  4. Fehler nach Zigbee Adapter Update auf 1.8.25
30 Beiträge 8 Kommentatoren 4.7k Aufrufe 7 Beobachtet
  • Pedder007P Pedder007
    Hallo @arteck ich habe gerade auch die 1.9.3 getestet.
    Leider funktioniert diese mit dem ZigStar GW (FW Vers.: 0.6.10) noch nicht.
    Adapter bleibt rot und in der GW Web-Oberfläche bleibt auch 'General - Socket' auf 'rot'.
    Log sagt folgendes:
    zigbee.0
    2023-12-28 10:08:07.477	info	terminating
    zigbee.0
    2023-12-28 10:08:06.976	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2023-12-28 10:08:06.976	info	terminating
    zigbee.0
    2023-12-28 10:08:06.976	info	cleaned everything up...
    zigbee.0
    2023-12-28 10:08:06.961	error	JSON.stringfy is not a function
    zigbee.0
    2023-12-28 10:08:06.961	error	TypeError: JSON.stringfy is not a function at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:286:75) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:195:14) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:68:37) at Zigbee.emit (node:events:517:28) at Zigbee.emit (node:domain:489:12) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11928:18) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11905:26
    zigbee.0
    2023-12-28 10:08:06.894	error	unhandled promise rejection: JSON.stringfy is not a function
    zigbee.0
    2023-12-28 10:08:06.894	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2023-12-28 10:08:06.892	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/water.js
    zigbee.0
    2023-12-28 10:08:06.881	info	starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    zigbee.0
    2023-12-28 10:08:03.851	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    zigbee.0
    2023-12-28 10:08:03.760	error	adapter disabled
    Nach Downgrade auf 1.8.24 läuft sofort alles wieder.
    Ich nehme auch mal @dimaiv mit hier rein, evtl. braucht ja auch die GW Firmware ein Update?
    dimaiv
    schrieb am zuletzt editiert von dimaiv
    @pedder007
    Hi.
    Zigbee GW läuft einwandfrei mit dem Zigbee Adapter in Version 1.9.3, ausser bekannte Fehler mit IKEA Lampen.
    Wenn du einen externen Converter in Zigbee Adapter Einstellungen eingetragen hast, deaktiviere denn bitte und versuche noch mal.
    P.S.: habe gerade genau angeguckt, ja, du hast mindestens einen externen Converter water.js.
    Der ist jetz, wahrscheinlich, in Original Converter vorhanden.
    ioBroker- NUC8i3 / Proxmox / VM
    Node.js v22.21.0
    NPM v10.9.4
    JS controller 7.1.0
    Admin 7.7.20
    ZigBee Adapter 3.3.1alpha.0
    Zigbee LAN Gateway CC2652P
    Zigbee Firmware 20250321
    Pedder007P 1 Antwort Letzte Antwort
      Log sagt folgendes:
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      arteckA Offline
      arteckA Offline
      arteck
      @pedder007 sagte in Fehler nach Zigbee Adapter Update auf 1.8.25:
      du hast gerade noch ein Fehler gefunden.... installier mal die GIT version
      • D dimaiv
        @pedder007
        Hi.
        Pedder007P Offline
        Pedder007P Offline
        Pedder007
        @dimaiv das war es, den Konverter hatte ich vor Wochen/Monaten mal, ich meine mit Unterstützung hier aus dem Forum ( @arteck
        / @Asgothian ?) eingerichtet. Den hatte ich überhaupt nicht mehr auf dem Schirm.
        Den habe ich nun herausgenommen und dann, @arteck, von GIT die 1.9.4 installiert. Danach startet der Adapter wieder durch.
        Die beiden Wassermelder (Stichw.: Konverter) habe ich dann neu angelernt, allerdings kommen die dann noch mit folgender Fehlermeldung, welche beim Neustart des Adapter so auch reproduzierbar ist. Funktionieren tun sie trotzdem noch.
        Ich weiß auch leider überhaupt nicht mehr, ob das der Grund damals für den Konverter war.
        zigbee.0
        2023-12-29 11:11:56.007	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x84fd27fffe31acc7 TS0207 (Error: Bind 0x84fd27fffe31acc7/1 genPowerCfg from '0x00124b0025793af8/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
        zigbee.0
        2023-12-29 11:11:45.874	info	Configuring 0x84fd27fffe31acc7 TS0207
        zigbee.0
        2023-12-29 11:11:45.873	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x804b50fffe2533cb TS0207 (Error: Bind 0x804b50fffe2533cb/1 genPowerCfg from '0x00124b0025793af8/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
        Pedder
        All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
        Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
        Under construction: Smart-WoMo auf Raspi4
          zigbee.0
          zigbee.0
          zigbee.0
          dimaiv
          @pedder007
          Du muss den Wassermelder aufwachen während Configurierung.
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          • D dimaiv
            @pedder007
            Pedder007P Offline
            Pedder007P Offline
            Pedder007
            schrieb am zuletzt editiert von Pedder007
            @dimaiv sagte in Fehler nach Zigbee Adapter Update auf 1.8.25:
            Wie meinst Du das? - soll ich sie auslösen? Weil neu angelernt hatte ich die beiden ja schon.
            Da kommen jetzt auch noch ausführlichere Fehlermeldungen:
            zigbee.0
            2023-12-29 15:05:03.488	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x84fd27fffe31acc7 TS0207 (Error: ConfigureReporting 0x84fd27fffe31acc7/1 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"maximumReportInterval":65000,"reportableChange":0}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 31277 - 1 - 194 - 1 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
            zigbee.0
            2023-12-29 15:04:38.238	info	Configuring 0x84fd27fffe31acc7 TS0207
            zigbee.0
            2023-12-29 14:55:09.605	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x804b50fffe2533cb TS0207 (Error: ConfigureReporting 0x804b50fffe2533cb/1 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"maximumReportInterval":65000,"reportableChange":0}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
            zigbee.0
            2023-12-29 14:54:11.879	info	Configuring 0x804b50fffe2533cb TS0207
            Pedder
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              Pedder007P Offline
              Pedder007P Offline
              Pedder007
              Hallo nochmal.
              Danke Euch für die nun offizielle 1.9.5 👍 läuft sofort. 👍
              Bzgl. des Problemchens mit den Wassermeldern habe ich nun beim Adapterneustart mal den einen Wassermelder ausgelöst, bzw. auch mal kurz den Anlernknopf gedrückt.
              Darauf kam zumindest schon einmal bei diesem, nach 'Configuring .... TS0207' keine Fehlermeldung mehr und im ZigBee Adapter wird nun auch der Batteriestand in % angezeigt.
              Wenn das da so bleibt, mache ich das auch noch mit dem anderen. Der ist nur etwas schwer zugänglich verbaut und löst ggf. auch direkt den Hausalarm aus ;-)
              Edit:
              Zu früh gefreut. Kaum hatte ich das hier gepostet kam schon wieder:
              zigbee.0
              2023-12-30 13:00:11.540	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x804b50fffe2533cb TS0207 (Error: Bind 0x804b50fffe2533cb/1 genPowerCfg from '0x00124b0025793af8/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
              Pedder
                Hallo nochmal.
                Edit:
                zigbee.0
                arteckA Offline
                arteckA Offline
                arteck
                @pedder007 das ist aber was anderes.. da antwortet was nicht..
                • arteckA arteck
                  Pedder007P Offline
                  Pedder007P Offline
                  Pedder007
                  Hallo @arteck, dank auch für Deine Rückmeldung.
                  Sorry aber das ließt sich für mich alles halbwegs gleich kryptisch (habe hier leider immer so viele weitere, auch außerhalb Smarthome, Baustellen parallel, dass ich nie die Zeit finde, da mal tiefer einzutauchen, wenn ich mal Rentner bin, ... ;-) )
                  Das kam wie gesagt gestern so, nachdem ich den einen Melder neu angelernt hatte. Wenn ich nun im Log zurückschaue, dann finde ich wieder für beide Melder, immer so ca. alle 2 Stunden, so etwas:
                  zigbee.0
                  2023-12-31 09:38:05.556	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x804b50fffe2533cb TS0207 (Error: ConfigureReporting 0x804b50fffe2533cb/1 genPowerCfg([{"attribute":"batteryPercentageRemaining","minimumReportInterval":3600,"maximumReportInterval":65000,"reportableChange":0}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
                  zigbee.0
                  2023-12-31 09:37:08.319	info	Configuring 0x804b50fffe2533cb TS0207
                  Im Adapter werden sie allerdings unterschiedlich dargestellt (einer mit und einer ohne Batteriestand):
                  Wenn Du mir evtl. noch einen Hinweis bzgl. des 'Aufwachens', was @dimaiv schrieb, geben könntest, würde ich das mal ausprobieren. Ich hatte da gestern bereits in der Instanz unter 'Entwickler' herumgetüftelt, aber das ist dann bei mir immer eher wie, 'mal sehen was passiert' und kein gezielter Umgang damit 😢
                  Pedder
                  keksnK 1 Antwort Letzte Antwort
                    zigbee.0
                    zigbee.0
                    keksnK Offline
                    keksnK Offline
                    keksn
                    @arteck Hallo, ich hab auch seit dem Update auf die V 1.8.25 Probleme mit meinen Sonoff Zigbee Geräten. Dieser Fehler tritt auch bei der Versionen 1.9.6 auf.
                    Nach downgrade auf V 1.8.4 läuft wieder alles normal.
                    2024-01-01 09:24:50.512	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b001e721e35 BASICZBR3 (Error: ConfigureReporting 0x00124b001e721e35/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 57020 - 1 - 9 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
                    zigbee.0
                    2024-01-01 09:24:49.257	info	Configuring 0x00124b001e722512 BASICZBR3
                    zigbee.0
                    2024-01-01 09:24:49.225	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b001e722512 BASICZBR3 (Error: ConfigureReporting 0x00124b001e722512/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 22884 - 1 - 2 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
                    • keksnK keksn
                      zigbee.0
                      zigbee.0
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @keksn zeig mir den start des Adapter..aus dem LOG und nicht nur 3 Zeilen
                      keksnK Pedder007P 3 Antworten Letzte Antwort
                      • arteckA arteck
                        keksnK Offline
                        keksnK Offline
                        keksn
                        @arteck ich habe die 1.9.5 nochmals installiert...
                        2024-01-01 09:53:08.953	warn	DeviceAvailability:Failed to ping 0x7cb03eaa0a008701 LIGHTIFY Indoor Flex RGBW
                        zigbee.0
                        2024-01-01 09:53:08.452	warn	DeviceAvailability:Failed to ping 0x7cb03eaa0a07b3dd Plug 01
                        zigbee.0
                        2024-01-01 09:53:05.175	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b001e721e35 BASICZBR3 (Error: ConfigureReporting 0x00124b001e721e35/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 57020 - 1 - 9 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
                        zigbee.0
                        2024-01-01 09:53:03.948	info	Configuring 0x00124b001e722512 BASICZBR3
                        zigbee.0
                        2024-01-01 09:53:03.921	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b001e722512 BASICZBR3 (Error: ConfigureReporting 0x00124b001e722512/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 22884 - 1 - 2 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
                        zigbee.0
                        2024-01-01 09:53:01.754	warn	DeviceAvailability:Failed to ping 0x18fc260000b3cce1 RB 266
                        zigbee.0
                        2024-01-01 09:52:59.764	warn	DeviceAvailability:Failed to ping 0x7cb03eaa0a045b3e Classic A60 W clear - LIGHTIFY
                        zigbee.0
                        2024-01-01 09:52:42.061	info	Configuring 0x00124b001e721e35 BASICZBR3
                        zigbee.0
                        2024-01-01 09:52:40.826	info	debug devices set to []
                        zigbee.0
                        2024-01-01 09:52:40.773	warn	download icon from https://www.zigbee2mqtt.io/images/devices/GZCGQ11LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/GZCGQ11LM.png
                        zigbee.0
                        2024-01-01 09:52:40.771	warn	download icon from https://www.zigbee2mqtt.io/images/devices/RB-266.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/RB 266.png
                        zigbee.0
                        2024-01-01 09:52:40.769	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0044.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0044.png
                        zigbee.0
                        2024-01-01 09:52:40.768	warn	download icon from https://www.zigbee2mqtt.io/images/devices/RB-266.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/RB 266.png
                        zigbee.0
                        2024-01-01 09:52:40.764	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0504B.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0504B.png
                        zigbee.0
                        2024-01-01 09:52:40.763	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0044.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0044.png
                        zigbee.0
                        2024-01-01 09:52:40.762	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0044.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0044.png
                        zigbee.0
                        2024-01-01 09:52:40.761	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0044.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0044.png
                        zigbee.0
                        2024-01-01 09:52:40.760	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZBMINI.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZBMINI.png
                        zigbee.0
                        2024-01-01 09:52:40.756	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0504B.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0504B.png
                        zigbee.0
                        2024-01-01 09:52:40.754	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0504B.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0504B.png
                        zigbee.0
                        2024-01-01 09:52:40.749	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0504B.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0504B.png
                        zigbee.0
                        2024-01-01 09:52:40.739	info	Zigbee started
                        zigbee.0
                        2024-01-01 09:52:40.739	info	0x54ef441000a2032d (addr 12726): GZCGQ11LM - Xiaomi Aqara T1 light intensity sensor (EndDevice)
                        • arteckA arteck
                          keksnK Offline
                          keksnK Offline
                          keksn
                          @arteck Danke für die Korrektur, der Fehler tritt in der Version V 1.9.7 nicht mehr auf!
                          • arteckA arteck
                            Pedder007P Offline
                            Pedder007P Offline
                            Pedder007
                            @arteck hallo nochmal,
                            ich hatte jetzt nochmals ein paar Nachforschungen zu meinen Wassermeldern angestellt. Ich hatte damals mit Hilfe von @Asgothian (im Discord-Call) einen externen Konverter gebaut, welcher bei meiner ioBroker Migration vom Raspi in einen Proxmox Container wahrscheinlich verloren gegangen ist.
                            Ich habe nun auch nochmals auf dem alten Raspi gesucht, kann ihn dort aber auch nicht mehr finden. Das war der Konverter 'water..js', der mir hier (weiter oben) beim Update Probleme gemacht hatte.
                            Wie bekommen wir das nun wieder hin? Soll ich einen Device-Request auf GIT erstellen?
                            Mir ist nur nicht so ganz klar was dafür konkret benötigt wird.
                            Der Zigbee Adapter erkennt da aktuell dieses Device: 'https://www.zigbee2mqtt.io/devices/TS0207_water_leak_detector.html'.
                            Meins sieht allerdings anders aus: Kompakte Bauform (wie die Xiaomis: https://www.zigbee2mqtt.io/devices/SJCGQ11LM.html), allerdings mit Gummi-Einsatz oben drauf, worunter sich der Pairing-Knopf befindet.
                            Pedder
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @pedder007 gehts nur um das Bild oder die Funktionsweise ?? wenn erstes dann ist es völlig egal ie es auf dem Bild aussieht
                              • arteckA arteck
                                Pedder007P Offline
                                Pedder007P Offline
                                Pedder007
                                @arteck nee, das Bildchen ist mir egal, war nur ein Versuch der Zustandsbeschreibung ;-)
                                Das Problem hatte ich ja bereits weiter oben gepostet:
                                 zigbee.0
                                zigbee.0
                                Wenn ich mich da richtig erinnere, wird beim anlernen zwar ein Datenpunkt 'Battery in %' angelegt, aber der führt dann irgendwie zu Problemen und deshalb gibt's dann da die Errors.
                                In den Objekten sieht das Ding so aus:
                                Bzw. der DP 'Battery percent' so:
                                  "type": "state",
                                  "common": {
                                    "name": "Battery percent",
                                    "type": "number",
                                    "unit": "%",
                                    "read": true,
                                    "write": false,
                                    "role": "value.battery",
                                    "min": 0,
                                    "max": 120,
                                    "icon": "img/battery_p.png"
                                  "native": {},
                                  "from": "system.adapter.zigbee.0",
                                  "user": "system.user.admin",
                                  "ts": 1703953524774,
                                  "_id": "zigbee.0.804b50fffe2533cb.battery",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                    "owner": "system.user.admin",
                                Pedder
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  der kriegt ein timeout.. bei configure.. musst den mal wecken..
                                  • arteckA arteck
                                    Pedder007P Offline
                                    Pedder007P Offline
                                    Pedder007
                                    @arteck die Frage hatte ich ja auch schon oben gestellt ;-) , was heißt 'wecken' denn genau?
                                    Ich hatte die beiden beim anlernen jeweils ausgelöst (Wasserkontakte), bzw. auch noch zusätzlich 2-3x jeweils kurz den Anlernknopf gedrückt. Das hatte erstmal nicht geholfen. Danach habe ich dann noch zusätzlich im Adapter unter Entwickler mal 1-2 'reads' abgesetzt.
                                    Danach waren die Meldungen aber immer noch da.
                                    Was jetzt nur komisch ist, ich habe gerade nochmals im Log nachgeschaut, aktuell kommt da anscheinend nichts mehr rein.
                                    Kann sich das 'von selber' geregelt haben? 🤔
                                    Pedder
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      ja...
                                      die Batteriegeräte gehen in schlafmodus.. jedes hat auch ein Knopp zum anlernen .. ein wecken ist.. diesen Knopp mal kurz zu drücken..dan sendet es paar Daten.. und empfängt fals nötig ein configure
                                      • arteckA arteck
                                        ja...
                                        Pedder007P Offline
                                        Pedder007P Offline
                                        Pedder007
                                        @arteck ok, danke Dir! Dann war ich ja schon richtig unterwegs und mache mal nix weiter...
                                        Dir dann einen schönen sonnigen Tag noch :-)
                                        Pedder
