  3. Entwicklung
  4. [Neuer Adapter] Proxmox VM
    6.5k
proxmox
486 Beiträge 75 Kommentatoren 175.4k Aufrufe 57 Beobachtet
  • NegaleinN Negalein
    Hallo
    Hat noch jemand das Problem mit has no existing object, this might lead to an error in future versions?
    Issue hab ich gerade erstellt.
    arteckA Offline
    arteckA Offline
    arteck
    #292
    @negalein welche adapter version..ahh ich seh 2.2.0
    da wurde das object nicht angelegt
    proxmox.0.storage_proxmox_local-lvm
    lösche den mal .. und starte den adapter neu
    ? NegaleinN 2 Antworten Letzte Antwort
    • arteckA arteck
      #293
      @arteck
      wenn du grad an dem Thema bist, ich hab mal alle Objects von Proxmox geloescht und den Adapter dann neu gestartet, hier kommt das bei den vmid , Adapter Version 2.2.0 :
      2023-10-27 09:16:32.292  - info: host.themachine instance system.adapter.proxmox.0 started with pid 78860
      2023-10-27 09:16:33.146  - info: proxmox.0 (78860) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.proxmox, node: v20.9.0, js-controller: 5.0.14
      2023-10-27 09:16:33.156  - warn: proxmox.0 (78860) Using Proxmox API: https://192.168.0.210:8006/api2/json
      2023-10-27 09:16:33.605  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.docker.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.672  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.bookworm-ilovegym.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.742  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.themachine.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.789  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.redis.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.826  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.octoprint.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.902  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.grafana.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:33.960  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.wireguard.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.023  - info: proxmox.0 (78860) State value to set for "proxmox.0.qemu.pfSense.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.054  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.Network-Test.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.141  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.node-red.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.219  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.uptimekuma.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.275  - info: proxmox.0 (78860) State value to set for "proxmox.0.qemu.iobroker.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:34.335  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.redisdb.vmid" has to be type "string" but received type "number"
      2023-10-27 09:16:32.256  - info: host.themachine "system.adapter.proxmox.0" enabled
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        #294
        @ilovegym schau ich mir an.. welche proxmox version ?? 6,7,8 ?
        • arteckA arteck
          #295
          @arteck
          Proxmox V8.0.4
          • T Nicht stören
            T Nicht stören
            ticaki
            #296
            Adapter v2.2.0
            Proxmox v8.0.4
            Löschen der Objekte und restart.
            Ich habe den String proxmox.0.lxc_pihole.vmid nicht in den letzten 2 Tagen im Log gefunden, scheint also nur bei/mit/vor/nach dem Erstellen der States zu passieren. :)
            2023-10-27 09:59:39.426 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_pihole.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:39.738 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_zigbee2mqtt.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:39.998 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mqtt.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:40.287 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_influxdb.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:40.466 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_bind.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:40.774 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mariadb.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:41.163 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_grafana.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:41.600 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_samba.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:41.718 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_scrypted.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.019 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_plex.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.223 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_wireguard.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.431 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_openssl.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.627 - info: proxmox.0 (1159091) State value to set for "proxmox.0.qemu_iobroker.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.794 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_iobroker-test.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:42.932 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_tautulli.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:43.177 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_wikijs.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:43.307 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mediamtx.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:43.619 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_redis.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:43.760 - info: proxmox.0 (1159091) State value to set for "proxmox.0.qemu_iobroker-devel.vmid" has to be type "string" but received type "number"
            2023-10-27 09:59:43.917 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_bookworm-template-sudo-tim.vmid" has to be type "string" but received type "number"
            Spenden
            • arteckA Offline
              arteckA Offline
              arteck
              #297
              isch guck später nach
              • arteckA arteck
                #298
                @arteck sagte in [Neuer Adapter] Proxmox VM:
                ... wenn du schon dabei bist... hier kam gerade waehrend des Backups des LXC, indem iobroker laeuft, diese Errors:
                2023-10-27 12:26:58.713  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:26:58.714  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:26:58.832  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
                2023-10-27 12:26:58.669  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: unlocked
                2023-10-27 12:27:01.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
                2023-10-27 12:27:01.121  - info: sonoff.0 (640) Client [S5V-4] connection closed: closed
                2023-10-27 12:27:02.964  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Querying lock battery state: failed
                2023-10-27 12:27:03.716  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:08.116  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading config. Result: failed
                2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:09.061  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402429044_5996
                2023-10-27 12:27:11.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
                2023-10-27 12:27:12.460  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading advanced config. Result: failed
                2023-10-27 12:27:13.721  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:21.064  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
                2023-10-27 12:27:23.725  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:31.066  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
                2023-10-27 12:27:32.385  - info: mqtt.1 (1223) Client [Presence1221] connection closed: timeout
                2023-10-27 12:27:33.730  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:43.734  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:48.735  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:48.736  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:53.738  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:27:56.752  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
                2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:02.713  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402482713_3323
                2023-10-27 12:28:03.321  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: unlocked
                2023-10-27 12:28:03.742  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:13.746  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:17.676  - warn: synochat.0 (5912) Attempt to send message '8b032070-74b3-11ee-8289-9fa88030d194' failed due to too fast sending sequence: 'create post too fast' > Delaying the message for 1 second/s...
                2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:23.750  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:33.753  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:41.532  - info: mqtt.1 (1223) Client [Presence1220] connection closed: timeout
                2023-10-27 12:28:43.758  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:48.890  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
                2023-10-27 12:28:53.762  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:01.064  - info: mqtt.1 (1223) Client [Presence1222] connection closed: timeout
                2023-10-27 12:29:02.932  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
                2023-10-27 12:29:03.766  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:29:07.889  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: unlocked
                2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:13.229  - info: mqtt.1 (1223) Client [Presence1220] connected with secret 1698402553186_4082
                2023-10-27 12:29:13.771  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:29:16.778  - info: bluelink.0 (1435) Read new update for KMHKR81AFNU011963 directly from the car
                2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:21.407  - info: sonoff.0 (640) Client [nx4519-1] reconnected. Old secret 1698388565136_7187. New secret 1698402561404_1831
                2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends publish. Ignore! Actual secret is 1698402561404_1831
                2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends pingreq. Ignore! Actual secret is 1698402561404_1831
                2023-10-27 12:29:21.889  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402561878_5954
                2023-10-27 12:29:23.775  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:31.327  - info: mqtt.1 (1223) Client [Presence1222] connected with secret 1698402571314_8823
                2023-10-27 12:29:32.379  - info: tuya.0 (788) 30530530c45bbedb673e: Connect locally to device
                2023-10-27 12:29:32.380  - info: tuya.0 (788) 30530530c45bbedb673e Init with IP=10.1.12.106, Key=>':x*F6`S#`J14cF, Version=3.3
                2023-10-27 12:29:33.779  - error: proxmox.0 (78860) Unable to update ticket: -1
                2023-10-27 12:29:37.865  - info: bluelink.0 (1435) Update for KMHKR81AFNU011963 successfull
                2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
                2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #299
                  @ilovegym sagte in [Neuer Adapter] Proxmox VM:
                  da ist der storage nicht da.. und da du nur 1 node hast oder nur angegeben hast, kann der nicht switchen
                  früher war die meldung unterdrückt
                  • arteckA arteck
                    #300
                    @arteck
                    ja, weil er gerade am backup schreiben ist.. hmmpff d.h. die Meldung kommt jetzt immer, wenn ich ein Backup mache in Proxmox.. ? mit dem LXC.. ?
                    Kann man da das Timeout hoeher setzen.. fuer den Fehler? er kommt genau einmal, wie im Logfile, dann ist wieder ruhe..
                    • arteckA arteck
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #301
                      Danke, funktioniert wieder.
                      ° Fixer ---> iob fix
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #302
                        @ilovegym dann guckemal jetzt
                        • arteckA arteck
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #303
                          @arteck
                          habe auch von git installiert.
                          Bitte noch überprüfen:
                          maxmem wird bei den Objekten nicht aktualisiert.
                          sowohl dies:
                          als auch dies:
                          Danke.
                          • bahnuhrB bahnuhr
                            @arteck
                            sowohl dies:
                            als auch dies:
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #304
                            @bahnuhr
                            vm :
                            doch..die maschiene muss aber laufen..
                            node schau ich noch
                            das ist die einstellung
                            • arteckA arteck
                              @bahnuhr
                              vm :
                              node schau ich noch
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #305
                              @arteck
                              Na klar ist die Maschine an.
                              Und ja, der DP wird bei start der Instanz aktualisiert.
                              Aber dann nicht mehr.
                              Die anderen DP von mem werden dagegen regelmäßig (so alle 30 Sek.) aktualisiert.
                              Danke.
                              arteckA ? 2 Antworten Letzte Antwort
                              • bahnuhrB bahnuhr
                                @arteck
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #306
                                @bahnuhr guckmal jetzt
                                ausserdem macht der nur eine Aktualisierung wenn sich was geändert hat...
                                • bahnuhrB bahnuhr
                                  @arteck
                                  #307
                                  @bahnuhr sagte in [Neuer Adapter] Proxmox VM:
                                  Moin,
                                  max Mem. ist ja eher ein statischer Wert, der sich nicht laufend ändert, wohin gegen Mem. sich zur Laufzeit schon veränder, Du muss mal mit der Einstellung von MaxMem, spielen und dann schauen, ob die Änderung angezeigt wird.
                                  Bernd
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #308
                                    Neulich ist ja ein DP mit einer JSON der die Backups beinhaltet in den Adapter gekommen.
                                    Ich habe da mal eine kleine Tabelle für meine Visu für gemacht.
                                    Ist die Unterste Tabelle im ersten Post
                                    https://forum.iobroker.net/topic/59661/zusammenstellung-meiner-tabellen?_=1701274643122
                                    Edit:
                                    @Meistertr
                                    Wie oft wird die Datei mit den Infos über die Backups aktualisiert?
                                    Durch die Tabelle habe ich jetzt gemerkt, dass es Teilweise Stunden braucht, bis ich aktuelle Daten bekomme.
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      #309
                                      Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
                                      Mal nach ein paar Minuten, mL nach ein paar Stunden.
                                      Das war der Log vor dem letzten Crash.
                                      Jemand eine Idee?
                                      -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
                                      2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
                                      2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
                                      2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
                                      2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
                                      2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                                      2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
                                      2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
                                      2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                                      2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
                                      Ab hier kommt im Log nichts mehr mit Proxmox.
                                      Adapter v. 2.2.2
                                      Proxmox 8.3.1
                                      Admin: 6.12.0
                                      node: 18.19
                                      O/S: bookworm
                                      • David G.D David G.
                                        Jemand eine Idee?
                                        Adapter v. 2.2.2
                                        Proxmox 8.3.1
                                        Admin: 6.12.0
                                        node: 18.19
                                        O/S: bookworm
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #310
                                        @david-g poste mal den gesammten LOG..
                                        David G.D Eduard77E 2 Antworten Letzte Antwort
                                        • arteckA arteck
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          #311
                                          @arteck
                                          Den gesamten mit allen Adaptern oder nur mit proxmox.0?
