File tab_m.html not found
Nach der Installation von Text2Command (3.0.2) bekomme nach Selektion von Kommandos
Zudem fehlt der Schraubenschlüssel in der Instanz.
Löschen/Neu installieren brachte nichts.
klu@iobroker:~$ cd /opt/iobroker klu@iobroker:/opt/iobroker$ iobroker update -i Used repository: beta Adapter "admin" : 6.12.9 , installed 6.12.9 Adapter "backitup" : 2.9.7 , installed 2.9.7 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "doorbird" : 1.3.0 , installed 1.3.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.2.1 , installed 1.2.1 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.15.19 , installed 1.15.19 Adapter "ical" : 1.13.4 , installed 1.13.4 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "javascript" : 7.4.0 , installed 7.4.0 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "logparser" : 2.2.0 , installed 2.2.0 Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "mbus" : 2.6.1 , installed 2.6.1 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "pushsafer" : 1.0.3 , installed 1.0.3 Adapter "pvforecast" : 2.9.0 , installed 2.9.0 Adapter "sainlogic" : 0.10.5 , installed 0.10.5 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.6.3 , installed 1.6.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.1.1 , installed 0.1.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.2.1 , installed 6.2.1 Adapter "wolf-smartset": 1.1.1 , installed 1.1.1 Adapter "ws" : 2.5.8 , installed 2.5.8 klu@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: failed to create symbolic link '/usr/bin/nodejs': File exists klu@iobroker:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs x86_64 /usr/bin/nodejs /usr/bin/node /usr/bin/npm v18.17.1 v18.17.1 10.2.0 klu /opt/iobroker OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease OK:2 https://apt.grafana.com stable InRelease OK:3 https://repos.influxdata.com/debian jammy InRelease OK:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease OK:5 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease OK:6 https://dl.yarnpkg.com/debian stable InRelease OK:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Aktualisierung für 6 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paketaktualisierung (Upgrade) wird berechnet… Fertig Die folgenden Pakete sind zurückgehalten worden: cryptsetup cryptsetup-bin cryptsetup-initramfs libcryptsetup12 python3-update-manager update-manager-core 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 6 nicht aktualisiert. nodejs: Installiert: 18.17.1-deb-1nodesource1 Installationskandidat: 18.17.1-deb-1nodesource1 Versionstabelle: *** 18.17.1-deb-1nodesource1 100 100 /var/lib/dpkg/status 12.22.9~dfsg-1ubuntu3.2 500 500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 PackagesSystemdata Bitte Ausfüllen Hardwaresystem: NUC Arbeitsspeicher: 32GB Festplattenart: SSD Betriebssystem: Ubuntu Node-Version: 10.2.0 Nodejs-Version: 18.17.1 NPM-Version: 18.17.1 Installationsart: Skript Image genutzt: Nein Ort/Name der Imagedatei: Link -
======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 5.15.0-91-generic Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 10:55:24 up 5 days, 22:43, 2 users, load average: 0.04, 0.08, 0.04 CPU threads: 4 *** Time and Time Zones *** Local time: Thu 2023-12-14 10:55:24 CET Universal time: Thu 2023-12-14 09:55:24 UTC RTC time: Thu 2023-12-14 09:55:24 Time zone: Europe/Amsterdam (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** klu /home/klu klu adm cdrom sudo dip plugdev lxd iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 3.6G 2.3G 1.0M 2.0G 4.1G Swap: 0B 0B 0B Total: 7.9G 3.6G 2.3G 7937 M total memory 3594 M used memory 771 M active memory 4492 M inactive memory 2299 M free memory 181 M buffer memory 1861 M swap cache 0 M total swap 0 M used swap 0 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 794M 1.1M 793M 1% /run /dev/mapper/ubuntu--vg-ubuntu--lv ext4 30G 9.7G 19G 35% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda2 ext4 2.0G 251M 1.6G 14% /boot tmpfs tmpfs 794M 4.0K 794M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Dec 8 12:11:39 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Fri Dec 8 12:11:39 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none. [Fri Dec 8 12:11:39 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core20/2015 /dev/loop1 squashfs ro,nodev,relatime,errors=continue |-/snap/lxd/24322 /dev/loop2 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/20290 /dev/loop3 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/20092 /dev/loop4 squashfs ro,nodev,relatime,errors=continue |-/boot /dev/sda2 ext4 rw,relatime `-/snap/core20/2105 /dev/loop5 squashfs ro,nodev,relatime,errors=continue Files in neuralgic directories: /var: 3.0G /var/ 2.2G /var/log 2.1G /var/log/journal/ae98c2ea2f1b47099af7b83f9e96f873 2.1G /var/log/journal 755M /var/lib Archived and active journals take up 2.0G in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 302M /opt/iobroker/iobroker-data/ 184M /opt/iobroker/iobroker-data/files 81M /opt/iobroker/iobroker-data/backup-objects 55M /opt/iobroker/iobroker-data/files/javascript.admin 36M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/objects.jsonl 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c98a13fc.js.map 18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map 14M /opt/iobroker/iobroker-data/states.jsonl 8.2M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c98a13fc.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_DNBNt114J20-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 10.2.0 /usr/bin/npx 10.2.0 /usr/bin/corepack 0.18.0 nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 100 100 /var/lib/dpkg/status 12.22.9~dfsg-1ubuntu3.2 500 500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.9 javascript: 7.4.0 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.discovery.0 : discovery : iobroker - enabled + system.adapter.doorbird.0 : doorbird : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled system.adapter.email.0 : email : iobroker - disabled system.adapter.energiefluss.0 : energiefluss : iobroker - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - disabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 2001 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 18701 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 12010 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.influxdb.0 : influxdb : iobroker - disabled, port: 8086 system.adapter.influxdb.1 : influxdb : iobroker - disabled, port: 8086 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.5 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.6 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.javascript.1 : javascript : iobroker - enabled system.adapter.logparser.0 : logparser : iobroker - disabled system.adapter.luftdaten.0 : luftdaten : iobroker - enabled + system.adapter.mbus.0 : mbus : iobroker - enabled, port: 3493 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.41 + system.adapter.nut.0 : nut : iobroker - enabled system.adapter.pushsafer.0 : pushsafer : iobroker - disabled + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled + system.adapter.sayit.0 : sayit : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 192.168.178.41 system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - disabled system.adapter.smartthings.0 : smartthings : iobroker - disabled system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - disabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : iobroker - disabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wolf-smartset.0 : wolf-smartset : iobroker - enabled + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 2001 + system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 18701 + system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 12010 + system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.3 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.4 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.5 : influxdb : iobroker - enabled, port: 8086 + system.adapter.influxdb.6 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mbus.0 : mbus : iobroker - enabled, port: 3493 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 192.168.178.41 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 192.168.178.41 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): beta Installed ioBroker-Instances Used repository: beta Adapter "admin" : 6.12.9 , installed 6.12.9 Adapter "backitup" : 2.9.7 , installed 2.9.7 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "doorbird" : 1.3.0 , installed 1.3.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.2.1 , installed 1.2.1 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.15.19 , installed 1.15.19 Adapter "ical" : 1.13.4 , installed 1.13.4 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "javascript" : 7.4.0 , installed 7.4.0 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "logparser" : 2.2.0 , installed 2.2.0 Adapter "luftdaten" : 3.1.0 , installed 3.1.0 Adapter "mbus" : 2.6.1 , installed 2.6.1 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "pushsafer" : 1.0.3 , installed 1.0.3 Adapter "pvforecast" : 2.9.0 , installed 2.9.0 Adapter "sainlogic" : 0.10.5 , installed 0.10.5 Adapter "sayit" : 3.0.5 , installed 3.0.5 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.6.3 , installed 1.6.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.1.1 , installed 0.1.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.2.1 , installed 6.2.1 Adapter "wolf-smartset": 1.1.1 , installed 1.1.1 Adapter "ws" : 2.5.8 , installed 2.5.8 Objects and States Please stand by - This may take a while Objects: 11455 States: 9719 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:3 https://repos.influxdata.com/debian jammy InRelease Hit:4 https://dl.yarnpkg.com/debian stable InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 192.168.178.41:18701 0.0.0.0:* LISTEN 1001 3117353 900638/io.hm-rpc.1 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17246 1/init tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 23584 707/sshd: /usr/sbin tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 23782 818/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 23775 818/iobroker.js-con tcp 0 0 192.168.178.41:8100 0.0.0.0:* LISTEN 1001 22369 1279/io.doorbird.0 tcp 0 0 192.168.178.41:12010 0.0.0.0:* LISTEN 1001 3158551 912164/io.hm-rpc.2 tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 1000 3542030 1017403/sshd: klu@p tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 21685 658/systemd-resolve tcp 0 0 192.168.178.41:2001 0.0.0.0:* LISTEN 1001 3117338 900623/io.hm-rpc.0 tcp 0 0 192.168.178.41:1883 0.0.0.0:* LISTEN 1001 24069 1196/io.mqtt.0 tcp6 0 0 :::111 :::* LISTEN 0 13298 1/init tcp6 0 0 :::22 :::* LISTEN 0 23586 707/sshd: /usr/sbin tcp6 0 0 ::1:6010 :::* LISTEN 1000 3542029 1017403/sshd: klu@p tcp6 0 0 :::3000 :::* LISTEN 117 23792 817/grafana tcp6 0 0 :::8084 :::* LISTEN 1001 28137 1841/io.ws.0 tcp6 0 0 :::8086 :::* LISTEN 114 23652 710/influxd tcp6 0 0 :::8081 :::* LISTEN 1001 3114994 900407/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 28682 1826/io.web.0 udp 0 0 127.0.0.53:53 0.0.0.0:* 102 21684 658/systemd-resolve udp 0 0 192.168.178.41:68 0.0.0.0:* 101 2937171 656/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17247 1/init udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 21482 1166/io.shelly.0 udp 0 0 0.0.0.0:42946 0.0.0.0:* 1001 3536157 1166/io.shelly.0 udp6 0 0 :::111 :::* 0 17248 1/init udp6 0 0 fe80::6861:5dff:fee:546 :::* 101 23202 656/systemd-network *** Log File - Last 25 Lines *** 2023-12-14 10:42:44.498 - info: javascript.0 (186252) Start javascript script.js.common.Wartung.USV_Check 2023-12-14 10:42:44.505 - info: javascript.0 (186252) script.js.common.Wartung.USV_Check: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2023-12-14 10:44:00.019 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1012205 2023-12-14 10:44:01.034 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:45:00.018 - info: host.iobroker instance system.adapter.dwd.0 started with pid 1012241 2023-12-14 10:45:02.337 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-12-14 10:45:11.885 - info: javascript.1 (186259) Stop script script.js.common.Mitteilungen.Abfalltonne 2023-12-14 10:45:11.886 - info: javascript.0 (186252) Stop script script.js.common.Mitteilungen.Abfalltonne 2023-12-14 10:45:11.931 - info: javascript.0 (186252) Start javascript script.js.common.Mitteilungen.Abfalltonne 2023-12-14 10:45:11.935 - info: javascript.0 (186252) script.js.common.Mitteilungen.Abfalltonne: Debug: true 2023-12-14 10:45:11.935 - info: javascript.0 (186252) script.js.common.Mitteilungen.Abfalltonne: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2023-12-14 10:46:00.016 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1012446 2023-12-14 10:46:01.036 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:48:00.015 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1014104 2023-12-14 10:48:01.077 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:50:00.015 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1014499 2023-12-14 10:50:01.032 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:50:04.027 - info: host.iobroker instance system.adapter.dwd.0 started with pid 1014535 2023-12-14 10:50:05.172 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-12-14 10:52:00.016 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1015525 2023-12-14 10:52:00.990 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:54:00.018 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 1016719 2023-12-14 10:54:01.033 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR) 2023-12-14 10:55:00.020 - info: host.iobroker instance system.adapter.dwd.0 started with pid 1017114 2023-12-14 10:55:01.223 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) ============ Mark until here for C&P ============= iob diag has finished. Press any key for a summary ======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 5.15.0-91-generic Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Installation: kvm Kernel: x86_64 Userland: amd64 Timezone: Europe/Amsterdam (CET, +0100) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 10.2.0 /usr/bin/npx 10.2.0 /usr/bin/corepack 0.18.0 Recommended versions are nodejs 18.19.0 and npm 10.2.3 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.9G 3.6G 2.3G 1.0M 2.0G 4.0G Swap: 0B 0B 0B Total: 7.9G 3.6G 2.3G Active iob-Instances: 29 Active repo(s): beta ioBroker Core: js-controller 5.0.17 admin 6.12.9 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 11455 States: 9719 Size of iob-Database: 24M /opt/iobroker/iobroker-data/objects.jsonl 15M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== -
klu@iobroker:~$ iob nodejs-update
iobroker nodejs-update [<major-version>]Upgrade the Node.JS installation to the current LTS
Options:
--help Show help [boolean] -
Options:
ioBroker nodejs fixer 2023-10-13 Recommended nodejs-version is: 18.19.0 Checking your installation now. Please be patient! Your current setup is: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 10.2.0 /usr/bin/npx 10.2.0 /usr/bin/corepack 0.18.0 We found these nodejs versions available for installation: nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 100 100 /var/lib/dpkg/status 12.22.9~dfsg-1ubuntu3.2 500 500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Nothing to do - Your installation is using the correct paths. You are running nodejs v18.17.1. Do you want to install recommended version 18.19.0? Press <y> to continue or any other key to quit Trying to update your installation now. Please be patient. Virtualization: kvm Waiting for ioBroker to shut down - Give me a minute... ############################################################ *** These repos are active on your system: Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:3 https://repos.influxdata.com/debian jammy InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:5 https://dl.yarnpkg.com/debian stable InRelease Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease Hit:7 https://apt.grafana.com stable InRelease Reading package lists... Done *** Installing ca-certificates, curl and gnupg, just in case they are missing. *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main Package: nodejs Pin: origin deb.nodesource.com Pin-Priority: 1001 *** These repos are active after the adjustments: Hit:1 https://apt.grafana.com stable InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease Hit:3 https://repos.influxdata.com/debian jammy InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:5 https://dl.yarnpkg.com/debian stable InRelease Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB] Get:9 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6451 B] Fetched 18.6 kB in 0s (42.1 kB/s) Reading package lists... Done Installing the recommended nodejs version now! Installing the recommended nodejs version! (Reading database ... 134957 files and directories currently installed.) Preparing to unpack .../nodejs_18.19.0-1nodesource1_amd64.deb ... Detected old npm client, removing... Unpacking nodejs (18.19.0-1nodesource1) over (18.17.1-deb-1nodesource1) ... Setting up nodejs (18.19.0-1nodesource1) ... Processing triggers for man-db (2.10.2-1) ... Scanning processes... Scanning linux images... Running kernel seems to be up-to-date. No services need to be restarted. No containers need to be restarted. No user sessions are running outdated binaries. No VM guests are running outdated hypervisor (qemu) binaries on this host. *** You need to manually restart your container/virtual machine now! *** We tried our best to fix your nodejs. Please run 'iob diag' again to verify. klu@iobroker:~$Habe danach text2command deinstalliert/installiert. Fehler bleibt.
Hast du den Container jetzt neugestartet?
Ist nodejs jetzt aktuell?Dann
iob upload allausführen.
ja, es wird keine neuere Version angezeigt.
Was für einen Container meinst du? Ich habe keine Docker Installation.
iobroker wurde natürlich neu gestartet, da ich ihn ja gestoppt hatte.
Danach text2command deinstalliert/installiert.
Log vom upload all:
upload all.txt -
Log vom upload all:
upload all.txt@int17 sagte in File tab_m.html not found:
Nee, aber eine kvm-Installation.
die VM habe ich neu gestartet. Dann noch mal iob upload all. Fehler bleibt. -
die VM habe ich neu gestartet. Dann noch mal iob upload all. Fehler bleibt.Also die Datei tab_m.html gibt es nicht. Es existiert nur die Datei tab.html.
Mach mal ein Issue beim Adapter auf.
Und bitte gib ALLE relevanten Versionen an
Adapter: 3.0.2
Admin
js-controller
nodeKönnte sein, dass sich da was am admin geändert hat.
Adapter: 3.0.2
Admin
js-controller
@int17
Bitte Release 3.0.3 testen. Ist ab sofort via npm und ab spätestens morgen via LATEST Repository verfügbar.(Note: Dank für Korrektur geht an @Bluefox !)
Ref: https://github.com/ioBroker/ioBroker.text2command/issues/299
bei mir kommt nun auch der Fehler "File tab_m.html not found" hoch.
Was war denn nun die Lösung?
(iobroker gerade erst frisch installiert und Backup eingespielt)
Peter@peterle sagte in File tab_m.html not found:
(iobroker gerade erst frisch installiert und Backup eingespielt)restore noch nicht fertig!???
nicht diesen Vorgang durch irgendwelche Aktionen stören. -
ich hab den restore mit dem Adapter "backitup" gemacht und gewartet bis die Meldung kam, das der Vorgang abgeschlossen ist,
dann erst weiter gemacht.
Die anderen Adapter funktionieren alle.@peterle Wenn die Meldung kommt, fängt der restore erst mit der eigentlichen Arbeit an. Es werden nach und nach alle Adapter, die benötigt werden, installiert. Kann auch mal bis zu einer Stunde dauern und sollte nicht gestört werden, indem man da bereits manuell eingreift, oder ein System bedienen will, was erst gerade im Aufbau ist.
Gruss, Jürgen
Die anderen Adapter funktionieren alle.@peterle sagte in File tab_m.html not found:
dann war zwat backitup mit seiner Arbeit die gesicherten Konfigurationen wiederherzustellen fertig, aber das System noch lange nicht.
Danach werden alle Adapter neu gebaut.
Das kann man mitiob logs --watchverfolgen oder im Admin zusehen, wie weitestgrhrnd alphabetisch die Instanzen ihre Icons erhalten.Etwas anderes sollte nicht gemacht werden, da es sonst zu einem inconsistenten System komnen kann.
Danke für die Info
Dann muss ich den Restore wohl nochmal machen... Schade ...
Es wäre vermutlich gut die Meldung des backitup Adapters entsprechend anzupassen
(zB "Restore gestartet und läuft im Hintergrund. Fortschritt kann in der Konsole per <iob logs --watch> geprüft werden")
