG Online
                          GaspodeG Online
                          Gaspode
                          #196
                          @klassisch
                          Hatte ich befürchtet. Wie gesagt, ich muss heute Abend mal Tante Googel bemühen, wenn vorher niemand anders einen Tipp hat.
                          • GaspodeG Gaspode
                            @klassisch
                            klassisch
                            #197
                            @gaspode
                            Habe mal alle npm.cmd gesucht und auf Version getestet.
                            Versprengte 8er und 5er gefunden. Leider nicht die 6er, die manchmal aufblitzt
                            C:\ioBroker>"\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\NodeJs\npm" -v
                            8.3.1
                            C:\ioBroker>"\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VisualStudio\NodeJs\node_modules\.bin\npm" -v
                            8.3.1
                            C:\ioBroker>"\Users\JS\AppData\Local\npm-cache\_npx\df100e174afb6ecd\node_modules\npx\node_modules\.bin\npm" -v
                            5.1.0
                            • K klassisch
                              @gaspode
                              8.3.1
                              8.3.1
                              5.1.0
                              GaspodeG Online
                              GaspodeG Online
                              Gaspode
                              #198
                              @klassisch
                              Hmm, npx scheint ja noch einige Leichen im Keller zu haben.
                              Ich bin jetzt auf folgendes Package gestoßen: https://www.npmjs.com/package/clear-npx-cache
                              Usage:
                              npx clear-npx-cache
                              Wobei das Package, so wie ich es sehe, nix anderes macht, als alle Einträge im npx Cache Verzeichnis zu löschen. Das Cache Verzeichnis wird mit ...
                              npm config get cache
                              ... ermittelt und darin wird der Inhalt des Verzeichnisses _npx gelöscht.
                              Die etwas vorsichtigere Variante wäre also, einfach das Verzeichnis _npx dort umzubenennen und zu gucken, ob sich das Verhalten bessert.
                              • GaspodeG Gaspode
                                @klassisch
                                Usage:
                                npx clear-npx-cache
                                klassisch
                                #199
                                @gaspode Vielen Dank und Sorry, hatte gestern Abend leider keine Zeit für ioBroker
                                C:\ioBroker>npm config get cache
                                Habe jetzt mal
                                in
                                c:\Users\JS\AppData\Local\npm-cache\Renamed_npx\
                                umbenannt.
                                Ergebnis
                                C:\ioBroker>iob fix
                                Need to install the following packages:
                                @iobroker/fix@5.0.0
                                Ok to proceed? (y) y
                                NPM version: 10.2.3
                                    whoami
                                    C:\Users\JS\.npmrc
                                    throw err;
                                  status: 1,
                                  signal: null,
                                  pid: 1132,
                                  stdout: null,
                                  stderr: null
                                Node.js v18.19.0
                                C:\ioBroker>
                                Nach Neustart des Rechners wurde das Verzeichnis
                                neu angelegt
                                Fix bricht leider immer noch ab
                                C:\ioBroker>iob fix
                                NPM version: 10.2.3
                                    whoami
                                    C:\Users\JS\.npmrc
                                    throw err;
                                  status: 1,
                                  signal: null,
                                  pid: 12764,
                                  stdout: null,
                                  stderr: null
                                Node.js v18.19.0
                                C:\ioBroker>
                                • K klassisch
                                  Habe jetzt mal
                                  in
                                  umbenannt.
                                  Ergebnis
                                  C:\ioBroker>iob fix
                                  @iobroker/fix@5.0.0
                                  NPM version: 10.2.3
                                      whoami
                                      C:\Users\JS\.npmrc
                                      throw err;
                                    status: 1,
                                    signal: null,
                                    pid: 1132,
                                    stdout: null,
                                    stderr: null
                                  Node.js v18.19.0
                                  C:\ioBroker>
                                  neu angelegt
                                  C:\ioBroker>iob fix
                                  NPM version: 10.2.3
                                      whoami
                                      C:\Users\JS\.npmrc
                                      throw err;
                                    status: 1,
                                    signal: null,
                                    pid: 12764,
                                    stdout: null,
                                    stderr: null
                                  Node.js v18.19.0
                                  C:\ioBroker>
                                  GaspodeG Online
                                  GaspodeG Online
                                  Gaspode
                                  #200
                                  Kein Problem. Ich danke dir, dass du so geduldig mit hilfst. Wie gesagt, ich würde das Problem gerne verstehen, um es in Zukunft entweder im Installer zu berücksichtigen oder es zumindest in die Doku aufzunehmen.
                                  So langsam gehen mir die Ideen aus. ;)
                                  Die Meldung "Usage: npm < command>" etc. kommt daher, dass bei dir aus mir bisher unerklärlichen Gründen npm in der Version 6.14.17 verwendet wird. Das Kommando "npm x ...", das im Fixer zum Einsatz kommt, kennt npm in der Version 6.14.17 noch nicht. Und jetzt wird es interessant bzw. seltsam: In Zeile 31 deines letzten Logs wird ausgegeben, wo die verwendete npm Version liegt:
                                  Demnach ist das ein lokales Package(!?) in deinem ioBroker Verzeichnis. Allerdings hat ...
                                  npm ls
                                  ... das nicht bei dir als installiertes Package angezeigt (so wie es auch sein soll). Guck bitte zunächst mal, ob das Verzeichnis da ist und was drin ist. Im nächsten Schritt könntest du - wenn es da ist - mal versuchen, es umzubenennen oder evtl. besser mit ...
                                  npm uninstall npm
                                  los zu werden. Das dürfte nix kaputt machen, aber eine Garantie gibt es bei so was halt nie.
                                  • GaspodeG Gaspode
                                    npm ls
                                    npm uninstall npm
                                    klassisch
                                    #201
                                    war mir auch schon aufgefallen. Aber
                                    C:\ioBroker>cd C:\ioBroker\node_modules\npm
                                    C:\ioBroker\node_modules\npm>npm -v
                                    10.2.3
                                    Das Verzeichnis existiert:
                                    C:\ioBroker\node_modules\npm>dir
                                     Volume in Laufwerk C: hat keine Bezeichnung.
                                     Volumeseriennummer: B41E-9983
                                     Verzeichnis von C:\ioBroker\node_modules\npm
                                    19.11.2022  20:01    <DIR>          .
                                    19.11.2022  20:01    <DIR>          ..
                                    19.11.2022  20:01                30 .eslintrc
                                    19.11.2022  20:01               245 .licensee.json
                                    19.11.2022  20:01             3.274 .mailmap
                                    19.11.2022  20:01               368 .npmignore
                                    19.11.2022  20:01               269 .travis.yml
                                    19.11.2022  20:01            27.151 AUTHORS
                                    19.11.2022  20:01    <DIR>          bin
                                    19.11.2022  20:01           161.620 CHANGELOG.md
                                    19.11.2022  20:01    <DIR>          changelogs
                                    19.11.2022  20:01               529 configure
                                    19.11.2022  20:01             9.515 CONTRIBUTING.md
                                    19.11.2022  20:01    <DIR>          docs
                                    19.11.2022  20:01    <DIR>          lib
                                    19.11.2022  20:01             9.742 LICENSE
                                    19.11.2022  20:01               156 make.bat
                                    19.11.2022  20:01             4.120 Makefile
                                    19.11.2022  20:01    <DIR>          man
                                    19.11.2022  20:01    <DIR>          node_modules
                                    19.11.2022  20:01             8.082 package.json
                                    19.11.2022  20:01             4.491 README.md
                                    19.11.2022  20:01    <DIR>          scripts
                                                  14 Datei(en),        229.592 Bytes
                                                   9 Verzeichnis(se), 149.716.340.736 Bytes frei
                                    Kann ich vor dem enfernen feststellen / anfragen, welche Version er entfernt.
                                    Bisher hat er auf eine Anfrage npm - v immer mit einer 10er geantwortet. Nur dem Fixer antwortet er mit 6er. Kann ich diesen Schritt auf der Konsole irgendwie nachvollziehen?
                                    Edit: npm ls aus diesem Verzeichnis zeigt die 6er und etliche Fehler:
                                    C:\ioBroker\node_modules\npm\node_modules>npm ls
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! missing: bl@^3.0.1, required by npm@6.14.17
                                    npm ERR! missing: deep-equal@^1.0.1, required by npm@6.14.17
                                    npm ERR! missing: licensee@^7.0.3, required by npm@6.14.17
                                    npm ERR! missing: marked-man@^0.7.0, required by npm@6.14.17
                                    npm ERR! missing: marked@^0.7.0, required by npm@6.14.17
                                    npm ERR! missing: npm-registry-mock@^1.3.1, required by npm@6.14.17
                                    npm ERR! missing: require-inject@^1.4.4, required by npm@6.14.17
                                    npm ERR! missing: sprintf-js@^1.1.2, required by npm@6.14.17
                                    npm ERR! missing: standard@^11.0.1, required by npm@6.14.17
                                    npm ERR! missing: tacks@^1.3.0, required by npm@6.14.17
                                    npm ERR! missing: tap@^12.7.0, required by npm@6.14.17
                                    npm ERR! missing: tar-stream@^2.1.0, required by npm@6.14.17
                                    +-- abbrev@1.1.1
                                    +-- ansicolors@0.3.2
                                    +-- ansistyles@0.1.3
                                    +-- aproba@2.0.0
                                    +-- archy@1.0.0
                                    +-- bin-links@1.1.8
                                    +-- UNMET DEPENDENCY bl@^3.0.1
                                    +-- bluebird@3.5.5
                                    +-- byte-size@5.0.1
                                    +-- cacache@12.0.3
                                    +-- call-limit@1.1.1
                                    +-- chownr@1.1.4
                                    +-- ci-info@2.0.0
                                    +-- cli-columns@3.1.2
                                    +-- cli-table3@0.5.1
                                    +-- cmd-shim@3.0.3
                                    +-- columnify@1.5.4
                                    +-- config-chain@1.1.12
                                    +-- UNMET DEPENDENCY deep-equal@^1.0.1
                                    +-- detect-indent@5.0.0
                                    +-- detect-newline@2.1.0
                                    +-- dezalgo@1.0.3
                                    +-- editor@1.0.0
                                    +-- figgy-pudding@3.5.1
                                    +-- find-npm-prefix@1.0.2
                                    +-- fs-vacuum@1.2.10
                                    +-- fs-write-stream-atomic@1.0.10
                                    +-- gentle-fs@2.3.1
                                    +-- get-stream@4.1.0
                                    +-- glob@7.1.6
                                    +-- graceful-fs@4.2.4
                                    +-- has-unicode@2.0.1
                                    +-- hosted-git-info@2.8.9
                                    +-- iferr@1.0.2
                                    +-- infer-owner@1.0.4
                                    +-- inflight@1.0.6
                                    +-- inherits@2.0.4
                                    +-- ini@1.3.8
                                    +-- init-package-json@1.10.3
                                    +-- is-cidr@3.0.0
                                    +-- json-parse-better-errors@1.0.2
                                    +-- JSONStream@1.3.5
                                    +-- lazy-property@1.0.0
                                    +-- libcipm@4.0.8
                                    +-- libnpm@3.0.1
                                    +-- libnpmaccess@3.0.2
                                    +-- libnpmhook@5.0.3
                                    +-- libnpmorg@1.0.1
                                    +-- libnpmsearch@2.0.2
                                    +-- libnpmteam@1.0.2
                                    +-- libnpx@10.2.4
                                    +-- UNMET DEPENDENCY licensee@^7.0.3
                                    +-- lock-verify@2.1.0
                                    +-- lockfile@1.0.4
                                    +-- lodash._baseuniq@4.6.0
                                    +-- lodash.clonedeep@4.5.0
                                    +-- lodash.union@4.6.0
                                    +-- lodash.uniq@4.5.0
                                    +-- lodash.without@4.4.0
                                    +-- lru-cache@5.1.1
                                    +-- UNMET DEPENDENCY marked-man@^0.7.0
                                    +-- UNMET DEPENDENCY marked@^0.7.0
                                    +-- meant@1.0.2
                                    +-- mississippi@3.0.0
                                    +-- mkdirp@0.5.5
                                    +-- move-concurrently@1.0.1
                                    +-- node-gyp@5.1.0
                                    +-- nopt@4.0.3
                                    +-- normalize-package-data@2.5.0
                                    +-- npm-audit-report@1.3.3
                                    +-- npm-cache-filename@1.0.2
                                    +-- npm-install-checks@3.0.2
                                    +-- npm-lifecycle@3.1.5
                                    +-- npm-package-arg@6.1.1
                                    +-- npm-packlist@1.4.8
                                    +-- npm-pick-manifest@3.0.2
                                    +-- npm-profile@4.0.4
                                    +-- npm-registry-fetch@4.0.7
                                    +-- UNMET DEPENDENCY npm-registry-mock@^1.3.1
                                    +-- npm-user-validate@1.0.1
                                    +-- npmlog@4.1.2
                                    +-- once@1.4.0
                                    +-- opener@1.5.2
                                    +-- osenv@0.1.5
                                    +-- pacote@9.5.12
                                    +-- path-is-inside@1.0.2
                                    +-- promise-inflight@1.0.1
                                    +-- qrcode-terminal@0.12.0
                                    +-- query-string@6.8.2
                                    +-- qw@1.0.1
                                    +-- read-cmd-shim@1.0.5
                                    +-- read-installed@4.0.3
                                    +-- read-package-json@2.1.1
                                    +-- read-package-tree@5.3.1
                                    +-- read@1.0.7
                                    +-- readable-stream@3.6.0
                                    +-- readdir-scoped-modules@1.1.0
                                    +-- request@2.88.0
                                    +-- UNMET DEPENDENCY require-inject@^1.4.4
                                    +-- retry@0.12.0
                                    +-- rimraf@2.7.1
                                    +-- safe-buffer@5.1.2
                                    +-- semver@5.7.1
                                    +-- sha@3.0.0
                                    +-- slide@1.1.6
                                    +-- sorted-object@2.0.1
                                    +-- sorted-union-stream@2.1.3
                                    +-- UNMET DEPENDENCY sprintf-js@^1.1.2
                                    +-- ssri@6.0.2
                                    +-- UNMET DEPENDENCY standard@^11.0.1
                                    +-- stringify-package@1.0.1
                                    +-- UNMET DEPENDENCY tacks@^1.3.0
                                    +-- UNMET DEPENDENCY tap@^12.7.0
                                    +-- UNMET DEPENDENCY tar-stream@^2.1.0
                                    +-- tar@4.4.19
                                    +-- text-table@0.2.0
                                    +-- tiny-relative-date@1.3.0
                                    +-- uid-number@0.0.6
                                    +-- umask@1.1.0
                                    +-- unique-filename@1.1.1
                                    +-- unpipe@1.0.0
                                    +-- update-notifier@2.5.0
                                    +-- uuid@3.3.3
                                    +-- validate-npm-package-license@3.0.4
                                    +-- validate-npm-package-name@3.0.0
                                    +-- which@1.3.1
                                    +-- worker-farm@1.7.0
                                    `-- write-file-atomic@2.4.3
                                    npm ERR! A complete log of this run can be found in: C:\Users\JS\AppData\Local\npm-cache\_logs\2024-01-04T07_25_50_881Z-debug-0.log
                                    Edit 2: der npm ls aus dem ioBroker Verzeichnis sieht hingegen anders aus:
                                    C:\ioBroker>npm ls
                                    iobroker.inst@4.1.11 C:\ioBroker
                                    +-- fs-extra@10.1.0
                                    +-- iobroker.admin@6.12.0
                                    +-- iobroker.alias-manager@1.2.6
                                    +-- iobroker.backitup@2.9.8
                                    +-- iobroker.bydbatt@1.1.0
                                    +-- iobroker.bydhvs@1.5.0
                                    +-- iobroker.coronavirus-statistics@0.9.0
                                    +-- iobroker.daswetter@3.0.4
                                    +-- iobroker.discovery@3.0.3
                                    +-- iobroker.dwd@2.8.5
                                    +-- iobroker.echarts@1.0.12
                                    +-- iobroker.email@1.2.1
                                    +-- iobroker.energiefluss@3.3.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#d56d6644148f54ad23e17c1b1af19e5f83306c72)
                                    +-- iobroker.envertech-pv@0.0.8 (git+ssh://git@github.com/adcrafter27/ioBroker.envertech-pv.git#46284699d12834e862402428e0153f1150a2b307)
                                    +-- iobroker.flot@1.12.0
                                    +-- iobroker.fritzdect@2.2.6
                                    +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
                                    +-- iobroker.fronius-wattpilot@4.6.2
                                    +-- iobroker.fronius@2.0.2
                                    +-- iobroker.fullybrowser@2.0.1
                                    +-- iobroker.habpanel@0.4.3
                                    +-- iobroker.heatingcontrol@2.11.1
                                    +-- iobroker.heizoel@1.0.3
                                    +-- iobroker.history@2.2.4
                                    +-- iobroker.hm-rega@4.0.0
                                    +-- iobroker.hm-rpc@1.15.19
                                    +-- iobroker.ical@1.7.0
                                    +-- iobroker.icons-mfd-png@1.2.1
                                    +-- iobroker.icons-mfd-svg@1.0.2
                                    +-- iobroker.influxdb@3.2.0
                                    +-- iobroker.info@2.0.0
                                    +-- iobroker.iqontrol@2.3.0
                                    +-- iobroker.javascript@5.2.13
                                    +-- iobroker.js-controller@5.0.17
                                    +-- iobroker.lowpass-filter@2.2.3
                                    +-- iobroker.material@1.3.1
                                    +-- iobroker.mercedesme@0.1.6 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#b58e9673d5c28e358830fd45d231dd97ab425219)
                                    +-- iobroker.mihome-vacuum@2.1.1
                                    +-- iobroker.mobile@1.0.1
                                    +-- iobroker.modbus@6.0.1
                                    +-- iobroker.mqtt@5.1.0
                                    +-- iobroker.node-red@4.0.3
                                    +-- iobroker.nut@1.6.0
                                    +-- iobroker.odl@3.0.1
                                    +-- iobroker.opendtu@1.0.1
                                    +-- iobroker.parser@2.0.7
                                    +-- iobroker.paw@0.3.2
                                    +-- iobroker.pid@0.0.8 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.pid.git#bf251adf86f5816a530d73b83939bad2272f4d2b)
                                    +-- iobroker.ping@1.6.2
                                    +-- iobroker.pvforecast@2.9.0
                                    +-- iobroker.rflink@2.1.6 (git+ssh://git@github.com/ioBroker/ioBroker.rflink.git#361e6e65f4bf3aede6e53a754571b24cb73b5ebe)
                                    +-- iobroker.rickshaw@1.0.0
                                    +-- iobroker.robonect@0.1.3
                                    +-- iobroker.shelly@4.0.7
                                    +-- iobroker.shuttercontrol@1.2.0
                                    +-- iobroker.simple-api@2.7.2
                                    +-- iobroker.smartcontrol@1.2.1
                                    +-- iobroker.smartmeter@3.4.0
                                    +-- iobroker.socketio@6.6.0
                                    +-- iobroker.sonoff@2.4.0
                                    +-- iobroker.sourceanalytix@0.4.8-alpha.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#488f8c151b7049a1e6579b27cb02686ea0cc5f72)
                                    +-- iobroker.sql@2.2.0
                                    +-- iobroker.statistics@2.4.0
                                    +-- iobroker.stromgedacht@0.1.0 (git+ssh://git@github.com/ANierbeck/ioBroker.stromgedacht.git#8ed32a0da352be5991778945053545edea235ed0)
                                    +-- iobroker.telegram@3.0.0
                                    +-- iobroker.tr-064@4.2.12
                                    +-- iobroker.tradfri@2.6.5
                                    +-- iobroker.vis-hqwidgets@1.1.4
                                    +-- iobroker.vis-jqui-mfd@1.0.12
                                    +-- iobroker.vis-timeandweather@1.1.7
                                    +-- iobroker.vis@1.5.4
                                    +-- iobroker.weatherunderground@3.2.1
                                    +-- iobroker.web@6.1.10
                                    +-- iobroker.whatsapp-cmb@0.2.2
                                    +-- iobroker.wifilight@1.1.0
                                    +-- iobroker.zigbee@1.9.5
                                    +-- iobroker.zwave2@1.8.11
                                    +-- node-windows@1.0.0-beta.6
                                    +-- semver@7.5.4
                                    `-- yargs@17.6.2
                                    C:\ioBroker>
                                    • K klassisch
                                      10.2.3
                                      +-- abbrev@1.1.1
                                      +-- aproba@2.0.0
                                      +-- archy@1.0.0
                                      +-- bin-links@1.1.8
                                      +-- bluebird@3.5.5
                                      +-- byte-size@5.0.1
                                      +-- cacache@12.0.3
                                      +-- chownr@1.1.4
                                      +-- ci-info@2.0.0
                                      +-- cmd-shim@3.0.3
                                      +-- columnify@1.5.4
                                      +-- dezalgo@1.0.3
                                      +-- editor@1.0.0
                                      +-- gentle-fs@2.3.1
                                      +-- glob@7.1.6
                                      +-- iferr@1.0.2
                                      +-- inflight@1.0.6
                                      +-- inherits@2.0.4
                                      +-- ini@1.3.8
                                      +-- is-cidr@3.0.0
                                      +-- libcipm@4.0.8
                                      +-- libnpm@3.0.1
                                      +-- libnpmorg@1.0.1
                                      +-- libnpx@10.2.4
                                      +-- lockfile@1.0.4
                                      +-- lru-cache@5.1.1
                                      +-- meant@1.0.2
                                      +-- mkdirp@0.5.5
                                      +-- node-gyp@5.1.0
                                      +-- nopt@4.0.3
                                      +-- npmlog@4.1.2
                                      +-- once@1.4.0
                                      +-- opener@1.5.2
                                      +-- osenv@0.1.5
                                      +-- pacote@9.5.12
                                      +-- qw@1.0.1
                                      +-- read@1.0.7
                                      +-- request@2.88.0
                                      +-- retry@0.12.0
                                      +-- rimraf@2.7.1
                                      +-- semver@5.7.1
                                      +-- sha@3.0.0
                                      +-- slide@1.1.6
                                      +-- ssri@6.0.2
                                      +-- tar@4.4.19
                                      +-- umask@1.1.0
                                      +-- unpipe@1.0.0
                                      +-- uuid@3.3.3
                                      +-- which@1.3.1
                                      C:\ioBroker>npm ls
                                      +-- fs-extra@10.1.0
                                      +-- semver@7.5.4
                                      `-- yargs@17.6.2
                                      C:\ioBroker>
                                      GaspodeG Online
                                      GaspodeG Online
                                      Gaspode
                                      #202
                                      Auf jeden Fall hat npm als lokales Package da normalerweise nix verloren. Mir ist auch kein Fall bekannt, wo das Sinn ergeben würde.
                                      Im übergeordneten package.json (also c:\ioBroker\package.json) ist es ja anscheinend auch nicht drin, sonst hätte "npm ls" im ioBroker root Verzeichnis es ja aufgelistet. Wenn dir "npm uninstall npm" zu gefährlich erscheint, kannst du es ja auch zuerst mal einfach umbenennen.
                                      • GaspodeG Gaspode
                                        klassisch
                                        #203
                                        @gaspode
                                        Hatte inzwischen zum obigen Posts noch einige Edits mit npm ls aus verschiedenen Verzeichnissen gepostet. Vielleicht hilft das.
                                        Was soll ich umbenennen? Das Verzeichnis
                                        • K klassisch
                                          @gaspode
                                          GaspodeG Online
                                          GaspodeG Online
                                          Gaspode
                                          #204
                                          Ja, npm in npm_xxx oder so.
