  4. JavaScript
  5. [Vorlage] Generisches Fensteroffenskript + Vis
javascripttemplatemonitoring
768 Beiträge 81 Kommentatoren 340.4k Aufrufe 97 Beobachtet
  • A
    A
    Alero
    #719
    HI, bekomme immer wieder fehler unter Iobroker Protokoll von der Fenterueberwachung. Im Log vom Script ist alles soweit ok.
    	2023-10-04 08:42:54.882	error	at processTimers (node:internal/timers:512:7)
    javascript.0
    2023-10-04 08:42:54.882	error	at listOnTimeout (node:internal/timers:569:17)
    javascript.0
    2023-10-04 08:42:54.882	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2743:34)
    javascript.0
    2023-10-04 08:42:54.882	error	at Object.<anonymous> (script.js.common.FensterUeberwachung:1070:81)
    javascript.0
    2023-10-04 08:42:54.882	error	at Meldung (script.js.common.FensterUeberwachung:387:25)
    javascript.0
    2023-10-04 08:42:54.882	error	Error in callback: ReferenceError: Say is not defined
    javascript.0
    2023-10-04 08:42:48.964	error	at processTimers (node:internal/timers:512:7)
    javascript.0
    2023-10-04 08:42:48.964	error	at listOnTimeout (node:internal/timers:569:17)
    javascript.0
    2023-10-04 08:42:48.964	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2743:34)
    javascript.0
    2023-10-04 08:42:48.964	error	at Object.<anonymous> (script.js.common.FensterUeberwachung:1032:83)
    javascript.0
    2023-10-04 08:42:48.964	error	at Meldung (script.js.common.FensterUeberwachung:387:25)
    javascript.0
    2023-10-04 08:42:48.964	error	Error in callback: ReferenceError: Say is not defined
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    2023-10-04 08:42:48.962	error	at processTimers (node:internal/timers:512:7)
    javascript.0
    2023-10-04 08:42:48.962	error	at listOnTimeout (node:internal/timers:569:17)
    javascript.0
    2023-10-04 08:42:48.962	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2743:34)
    javascript.0
    2023-10-04 08:42:48.962	error	at Object.<anonymous> (script.js.common.FensterUeberwachung:1032:83)
    javascript.0
    2023-10-04 08:42:48.962	error	at Meldung (script.js.common.FensterUeberwachung:387:25)
    javascript.0
    2023-10-04 08:42:48.962	error	Error in callback: ReferenceError: Say is not defined
    • A Alero
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      sigi234S
      sigi234S
      #720
      @alero sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
      Say is not defined
      Im Skript auf false setzen
      const UseSay = true; // Sollen Nachrichten via Say ausgegeben werden? Autorenfunktion, muß deaktiviert werden.
      • sigi234S sigi234
        Say is not defined
        A
        A
        Alero
        #721
        @sigi234
        hi, danke. warum das auf true stand- keine Ahnung.
        Ich möchte telegram nutzen habe auch Telegram auf true gesetzt. bekomme aber auf Telegram 0 keine Meldungen.
        //Telegram
        const UseTelegram = true; // Sollen Nachrichten via Telegram gesendet werden?
        • A Alero
          @sigi234
          //Telegram
          D
          D
          dike1982
          schrieb am zuletzt editiert von dike1982
          #722
          Hallo Zusammen,
          habe eben das Skript installiert. Tabelle wird in der VIS angezeigt, wenn ich ein Fenster öffne wird es auch als geöffnet angezeigt.
          Nur wenn ich es schließe kommt die Änderung in der VIS nicht an, Fenster bleibt geöffnet.
          Das Log weißt auch einen gehler auf!
          21:34:27.465	error	javascript.0 (110050) at Meldung (script.js.common.Visu.Status_Fenster.Fenster:387:25)
          21:34:27.466	error	javascript.0 (110050) at CheckWindow (script.js.common.Visu.Status_Fenster.Fenster:1014:64)
          21:34:27.466	error	javascript.0 (110050) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:1388:25)
          21:35:41.881	info	javascript.0 (110050) script.js.common.Visu.Status_Fenster.Fenster: Trigger= 1 Wert= 0 Alter Wert= 1 dp.channelId=hm-rpc.1.0000D8A991D684.1 dp.channelName=OGEZ_Türkomtakt_Terrasse:1
          Kann mir hier jemand helfen?
          P 1 Antwort Letzte Antwort
          • D dike1982
            Hallo Zusammen,
            P
            P
            papaechokilo
            #723
            @dike1982 Zeile 42 auf false stellen.
            const UseSay = false; // Sollen Nachrichten via Say ausgegeben werden? Autorenfunktion, muß deaktiviert werden.
            • P papaechokilo
              D
              D
              dike1982
              #724
              @papaechokilo
              Perfekt vielen Dank das wars!
              Zeile 43 habe ich auch noch auf fasle gesetzt!
              • D dike1982
                @papaechokilo
                P
                P
                papaechokilo
                #725
                @dike1982 kleiner Tipp: die Lüftungsdauer ist fix eingetragen. Ich habe ein Zusatzprogramm geschrieben, dass je Außentemperatur eine Lüftungsdauer bestimmt um in einen Datenpunkt schreibt. Ich lüfte bei -5 Grad anders als bei 20 Grad.
                • P papaechokilo
                  A
                  A
                  AndreasW63
                  #726
                  Mahlzeit,
                  hat jemand die Zeitangaben hinter der Zeile "Fenster / Tür geöffnet bzw. geschlossen" ausgeblendet.
                  Uns reicht der Hinweis "Fenster / Tür geöffnet bzw. geschlossen" da unser Haus mit einer zentralen Lüftungsanlage
                  ausgestattet ist.
                  • LongbowL
                    LongbowL
                    Longbow
                    #727
                    Hat jemandes das mit der Lüftung hin bekommen, bei mir wird es nicht angezeigt. Was mache ich falsch?
                    • LongbowL Longbow
                      P
                      P
                      papaechokilo
                      #728
                      @longbow was genau funktioniert nicht?
                      LongbowL 1 Antwort Letzte Antwort
                      • P papaechokilo
                        LongbowL
                        LongbowL
                        Longbow
                        #729
                        @papaechokilo ich bekomme keine Lüftungsempfehlung hin.
                        • LongbowL Longbow
                          P
                          P
                          papaechokilo
                          #730
                          @longbow habe ich nicht in Verwendung. Ich verwende ein Skript mit Luftfeuchtigkeit für die Lüftungsempfehlung.
                          • P papaechokilo
                            LongbowL
                            LongbowL
                            Longbow
                            #731
                            @papaechokilo wie sieht es bei dir aus? Würde mich Interessieren.
                            • LongbowL Longbow
                              P
                              P
                              papaechokilo
                              #732
                              @longbow ich verwende ein Script von Moritz Heusinger. https://github.com/foxriver76/iot-blog-scripts/blob/master/ventilationCheckMultiRoom.js
                              • P papaechokilo
                                LongbowL
                                LongbowL
                                Longbow
                                #733
                                @papaechokilo Danke, blöde Frage, wie wende ich das nun an? Gibt es eine Anleitung?
                                • LongbowL Longbow
                                  P
                                  P
                                  papaechokilo
                                  #734
                                  @longbow iot-Blog.net/20192/03/08/iobroker-intelligente-belueftung-des-ganzen-hauses
                                  • P papaechokilo
                                    D
                                    D
                                    dike1982
                                    #735
                                    Vielen Dank das schau ich mir an!
                                    • D dike1982
                                      D
                                      D
                                      dike1982
                                      #736
                                      Hallo Zusammen,
                                      ich habe einige Fensterkontakt hinzugefügt nun bekomme ich ein paart Warnungen im Skirpt:
                                      16:40:45.532	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 3 = DG Schlafzimmer hat Fenstersensor/en
                                      16:40:45.533	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 4 = EG CrossFit hat Fenstersensor/en
                                      16:40:45.536	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 6 = OG Esszimmer hat Fenstersensor/en
                                      16:40:45.540	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 9 = OG Speisekammer hat Fenstersensor/en
                                      16:40:45.541	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 10 = OG Spielzimmer hat Fenstersensor/en
                                      16:40:45.549	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Raum- 12 = OG Klo hat Fenstersensor/en
                                      16:40:45.635	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: x=1=DG Laura SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                                      16:40:45.637	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: x=4=EG CrossFit SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                                      16:40:45.643	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: x=11=OG Spielzimmer SendWindowWarnMsg=true SendDoorWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                                      16:40:45.685	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.686	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.687	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.687	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.689	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.690	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.691	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.691	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.693	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=3 Sensor[x]=hm-rpc.1.0000D8A99BC083.1
                                      16:40:45.693	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.0000D8A99BC083.1, please check your configuration
                                      16:40:45.694	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=3
                                      16:40:45.695	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[3]=unknown SensorOldVal= TempRoom=DG Schlafzimmer SensorType[x]=Window TempRoomIndex=3
                                      16:40:45.696	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.696	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.697	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.698	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.700	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.700	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.700	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.703	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.704	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=4 Sensor[x]=hm-rpc.1.003660C993CF95.1
                                      16:40:45.704	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CF95.1, please check your configuration
                                      16:40:45.705	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=4
                                      16:40:45.706	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[4]=unknown SensorOldVal= TempRoom=DG Schlafzimmer SensorType[x]=Window TempRoomIndex=3
                                      16:40:45.711	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.712	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.712	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.723	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.726	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.726	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.726	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.727	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.727	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=5 Sensor[x]=hm-rpc.1.003660C993CF16.1
                                      16:40:45.728	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CF16.1, please check your configuration
                                      16:40:45.728	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=5
                                      16:40:45.729	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[5]=unknown SensorOldVal= TempRoom=EG CrossFit SensorType[x]=Window TempRoomIndex=4
                                      16:40:45.730	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.730	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.730	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.730	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.731	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.731	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.732	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.732	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.732	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=6 Sensor[x]=hm-rpc.1.003660C993C8E8.1
                                      16:40:45.732	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C8E8.1, please check your configuration
                                      16:40:45.732	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=6
                                      16:40:45.733	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[6]=unknown SensorOldVal= TempRoom=OG Arbeitszimmer SensorType[x]=Window TempRoomIndex=5
                                      16:40:45.733	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.733	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.733	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.734	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.735	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.735	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.735	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.735	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.735	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=7 Sensor[x]=hm-rpc.1.003660C993CFDA.1
                                      16:40:45.736	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CFDA.1, please check your configuration
                                      16:40:45.736	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=7
                                      16:40:45.736	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[7]=unknown SensorOldVal= TempRoom=OG Arbeitszimmer SensorType[x]=Window TempRoomIndex=5
                                      16:40:45.736	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.737	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.737	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.738	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.740	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.740	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.740	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.740	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.741	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=8 Sensor[x]=hm-rpc.1.003660C993C66D.1
                                      16:40:45.741	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C66D.1, please check your configuration
                                      16:40:45.742	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=8
                                      16:40:45.743	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[8]=unknown SensorOldVal= TempRoom=OG Esszimmer SensorType[x]=Window TempRoomIndex=6
                                      16:40:45.744	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.744	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.744	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.745	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.748	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.749	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.749	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.749	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.750	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=9 Sensor[x]=hm-rpc.1.003660C993C8C5.1
                                      16:40:45.750	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C8C5.1, please check your configuration
                                      16:40:45.750	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=9
                                      16:40:45.750	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[9]=unknown SensorOldVal= TempRoom=OG Esszimmer SensorType[x]=Window TempRoomIndex=6
                                      16:40:45.751	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.751	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.751	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.752	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.753	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.753	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.753	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.753	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.753	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=10 Sensor[x]=hm-rpc.1.0000D8A991D684.1
                                      16:40:45.754	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.0000D8A991D684.1, please check your configuration
                                      16:40:45.754	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=10
                                      16:40:45.755	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[10]=unknown SensorOldVal= TempRoom=OG Esszimmer SensorType[x]=Window TempRoomIndex=6
                                      16:40:45.755	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.755	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.756	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.756	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.757	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.757	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.757	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.757	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.758	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=11 Sensor[x]=hm-rpc.1.003660C993CB2D.1
                                      16:40:45.758	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CB2D.1, please check your configuration
                                      16:40:45.758	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=11
                                      16:40:45.758	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[11]=unknown SensorOldVal= TempRoom=OG Gästerbad SensorType[x]=Window TempRoomIndex=7
                                      16:40:45.759	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.759	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.760	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.760	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.761	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.762	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.762	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.762	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.762	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=12 Sensor[x]=hm-rpc.1.003660C993C8C9.1
                                      16:40:45.763	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C8C9.1, please check your configuration
                                      16:40:45.763	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=12
                                      16:40:45.763	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[12]=unknown SensorOldVal= TempRoom=OG Kueche SensorType[x]=Window TempRoomIndex=9
                                      16:40:45.764	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.764	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.764	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.765	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.771	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.772	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.772	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.772	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.772	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=13 Sensor[x]=hm-rpc.1.003660C993C8F0.1
                                      16:40:45.772	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C8F0.1, please check your configuration
                                      16:40:45.773	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=13
                                      16:40:45.773	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[13]=unknown SensorOldVal= TempRoom=OG Kueche SensorType[x]=Window TempRoomIndex=9
                                      16:40:45.773	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.773	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.774	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.774	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.775	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.775	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.775	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.776	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.776	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=14 Sensor[x]=hm-rpc.1.003660C993C7C8.1
                                      16:40:45.776	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C7C8.1, please check your configuration
                                      16:40:45.776	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=14
                                      16:40:45.776	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[14]=unknown SensorOldVal= TempRoom=OG Speisekammer SensorType[x]=Window TempRoomIndex=10
                                      16:40:45.777	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.777	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.777	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.778	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.779	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.779	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.779	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.779	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.779	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=15 Sensor[x]=hm-rpc.1.003660C993CF1A.1
                                      16:40:45.780	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CF1A.1, please check your configuration
                                      16:40:45.780	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=15
                                      16:40:45.780	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[15]=unknown SensorOldVal= TempRoom=OG Speisekammer SensorType[x]=Window TempRoomIndex=10
                                      16:40:45.781	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.781	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.781	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.781	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.782	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.783	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.783	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.783	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.783	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=16 Sensor[x]=hm-rpc.1.003660C993CF98.1
                                      16:40:45.783	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CF98.1, please check your configuration
                                      16:40:45.784	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=16
                                      16:40:45.784	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[16]=unknown SensorOldVal= TempRoom=OG Spielzimmer SensorType[x]=Window TempRoomIndex=11
                                      16:40:45.784	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.785	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.785	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.785	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.786	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.786	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.786	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.787	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.787	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=17 Sensor[x]=hm-rpc.1.0000D8A99BBF81.1
                                      16:40:45.787	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.0000D8A99BBF81.1, please check your configuration
                                      16:40:45.787	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=17
                                      16:40:45.788	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[17]=unknown SensorOldVal= TempRoom=OG Spielzimmer SensorType[x]=Window TempRoomIndex=11
                                      16:40:45.788	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.788	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.789	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.789	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.790	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.790	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.790	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.790	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.791	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=18 Sensor[x]=hm-rpc.1.003660C993CB8E.1
                                      16:40:45.791	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CB8E.1, please check your configuration
                                      16:40:45.791	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=18
                                      16:40:45.791	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[18]=unknown SensorOldVal= TempRoom=Treppenhaus SensorType[x]=Window TempRoomIndex=13
                                      16:40:45.792	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.792	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.792	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.793	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.794	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.794	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.794	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.794	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.794	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=19 Sensor[x]=hm-rpc.1.003660C993CE41.1
                                      16:40:45.795	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CE41.1, please check your configuration
                                      16:40:45.795	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=19
                                      16:40:45.795	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[19]=unknown SensorOldVal= TempRoom=Treppenhaus SensorType[x]=Window TempRoomIndex=13
                                      16:40:45.796	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.796	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.796	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.796	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.801	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.801	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.801	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.801	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.802	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=20 Sensor[x]=hm-rpc.1.003660C993CF42.1
                                      16:40:45.802	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993CF42.1, please check your configuration
                                      16:40:45.802	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=20
                                      16:40:45.802	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[20]=unknown SensorOldVal= TempRoom=OG Klo SensorType[x]=Window TempRoomIndex=8
                                      16:40:45.803	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.803	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.803	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.804	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.804	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.805	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.805	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.805	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.805	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=21 Sensor[x]=hm-rpc.1.003660C993C87F.1
                                      16:40:45.805	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C87F.1, please check your configuration
                                      16:40:45.806	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=21
                                      16:40:45.806	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[21]=unknown SensorOldVal= TempRoom=OG Wohnzimmer SensorType[x]=Window TempRoomIndex=12
                                      16:40:45.806	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.807	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.807	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.807	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.819	warn	javascript.0 (809) at init (script.js.common.Visu.Status_Fenster.Fenster:334:45)
                                      16:40:45.819	warn	javascript.0 (809) at main (script.js.common.Visu.Status_Fenster.Fenster:349:5)
                                      16:40:45.819	warn	javascript.0 (809) at InitialSort (script.js.common.Visu.Status_Fenster.Fenster:314:5)
                                      16:40:45.820	warn	javascript.0 (809) at Object.<anonymous> (script.js.common.Visu.Status_Fenster.Fenster:278:13)
                                      16:40:45.820	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CheckForHmShit val=null typof val=string x=22 Sensor[x]=hm-rpc.1.003660C993C8BB.1
                                      16:40:45.820	warn	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Unknown Windowstate undefined detected at hm-rpc.1.003660C993C8BB.1, please check your configuration
                                      16:40:45.820	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching GetRoom x=22
                                      16:40:45.820	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: reaching CheckWindow, SensorVal[22]=unknown SensorOldVal= TempRoom=OG Wohnzimmer SensorType[x]=Window TempRoomIndex=12
                                      16:40:45.821	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Fenster geschlossen.
                                      16:40:45.821	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Fenster gesamt= 0
                                      16:40:45.821	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Alle Türen geschlossen.
                                      16:40:45.821	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Offene Türen gesamt= 0
                                      16:40:45.822	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=0 Init=true VentwarnTime[x]=1 RoomStateTimeStamp[x]=1705130213512
                                      16:40:45.822	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Starting VentInterval for Room DG Bad Time set to: 1 days
                                      16:40:45.823	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.824	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching Meldung, msg= DG Bad nicht gelüftet 1 Tag 8 Std. 23 Min. NoMsgAtPresence= false Presence= true
                                      16:40:45.824	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching WriteMessageLog, Message=DG Bad nicht gelüftet 1 Tag 8 Std. 23 Min.
                                      16:40:45.825	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: VentMsg=1 Tag 8 Std. 23 Min.
                                      16:40:45.826	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705130228125
                                      16:40:45.826	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 1 = DG Laura is open or disabled, no vent warning set
                                      16:40:45.827	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.827	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 3 = DG Schlafzimmer is open or disabled, no vent warning set
                                      16:40:45.826	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.826	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705216971568
                                      16:40:45.826	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 2 = DG Moritz is open or disabled, no vent warning set
                                      16:40:45.827	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=3 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1704808444537
                                      16:40:45.827	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=4 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983769
                                      16:40:45.827	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 4 = EG CrossFit is open or disabled, no vent warning set
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=5 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705226230397
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 5 = OG Arbeitszimmer is open or disabled, no vent warning set
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=6 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705243779776
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 6 = OG Esszimmer is open or disabled, no vent warning set
                                      16:40:45.828	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=7 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705242592635
                                      16:40:45.829	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 7 = OG Gästerbad is open or disabled, no vent warning set
                                      16:40:45.829	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.829	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=8 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705223702363
                                      16:40:45.829	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 8 = OG Klo is open or disabled, no vent warning set
                                      16:40:45.829	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=9 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705217920251
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 9 = OG Kueche is open or disabled, no vent warning set
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=10 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983301
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 10 = OG Speisekammer is open or disabled, no vent warning set
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=11 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705226196666
                                      16:40:45.830	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 11 = OG Spielzimmer is open or disabled, no vent warning set
                                      16:40:45.831	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      16:40:45.831	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=12 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983307
                                      16:40:45.831	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 12 = OG Wohnzimmer is open or disabled, no vent warning set
                                      16:40:45.831	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=13 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983768
                                      16:40:45.831	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Room 13 = Treppenhaus is open or disabled, no vent warning set
                                      16:40:45.835	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenDoorsList
                                      16:40:45.836	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenDoors: Keine Tür/en geöffnet
                                      16:40:45.836	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedDoorsList
                                      16:40:45.836	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedDoors: Keine Tür gekippt
                                      16:40:45.837	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenWindowsList
                                      16:40:45.837	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenWindows: Alle Fenster sind geschlossen
                                      16:40:45.838	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedWindowsList
                                      16:40:45.838	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedWindows: Keine Fenster gekippt
                                      16:40:45.838	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: CreateOpenRoomsList()
                                      16:40:45.839	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenings:
                                      16:40:45.839	info	javascript.0 (809) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                                      Ansonst läuft es aber? Was ist falsch?
                                      C 1 Antwort Letzte Antwort
                                      • D dike1982
                                        Hallo Zusammen,
                                        C
                                        C
                                        Chrunchy
                                        #737
                                        @dike1982 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                        Fehlt da nicht der Datenpunkt STATE?
                                        Gruß Chrunchy
                                        • C Chrunchy
                                          D
                                          D
                                          dike1982
                                          #738
                                          @chrunchy
                                          Kann sein aber warum?
                                          83.8k
