  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
  • R Radix75
    @thomas-braun r
    radix1975@raspberrypi5:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installer!
        Installer version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    OK:1 http://deb.debian.org/debian bookworm InRelease
    OK:2 http://phoscon.de/apt/deconz bookworm InRelease
    OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
    OK:4 http://deb.debian.org/debian bookworm-updates InRelease
    OK:5 http://archive.raspberrypi.com/debian bookworm InRelease
    OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! node:internal/modules/cjs/loader:1137
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR! Error: Cannot find module '@colors/colors/safe'
    npm ERR! Require stack:
    npm ERR! - /opt/iobroker/node_modules/logform/colorize.js
    npm ERR! - /opt/iobroker/node_modules/logform/levels.js
    npm ERR! - /opt/iobroker/node_modules/logform/index.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/winston/lib/winston.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/logger.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
    npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:975:27)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
    npm ERR!     at require (node:internal/modules/helpers:177:18)
    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/logform/colorize.js:3:16)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19) {
    npm ERR!   code: 'MODULE_NOT_FOUND',
    npm ERR!   requireStack: [
    npm ERR!     '/opt/iobroker/node_modules/logform/colorize.js',
    npm ERR!     '/opt/iobroker/node_modules/logform/levels.js',
    npm ERR!     '/opt/iobroker/node_modules/logform/index.js',
    npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/winston/lib/winston.js',
    npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/logger.js',
    npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js',
    npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
    npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
    npm ERR!     '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    npm ERR!   ]
    npm ERR! }
    npm ERR!
    npm ERR! Node.js v18.19.0
    npm ERR! A complete log of this run can be found in: /home/radix1975/.npm/_logs/2023-12-23T08_03_27_029Z-debug-0.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.1.225:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    Ist die installation so richtig???
    ich habe zahlreiche Fehlermeldungen und komme auch nicht auf die Webseite
    Die Website ist nicht erreichbar
    192.168.1.225 hat die Verbindung abgelehnt.
    Versuche Folgendes:
    Verbindung prüfen
    Checking the proxy and the firewall
    ERR_CONNECTION_REFUSED
    Überprüfen Sie Ihre Internetverbindung.
    Check any cables and reboot any routers, modems, or other network devices you may be using.
    Erlauben Sie Opera den Netzwerkzugriff in den Firewall- oder Antivirus-Einstellungen.
    Falls das Programm schon in der Liste mit erlaubtem Netzwerkzugriff eingetragen ist, entferne es aus der Liste und füge es noch einmal hinzu.
    Falls du einen Proxyserver verwendest…
    Überprüfen Sie Ihre Proxyservereinstellungen oder kontaktieren Sie Ihren Netzwerkadministrator, um sicherzustellen, dass der Proxyserver funktioniert. Wenn Sie glauben, dass Sie keinen Proxyserver verwenden sollten: Rufen Sie das Hauptmenü und dann > Einstellungen > Proxyeinstellungen ändern… > LAN-Einstellungen auf. Deaktivieren Sie »Proxyserver für LAN verwenden«.
    Thomas BraunT Offline
    @radix75 sagte in Daikin Adapter:
    Dann ist die Installation auch nicht richtig...
    R 1 Antwort Letzte Antwort
      Radix75
      @thomas-braun mit welchen Befehlen kann ich es nochmal neu machen?
      • R Radix75
        @radix75
        Mach es komplett neu, lass die Sprache dann auf Englisch und leg das phoscon-Repository nach aktuellem Stand an.
        Was da allerdings genau klemmt sehr ich auch nicht. Netzwerk läuft mit IPv6?
          @radix75
          Radix75
          @thomas-braun Netzwerk kann IP6 die Rasp. hat aber derzeit eine IP 4 Adresse.
          "Mach es komplett neu, lass die Sprache dann auf Englisch und leg das phoscon-Repository nach aktuellem Stand an."
          Das bitte mal genau mit Befehlen erklären wie bekomme ich die def . Installation deinstalliert ?
          • R Radix75
            Wenn du komplett neuaufbaust wird eh die komplette Partition verwendet.
            • R Radix75
              Dann stell die auf Dual-Betrieb um. Auf dem Interface sollte sowohl IPv6 wie auch IPv4 vorhanden sein.
                Radix75
                @thomas-braun said in Daikin Adapter:
                Ich habe mir eine neue Raspi 5 mit 8GB geholt dazu das Passende Netzteil mit SanDisk Extreme PRO microSDXC UHS-I Speicherkarte 256 GB + Adapter & RescuePRO Deluxe (Für Smartphones, Actionkameras oder Drohnen, A2, Class 10, V30, U3, 200 MB/s Übertragung).
                Folgende Schritte habe ich gemacht :
                1. Downloade Bookworm 64 Bit
                2. mit Balena Etcher auf SD Karte schreiben
                  3 Einrichten von User, Netzwerk und Sprache usw.
                3. Installation von Node nach https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                4. Installation von IO Broker mit curl -sL https://iobroker.net/install.sh | bash -
                5. Installation von Dekonz ConBee II Zigbee USB-Gateway über Anleitung https://phoscon.de/de/conbee2/install
                  7 Installation von CCU piVCCU über Anleitung von https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                  (ist noch zu machen}
                Muss ich jetzt Komplet von vorne anfangen und die SD karte neu schreiben???
                • R Radix75
                  Mach es mit dem Raspberry OS Imager.
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  Nodejs braucht nicht separat Installiert werden, macht der ioBroker-Installer.
                  Deconz:
                  https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                  Und pivCCU würde ich als erstes einrichten und dann erst den ioBroker.
                    Deconz:
                    Radix75
                    schrieb am zuletzt editiert von Radix75
                    @thomas-braun Ok ich habe jetzt die SD Karte neu geschrieben und beginne wie vorgeschlagen mit der Installation von piCCU
                    leider verliere ich nach einen der unteren Punkte den Netzwerkzugriff über meine LAN Adresse ich komme nur noch per WLAN auf meine Raspberry was ich später aber nicht will .
                    Wo ist der Fehler ? wie bekomme ich mein LAN zurück???
                    Disable serial console in command line (You can skip this step, if you do not use the HM-MOD-RPI-PCB or RPI-RF-MOD on GPIO header, for the HB-RF-USB this step is not neccessary)
                    sudo sed -i /boot/cmdline.txt -e "s/console=serial0,[0-9]+ //"
                    sudo sed -i /boot/cmdline.txt -e "s/console=ttyAMA0,[0-9]+ //"
                    Add network bridge (if you are using wifi please refer to the debian documentation how to configure the network and the bridge)
                    Verify, that eth0 is the name of your primary network interface:
                    sudo ip link show | cut -d' ' -f2 | cut -d: -f1 | grep -e '^e.*'
                    Update your config. (Replace eth0 if necessary)
                    sudo apt remove dhcpcd5
                    sudo apt install bridge-utils
                    sudo bash -c 'cat << EOT > /etc/network/interfaces
                    source-directory /etc/network/interfaces.d
                    auto lo
                    iface lo inet loopback
                    iface eth0 inet manual
                    auto br0
                    iface br0 inet dhcp
                    bridge_ports eth0
                    EOT'
                    You can use an static IP address, too. In that case use instead:
                    auto lo
                    auto br0
                    iface br0 inet static
                    bridge_ports eth0
                    address <address>
                    netmask <netmask>
                    gateway <gateway>
                    dns-nameservers <dns1> <dns2>
                    EOT'
                    Das habe ich schon so versucht
                    auto lo
                    auto br0
                    bridge_ports eth0
                    address <192.168.1.225>
                    netmask <255.255.255.0>
                    gateway <192.168.1.1>
                    dns-nameservers <37.4.251.175> <192.168.1.1>
                    EOT'
                    • R Radix75
                      auto lo
                      auto br0
                      iface br0 inet dhcp
                      bridge_ports eth0
                      EOT'
                      auto lo
                      auto br0
                      bridge_ports eth0
                      address <address>
                      netmask <netmask>
                      gateway <gateway>
                      EOT'
                      auto lo
                      auto br0
                      bridge_ports eth0
                      EOT'
                      @radix75
                      Frag das bei pivCCU. Ich weiß nur, das da bridge-Interfaces usw. angelegt werden.
                      • R Radix75
                        auto lo
                        auto br0
                        iface br0 inet dhcp
                        bridge_ports eth0
                        EOT'
                        auto lo
                        auto br0
                        bridge_ports eth0
                        address <address>
                        netmask <netmask>
                        gateway <gateway>
                        EOT'
                        auto lo
                        auto br0
                        bridge_ports eth0
                        EOT'
                        Wo ist der Fehler ?
                        was hast du denn gemacht?
                        da stehen diverse verschiedene Optionen in der Anleitung.
                        • R Offline
                          Radix75
                          Ich habe alles so wie oben geschrieben gemacht
                          auto lo
                          auto br0
                          bridge_ports eth0
                          EOT'
                          die Variante mit
                          auto lo
                          auto br0
                          iface br0 inet dhcp
                          bridge_ports eth0
                          EOT'
                          hab ich nicht gemacht
                          • R Radix75
                            auto lo
                            auto br0
                            bridge_ports eth0
                            EOT'
                            die Variante mit
                            auto lo
                            auto br0
                            iface br0 inet dhcp
                            bridge_ports eth0
                            EOT'
                            und vorher auch geprüft ob deine Schnittstelle so heisst?
                            warum statische Adressen?
                            • R Radix75
                              auto lo
                              auto br0
                              bridge_ports eth0
                              EOT'
                              die Variante mit
                              auto lo
                              auto br0
                              iface br0 inet dhcp
                              bridge_ports eth0
                              EOT'
                              @radix75 nix nachträglich ändern!
                                Radix75
                                @homoran said in Daikin Adapter:
                                warum statische Adressen? Haben die nicht alle? Für die Nutzung sollte die Raspberry immer auf der selben IP liegen oder?
                                • R Radix75
                                  dann nimmt msn DHCP und bindet im Router die IP an die MAC Adresse des RasPi
                                  und die anderen Fragen?
                                  • R Offline
                                    Radix75
                                    Das Problem mit dem Netzwerk habe ich behoben.
                                    Ich hatte versehentlich eine IP vergeben die bereits vergeben war.
                                    Jetzt hab ich noch ein neues Problem mit dem HM Mod auf der Raspberry denn es wird nicht erkannt.
                                    Ich habe mir nochmal das Video von https://de.elv.com/elv-komplettbausatz-funk-modulplatine-fuer-raspberry-pi-3-b-rpi-rf-mod-fuer-homematic-und-homematic-ip-152941?_gl=1*b25d5s*_up*MQ..&gclid=CjwKCAiAyp-sBhBSEiwAWWzTnnyIMD19_yYn4rTSmTxwN1o9YppDlMm2GaZZ_NF1g4mxYuUU39Fp1hoCBKsQAvD_BwE
                                    angesehen und es steckt richtigrum drauf.
                                    Radix1975@raspberrypi5:~ $ sudo pivccu-info
                                    piVCCU version: 3.73.9-87
                                    OS: Debian GNU/Linux 12 (bookworm)
                                    Kernel: 6.1.0-rpi7-rpi-2712 aarch64
                                    Kernel modules: Available
                                    Raw UART dev: Available
                                    Rasp.Pi UART: Assigned to GPIO pins
                                    HMRF Hardware: unknown
                                    HMIP Hardware: unknown
                                    State: RUNNING
                                    PID: 2913
                                    IP: 192.168.1.63
                                    IP: 2a02:810a:1c0:55b:a828:90ff:fea9:98a9
                                    Link: vethpivccu
                                    TX bytes: 107.28 KiB
                                    RX bytes: 1.71 MiB
                                    Total bytes: 1.82 MiB
                                    HomoranH R 2 Antworten Letzte Antwort
                                    • R Radix75
                                      State: RUNNING
                                      PID: 2913
                                      IP: 192.168.1.63
                                      Link: vethpivccu
                                      RX bytes: 1.71 MiB
                                      das passiert bei DHCP mit Bindung an die MAC-Adresse nicht.
                                      zeigen!
                                      den Workout für die Nutzung ser GPIOs für das Funkmodul während der piVCCU Installation hast du beachtet?
                                      • R Radix75
                                        State: RUNNING
                                        PID: 2913
                                        IP: 192.168.1.63
                                        Link: vethpivccu
                                        RX bytes: 1.71 MiB
                                        Radix75
                                        @radix75 said in Daikin Adapter:
                                        State: RUNNING
                                        PID: 2913
                                        IP: 192.168.1.63
                                        Link: vethpivccu
                                        RX bytes: 1.71 MiB
                                        sudo dpkg -s pivccu | grep 'Version'
                                        dpkg-query: Paket »pivccu« ist nicht installiert und es ist keine Information verfügbar
                                        Verwenden Sie dpkg --info (= dpkg-deb --info) zum Untersuchen von Archiven.
                                        • R Radix75
                                          State: RUNNING
                                          PID: 2913
                                          IP: 192.168.1.63
                                          Link: vethpivccu
                                          RX bytes: 1.71 MiB
                                          @radix75 ???
