  4. ical zeigt keine ganztägigen Ereignisse
25 Beiträge 5 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • E ehome
    @wendy2702
    sorry hatte ihn wohl nicht "richtig" umgestellt - hatte einen langen Tag.....
    im Log:
    2023-01-23 21:53:31.259  - info: host.iobroker stopInstance system.adapter.ical.0 (force=false, process=false)
    2023-01-23 21:53:31.259  - info: host.iobroker stopInstance canceled schedule system.adapter.ical.0
    2023-01-23 21:53:34.311  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
    2023-01-23 21:53:34.327  - info: host.iobroker instance system.adapter.ical.0 started with pid 821589
    2023-01-23 21:53:34.731  - debug: ical.0 (821589) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-01-23 21:53:34.831  - debug: ical.0 (821589) Objects client ready ... initialize now
    2023-01-23 21:53:34.912  - debug: ical.0 (821589) Objects create System PubSub Client
    2023-01-23 21:53:34.913  - debug: ical.0 (821589) Objects create User PubSub Client
    2023-01-23 21:53:35.028  - debug: ical.0 (821589) Objects client initialize lua scripts
    2023-01-23 21:53:35.040  - debug: ical.0 (821589) Objects connected to redis: 0.0.0.0:9001
    2023-01-23 21:53:35.084  - debug: ical.0 (821589) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-01-23 21:53:35.160  - debug: ical.0 (821589) States create System PubSub Client
    2023-01-23 21:53:35.161  - debug: ical.0 (821589) States create User PubSub Client
    2023-01-23 21:53:35.265  - debug: ical.0 (821589) States connected to redis: 0.0.0.0:9000
    2023-01-23 21:53:35.497  - debug: ical.0 (821589) Plugin sentry Initialize Plugin (enabled=true)
    2023-01-23 21:53:35.838  - info: ical.0 (821589) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 21:53:35.915  - debug: ical.0 (821589) reading calendar from URL: http://XXXXXXXXXXXXXXXXXXXX, color: #FF0000
    2023-01-23 21:53:36.121  - debug: ical.0 (821589) Successfully cached content for calendar "http://XXXXXXXXXXXXXXXXXXXX" as /opt/iobroker/node_modules/iobroker.ical/f6ec509df398a71e0388b06f149fb688
    2023-01-23 21:53:36.121  - debug: ical.0 (821589) File read successfully http://XXXXXXXXXXXXXXXXXXXX
    2023-01-23 21:53:36.123  - info: ical.0 (821589) processing URL: Abfuhrtermine http://XXXXXXXXXXXXXXXXXXXX
    2023-01-23 21:53:36.124  - debug: ical.0 (821589) {"vcalendar":{"type":"VCALENDAR","version":"2.0","WR-CALNAME":"Abfuhrtermine Dorfstraße 27","APPLE-CALENDAR-COLOR":"#1BADF8"}}
    2023-01-23 21:53:36.124  - debug: ical.0 (821589) checkICal: startpreview - Mon Jan 23 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit)
    2023-01-23 21:53:36.124  - debug: ical.0 (821589) checkICal: endpreview - Fri Mar 24 2023 21:53:36 GMT+0100 (Mitteleuropäische Normalzeit)
    2023-01-23 21:53:36.126  - debug: ical.0 (821589) displaying dates because of callback
    2023-01-23 21:53:41.205  - debug: ical.0 (821589) Plugin sentry destroyed
    2023-01-23 21:53:41.206  - info: ical.0 (821589) Terminated (NO_ERROR): Without reason
    2023-01-23 21:53:41.911  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    haus-automatisierungH Offline
    @ehome Mh, das ist komisch. Ich glaube der iCal Prozess wird beendet, bevor die Kalender überhaupt verarbeitet werden. Müsste man in Ruhe debuggen wann das passieren kann. Kannst Du das iCal File zur Verfügung stellen?
    📚 Meine Dokumentation
    E 1 Antwort Letzte Antwort
      ehome
      @haus-automatisierung
      Hier das Original-File vom Versorger - ja da ist meine Adresse zu sehen ;)
      dorfstrasse27issum-2.ics
      Hier der Link zum öffentlich sichtbaren Müllkalender, den ich auch in iobroker eingetragen habe:
      • E Offline
        ehome
        Hi, konntets du dir die Kalender mal ansehen ?
        Ich habe zwischenzeitlich ical mal komplett gelöscht und neu installiert - hat aber nix gebracht ;(
        haus-automatisierungH 2 Antworten Letzte Antwort
        • E ehome
          @ehome sagte in ical zeigt keine ganztägigen Ereignisse:
          Habe ich leider noch nicht geschafft - momentan zu viel anderen Kram drumherum. Komme hoffentlich bald dazu.
          • E ehome
            Ich habe es gerade mit der URL direkt aus dem Forum von deinem Upload getestet und alles funktioniert. Was es nicht einfacher macht den Fehler zu finden...
              ehome
              danke fürs's testen- auch wenn es immer komischer wird.
              Habe folgendes nochmals ausprobiert:
              Instanz und Adapter gelöscht, von GitHub installiert -> keine Veränderung. Ganztägige Ereignisse werden nicht gefunden, Termine mit Start/Endzeit sofort.
              Daraufhin habe ich einfach mal das Docker-Compose File genommen und iobroker in einem anderen Container gestartet, ical ausgewählt und eine Instanz erstellt - und siehe da, sofort hat er auch ganztägige Termine erkannt. Es ist offensichtlich etwas an meiner iobroker Installation nicht in Ordnung - was mich etwas nervös werden lässt, ist eine sehr umfangreiche Installation und wer weiss, was sonst so alles nicht richtig läuft ;(
              Heute Abend werde ich mal per Backup/Restore auf den neuen Container umziehen - vielleicht hilft das ja....
              • E ehome
                Naja was soll das schon sein? Wenn die Versionen vom js-controller identisch sind und auch die gleiche nodejs Version verwendet wird bleibt ja nicht mehr viel Luft für Abweichungen.
                E 2 Antworten Letzte Antwort
                  ehome
                  zu früh gefreut - war mein Test-Event was ich bei der Neuinstallation gesehen habe - sch... zu blöd.
                  Da war wohl der Wunsch Vater des Gedanken .......
                  Zumindest habe ich das Backup mal wieder getestet. Leider besteht das Problem
                  mit den ganztägigen Events noch immer.
                  Sorry für die Verwirrung .....
                    ehome
                    so, wollte dann mal nach langer Zeit eine Rückmeldung geben.
                    Nachdem ich das ganze für ein paar Wochen gefrustet liegen gelassen habe,
                    hab ich mich ab WE nochmal damit versucht. Beide Adapter gelöscht, die verbleibenden
                    Datenpunkte gelöscht und anschließend die Adapter neu installiert (hatte ich zwar schon versucht ...)
                    Und dann ging es sofort - warum auch immer.
                    Nochmal allen Danke für die Unterstützung und einen schönen Abend noch.
                    • ldittmarL Offline
                      ldittmarL Offline
                      ldittmar
                      schrieb am zuletzt editiert von ldittmar
                      Hmm... bei mir werden ganztägige Events, die über mehrere Tage gehen, nicht angezeigt. Ich habe hier ein Beispiel:
                      BEGIN:VEVENT
                      DTSTART;VALUE=DATE:20231207
                      DTEND;VALUE=DATE:20231211
                      DTSTAMP:20231205T114107Z
                      UID:xxxxxx
                      CREATED:20231205T111510Z
                      LAST-MODIFIED:20231205T111601Z
                      SEQUENCE:0
                      STATUS:CONFIRMED
                      SUMMARY:Flug Curitiba ✈️
                      TRANSP:TRANSPARENT
                      END:VEVENT
                      Ich habe ein Event angelegt "Flug " und das wird richtig ausgewertet, aber der Termin erscheint weder unter ical.5.data.html noch unter ical.5.data.table.
                      Bin ich blöd oder kann mir jemand das bestätigen? Gänztägige Termine, die nur 1 Tag gehen, funktionieren.
                      EDIT:
                      Ich nehme alles wieder zurück und behaupte das Gegenteil... ich habe beim Event "Anzeigen" nicht angehakt.
