  4. File tab_m.html not found
    6.4k
61 Beiträge 13 Kommentatoren 9.0k Aufrufe 9 Beobachtet
  • DJMarc75D DJMarc75
    @int17 zeig mal die Langfassung von
    iob diag
    I Offline
    I Offline
    Int17
    schrieb am zuletzt editiert von Int17
    @djmarc75
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 5.15.0-91-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     10:55:24 up 5 days, 22:43,  2 users,  load average: 0.04, 0.08, 0.04
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Thu 2023-12-14 10:55:24 CET
               Universal time: Thu 2023-12-14 09:55:24 UTC
                     RTC time: Thu 2023-12-14 09:55:24
                    Time zone: Europe/Amsterdam (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    klu
    /home/klu
    klu adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        3.6G        2.3G        1.0M        2.0G        4.1G
    Swap:             0B          0B          0B
    Total:          7.9G        3.6G        2.3G
             7937 M total memory
             3594 M used memory
              771 M active memory
             4492 M inactive memory
             2299 M free memory
              181 M buffer memory
             1861 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  794M  1.1M  793M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    30G  9.7G   19G  35% /
    tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
    tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
    [Fri Dec  8 12:11:39 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Fri Dec  8 12:11:39 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Fri Dec  8 12:11:39 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/2015 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20290 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20092 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    |-/boot             /dev/sda2                         ext4     rw,relatime
    `-/snap/core20/2105 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
    /var:
    3.0G    /var/
    2.2G    /var/log
    2.1G    /var/log/journal/ae98c2ea2f1b47099af7b83f9e96f873
    755M    /var/lib
    Archived and active journals take up 2.0G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    302M    /opt/iobroker/iobroker-data/
    184M    /opt/iobroker/iobroker-data/files
    81M     /opt/iobroker/iobroker-data/backup-objects
    55M     /opt/iobroker/iobroker-data/files/javascript.admin
    36M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c98a13fc.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    14M     /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c98a13fc.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_DNBNt114J20-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            10.2.0
    /usr/bin/npx            10.2.0
    /usr/bin/corepack       0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 100
         12.22.9~dfsg-1ubuntu3.2 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.9
    javascript:     7.4.0
    Adapters from github:   2
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.email.0                  : email                 : iobroker                                 - disabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 2001
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.3               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.4               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.5               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.6               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
      system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : iobroker                                 -  enabled, port: 3493
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.41
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.pushsafer.0              : pushsafer             : iobroker                                 - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.41
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
      system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.12.9   , installed 6.12.9
    Adapter    "backitup"     : 2.9.7    , installed 2.9.7
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
    Adapter    "email"        : 1.2.1    , installed 1.2.1
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.4   , installed 1.13.4
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.4.0    , installed 7.4.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "mbus"         : 2.6.1    , installed 2.6.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.1    , installed 6.2.1
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        11455
    States:         9719
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://repos.influxdata.com/debian jammy InRelease
    Hit:4 https://dl.yarnpkg.com/debian stable InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.41:18701    0.0.0.0:*               LISTEN      1001       3117353    900638/io.hm-rpc.1
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17246      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23584      707/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23782      818/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23775      818/iobroker.js-con
    tcp        0      0 192.168.178.41:8100     0.0.0.0:*               LISTEN      1001       22369      1279/io.doorbird.0
    tcp        0      0 192.168.178.41:12010    0.0.0.0:*               LISTEN      1001       3158551    912164/io.hm-rpc.2
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       3542030    1017403/sshd: klu@p
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21685      658/systemd-resolve
    tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       3117338    900623/io.hm-rpc.0
    tcp        0      0 192.168.178.41:1883     0.0.0.0:*               LISTEN      1001       24069      1196/io.mqtt.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13298      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          23586      707/sshd: /usr/sbin
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       3542029    1017403/sshd: klu@p
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        23792      817/grafana
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       28137      1841/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      114        23652      710/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3114994    900407/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28682      1826/io.web.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21684      658/systemd-resolve
    udp        0      0 192.168.178.41:68       0.0.0.0:*                           101        2937171    656/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17247      1/init
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21482      1166/io.shelly.0
    udp        0      0 0.0.0.0:42946           0.0.0.0:*                           1001       3536157    1166/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          17248      1/init
    udp6       0      0 fe80::6861:5dff:fee:546 :::*                                101        23202      656/systemd-network
    2023-12-14 10:42:44.498  - info: javascript.0 (186252) Start javascript script.js.common.Wartung.USV_Check
    2023-12-14 10:42:44.505  - info: javascript.0 (186252) script.js.common.Wartung.USV_Check: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-12-14 10:44:00.019  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1012205
    2023-12-14 10:44:01.034  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:45:00.018  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1012241
    2023-12-14 10:45:02.337  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-14 10:45:11.885  - info: javascript.1 (186259) Stop script script.js.common.Mitteilungen.Abfalltonne
    2023-12-14 10:45:11.886  - info: javascript.0 (186252) Stop script script.js.common.Mitteilungen.Abfalltonne
    2023-12-14 10:45:11.931  - info: javascript.0 (186252) Start javascript script.js.common.Mitteilungen.Abfalltonne
    2023-12-14 10:45:11.935  - info: javascript.0 (186252) script.js.common.Mitteilungen.Abfalltonne: Debug: true
    2023-12-14 10:45:11.935  - info: javascript.0 (186252) script.js.common.Mitteilungen.Abfalltonne: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-12-14 10:46:00.016  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1012446
    2023-12-14 10:46:01.036  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:48:00.015  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1014104
    2023-12-14 10:48:01.077  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:50:00.015  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1014499
    2023-12-14 10:50:01.032  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:50:04.027  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1014535
    2023-12-14 10:50:05.172  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-14 10:52:00.016  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1015525
    2023-12-14 10:52:00.990  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:54:00.018  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1016719
    2023-12-14 10:54:01.033  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-12-14 10:55:00.020  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1017114
    2023-12-14 10:55:01.223  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    Press any key for a summary
                            v.2023-10-10
             Chassis: vm
      Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Amsterdam (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            10.2.0
                            /usr/bin/npx            10.2.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            7.9G        3.6G        2.3G        1.0M        2.0G        4.0G
    Swap:             0B          0B          0B
    Active iob-Instances:   29
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.9
    Objects type: jsonl
    States  type: jsonl
    Objects:                11455
    States:                 9719
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/states.jsonl
      @int17
      iob nodejs-update
      Das ist nämlich zu 100% falsch installiert.
      I Offline
      I Offline
      Int17
      klu@iobroker:~$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
      --help Show help [boolean]
      • I Int17
        Options:
        @int17
        iob stop
        iob fix
        Danach dürfte
        iob nodejs-update
        dann funktionieren.
        I 1 Antwort Letzte Antwort
          @int17
          iob stop
          iob fix
          Danach dürfte
          iob nodejs-update
          dann funktionieren.
          I Offline
          I Offline
          Int17
          ioBroker nodejs fixer 2023-10-13
          Recommended nodejs-version is: 18.19.0
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/npm            10.2.0
          /usr/bin/npx            10.2.0
          We found these nodejs versions available for installation:
          nodejs:
            Version table:
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.17.1. Do you want to install recommended version 18.19.0?
          Press <y> to continue or any other key to quit
          Trying to update your installation now. Please be patient.
          Virtualization: kvm
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:5 https://dl.yarnpkg.com/debian stable InRelease
          Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Hit:7 https://apt.grafana.com stable InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:1 https://apt.grafana.com stable InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:9 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6451 B]
          Fetched 18.6 kB in 0s (42.1 kB/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          (Reading database ... 134957 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.19.0-1nodesource1_amd64.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.19.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
          Setting up nodejs (18.19.0-1nodesource1) ...
          Processing triggers for man-db (2.10.2-1) ...
          Scanning processes...
          Scanning linux images...
          Running kernel seems to be up-to-date.
          No services need to be restarted.
          No containers need to be restarted.
          No user sessions are running outdated binaries.
          No VM guests are running outdated hypervisor (qemu) binaries on this host.
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
          klu@iobroker:~$
          Habe danach text2command deinstalliert/installiert. Fehler bleibt.
          • I Int17
            /usr/bin/npm            10.2.0
            /usr/bin/npx            10.2.0
            nodejs:
              Version table:
            Virtualization: kvm
            Package: nodejs
            Pin-Priority: 1001
            klu@iobroker:~$
            @int17
            Hast du den Container jetzt neugestartet?
            Ist nodejs jetzt aktuell?
            Dann
            iob upload all
            ausführen.
              @int17
              Dann
              iob upload all
              ausführen.
              I Offline
              I Offline
              Int17
              ja, es wird keine neuere Version angezeigt.
              Was für einen Container meinst du? Ich habe keine Docker Installation.
              iobroker wurde natürlich neu gestartet, da ich ihn ja gestoppt hatte.
              Danach text2command deinstalliert/installiert.
              Log vom upload all:
              upload all.txt
              • I Int17
                Log vom upload all:
                upload all.txt
                @int17 sagte in File tab_m.html not found:
                Nee, aber eine kvm-Installation.
                  I Offline
                  I Offline
                  Int17
                  die VM habe ich neu gestartet. Dann noch mal iob upload all. Fehler bleibt.
                  • I Int17
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @int17
                    Also die Datei tab_m.html gibt es nicht. Es existiert nur die Datei tab.html.
                    Mach mal ein Issue beim Adapter auf.
                    Und bitte gib ALLE relevanten Versionen an
                    Adapter: 3.0.2
                    Admin
                    js-controller
                    node
                    Könnte sein, dass sich da was am admin geändert hat.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      @int17
                      Adapter: 3.0.2
                      Admin
                      js-controller
                      node
                      I Offline
                      I Offline
                      Int17
                      @mcm57
                      Hört sich nach einem Plan an. Danke für den Tipp.
                      • I Int17
                        @mcm57
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @int17
                        Bitte Release 3.0.3 testen. Ist ab sofort via npm und ab spätestens morgen via LATEST Repository verfügbar.
                        (Note: Dank für Korrektur geht an @Bluefox !)
                        Ref: https://github.com/ioBroker/ioBroker.text2command/issues/299
                        • PeterLeP Offline
                          PeterLeP Offline
                          PeterLe
                          schrieb am zuletzt editiert von PeterLe
                          bei mir kommt nun auch der Fehler "File tab_m.html not found" hoch.
                          Was war denn nun die Lösung?
                          (iobroker gerade erst frisch installiert und Backup eingespielt)
                          Peter
                          • PeterLeP PeterLe
                            Peter
                            @peterle sagte in File tab_m.html not found:
                            restore noch nicht fertig!???
                            nicht diesen Vorgang durch irgendwelche Aktionen stören.
                            PeterLeP 1 Antwort Letzte Antwort
                              PeterLeP Offline
                              PeterLeP Offline
                              PeterLe
                              ich hab den restore mit dem Adapter "backitup" gemacht und gewartet bis die Meldung kam, das der Vorgang abgeschlossen ist,
                              dann erst weiter gemacht.
                              Die anderen Adapter funktionieren alle.
                              W HomoranH 2 Antworten Letzte Antwort
                              • PeterLeP PeterLe
                                W Offline
                                W Offline
                                Wildbill
                                @peterle Wenn die Meldung kommt, fängt der restore erst mit der eigentlichen Arbeit an. Es werden nach und nach alle Adapter, die benötigt werden, installiert. Kann auch mal bis zu einer Stunde dauern und sollte nicht gestört werden, indem man da bereits manuell eingreift, oder ein System bedienen will, was erst gerade im Aufbau ist.
                                Gruss, Jürgen
                                • PeterLeP PeterLe
                                  dann war zwat backitup mit seiner Arbeit die gesicherten Konfigurationen wiederherzustellen fertig, aber das System noch lange nicht.
                                  Danach werden alle Adapter neu gebaut.
                                  Das kann man mit iob logs --watch verfolgen oder im Admin zusehen, wie weitestgrhrnd alphabetisch die Instanzen ihre Icons erhalten.
                                  Etwas anderes sollte nicht gemacht werden, da es sonst zu einem inconsistenten System komnen kann.
                                    PeterLeP Offline
                                    PeterLeP Offline
                                    PeterLe
                                    Danke für die Info
                                    Dann muss ich den Restore wohl nochmal machen... Schade ...
                                    Es wäre vermutlich gut die Meldung des backitup Adapters entsprechend anzupassen
                                    (zB "Restore gestartet und läuft im Hintergrund. Fortschritt kann in der Konsole per <iob logs --watch> geprüft werden")
                                    • PeterLeP PeterLe
                                      Danke für die Info
                                      naja, backitup hat ja das was es gesichert hat vollständig wieder hergestellt.
                                      Also stimmt die Meldung.
                                      Der Rest ist ein neuer Build passend zur möglicherweise neuen Hardware, neuem Betriebssystem und neuem nodejs und hat mit backitup nichts zu tun.
                                      • PeterLeP Offline
                                        PeterLeP Offline
                                        PeterLe
                                        @Homoran
                                        nach einigen Versuchen habe ich am Ende nun den Raspi komplett neu aufgesetzt,
                                        iobroker neu installiert und das Backup über "backitup" angestossen.
                                        Dann das System in Ruhe gelassen bis im Log keine Aktivitäten mehr geloggt wurden,
                                        dann sicherheitshalber noch zusätzlich 1 Stunde nix gemacht
                                        (gem. Unix "top" war das System mit 1% ausgelastet - da lief aus meiner Sicht kein Compiler o.ä. mehr)
                                        Ergebnis ist das gleich:
                                        Beim Klicken auf den Punkt "Info" im Menü kommt die Meldung "File tab_m.html not found".
                                        Was mich auch wundert ist das nach Neuinstallation des iobroker (also VOR Einspielen des Backups)
                                        der Menüpunkt "Info" gar nicht existiert hat.
                                        D.h. der muss erst durch den Restore reingekommen sein.
                                        Einen eigenen Adapter "Info" hab' ich nicht gefunden - durch welchen Adapter wird der Menüpunkt "Info" denn installiert?
                                        Danke!
                                        • PeterLeP PeterLe
                                          @Homoran
                                          Danke!
                                          Wo meinst du genau?
                                          Zeig mal die Langfassung von
                                          iob diag
