  4. File tab_m.html not found
    6.4k
61 Beiträge 13 Kommentatoren 9.0k Aufrufe 9 Beobachtet
  • I Int17
    ioBroker nodejs fixer 2023-10-13
    Recommended nodejs-version is: 18.19.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            10.2.0
    /usr/bin/npx            10.2.0
    /usr/bin/corepack       0.18.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 100
         12.22.9~dfsg-1ubuntu3.2 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.17.1. Do you want to install recommended version 18.19.0?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    Virtualization: kvm
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://repos.influxdata.com/debian jammy InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 https://dl.yarnpkg.com/debian stable InRelease
    Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:7 https://apt.grafana.com stable InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 https://apt.grafana.com stable InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:9 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6451 B]
    Fetched 18.6 kB in 0s (42.1 kB/s)
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    (Reading database ... 134957 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.19.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.19.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
    Setting up nodejs (18.19.0-1nodesource1) ...
    Processing triggers for man-db (2.10.2-1) ...
    Scanning processes...
    Scanning linux images...
    Running kernel seems to be up-to-date.
    No services need to be restarted.
    No containers need to be restarted.
    No user sessions are running outdated binaries.
    No VM guests are running outdated hypervisor (qemu) binaries on this host.
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    klu@iobroker:~$
    Habe danach text2command deinstalliert/installiert. Fehler bleibt.
    @int17
    Hast du den Container jetzt neugestartet?
    Ist nodejs jetzt aktuell?
    Dann
    iob upload all
    ausführen.
    I 1 Antwort Letzte Antwort
      @int17
      Dann
      iob upload all
      ausführen.
      I Offline
      I Offline
      Int17
      ja, es wird keine neuere Version angezeigt.
      Was für einen Container meinst du? Ich habe keine Docker Installation.
      iobroker wurde natürlich neu gestartet, da ich ihn ja gestoppt hatte.
      Danach text2command deinstalliert/installiert.
      Log vom upload all:
      upload all.txt
      • I Int17
        Log vom upload all:
        upload all.txt
        @int17 sagte in File tab_m.html not found:
        Nee, aber eine kvm-Installation.
          I Offline
          I Offline
          Int17
          schrieb am zuletzt editiert von Int17
          die VM habe ich neu gestartet. Dann noch mal iob upload all. Fehler bleibt.
          • I Int17
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @int17
            Also die Datei tab_m.html gibt es nicht. Es existiert nur die Datei tab.html.
            Mach mal ein Issue beim Adapter auf.
            Und bitte gib ALLE relevanten Versionen an
            Adapter: 3.0.2
            Admin
            js-controller
            node
            Könnte sein, dass sich da was am admin geändert hat.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • mcm1957M mcm1957
              @int17
              Adapter: 3.0.2
              Admin
              js-controller
              node
              I Offline
              I Offline
              Int17
              @mcm57
              Hört sich nach einem Plan an. Danke für den Tipp.
              • I Int17
                @mcm57
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @int17
                Bitte Release 3.0.3 testen. Ist ab sofort via npm und ab spätestens morgen via LATEST Repository verfügbar.
                (Note: Dank für Korrektur geht an @Bluefox !)
                Ref: https://github.com/ioBroker/ioBroker.text2command/issues/299
                • PeterLeP Offline
                  PeterLeP Offline
                  PeterLe
                  schrieb am zuletzt editiert von PeterLe
                  bei mir kommt nun auch der Fehler "File tab_m.html not found" hoch.
                  Was war denn nun die Lösung?
                  (iobroker gerade erst frisch installiert und Backup eingespielt)
                  Peter
                  • PeterLeP PeterLe
                    Peter
                    @peterle sagte in File tab_m.html not found:
                    restore noch nicht fertig!???
                    nicht diesen Vorgang durch irgendwelche Aktionen stören.
                    PeterLeP 1 Antwort Letzte Antwort
                      PeterLeP Offline
                      PeterLeP Offline
                      PeterLe
                      ich hab den restore mit dem Adapter "backitup" gemacht und gewartet bis die Meldung kam, das der Vorgang abgeschlossen ist,
                      dann erst weiter gemacht.
                      Die anderen Adapter funktionieren alle.
                      W HomoranH 2 Antworten Letzte Antwort
                      • PeterLeP PeterLe
                        W Online
                        W Online
                        Wildbill
                        @peterle Wenn die Meldung kommt, fängt der restore erst mit der eigentlichen Arbeit an. Es werden nach und nach alle Adapter, die benötigt werden, installiert. Kann auch mal bis zu einer Stunde dauern und sollte nicht gestört werden, indem man da bereits manuell eingreift, oder ein System bedienen will, was erst gerade im Aufbau ist.
                        Gruss, Jürgen
                        • PeterLeP PeterLe
                          dann war zwat backitup mit seiner Arbeit die gesicherten Konfigurationen wiederherzustellen fertig, aber das System noch lange nicht.
                          Danach werden alle Adapter neu gebaut.
                          Das kann man mit iob logs --watch verfolgen oder im Admin zusehen, wie weitestgrhrnd alphabetisch die Instanzen ihre Icons erhalten.
                          Etwas anderes sollte nicht gemacht werden, da es sonst zu einem inconsistenten System komnen kann.
                            PeterLeP Offline
                            PeterLeP Offline
                            PeterLe
                            Danke für die Info
                            Dann muss ich den Restore wohl nochmal machen... Schade ...
                            Es wäre vermutlich gut die Meldung des backitup Adapters entsprechend anzupassen
                            (zB "Restore gestartet und läuft im Hintergrund. Fortschritt kann in der Konsole per <iob logs --watch> geprüft werden")
                            • PeterLeP PeterLe
                              Danke für die Info
                              naja, backitup hat ja das was es gesichert hat vollständig wieder hergestellt.
                              Also stimmt die Meldung.
                              Der Rest ist ein neuer Build passend zur möglicherweise neuen Hardware, neuem Betriebssystem und neuem nodejs und hat mit backitup nichts zu tun.
                              • PeterLeP Offline
                                PeterLeP Offline
                                PeterLe
                                @Homoran
                                nach einigen Versuchen habe ich am Ende nun den Raspi komplett neu aufgesetzt,
                                iobroker neu installiert und das Backup über "backitup" angestossen.
                                Dann das System in Ruhe gelassen bis im Log keine Aktivitäten mehr geloggt wurden,
                                dann sicherheitshalber noch zusätzlich 1 Stunde nix gemacht
                                (gem. Unix "top" war das System mit 1% ausgelastet - da lief aus meiner Sicht kein Compiler o.ä. mehr)
                                Ergebnis ist das gleich:
                                Beim Klicken auf den Punkt "Info" im Menü kommt die Meldung "File tab_m.html not found".
                                Was mich auch wundert ist das nach Neuinstallation des iobroker (also VOR Einspielen des Backups)
                                der Menüpunkt "Info" gar nicht existiert hat.
                                D.h. der muss erst durch den Restore reingekommen sein.
                                Einen eigenen Adapter "Info" hab' ich nicht gefunden - durch welchen Adapter wird der Menüpunkt "Info" denn installiert?
                                Danke!
                                • PeterLeP PeterLe
                                  @Homoran
                                  Danke!
                                  Wo meinst du genau?
                                  Zeig mal die Langfassung von
                                  iob diag
                                  • PeterLeP PeterLe
                                    @Homoran
                                    Danke!
                                    info ist in diesem Fall ein Sonderfall, weil es den nicht mehr im offiziellen Repo gibt, und er somit nicht wieder installiert werden konnte.
                                    dann ist die Meldung auch "normal"
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @homoran said in File tab_m.html not found:
                                      Info kommt vom infoadapter. Wenn das Restore den teilweisecreinstalliert hat lösch bitte den Adapter info. Dieser wurde beerdigt.
                                        Wo meinst du genau?
                                        iob diag
                                        PeterLeP Offline
                                        PeterLeP Offline
                                        PeterLe
                                        du meinst nicht die Summary sondern in lang...
                                        (btw. wohl auch ein Fehler im "hm-rpc" Adapter - muss ich auch schauen)
                                        Danke für's "schauen" ...
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                         Static hostname: Raspberry4
                                               Icon name: computer
                                                  Kernel: Linux 6.6.31+rpt-rpi-v8
                                            Architecture: arm64
                                        Model           : Raspberry Pi 4 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         07:21:13 up 1 day, 21:38,  2 users,  load average: 1.15, 0.92, 0.57
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Mon 2024-06-17 07:21:14 CEST
                                                   Universal time: Mon 2024-06-17 05:21:14 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        <hidden>
                                        HOME=/home/<hidden>
                                        GROUPS=<hidden> adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        *** Display-Server-Setup ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            4.0G        1.5G        1.0G        1.2M        1.5G        2.4G
                                        Swap:           209M          0B        209M
                                        Total:          4.2G        1.5G        1.2G
                                        Active iob-Instances:   17
                                                 3792 M total memory
                                                 1470 M used memory
                                                 1461 M active memory
                                                 1207 M inactive memory
                                                  961 M free memory
                                                  114 M buffer memory
                                                 1321 M swap cache
                                                  199 M total swap
                                                    0 M used swap
                                                  199 M free swap
                                        top - 07:21:14 up 1 day, 21:38,  2 users,  load average: 1.22, 0.94, 0.58
                                        Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3792.1 total,    960.3 free,   1472.4 used,   1436.2 buff/cache
                                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2319.7 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                        tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                        /dev/mmcblk0p2 ext4      117G  4.3G  107G   4% /
                                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                        [Sat Jun 15 09:42:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:22:A6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c9bf5144-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                        [Sat Jun 15 09:42:24 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                        [Sat Jun 15 09:42:26 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET                                                  SOURCE         FSTYPE      OPTIONS
                                        /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                                        |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                        | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                                        | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                                        |-/proc                                                 proc           proc        rw,relatime
                                        | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1988
                                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                                        |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671308k,nr_inodes=417827,mode=755
                                        | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                        | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                                        | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                                        |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
                                        | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                        | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                                        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
                                        `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        632M    /var/
                                        206M    /var/cache
                                        200M    /var/cache/apt
                                        165M    /var/lib
                                        133M    /var/lib/apt/lists
                                        Archived and active journals take up 60.0M in the file system.
                                        /opt/iobroker/backups:
                                        3.9M    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        419M    /opt/iobroker/iobroker-data/
                                        299M    /opt/iobroker/iobroker-data/files
                                        138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                        26M     /opt/iobroker/iobroker-data/objects.jsonl
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                                        9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.14.0
                                        /usr/bin/node           v20.14.0
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        /usr/bin/corepack       0.28.1
                                        nodejs:
                                          Installed: 20.14.0-1nodesource1
                                          Candidate: 20.14.0-1nodesource1
                                          Version table:
                                         *** 20.14.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                             18.13.0+dfsg1-1 500
                                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  5.0.19
                                        admin:          6.13.16
                                        javascript:     8.3.1
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : Raspberry4                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.backitup.0               : backitup              : Raspberry4                               -  enabled
                                        + system.adapter.discovery.0              : discovery             : Raspberry4                               -  enabled
                                          system.adapter.ds18b20.0                : ds18b20               : Raspberry4                               - disabled
                                        + system.adapter.email.0                  : email                 : Raspberry4                               -  enabled
                                          system.adapter.flot.0                   : flot                  : Raspberry4                               - disabled
                                        + system.adapter.hekr.0                   : hekr                  : Raspberry4                               -  enabled
                                        + system.adapter.history.0                : history               : Raspberry4                               -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : Raspberry4                               -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberry4                               -  enabled, port: 0
                                          system.adapter.hm-rpc.1                 : hm-rpc                : Raspberry4                               -  enabled, port: 0
                                          system.adapter.info.0                   : info                  : Raspberry4                               - disabled
                                        + system.adapter.javascript.0             : javascript            : Raspberry4                               -  enabled
                                          system.adapter.material.0               : material              : Raspberry4                               - disabled
                                          system.adapter.modbus.0                 : modbus                : Raspberry4                               - disabled
                                        + system.adapter.mqtt.0                   : mqtt                  : Raspberry4                               -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.mqtt.1                   : mqtt                  : Raspberry4                               -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.musiccast.0              : musiccast             : Raspberry4                               - disabled
                                          system.adapter.pvforecast.0             : pvforecast            : Raspberry4                               - disabled
                                        + system.adapter.rpi2.0                   : rpi2                  : Raspberry4                               -  enabled
                                        + system.adapter.senec.0                  : senec                 : Raspberry4                               -  enabled
                                        + system.adapter.shelly.0                 : shelly                : Raspberry4                               -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.socketio.0               : socketio              : Raspberry4                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          system.adapter.vis-history.0            : vis-history           : Raspberry4                               - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspberry4                               - disabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Raspberry4                               - disabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : Raspberry4                               - disabled
                                          system.adapter.vis.0                    : vis                   : Raspberry4                               - disabled
                                        + system.adapter.web.0                    : web                   : Raspberry4                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                        Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
                                        Adapter    "email"        : 1.3.0    , installed 1.3.0
                                        Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                        Controller "js-controller": 5.0.19   , installed 5.0.19
                                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                                        Adapter    "modbus"       : 6.1.0    , installed 6.2.3
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
                                        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                        Adapter    "senec"        : 1.6.12   , installed 1.6.12
                                        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                        Adapter    "web"          : 6.2.5    , installed 6.2.5
                                        Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                        Objects and States
                                        Objects:        5926
                                        States:         5335
                                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Pending Updates: 1
                                        *** Listening Ports ***
                                        <hidden>
                                        2024-06-17 07:17:20.180  - info: host.Raspberry4 Restart adapter system.adapter.hm-rpc.1 because enabled
                                        2024-06-17 07:17:50.293  - info: host.Raspberry4 instance system.adapter.hm-rpc.1 started with pid 69806
                                        2024-06-17 07:17:52.518  - error: hm-rpc.1 (69806) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                        2024-06-17 07:18:22.514  - error: hm-rpc.1 (69806) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                        2024-06-17 07:18:22.534  - error: hm-rpc.1 (69806) Cannot call init: [http://192.168.<hidden>:<hidden>, ""] Unknown XML-RPC tag 'TITLE'
                                        2024-06-17 07:18:23.250  - info: host.Raspberry4 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                        2024-06-17 07:21:33.617  - info: host.Raspberry4 Restart adapter system.adapter.hm-rpc.1 because enabled
                                        • PeterLeP PeterLe
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          <hidden>
                                          HOME=/home/<hidden>
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           209M          0B        209M
                                                   3792 M total memory
                                                   1470 M used memory
                                                    961 M free memory
                                                    114 M buffer memory
                                                   1321 M swap cache
                                                    199 M total swap
                                                      0 M used swap
                                                    199 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          632M    /var/
                                          206M    /var/cache
                                          200M    /var/cache/apt
                                          165M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.7.0
                                          /usr/bin/npx            10.7.0
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.13.16
                                          javascript:     8.3.1
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        5926
                                          States:         5335
                                          Pending Updates: 1
                                          <hidden>
                                          @peterle
                                          Kürz da nix raus.
