  4. Adapter werden nicht mehr geupdated
74 Beiträge 5 Kommentatoren 5.1k Aufrufe 5 Beobachtet
    @accu
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    Accu
    @thomas-braun Hat er sich jetzt aufgehangen oder soll man da wieder zum Prompt zurückkommen?
    pi@Raspi:~ $ cd /opt/iobroker
    pi@Raspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
    npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    (##################) ⠋ reify:syno: timing arborist:ctor Completed in 4ms
    • A Accu
      @accu
      Das läuft noch. Deine Kiste ist ja kein Rennpferd.
      A 2 Antworten Letzte Antwort
        @accu
        Accu
        schrieb am zuletzt editiert von Accu
        @thomas-braun :-) ok dann warte ich. Hat sich nur schon seit ner halben Ewigkeit nicht verändert. Nicht dass er sich aufgehangen hat.
          @accu sagte in Adapter werden nicht mehr geupdated:
          Glaube dann lasse ich es erstmal so
          Ein abgekündigtes System zu betreiben ist keine Option.
          Accu
          @thomas-braun kann ich das irgendwie komplett über das Terminal installieren ohne dass ich in die Verlegenheit komme einen Bildschirm an den Raspberry anschließen zu müssen? Mein Pi hängt im Keller am am Netzwerk, ich habe aber keinen Bildschirm angeschlossen.
          Falls ja gibt es irgendwo ein Tutorial wie ich das mache? (bin kein Linux Experte)
          • A Accu
            @accu
            Eine Neuinstallation?
              @accu
              Accu
              @thomas-braun ja genau - weil das war ja dein Vorschlag dachte ich? nachdem ich jetzt eh nicht mehr drauf komme.
              • A Accu
                @accu
                Soweit ich weiß geht's nur per Raspberry Imager an einem Bildschirm. Hab mich aber noch nie damit beschäftigt, das Headless zu machen.
                • A Accu
                  @thomas-braun die Frage ist ob das neue OS überhaupt irgendwie auf meinem alten Raspi mit dem kleinen Speicher läuft. Glaube dann lasse ich es erstmal so und nutze die paar Sachen weiter die laufen -- sofern ich den ioBroker irgendwie wieder zum Laufen bekomme.
                  wieso nicht?
                    wieso nicht?
                    Einem Rpi3 würde ich aber die 64Bit-Version spendieren.
                    HomoranH A 2 Antworten Letzte Antwort
                      klar!
                        @accu
                        @thomas-braun sagte in Adapter werden nicht mehr geupdated:
                        @accu
                        wieso nicht.
                        neue Karte am PC vorbereiten
                        alte Installation per ssh runterfahren
                        in den Keller gehen, Karte tauschen, Power on
                        bis er wieder am PC sitzt ist Bookworm hochgefahren
                        alles andere geht wieder mit SSH
                        A Thomas BraunT 2 Antworten Letzte Antwort
                          @accu
                          Accu
                          @thomas-braun hatte es nach 2h abgebrochen weil sich nix mehr getan hat. Jetzt gerade noch mal probiert:
                          Last login: Sun Dec  3 15:37:58 on ttys000
                          accu@iMac ~ % ssh pi@192.168.1.13
                          pi@192.168.1.13's password:
                          Linux Raspi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l
                          permitted by applicable law.
                          Last login: Sun Dec  3 15:39:14 2023 from 192.168.1.92
                          npm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /opt/iobroker/node_modules/agent-base
                          npm ERR! dest /opt/iobroker/node_modules/.agent-base-ZzrsLltQ
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/agent-base' -> '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ'
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-03T14_46_44_145Z-debug-0.log
                          gibts noch irgendeine Möglichkeit das alte System vorerst wieder zum Laufen zu bringen?
                            @accu
                            wieso nicht.
                            Accu
                            @homoran wie bereitet man die neue Karte am PC vor? einfach übern Card Reader?
                            • A Accu
                              wie sonst?
                              was hast du denn bisher gemacht?
                              • A Accu
                                npm ERR! errno -39
                                @accu
                                iob fix
                                  wie sonst?
                                  Accu
                                  @homoran ich hatte tatsächlich beim ersten mal den Raspi am Bildschirm
                                    @accu
                                    iob fix
                                    Accu
                                    @thomas-braun habe ich schon 2x drüber laufen lassen. Der Fehler bleibt der gleiche:
                                    pi@Raspi:~ $ iob fix
                                    library: loaded
                                    Library version=2023-10-13
                                        Welcome to the ioBroker installation fixer!
                                        Script version: 2023-10-13
                                        You might need to enter your password a couple of times.
                                        Installing prerequisites (1/5)
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    OK:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        Checking ioBroker user and directory permissions (2/5)
                                        Check and cleanup npm temporary directories (3/5)
                                    Done.
                                        Database maintenance (4/5)
                                    Checking for uncompressed JSONL databases... This might take a while!
                                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                    Compressed 2 JSONL files. Done
                                        Checking autostart (5/5)
                                    Enabling autostart...
                                    Autostart enabled!
                                        Your installation was fixed successfully
                                        Run iobroker start to start ioBroker again!
                                    pi@Raspi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                    npm ERR! code EACCES
                                    npm ERR! syscall mkdir
                                    npm ERR! path /home/pi/node_modules/iobroker.js-controller
                                    npm ERR! errno -13
                                    npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller'
                                    npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller'] {
                                    npm ERR!   errno: -13,
                                    npm ERR!   code: 'EACCES',
                                    npm ERR!   syscall: 'mkdir',
                                    npm ERR!   path: '/home/pi/node_modules/iobroker.js-controller'
                                    npm ERR! }
                                    npm ERR!
                                    npm ERR! The operation was rejected by your operating system.
                                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                                    npm ERR!
                                    npm ERR! If you believe this might be a permissions issue, please double-check the
                                    npm ERR! permissions of the file and its containing directories, or try running
                                    npm ERR! the command again as root/Administrator.
                                    npm ERR! A complete
                                      @accu
                                      wieso nicht.
                                      @homoran sagte in Adapter werden nicht mehr geupdated:
                                      wieso nicht.
                                      :-) Hatte irgendwie Richtung 'Image auf der Kommandozeile flashen' gedacht... Der Raspberry Imager hat aber afaik kein CLI.
                                      • A Accu
                                        library: loaded
                                        Done.
                                        Autostart enabled!
                                        npm ERR! errno -13
                                        npm ERR! }
                                        npm ERR!
                                        npm ERR!
                                        npm ERR! A complete
                                        Du stehst im falschen Verzeichnis.
                                        Und nein, der Fehler ist nicht der gleiche...
                                          Accu
                                          @thomas-braun ich habe jetzt mal meine Backup Speicherkarte vom System genommen, weil die andere Installation komplett zerschossen war.
                                          Habe jetzt alle Updates gemacht und der iobroker läuft wieder.
                                          Allerdings habe ich Probleme bei der Authentifizierung in den Adapter settings. Der Button lässt sich nicht drücken und erscheint ausgegraut. Auch in Firefox das gleiche. Liegt das evtl. an der veralteten Node Version. Gibt's da eine Möglichkeit noch aktuellere Versionen zu installieren ohne das bestehende Altsystem wieder zu Schrotten?
                                          mein System sieht so aus:
                                          Es gibt keine Nutzer-Sitzungen mit veralteten Prozessen.
                                          pi@Raspi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          /usr/bin/nodejs
                                          v14.21.3
                                          /usr/bin/node
                                          v14.21.3
                                          /usr/bin/npm
                                          6.14.18
                                          nodejs:
                                            Installiert:           14.21.3-deb-1nodesource1
                                            Installationskandidat: 14.21.3-deb-1nodesource1
                                            Versionstabelle:
                                           *** 14.21.3-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                               10.24.0~dfsg-1~deb10u3 500
