  4. js-controller 5.0.x jetzt für alle User im STABLE!
    1.0k
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.4k Aufrufe 65 Beobachtet
    @ingenii sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
    E: The repository 'cdrom://[Debian GNU/Linux 12.2.0 Bookworm - Official amd64 DVD Binary-1 with firmware 20231007-10:29] bookworm Release' does not have a Release file.
    Lösch den entsprechenden Eintrag in der /etc/apt/sources.list
    I Offline
    I Offline
    ingenii
    #436
    ja ich weis, das Sol noch weg kommen .
    angepasst aber das hat nicht geholfen.
    Was mach ich noch falsch?
    • I ingenii
      @mcm57
      hier ist log vom meinem Proxmox Test Iob:
      host.debian
      	2023-12-02 21:00:19.341	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.debian
      	2023-12-02 21:00:19.341	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:77:11)
      host.debian
      	2023-12-02 21:00:19.341	error	Caught by controller[0]: at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14
      host.debian
      	2023-12-02 21:00:19.341	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
      host.debian
      	2023-12-02 21:00:19.340	error	Caught by controller[0]: at Socket.emit (node:events:517:28)
      host.debian
      	2023-12-02 21:00:19.340	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1786:43)
      host.debian
      	2023-12-02 21:00:19.340	error	Caught by controller[0]: at Object.commands.logout (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:863:26)
      host.debian
      	2023-12-02 21:00:19.340	error	Caught by controller[0]: at AdapterClass.destroySession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1336:19)
      host.debian
      	2023-12-02 21:00:19.340	error	Caught by controller[0]: at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:241:19)
      host.debian
      	2023-12-02 21:00:19.339	error	Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      web.0
      	2023-12-02 21:00:19.276	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
      web.0
      	2023-12-02 21:00:19.276	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:241:19) at AdapterClass.destroySession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1336:19) at Object.commands.logout (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:863:26) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1786:43) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14 at processTicksAndRejections (node:internal/process/task_queues:77:11)
      web.0
      	2023-12-02 21:00:19.275	error	uncaught exception: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      und Iob diag:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: debian
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-13-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:15:34 up 1 day, 22:13,  2 users,  load average: 0.26, 0.17, 0.10
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sat 2023-12-02 21:15:34 CET
                 Universal time: Sat 2023-12-02 20:15:34 UTC
                       RTC time: Sat 2023-12-02 20:15:34
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      jozef
      /home/jozef
      jozef cdrom floppy audio dip video plugdev users netdev bluetooth lpadmin scanner
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        1.5G        1.7G        7.4M        1.2G        2.6G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        1.5G        2.7G
               3914 M total memory
               1397 M used memory
                548 M active memory
               1403 M inactive memory
               1639 M free memory
                207 M buffer memory
                965 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  1.1M  391M   1% /run
      /dev/sda1      ext4       31G  5.8G   24G  20% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M   60K  392M   1% /run/user/113
      tmpfs          tmpfs     392M   52K  392M   1% /run/user/1000
      [Thu Nov 30 23:01:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Nov 30 23:01:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      175M    /var/
      104M    /var/lib
      60M     /var/lib/dpkg
      56M     /var/lib/dpkg/info
      40M     /var/log
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      218M    /opt/iobroker/iobroker-data/
      175M    /opt/iobroker/iobroker-data/files
      37M     /opt/iobroker/iobroker-data/files/vis
      30M     /opt/iobroker/iobroker-data/files/web.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.8M    /opt/iobroker/iobroker-data/objects.jsonl
      6.7M    /opt/iobroker/iobroker-data/states.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 cdrom://[Debian GNU/Linux 12.2.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20231007-10:29] bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.10.1
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
      + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: debian                                   -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : debian                                   -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : debian                                   -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : debian                                   -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : debian                                   -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : debian                                   -  enabled
        system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : debian                                   -  enabled
        system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : debian                                   -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : debian                                   -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : debian                                   -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : debian                                   -  enabled
        system.adapter.vis-material.0           : vis-material          : debian                                   -  enabled
        system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : debian                                   -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
        system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
        system.adapter.vis.0                    : vis                   : debian                                   -  enabled
      + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.10.1 [Updatable]
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
      Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        291
      States:         181
      E: The repository 'cdrom://[Debian GNU/Linux 12.2.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20231007-10:29] bookworm Release' does not have a Release file.
      Pending Updates: 0
      *** Listening Ports ***
      sudo: netstat: command not found
      2023-12-02 21:00:19.276  - error: web.0 (13802) Parameter "id" needs to be of type "string" but type "undefined" has been passed
      2023-12-02 21:00:19.339  - error: host.debian Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      2023-12-02 21:00:19.340  - error: host.debian Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:241:19)
      2023-12-02 21:00:19.340  - error: host.debian Caught by controller[0]:     at AdapterClass.destroySession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1336:19)
      2023-12-02 21:00:19.340  - error: host.debian Caught by controller[0]:     at Object.commands.logout (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:863:26)
      2023-12-02 21:00:19.340  - error: host.debian Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1786:43)
      2023-12-02 21:00:19.340  - error: host.debian Caught by controller[0]:     at Socket.emit (node:events:517:28)
      2023-12-02 21:00:19.341  - error: host.debian Caught by controller[0]:     at Socket.emit (node:domain:489:12)
      2023-12-02 21:00:19.341  - error: host.debian Caught by controller[0]:     at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14
      2023-12-02 21:00:19.341  - error: host.debian Caught by controller[0]:     at processTicksAndRejections (node:internal/process/task_queues:77:11)
      2023-12-02 21:00:19.341  - error: host.debian instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-12-02 21:00:19.341  - info: host.debian Restart adapter system.adapter.web.0 because enabled
      2023-12-02 21:00:49.355  - info: host.debian instance system.adapter.web.0 started with pid 13864
      2023-12-02 21:00:49.998  - info: web.0 (13864) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.16
      2023-12-02 21:00:50.063  - info: web.0 (13864) socket.io server listening on port 8082
      2023-12-02 21:00:50.065  - info: web.0 (13864) http server listening on port 8082
      2023-12-02 21:00:50.195  - info: web.0 (13864) ==> Connected system.user.admin from ::ffff:192.168.178.35
      2023-12-02 21:00:50.480  - info: web.0 (13864) ==> Connected system.user.admin from ::ffff:192.168.178.35
      2023-12-02 21:03:20.192  - info: web.0 (13864) <== Disconnect system.user.admin from ::ffff:192.168.178.35
                              v.2023-10-10
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Vienna (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      Swap:           1.0G          0B        1.0G
      Active iob-Instances:   6
      ioBroker Core:          js-controller           5.0.16
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                291
      States:                 181
      Size of iob-Database:
      6.8M    /opt/iobroker/iobroker-data/states.jsonl
      iob diag has finished.
                              v.2023-10-10
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      MEMORY:
      Swap:           1.0G          0B        1.0G
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                291
      States:                 181
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #437
      @ingenii
      Also die Fehler kommen mal aus dem web Adapter. Da ist der js-controller unschuldig. Das einzige was der js-controller ab 5.x.x macht ist genauer auf ungültige Parameter zu prüfen. Das ist aber kein Fehler.
      Ok, da nutzt dir mal so nichts.
      Eigentliche Ursache ist, dass "irgendwer" im bzw. via web Adapter versucht einen State mit einer 'undefined'id anzusprechen. Das kann nicht funktionieren. Wahrscheinlich ist igrndwo in deiner vis ein (alter) "Unsinn" eingetragen. Im Moment weiß ich nicht wie das am besten einzugrenzen wäre.
      Deine Logs sind (auf Grund des Datums) aktuell und Versionen sind im diag enthalten. DANKE
      Ich werd mal versuchen jemadn zu kontaktieren der sich bei vis/web besser auskennt.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        @ingenii
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #438
        @ingenii
        Ich hab mal erste Rückmeldung.
        Leider wurde die Fehlerkonstellation noch nie beobachtet. ABer natürlcih soll sie gelöst / behoben werden.
        Bitte daher noch ein paar Auskünfte:
        • Kannst du sagen bei welcher Aktion / Eingabe / ... das Problem auftritt. Je genauer das bekannt ist desto eher läßt sich was eingrenzen.
        • Tritt das Problem reprodizierbar immer auf oder "nur" sporadisch und nicht wirklich vrohersagbar ?
        • Und zu SIcherheit: Hast du den Compact Mode ein- oder ausgeschaltet?
        I 1 Antwort Letzte Antwort
        • I ingenii
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #439
          @ingenii zeig mal bitte die Einstellungen vom Web Adapter über den du die vis nutzt
          Videotutorials & mehr
          • mcm1957M mcm1957
            @ingenii
            I Offline
            I Offline
            ingenii
            #440
            @mcm57
            Problem auftaucht jedes mal wen ich im VIS von eine Seite springe in andere.
            Dieser Compact Mode kännte ich nicht bist jetzt und sicher ist er AUS.
            • foxriver76F foxriver76
              I Offline
              I Offline
              ingenii
              #441
              @foxriver76
              Hallo, hier hab ich nie was umgestellt.
              Reicht die Erste Seite ?
              • I ingenii
                @foxriver76
                sigi234S Online
                sigi234S Online
                #442
                @ingenii
                Haken rein bei Reine-WEB Sockets
                • mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #443
                  @ingenii
                  Danke mal für die Infos.
                  Falls das aus irgeneinem Grund hier untergehen sollte undkeine Lösung auftritt, mach bitte ein Issue auf. Das ereeicht dann development direct (obwohl @foxriver hier eh schon aktiv ist)
                  • sigi234S sigi234
                    @ingenii
                    I Offline
                    I Offline
                    ingenii
                    #444
                    @sigi234
                    Danke für dein Typ aber es hat nicht geholfen.
                    • P Offline
                      peppino
                      #445
                      Ich habe mit js-controller 5.0.x ähnliche/selbe Probleme.
                      Nach einem reload der vis1 habe ich bei Datenpunkte die nicht von einem "alias.0 Datenpunkt" kommen "NaN" oder "null". Die Werte werden erst angezeigt wenn diese aktualisiert werden (z.B.: Temperaturwert ändert sich) nach einem View wechsel steht dann wieder "NaN" oder "null" bis zur nächsten Wertänderung.
                      Die selbe Vis konvertiert auf vis2 macht hingegen keine Probleme.
                      BG
                      Joe
                        Hallo ioBroker-Community,
                        Heute möchten wir Euch den js-controller 5.0 endlich auch im STABLE Repository zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos. Bitte unbedingt lesen!!
                        Wir bedanken uns bei allen Usern die bisher die neue Version bereits als Alpha oder Beta getestet und Feedback gegeben haben.
                        Node.js Versions-Anforderungen
                        In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird und Node.js 14.x welches seit April diesem Jahres EOL ist. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 16.4.0+ und 18.x und nach aktuellem Stand Node.js 20.x, wobei hier noch erfahrungen fehlen. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
                        Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
                        Informationen zur Version
                        Es gibt EINIGE Adapter die aktualisiert werden müssen!! Bitte weiter unten lesen!
                        In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 88%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
                        Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                        Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
                        ACHTUNG backups inkompatibel bei Downgrades!!
                        Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
                        Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                        Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
                        Bitte dazu die Informationen weiter unten beachten!
                        Installation
                        VOR der Installation
                        Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Vorheriger Stable Stand ist die 4.0.24)
                        Nötige Adapter-Aktualisierungen
                        Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
                        Diesmal sind doch einige Adapter auf der Liste die man updaten muss -falls installiert! Siehe Spoiler!
                        • ✅ acme - required: none / 0.1.0 - released
                        • ✅ admin - required: 6.8.0 - released
                        • ✅ anelhut - required: 1.0.15 - released
                        • ✅b-control-em - required: 0.3.1 - released
                        • ⚪ bosch-ebike - required: none
                        • ✅ cul - required: 2.2.0 - released (no change)
                        • ✅ daikin-cloud - required: 0.3.0 - released
                        • ✅ doorbird - required: 0.1.7 - newer released
                        • ✅ ds18b20 - required: 2.0.4 - released
                        • ✅ energymanager - required: 1.4.2 - released
                        • ⚪ enigma2 - required: none - not at stable yet
                        • ✅ fakeroku - required: 0.2.2+ - released
                        • ✅ fhem - required: 2.0.5 - released
                        • ✅ history - required: 2.2.6 - released
                        • ✅ iqontrol - required: 2.3.0 - released
                        • ⚪ javascript - required: none
                        • 🚫 km200 - deprecated - Ersatz: ems-esp
                        • ✅ lgtv - required: 1.1.12 - released
                        • ❗linux-control - required: ???
                        • ✅ maxcul - required: 1.3.1 (no change)
                        • ⚪ miio - required: none - not at stable
                        • ✅ mydlink - required: 1.3.4 - released
                        • ✅ nanoleaf-lightpanales - required: 1.4.0 - released
                        • ✅ node-red - required: 4.03+ (no change)
                        • ✅ notification.manager - required: 0.1.1 - released
                        • ✅ pi-hole - required: 1.3.6+ - released
                        • ✅ ping - required: 1.6.2 - released
                        • ✅ pushbullet - required: 1.0.1 - released
                        • 🚫 samsung_tyzen - stale repo - deprecated with js-controller 5
                        • ✅ socketio - required: 6.5.2 - released
                        • ✅ stiebel-isg - required: 1.7.6+ - newer released
                        • ✅ systeminfo - required: 1.0.0 - released
                        • ✅ viessmann - required: 1.4.4+ - released
                        • ✅ web - required: 6.1.0 - released
                        • ✅ ws - required: 2.5.3 - released
                        • ✅yahka - required: 1.0.1 - newer version released
                        • ✅ zigbee - required: 1.8.23 - released
                        Achtung: MASTER-Systeme Reihenfolgen beachten!
                        Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                        Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
                        Windows
                        Generell muss das Update manuell via npm installiert werden.
                        Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
                        Linux
                        • ioBroker stoppen (iobroker stop)
                        • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                        • cd /opt/iobroker
                        • Das Update erfolgt via iob upgrade self
                        • ioBroker starten (iobroker start)
                        Bei Fehlern:
                        Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                        NACH der Installation
                        Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                        Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                        Was hat sich geändert, was besonders ansehen/beachten?
                        Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                        • generell siehe Changelog, speziell auch für die Features
                        • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
                        • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
                        Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                        Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                        5.0. Release Jana
                        BREAKING CHANGES
                        • Support for Node.js 12 and 14 is dropped! Supported are Node.js 16.4.0+ and 18.x and hopefully 20.x
                        • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
                        • Update recommended npm version to 8
                        • Deprecate binary states, Adapters will change to use Files instead!
                        Features
                        • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
                        • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
                        • (foxriver76) Add support for windows for iob fix
                        • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
                        • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
                        • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
                        • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only)
                        Optimizations and Fixes
                        • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
                        • (foxriver76) significantly reduce backup size
                        • (foxriver76) Enhance CLI help for list command to show all possible types to list
                        • (foxriver76) Also stop instances before updating from GitHub
                        • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
                        • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
                        • (foxriver76) Optimize adapter unload and stop handling for edge cases
                        • (AlCalzone) Carefully normalize jsonlOptions
                        • (bluefox) Do not show warning on a requested adapter stop/termination
                        • (bluefox) Make sure that the first log line is not missing in Admin
                        • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
                        • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
                        • (foxriver76) Preserve tier setting on adapter upload
                        • (foxriver76) update apt sources before installing os dependencies
                        • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
                        • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
                        • (foxriver76) Remove windows bat files completely, installer will create them when needed
                        • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
                        • (foxriver76) Fixes iob file sync not working for jsonl
                        • (foxriver76) Do not crash if we cannot initialize db backup directory on start
                        • (foxriver76) Fixed issue with certificate validity on leap years
                        • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
                        • (foxriver76) fix wrong hostname after backup restore
                        • (bluefox) allow CLI vendor update without explicitly specifying vendor file (default file is used)
                        • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                        Developer relevant DEPRECATIONS/WARNINGS
                        • Deprecate binary states, Migrate your adapters to use Files instead!
                        • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
                        • Parameter that contain patterns (e.g. mqtt.*) are now checked for allowed characters and general correctness!
                        Developer relevant new Features
                        • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
                        • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
                        • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
                        • (foxriver76) Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core
                        • (foxriver76) Add JSON-Schema for iobroker.json
                        • (bluefox) Allowed export of password.js (to be used with adapter-core)
                        • (bluefox) Added _design/chart to the system designs
                        • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
                        • (foxriver76) Added (foreign)objectExists to adapter methods
                        • (bluefox) Extend getSuitableLicenses to look for other licenses
                        • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
                        • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
                        • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
                        • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
                        • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
                        • (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
                        • (foxriver76) adapter.sendTo now accepts an optional timeout argument
                        • Developer relevant Optimizations and Fixes
                        • (foxriver76) Ensure setObjectNotExists returns id on success
                        • (foxriver76) Fix Typings for sendTo/sendToHost
                        • (Bluefox) Add User permission check to requireLog
                        • (foxriver76) added nonEdit property of objects to types and document functionality
                        • (foxriver76) introduced constants for state quality
                        • (foxriver76) subscribeStates now also accepts an array of ids
                        • general dependency updates
                        • code style optimizations and streamline code
                        Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                        Wie Fehler melden?
                        Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                        Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                        Bitte postet auch die Ausgabe von iob diag mit rein.
                        Wir wünschen allen viel Spaß mit dem neuen Controller und vielen Dank für Eure Unterstützung!
                        fox
                        sonnenfreund
                        schrieb am zuletzt editiert von sonnenfreund
                        #446
                        @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                        wollte nun endlich mal meinen uralten js controller aktualisieren.
                        Habe die Schritte
                        • iobroker stop
                        • cd /opt/iobroker
                        abgearbeitet.
                        Leider läuft aber iob upgrade self nicht durch.
                        Es kommen folgende Fehlermeldungen. Woran kann das liegen / wie kann ich das lösen?
                        pi@raspberrypi4-iob:/ $ iobroker upgrade self
                        Update js-controller from @3.1.6 to @5.0.16
                        NPM version: 10.2.3
                        npm install iobroker.js-controller@5.0.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                         Objects 127.0.0.1:58398 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                         States 127.0.0.1:35658 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                         Objects 127.0.0.1:58398 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                         States 127.0.0.1:35658 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                         Objects 127.0.0.1:58398 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                         Objects 127.0.0.1:58398 Error from InMemDB: Error: scan NOT SUPPORTED
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                        npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                        npm ERR!         throw e;
                        npm ERR!         ^
                        npm ERR!
                        npm ERR! ReplyError: Error scan NOT SUPPORTED
                        npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                        npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                        npm ERR! Emitted 'error' event on ScanStream instance at:
                        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                        npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                        npm ERR!   command: {
                        npm ERR!     name: 'scan',
                        npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                        npm ERR!   }
                        npm ERR! }
                        npm ERR!
                        npm ERR! Node.js v18.19.0
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-07T19_37_56_146Z-debug-0.log
                        Starting node restart.js
                        Thomas BraunT foxriver76F 2 Antworten Letzte Antwort
                        • S sonnenfreund
                          Habe die Schritte
                          • iobroker stop
                          • cd /opt/iobroker
                          abgearbeitet.
                          NPM version: 10.2.3
                          npm ERR! code 1
                          npm ERR!         throw e;
                          npm ERR!         ^
                          npm ERR!
                          npm ERR!   command: {
                          npm ERR!   }
                          npm ERR! }
                          npm ERR!
                          #447
                          @sonnenfreund
                          iob diag
                          sagt zur Gesamtlage?
                          Die lange Version...
                          Und stell dich in dein /home
                          In / hast du nix verloren...
                            @sonnenfreund
                            iob diag
                            sonnenfreund
                            #448
                            Copy text starting here:
                                                    v.2023-10-10
                               Static hostname: raspberrypi4-iob
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 5.10.103-v7l+
                                  Architecture: arm
                            Kernel:                 armv7l
                            Userland:               armhf
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Pending iob updates:    21
                                                    /usr/bin/npm            10.2.3
                                                    /usr/bin/npx            10.2.3
                            Recommended versions are nodejs  and npm
                            MEMORY:
                            Mem:            1.9G        446M        645M        0.0K        780M        1.3G
                            Swap:            99M          0B         99M
                            Total:          2.0G        446M        745M
                            Active iob-Instances:   8
                            Active repo: default
                            ioBroker Core:          js-controller           3.1.6
                                                    admin                   4.2.1
                            At least one iobroker host is running.
                            Objects type: file
                            States  type: file
                              system.adapter.admin.0                 : admin                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.admin.1                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.web.0                   : web                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                1968
                            States:                 2764
                            5.5M    /opt/iobroker/iobroker-data/objects.json.bak
                            700K    /opt/iobroker/iobroker-data/states.json.bak
                            === Mark text until here for copying ===
                            • S sonnenfreund
                                                      v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm
                              Kernel:                 armv7l
                              Userland:               armhf
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            10.2.3
                                                      /usr/bin/npx            10.2.3
                              MEMORY:
                              Swap:            99M          0B         99M
                                                      admin                   4.2.1
                              Objects type: file
                              States  type: file
                              Objects:                1968
                              States:                 2764
                              #449
                              @sonnenfreund
                              Generell hast du es nicht so mit Updates, oder?
                              Ist da überhaupt noch irgendwas auf einem aktuellen Stand?
                              cd /opt/iobroker
                              iob update
                              iob upgrade
                              • S sonnenfreund
                                Habe die Schritte
                                • iobroker stop
                                • cd /opt/iobroker
                                abgearbeitet.
                                NPM version: 10.2.3
                                npm ERR! code 1
                                npm ERR!         throw e;
                                npm ERR!         ^
                                npm ERR!
                                npm ERR!   command: {
                                npm ERR!   }
                                npm ERR! }
                                npm ERR!
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                schrieb am zuletzt editiert von foxriver76
                                #450
                                @sonnenfreund hui ich würde erst mal versuchen auf eine 4.0.24 zu gehen zb bzw war da glaube noch ein Release dazwischen
                                  @sonnenfreund
                                  cd /opt/iobroker
                                  iob update
                                  iob upgrade
                                  sonnenfreund
                                  #451
                                  @thomas-braun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                  @sonnenfreund
                                  sei doch nicht so streng 👮
                                  cd /opt/iobroker
                                  hab ich grad gemacht und komme folgende Meldungen:
                                  pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                  npm ERR! code 1
                                  npm ERR!         throw e;
                                  npm ERR!         ^
                                  npm ERR!
                                  npm ERR!   command: {
                                  npm ERR!   }
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-07T20_09_35_513Z-debug-0.log
                                  • S sonnenfreund
                                    @sonnenfreund
                                    cd /opt/iobroker
                                    npm ERR! code 1
                                    npm ERR!         throw e;
                                    npm ERR!         ^
                                    npm ERR!
                                    npm ERR!   command: {
                                    npm ERR!   }
                                    npm ERR! }
                                    npm ERR!
                                    #452
                                    @sonnenfreund
                                    Dann versuch einen 4er-js-controller zu installieren.
                                      @sonnenfreund
                                      sonnenfreund
                                      #453
                                      @sonnenfreund
                                      Nach
                                      iobroker update
                                      iobroker fix
                                      gleiches Problem bei iobroker upgrade self:
                                      pi@raspberrypi4-iob:/home $ iobroker upgrade self
                                      NPM version: 10.2.3
                                       Objects 127.0.0.1:59744 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
                                       States 127.0.0.1:37004 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
                                       Objects 127.0.0.1:59744 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                                       States 127.0.0.1:37004 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                                       Objects 127.0.0.1:59744 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                                       Objects 127.0.0.1:59744 Error from InMemDB: Error: scan NOT SUPPORTED
                                      npm ERR! code 1
                                      npm ERR!         throw e;
                                      npm ERR!         ^
                                      npm ERR!
                                      npm ERR!   command: {
                                      npm ERR!   }
                                      npm ERR! }
                                      npm ERR!
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-07T20_23_32_051Z-debug-0.log
                                      • S sonnenfreund
                                        @sonnenfreund
                                        Nach
                                        iobroker update
                                        iobroker fix
                                        NPM version: 10.2.3
                                        npm ERR! code 1
                                        npm ERR!         throw e;
                                        npm ERR!         ^
                                        npm ERR!
                                        npm ERR!   command: {
                                        npm ERR!   }
                                        npm ERR! }
                                        npm ERR!
                                        Diamand2k22
                                        #454
                                        kann mir jemand sagen, was das zum Teufel ist?
                                        ich habe den Fehler seit dem Update auf JS-Controller 5.0.17
                                        • D Diamand2k22
                                          #455
                                          @diamand2k22 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                          Ein Screenshot, den man nur umständlich lesen kann.
                                          Deswegen Texte aus dem Log immer als Text in CodeTags eingebettet hier rein
