  3. Entwicklung
  4. [Neuer Adapter] Proxmox VM
    6.5k
proxmox
486 Beiträge 75 Kommentatoren 175.3k Aufrufe 57 Beobachtet
    @arteck sagte in [Neuer Adapter] Proxmox VM:
    isch guck später nach
    ... wenn du schon dabei bist... hier kam gerade waehrend des Backups des LXC, indem iobroker laeuft, diese Errors:
    2023-10-27 12:26:58.713  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:26:58.714  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:26:58.832  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
    2023-10-27 12:26:58.669  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: unlocked
    2023-10-27 12:27:01.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
    2023-10-27 12:27:01.121  - info: sonoff.0 (640) Client [S5V-4] connection closed: closed
    2023-10-27 12:27:02.964  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Querying lock battery state: failed
    2023-10-27 12:27:03.716  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:08.116  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading config. Result: failed
    2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:09.061  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402429044_5996
    2023-10-27 12:27:11.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
    2023-10-27 12:27:12.460  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading advanced config. Result: failed
    2023-10-27 12:27:13.721  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:21.064  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
    2023-10-27 12:27:23.725  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:31.066  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
    2023-10-27 12:27:32.385  - info: mqtt.1 (1223) Client [Presence1221] connection closed: timeout
    2023-10-27 12:27:33.730  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:43.734  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:48.735  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:48.736  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:53.738  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:27:56.752  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
    2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:02.713  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402482713_3323
    2023-10-27 12:28:03.321  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: unlocked
    2023-10-27 12:28:03.742  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:13.746  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:17.676  - warn: synochat.0 (5912) Attempt to send message '8b032070-74b3-11ee-8289-9fa88030d194' failed due to too fast sending sequence: 'create post too fast' > Delaying the message for 1 second/s...
    2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:23.750  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:33.753  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:41.532  - info: mqtt.1 (1223) Client [Presence1220] connection closed: timeout
    2023-10-27 12:28:43.758  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:48.890  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
    2023-10-27 12:28:53.762  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:01.064  - info: mqtt.1 (1223) Client [Presence1222] connection closed: timeout
    2023-10-27 12:29:02.932  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
    2023-10-27 12:29:03.766  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:29:07.889  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: unlocked
    2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:13.229  - info: mqtt.1 (1223) Client [Presence1220] connected with secret 1698402553186_4082
    2023-10-27 12:29:13.771  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:29:16.778  - info: bluelink.0 (1435) Read new update for KMHKR81AFNU011963 directly from the car
    2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:21.407  - info: sonoff.0 (640) Client [nx4519-1] reconnected. Old secret 1698388565136_7187. New secret 1698402561404_1831
    2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends publish. Ignore! Actual secret is 1698402561404_1831
    2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends pingreq. Ignore! Actual secret is 1698402561404_1831
    2023-10-27 12:29:21.889  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402561878_5954
    2023-10-27 12:29:23.775  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:31.327  - info: mqtt.1 (1223) Client [Presence1222] connected with secret 1698402571314_8823
    2023-10-27 12:29:32.379  - info: tuya.0 (788) 30530530c45bbedb673e: Connect locally to device
    2023-10-27 12:29:32.380  - info: tuya.0 (788) 30530530c45bbedb673e Init with IP=10.1.12.106, Key=>':x*F6`S#`J14cF, Version=3.3
    2023-10-27 12:29:33.779  - error: proxmox.0 (78860) Unable to update ticket: -1
    2023-10-27 12:29:37.865  - info: bluelink.0 (1435) Update for KMHKR81AFNU011963 successfull
    2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
    2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
    arteckA Offline
    arteckA Offline
    arteck
    #299
    @ilovegym sagte in [Neuer Adapter] Proxmox VM:
    da ist der storage nicht da.. und da du nur 1 node hast oder nur angegeben hast, kann der nicht switchen
    früher war die meldung unterdrückt
    • arteckA arteck
      #300
      @arteck
      ja, weil er gerade am backup schreiben ist.. hmmpff d.h. die Meldung kommt jetzt immer, wenn ich ein Backup mache in Proxmox.. ? mit dem LXC.. ?
      Kann man da das Timeout hoeher setzen.. fuer den Fehler? er kommt genau einmal, wie im Logfile, dann ist wieder ruhe..
      • arteckA arteck
        @negalein welche adapter version..ahh ich seh 2.2.0
        da wurde das object nicht angelegt
        proxmox.0.storage_proxmox_local-lvm
        lösche den mal .. und starte den adapter neu
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #301
        Danke, funktioniert wieder.
        ° Fixer ---> iob fix
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          #302
          @ilovegym dann guckemal jetzt
          • arteckA arteck
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #303
            @arteck
            habe auch von git installiert.
            Bitte noch überprüfen:
            maxmem wird bei den Objekten nicht aktualisiert.
            sowohl dies:
            als auch dies:
            Danke.
            • bahnuhrB bahnuhr
              @arteck
              sowohl dies:
              als auch dies:
              arteckA Offline
              arteckA Offline
              arteck
              #304
              @bahnuhr
              vm :
              doch..die maschiene muss aber laufen..
              node schau ich noch
              das ist die einstellung
              • arteckA arteck
                @bahnuhr
                vm :
                node schau ich noch
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #305
                @arteck
                Na klar ist die Maschine an.
                Und ja, der DP wird bei start der Instanz aktualisiert.
                Aber dann nicht mehr.
                Die anderen DP von mem werden dagegen regelmäßig (so alle 30 Sek.) aktualisiert.
                Danke.
                arteckA ? 2 Antworten Letzte Antwort
                • bahnuhrB bahnuhr
                  @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #306
                  @bahnuhr guckmal jetzt
                  ausserdem macht der nur eine Aktualisierung wenn sich was geändert hat...
                  • bahnuhrB bahnuhr
                    @arteck
                    #307
                    @bahnuhr sagte in [Neuer Adapter] Proxmox VM:
                    Moin,
                    max Mem. ist ja eher ein statischer Wert, der sich nicht laufend ändert, wohin gegen Mem. sich zur Laufzeit schon veränder, Du muss mal mit der Einstellung von MaxMem, spielen und dann schauen, ob die Änderung angezeigt wird.
                    Bernd
                    • David G.D Online
                      David G.D Online
                      David G.
                      #308
                      Neulich ist ja ein DP mit einer JSON der die Backups beinhaltet in den Adapter gekommen.
                      Ich habe da mal eine kleine Tabelle für meine Visu für gemacht.
                      Ist die Unterste Tabelle im ersten Post
                      https://forum.iobroker.net/topic/59661/zusammenstellung-meiner-tabellen?_=1701274643122
                      Edit:
                      @Meistertr
                      Wie oft wird die Datei mit den Infos über die Backups aktualisiert?
                      Durch die Tabelle habe ich jetzt gemerkt, dass es Teilweise Stunden braucht, bis ich aktuelle Daten bekomme.
                      • David G.D Online
                        David G.D Online
                        David G.
                        #309
                        Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
                        Mal nach ein paar Minuten, mL nach ein paar Stunden.
                        Das war der Log vor dem letzten Crash.
                        Jemand eine Idee?
                        -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
                        2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
                        2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
                        2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
                        2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
                        2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                        2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
                        2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
                        2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                        2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
                        Ab hier kommt im Log nichts mehr mit Proxmox.
                        Adapter v. 2.2.2
                        Proxmox 8.3.1
                        Admin: 6.12.0
                        node: 18.19
                        O/S: bookworm
                        • David G.D David G.
                          Jemand eine Idee?
                          Adapter v. 2.2.2
                          Proxmox 8.3.1
                          Admin: 6.12.0
                          node: 18.19
                          O/S: bookworm
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #310
                          @david-g poste mal den gesammten LOG..
                          David G.D Eduard77E 2 Antworten Letzte Antwort
                          • arteckA arteck
                            David G.D Online
                            David G.D Online
                            David G.
                            #311
                            @arteck
                            Den gesamten mit allen Adaptern oder nur mit proxmox.0?
                              @arteck
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #312
                              @david-g gesamt
                              • arteckA arteck
                                @david-g gesamt
                                David G.D Online
                                David G.D Online
                                David G.
                                #313
                                @arteck
                                Das Log ist 13 MB groß.
                                Wie darf ich es dir zukommen lassen? Darf hier nicht so viel hochladen.
                                Das PW vom Proxmoxuser habe ich ersetzt. Habe gesehen, dass das im Klartext im Log steht.
                                Hoffe, das machen die anderen Adapter nicht. Hab beim überfliegen nichts gesehen.
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #314
                                  @david-g was läuft denn da ..13 mb .. alder.
                                  dann machmal ab 23 Uhr
                                  • arteckA arteck
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    #315
                                    @arteck
                                    Anbei:
                                    iobroker.2023-12-12.log
                                    Zur Loggröße:
                                    Am 12ten lief der Proxmoxadapter.
                                    Da schiebe ich das eindeutig mal auf diesen.......
                                    Stand aber glaube auch auf debug, da ich mal sehen wollte ich ich was finde warum er abstürzt.
                                    Grad aber nciht sicher, ob das am 12ten auch noch so war.
                                      @arteck
                                      Anbei:
                                      Zur Loggröße:
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #316
                                      @david-g der startet neu.. und läuft danach.. nur warum der neu startet ??
                                      stell den mal auf debug,, dann ab der Zeile /das ist der start)
                                      bis nach abbruch posten
                                      ? David G.D 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        #317
                                        Moin,
                                        proxmox.0 steht doch schon auf Debug
                                        2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Got terminate signal TERMINATE_YOURSELF
                                        2023-12-12 23:12:03.174  - info: proxmox.0 (365461) terminating
                                        2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-12-12 23:12:03.303  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                                        2023-12-12 23:12:03.676  - info: proxmox.0 (365461) terminating
                                        2023-12-12 23:12:03.811  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-12-12 23:12:06.413  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395336
                                        2023-12-12 23:12:06.842  - debug: proxmox.0 (395336) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-12-12 23:12:06.875  - debug: proxmox.0 (395336) Objects client ready ... initialize now
                                        2023-12-12 23:12:06.919  - debug: proxmox.0 (395336) Objects create System PubSub Client
                                        2023-12-12 23:12:06.920  - debug: proxmox.0 (395336) Objects create User PubSub Client
                                        2023-12-12 23:12:06.981  - debug: proxmox.0 (395336) Objects client initialize lua scripts
                                        2023-12-12 23:12:06.991  - debug: proxmox.0 (395336) Objects connected to redis: 127.0.0.1:9001
                                        2023-12-12 23:12:07.024  - debug: proxmox.0 (395336) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-12-12 23:12:07.091  - debug: proxmox.0 (395336) States create System PubSub Client
                                        2023-12-12 23:12:07.092  - debug: proxmox.0 (395336) States create User PubSub Client
                                        2023-12-12 23:12:07.172  - debug: proxmox.0 (395336) States connected to redis: 127.0.0.1:9000
                                        2023-12-12 23:12:07.548  - info: proxmox.0 (395336) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                                        2023-12-12 23:12:07.562  - warn: proxmox.0 (395336) Using Proxmox API: https://192.168.99.58:8006/api2/json
                                        2023-12-12 23:12:07.688  - debug: proxmox.0 (395336) received 200 response from /access/ticket?username=root@pam&password=%23********** with content: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                                        2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) dataticket: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                                        2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) Updating ticket to "PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc
                                        Bernd
                                        • arteckA arteck
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          #318
                                          Die Zeile kommt ja im Log mehrmals vor. Sind also ein Paar Neustarts drinnen.
                                          Debug hatte ich scheinbar noch eingestellt, wie @dp20eic schon gesehen hat.
                                          Der Admin gibt mir keine Fehlermeldungen über einen regelmäßigen Absturz vom Adapter.
                                          Er ist im Moment auch grün und lauft trotzdem nicht.
