  4. ioBroker startet nicht nach Neuinstallation
67 Beiträge 7 Kommentatoren 9.2k Aufrufe 5 Beobachtet
  • W Willi-Wunder
    @ro75
    Die war Original verpackt, gestern.......ScanDisk High Endurance 32 GB
    W Offline
    W Offline
    Willi-Wunder
    Es scheint hier ein generelles Problem vorzuliegen, bullseye geht auch nicht. Hier der Log
    pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2023-10-13
    Welcome to the ioBroker installer!
    Installer version: 2023-10-13
    You might need to enter your password a couple of times.
    Installing prerequisites (1/4)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Fetched 44.1 kB in 1s (30.8 kB/s)
    Reading package lists... Done
    Changing npm registry to https://registry.npmjs.org
    Processing triggers for man-db (2.9.4-2) ...deb ...rrently installed.)
    Installed acl
    Preparing to unpack .../5-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_arm64.deb Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ....
    Installed libavahi-compat-libdnssd-dev
    Processing triggers for man-db (2.9.4-2) ...4) ...4_arm64.deb ...led.)
    Installed libudev-dev
    Processing triggers for man-db (2.9.4-2) ...u1+rpt2) ...2_arm64.deb ...
    Installed libpam0g-dev
    Processing triggers for man-db (2.9.4-2) ...11u2_arm64.deb .....lled.)
    Installed git
    Extracting templates from packages: 100%
    Preparing to unpack .../09-libcairo-script-interpreter2_1.16.0-5+rpt1_arm64.deb Preparing to unpack .../29-libpixman-1-dev_0.40.0-1.1~deb11u1+rpt1_arm64.deb .. Setting up libcairo2-dev:arm64 (1.16.0-5+rpt1) ...1+deb11u7) .........
    Installed libcairo2-dev
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) .... ........
    Installed libpango1.0-dev
    Setting up libjpeg-dev:arm64 (1:2.0.6-4) ...6-4) ...4.deb ....deb ...)
    Installed libjpeg-dev
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...lled.)
    Installed libgif-dev
    Preparing to unpack .../0-libgdk-pixbuf2.0-common_2.42.2+dfsg-1+deb11u1_all.deb Preparing to unpack .../2-libgdk-pixbuf-2.0-0_2.42.2+dfsg-1+deb11u1_arm64.deb . Preparing to unpack .../3-gir1.2-gdkpixbuf-2.0_2.42.2+dfsg-1+deb11u1_arm64.deb Preparing to unpack .../6-libgdk-pixbuf2.0-bin_2.42.2+dfsg-1+deb11u1_arm64.deb Preparing to unpack .../7-libgdk-pixbuf-2.0-dev_2.42.2+dfsg-1+deb11u1_arm64.deb Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u1) ...
    Installed librsvg2-dev
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...eb ......
    Installed cmake
    Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
    Installing ioBroker (3/4)
    npm ERR! code ECONNRESET
    npm ERR! syscall read
    npm ERR! errno ECONNRESET
    npm ERR! network Invalid response body while trying to fetch https://registry.np mjs.org/@sentry%2Fcore: read ECONNRESET
    npm ERR! network This is a problem related to network connectivity.
    npm ERR! network In most cases you are behind a proxy or have bad network settin gs.
    npm ERR! network
    npm ERR! network If you are behind a proxy, please make sure that the
    npm ERR! network 'proxy' config is set properly. See: 'npm help config'
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12 -22T20_57_17_197Z-debug-0.log
    Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → / lib/systemd/system/iobroker.service.
    Autostart enabled!
    ioBroker was installed successfully
    Open http://192.168.2.230:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    2023-12-22T20_57_17_197Z-debug-0.log
    2023-12-22T20_54_21_550Z-debug-0.log
    2023-12-22T20_54_20_596Z-debug-0.log
    2023-12-22T20_53_58_221Z-debug-0.log
    • W Willi-Wunder
      library: loaded
      Installed acl
      Installed git
      Installed cmake
      npm ERR! network
      Autostart enabled!
      Marc BergM Online
      Marc BergM Online
      Marc Berg
      @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
      Nein! Doch! Ohhh!
      Ist es der nicht in Code Tags gesetzten Ausgabe zu verdanken, dass da
      (mit Leerzeichen) steht?
      W 1 Antwort Letzte Antwort
      • Marc BergM Marc Berg
        Nein! Doch! Ohhh!
        W Offline
        W Offline
        Willi-Wunder
        @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
        Was willst du mir damit sagen? Verstehe ich gerade nicht.
        • W Willi-Wunder
          Marc BergM Online
          Marc BergM Online
          Marc Berg
          In deinem Ausdruck des Logs
          ist ein Leerzeichen. Ich wollte wissen, ob das im Original auch so ist.
            W Offline
            W Offline
            Willi-Wunder
            schrieb am zuletzt editiert von Willi-Wunder
            @marc-berg
            Das alte Putty Fenster werde ich nicht mehr aufrufen können, oder? Hab ein neues offen.
            Ich habe jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, vielleicht kommt es ja nochmal.
            Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
            • W Willi-Wunder
              @marc-berg
              @willi-wunder
              Dann zieh das Fenster breiter.
              puTTY macht da immer Murks bei Zeilenumbrüchen.
              Ist mit ein Grund, warum ich die Powershell bevorzuge.
              • W Willi-Wunder
                @marc-berg
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                Egal, ich gehe mal davon aus, dass es durch das Reinkopieren verhunzt wurde. Darum immer Text in Code Tags 03025542-0be1-4925-936a-dc88808a313d-grafik.png setzen, dann passiert das nicht.
                Was auffällt, dass die Installation ewig dauert
                npm Completed in 2042874ms
                das sind ja 30min! Vielleicht wird irgendwann ein Timeout erreicht.
                Du könntest als Workaround mal versuchen, IPv4 priorisieren:
                sudo nano /etc/gai.conf
                Dort die Zeile
                #precedence ::ffff:0:0/96  100
                suchen und einkommentieren (# löschen). Danach Datei speichern (Strg+o, <Enter>, Strg+x). Neustart ist normal nicht notwendig. Dann nochmal die Installation versuchen.
                Das ist jetzt aber nur ein Schuss ins Blaue.
                W 2 Antworten Letzte Antwort
                  Dort die Zeile
                  W Offline
                  W Offline
                  Willi-Wunder
                  @marc-berg
                  Werde ich gleich probieren, interssant das beim zweiten Versuch ein anderer Fehler kommt
                  library: loaded
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                  npm ERR! code 24
                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                  npm ERR! command failed
                  npm ERR! command sh -c node iobroker.js setup first
                  npm ERR! creating conf/iobroker.json
                  npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T21_53_43_910Z-debug-0.log
                  Autostart enabled!
                  • W Willi-Wunder
                    @marc-berg
                    library: loaded
                    npm ERR! code 24
                    Autostart enabled!
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    @marc-berg
                    Ich denke mal, das sind Folgefehler. Insofern wäre es wohl ratsam, nochmal bei Null zu beginnen. Und dann die lieben Mitbewohner darum bitten, mal nicht die Internet-Leitung lahmzulegen. :-)
                      @marc-berg
                      W Offline
                      W Offline
                      Willi-Wunder
                      Kann ich ausschließen, Kids schlafen, bin nur ich im Netz, hab 50 Mbit Leitung.
                      Ro75R 1 Antwort Letzte Antwort
                      • W Willi-Wunder
                        Ro75R Online
                        Ro75R Online
                        Ro75
                        @willi-wunder Falls du noch eine andere SD-Karte zur Hand haben solltest, probiere die mal. Das 2 Betriebssysteme das gleiche Problem aufweisen, halte ich für fast unmöglich.
                        Ro75.
                          Dort die Zeile
                          W Offline
                          W Offline
                          Willi-Wunder
                          @marc-berg
                          Du wirst es nicht glauben, jetzt geht es.
                          Dort die Zeile #precedence ::ffff:0:0/96 100
                          "#" löschen.
                          Dann setze ich jetzt aber bookworm auf, macht ja dann Sinn. Gibt es eine Erklärung warum das dann vermutlich nur bei mir so ist?
                          Du bist mein Held. 👍 👍 👍
                          • W Willi-Wunder
                            @marc-berg
                            "#" löschen.
                            @willi-wunder
                            Was hast du denn da für einen Internet-Anbieter?
                              @willi-wunder
                              W Offline
                              W Offline
                              Willi-Wunder
                              Telekom
                              • W Willi-Wunder
                                Telekom
                                @willi-wunder
                                Ich würde sagen, da ist was 'komisch'.
                                IPv6 sollte eigentlich funktionieren.
                                  @willi-wunder
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  • W Willi-Wunder
                                    @willi-wunder
                                    Keine Ahnung was da richtig wäre.
                                    Bei mir (Vodafone Cable 1GBit / DS Lite) steht das alles auf nativem IPv6.
                                    • Marc BergM Online
                                      Marc BergM Online
                                      Marc Berg
                                      #66
                                      @willi-wunder
                                      Bei mir (auch Telekom) steht das auf „natives IPv6 verwenden“. Bin mir aber nicht 100% sicher, was das bewirkt. Im Internet kann man dazu viele Aussagen finden, die irgendwie alle für mich nicht recht schlüssig sind. Probier's einfach aus.
                                      • W Offline
                                        W Offline
                                        Willi-Wunder
                                        #67
                                        @marc-berg
                                        Hat mich jetzt interssiert, hab es nochmal ausprobiert, in der Fritz Box unter IPv6 "natives IPv6" aktiviert, jetzt gings pfiffig durch. Vielen Dank an alle und besonders an dich. Wieder etwas gelernt. Fall gelöst. :-)
                                        Wünsche euche frohe und besinnliche Weihnachten
