  4. Neuer Adapter ecoflow-mqtt
    6.3k
804 Beiträge 62 Kommentatoren 308.2k Aufrufe 56 Beobachtet
  • F foxthefox
    Die Version 0.0.14 ist auf github online.
    Sie enthält nun die River Serie (River 2 Pro, River 2 Max, River Pro, River Max).
    Hier benötigt es aktives Feedback für die unterschiedlichen Modelle (River2PRO @Der-Tom).
    0.0.14
    • (foxthefox) new implementation of River 2 Pro, River 2 Max, River Pro, River Max
    • (foxthefox) new feature get "lastQuotas"
    • (foxthefox) refactoring of protobuf encoding
    • (foxthefox) watth5=daily energy plug, watth6=on time plug
    • (foxthefox) plug_heartbeat new values unknown16...19
    Der Tom
    #75
    @foxthefox
    Hier noch weitere Warnungen die ich gerade sehe:
    ecoflow-mqtt.0
    2023-12-26 20:05:22.065 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.outVol" has value "2052.7000000000003" greater than max "60"
    ecoflow-mqtt.0
    2023-12-26 20:05:22.017 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.inVol" has value "289.2" greater than max "150"
    ecoflow-mqtt.0
    2023-12-26 20:05:02.710 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.outAmp" has value "166.42000000000002" greater than max "13"
    ecoflow-mqtt.0
    2023-12-26 20:05:02.657 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.outVol" has value "2041.7" greater than max "60"
    ecoflow-mqtt.0
    2023-12-26 20:05:02.610 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.inVol" has value "290.7" greater than max "150"
    ecoflow-mqtt.0
    2023-12-26 20:04:14.913 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.outAmp" has value "168.03" greater than max "13"
    ecoflow-mqtt.0
    2023-12-26 20:04:14.857 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.outVol" has value "2031.4" greater than max "60"
    ecoflow-mqtt.0
    2023-12-26 20:04:14.812 warn State value to set for "ecoflow-mqtt.0.RXXXXXXXXXXXX.mppt.inVol" has value "289.2" greater than max "150"
    und 1-2 Anmerkung evtl.:
    Im Adapter ist die Vorgabe im Bereich: mqqt userid = 15XXX - Das kann für neue User verwirrend sein, da es bereits User mit 17XX gibt
    Im Device-Reiter ist die Vorgabe für die ID: DAExxxx - Das gilt aber nur für User mit einem Delta. Ich habe mit meinem River ein R6 am Anfang.
    Viele Grüße
    Der Tom
    F 1 Antwort Letzte Antwort
    • D Der Tom
      @foxthefox
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      ecoflow-mqtt.0
      Viele Grüße
      Der Tom
      foxthefox
      schrieb am zuletzt editiert von foxthefox
      #76
      @der-tom
      Ich vergaß zu erwähnen, das es auch noch Multiplikatoren anzupassen gilt. Das sind die meisten Meldungen, wo etwas zu groß ist.
      Das mit dem dsgCmd könnte daran liegen, dass ich noch keine Daten Punkte für bms_emsStatus habe. Dazu bräuchte ich einmal die JSON strings die bei den zyklischen Updates kommen. Dann kann ich die neuen erstellen.
      Wird denn überhaupt schon etwas in den Objekten aktualisiert?
      Werde morgen die Faktoren ändern.
      Adapterüberblick: Profil Github;
      Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
      Ein Aufruf: video
      D A 3 Antworten Letzte Antwort
      • F foxthefox
        @der-tom
        Der Tom
        #77
        @foxthefox said in Neuer Adapter ecoflow-mqtt:
        bms_emsStatus
        Guten Morgen,
        den bms_emsStatus gibt es nur in Deinem Script. Im Mqtt finde ich diesen nicht. Hilf mir mal bitte, wie ich Dir die Daten besorgen kann. Alternativ lasse ich das JSON-Script und den Mptt paralell laufen.
        Bei dieser Gelegenheit sei erwähnt, dass mich iobroker heute morgen informiert hat, dass der ecoflow-mqtt öfters abstürzt.
        Der Tom
        • F foxthefox
          @der-tom
          aherby
          #78
          @foxthefox Moin So mal Admiun 6.13.x installiert damit der Adapter funktioniert.
          PV input power
          ecoflow-mqtt.0.R351ZEB4HF4Exxxx.mppt.inWatts
          PV input power
          ecoflow-mqtt.0.R351ZEB4HF4Exxxx.mppt.pv2InWatts
          PV output power
          ecoflow-mqtt.0.R351ZEB4HF4Exxxx.mppt.outWatts
          ist um den Faktor 10 zu klein oder irre ich mich hier?
          • F foxthefox
            @der-tom
            aherby
            #79
            @foxthefox
            Beep mode normal?
            kommt wenn Piepen in der App eingeschaltet,
            Beep mode quit?
            vielleicht eher "quiet"
            wenn das Piepen ausgeschaltet.
            ecoflow-mqtt.0.R351ZEB4HF4Exxx.mppt.pv2Xt60ChgType
            liefert
            not detected?
            eigentlich sollte hier ein Kabel angeschlossen sein, wo aber der mittlere Pin fehlt.
            • A aherby
              @foxthefox
              Beep mode normal?
              Beep mode quit?
              liefert
              not detected?
              foxthefox
              #80
              @aherby
              Die "?"-Zeichen habe ich bei den Diagnosefunktionen drin, wo es als Antwort einen Zahlenwert gibt und es noch nicht sicher ist, ob die Bedeutung richtig ist.
              Für "beep" nehme ich es mal raus, da es passt und quit wird quiet.
              Das "not detected" gehört zur gleichen Kategorie und dürfte ja auch zum Zustand passen, wenn auf Grund des fehlenden Pins nichts erkannt werden kann.
              Auch da nehme ich mal "?" raus.
              Ein Aufruf: video
              • A aherby
                PV input power
                PV input power
                PV output power
                foxthefox
                #81
                @aherby
                Richtig, hier muß der Faktor noch angepasst werden, wobei einmal 10 und anderes Mal 100 fach zu groß.
                Allerdings bezogen auf den schon vorhandenen Faktor, aber das berücksichtige ich dann schon.
                Edit:
                Ich bezog mich auf die vorherigen logs, hab jetzt erst bemerkt, daß es hier um Watt geht, allerdings sehe ich keine Werte. Aber ich auch hier mal Faktor 10 kleiner.
                Edit2:
                Bezieht sich das auf Delta2Max oder River2Pro?
                pv2Xt60ChgType, pv2InWatts sollte es bei der River2Pro nicht geben.
                Ein Aufruf: video
                F A 2 Antworten Letzte Antwort
                • F foxthefox
                  @aherby
                  Edit:
                  Edit2:
                  foxthefox
                  #82
                  Also die Faktoren hab ich schonmal angepasst und auch die Texte.
                  Wenn ihr wollt, könnt ihr die derzeitige Version 0.0.15 vorab testen.
                  Dazu anstatt Github die benutzerdefinierte Version installieren, im Pfad ist dann
                  https://github.com/foxthefox/iobroker.ecoflow-mqtt/tree/0.0.15
                  einzutragen.
                  Das mit den dsgCmd ist damit noch nicht erledigt.
                  Ich baue mal noch ein paar mehr logs ein, um die UpdateDaten an der Stelle sichtbarer zu machen.
                  Ein Aufruf: video
                  • F foxthefox
                    einzutragen.
                    foxthefox
                    #83
                    habe noch logging für das dsgCmd ergänzt und da bräuchte ich dann den payload aus dem log um die Struktur zu bms_emsStatus aufzumchen.
                    Habe weitere unknownXX Datenpunkte für den plug aufgemacht. Da gibt es wohl mehr Daten als bisher bekannt.
                    Ein Aufruf: video
                    • F foxthefox
                      Der Tom
                      #84
                      @foxthefox
                      habe das eben noch gefunden:
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.754 debug not processed pd state: acAutoOutConfig value 0
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.749 debug not processed pd state: relaySwitchCnt value 2
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.741 debug not processed pd state: minAcoutSoc value 5
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.735 debug not processed pd state: watchIsConfig value 0
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.733 debug not processed pd state: acAutoOutPause value 0
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.727 debug not processed pd state: hysteresisAdd value 5
                      ecoflow-mqtt.0
                      2023-12-27 22:03:11.721 debug not processed pd state: bpPowerSoc value 18
                      Wie kann ich Dir mit dem dsgCmd weiterhelfen?
                      Der Tom
                      F 3 Antworten Letzte Antwort
                      • D Der Tom
                        @foxthefox
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        ecoflow-mqtt.0
                        Der Tom
                        foxthefox
                        #85
                        @der-tom
                        Da scheint es noch weitere Daten Punkte zu geben, die noch fehlen.
                        Zum dsgCmd müsste ja immer noch die Meldung
                        debug store payload TypeError: Cannot read properties of undefined (reading 'dsgCmd')
                        Kommen
                        Danach sollten auch debug mit „payload from Rxxxx was : …. „ kommen
                        Das was danach kommt, bräuchte ich. Und wahrscheinlich steht da derzeitig nur [object], weil ich es nicht in Text verwandelt habe😫. Mache morgen die kleine Änderung.
                        Ein Aufruf: video
                        • F foxthefox
                          @aherby
                          Edit:
                          Edit2:
                          aherby
                          #86
                          @foxthefox ich habe nur Delta 2 Max, sorry nicht geschrieben.
                          die oben genannten
                          mppt.inWatts
                          mppt.pv2InWatts
                          mppt.outWatts
                          waren alle um Faktor 10 zu klein. An anderen Stellen (kann aber gerade den Ort nicht benennen) passten die Werte mit der App überein.
                          Gibt es vielleicht auch bei der Delta 2Max. Hier wird seitens Ecoflow festgelegt, dass wenn die untere Ladegrenze einen Wert "xx" hat erst dieser Wert "xx" plus minACoutSoc-Wert erfüllt sein muss damit der AC-Output erfolgt. Beispiel:
                          minDsgSco=20 % plus minAcoutSoc =5 bedeutet Soc muss 25 % haben damit eingespeist wird.
                          klingt aber auch sehr nach dem Wert "hysteresisAdd value 5"
                          • F foxthefox
                            @der-tom
                            Kommen
                            aherby
                            #87
                            @foxthefox habe gerade noch das gefunden
                            Charger type
                            ...pd.pv1ChargeType Wert "2?"
                            Charger type
                            pd.pv2ChargeType Wert "2?"
                            Actual charging type
                            .mppt.chgType Wert "MPPT (Solar)"
                            .mppt.pv2ChgType Wert "MPPT (solar)2"
                            würde ja alles auf Solar / PV-Anschluss deuten. In der App wird auch das "falche" oder alte X60-Kabel als Solar erkannt.
                            Bei meinen PV1 ist ein X60i-Kabel angeschlossen. Ich müsste mal das KFZ-Kabel anschließen.
                            • F foxthefox
                              @der-tom
                              Kommen
                              aherby
                              schrieb am zuletzt editiert von aherby
                              #88
                              @foxthefox unknown32 hat sich gerade von 1 auf 2 aund dann 3 als Wert geändert.
                              Ich habe zwei Smarplugs beim Powerstrean im Netzwerk. Soll kein Smartplug berücksichtigt werden war
                              unknown32 = 1
                              .plug_heartbeat.unknown32
                              sobald ein Smartplug mit in die Leistungsbreitstellt berücksichtig wurde änderte sich der Wert auf
                              .plug_heartbeat.unknown32 =2
                              Bei zwei Smartplugs auf
                              .plug_heartbeat.unknown32 = 3
                              Smarplug:
                              .plug_heartbeat.unknown33
                              entspricht der über den Powerstream eingespeiste Leistung
                              Delta 2Max
                              Wird über die Lab-Funktion "AC immer eingeschaltet (Wird der Netzschalter automatisch eingeschaltet, nachdem wieder Strom anliegt. Bei ausgeschaltetem Schalter müssen Sie den Netzschalter manuellbetätigen. Der Netzschalter wird nicht abgeschaltet, wenn "AC AlwaysOn" aktiv ist) "
                              .pd.acAutoPause = 0 -> "AC immer eingeschaltet aus"
                              .pd.acAutoPause = 1 -> "AC immer eingeschaltet ein"
                              • H Online
                                H Online
                                holgerwolf
                                #89
                                Von den Warnungen hätte ich auch noch ein paar:
                                ecoflow-mqtt.0
                                	2023-12-28 10:51:25.878	warn	State value to set for "ecoflow-mqtt.0.DCEBZ8ZF1180811.bmsMaster.amp" has value "17.555" greater than max "13"
                                ecoflow-mqtt.0
                                	2023-12-28 10:51:24.925	warn	State value to set for "ecoflow-mqtt.0.DCEBZ8ZF1180811.bmsMaster.amp" has value "17.622" greater than max "13"
                                ecoflow-mqtt.0
                                	2023-12-28 10:51:24.438	warn	State value to set for "ecoflow-mqtt.0.DCEBZ8ZF1180811.bmsMaster.amp" has value "17.555" greater than max "13"
                                ecoflow-mqtt.0
                                	2023-12-28 10:51:23.893	warn	State value to set for "ecoflow-mqtt.0.DCEBZ8ZF1180811.bmsMaster.amp" has value "17.622" greater than max "13"
                                F 2 Antworten Letzte Antwort
                                • H holgerwolf
                                  ecoflow-mqtt.0
                                  ecoflow-mqtt.0
                                  ecoflow-mqtt.0
                                  ecoflow-mqtt.0
                                  foxthefox
                                  #90
                                  @holgerwolf
                                  Danke fürs mitmachen. Welches Gerät ist es denn?
                                  Ein Aufruf: video
                                  • F foxthefox
                                    @holgerwolf
                                    aherby
                                    #91
                                    @foxthefox ich habe diese Warnungen auch bei der Delta 2 Max
                                    State value to set for "ecoflow-mqtt.0.R351ZEB4HF4Exxxx.mppt.pv2InVol" has value "3729.1000000000004" greater than max "150"
                                    • A aherby
                                      foxthefox
                                      #92
                                      @aherby
                                      wird berücksichtigt und ich werde auch gleich mal pv2InAmp auch kleiner machen
                                      Ein Aufruf: video
                                      • H holgerwolf
                                        ecoflow-mqtt.0
                                        ecoflow-mqtt.0
                                        ecoflow-mqtt.0
                                        ecoflow-mqtt.0
                                        foxthefox
                                        #93
                                        @holgerwolf
                                        Delta Pro?
                                        ist der Wert von 17 A realistisch?
                                        Eventuell muss ich nur das Messbereichsende nach oben setzen, ist ja immerhin auch ne größere Station.
                                        Ein Aufruf: video
                                        H 1 Antwort Letzte Antwort
                                        • A aherby
                                          unknown32 = 1
                                          Smarplug:
                                          Delta 2Max
                                          foxthefox
                                          #94
                                          @aherby
                                          die unknown32 und 33 habe ich mal temporär umbenannt.
                                          Konntest du erkennen was unknown 34 ist, war ja auch irgendwie die Leistung der Powerstream?!
                                          Ein Aufruf: video
