  3. Entwicklung
  4. [Neuer Adapter] Proxmox VM
    6.5k
proxmox
486 Beiträge 75 Kommentatoren 175.4k Aufrufe 57 Beobachtet
  • arteckA arteck
    @negalein welche adapter version..ahh ich seh 2.2.0
    da wurde das object nicht angelegt
    proxmox.0.storage_proxmox_local-lvm
    lösche den mal .. und starte den adapter neu
    #293
    @arteck
    wenn du grad an dem Thema bist, ich hab mal alle Objects von Proxmox geloescht und den Adapter dann neu gestartet, hier kommt das bei den vmid , Adapter Version 2.2.0 :
    2023-10-27 09:16:32.292  - info: host.themachine instance system.adapter.proxmox.0 started with pid 78860
    2023-10-27 09:16:33.146  - info: proxmox.0 (78860) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.proxmox, node: v20.9.0, js-controller: 5.0.14
    2023-10-27 09:16:33.156  - warn: proxmox.0 (78860) Using Proxmox API: https://192.168.0.210:8006/api2/json
    2023-10-27 09:16:33.605  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.docker.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.672  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.bookworm-ilovegym.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.742  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.themachine.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.789  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.redis.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.826  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.octoprint.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.902  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.grafana.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:33.960  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.wireguard.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.023  - info: proxmox.0 (78860) State value to set for "proxmox.0.qemu.pfSense.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.054  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.Network-Test.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.141  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.node-red.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.219  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.uptimekuma.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.275  - info: proxmox.0 (78860) State value to set for "proxmox.0.qemu.iobroker.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:34.335  - info: proxmox.0 (78860) State value to set for "proxmox.0.lxc.redisdb.vmid" has to be type "string" but received type "number"
    2023-10-27 09:16:32.256  - info: host.themachine "system.adapter.proxmox.0" enabled
      @arteck
      arteckA Offline
      arteckA Offline
      arteck
      #294
      @ilovegym schau ich mir an.. welche proxmox version ?? 6,7,8 ?
      • arteckA arteck
        #295
        @arteck
        Proxmox V8.0.4
        • T Nicht stören
          T Nicht stören
          ticaki
          #296
          Adapter v2.2.0
          Proxmox v8.0.4
          Löschen der Objekte und restart.
          Ich habe den String proxmox.0.lxc_pihole.vmid nicht in den letzten 2 Tagen im Log gefunden, scheint also nur bei/mit/vor/nach dem Erstellen der States zu passieren. :)
          2023-10-27 09:59:39.426 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_pihole.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:39.738 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_zigbee2mqtt.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:39.998 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mqtt.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:40.287 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_influxdb.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:40.466 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_bind.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:40.774 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mariadb.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:41.163 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_grafana.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:41.600 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_samba.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:41.718 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_scrypted.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.019 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_plex.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.223 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_wireguard.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.431 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_openssl.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.627 - info: proxmox.0 (1159091) State value to set for "proxmox.0.qemu_iobroker.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.794 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_iobroker-test.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:42.932 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_tautulli.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:43.177 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_wikijs.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:43.307 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_mediamtx.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:43.619 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_redis.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:43.760 - info: proxmox.0 (1159091) State value to set for "proxmox.0.qemu_iobroker-devel.vmid" has to be type "string" but received type "number"
          2023-10-27 09:59:43.917 - info: proxmox.0 (1159091) State value to set for "proxmox.0.lxc_bookworm-template-sudo-tim.vmid" has to be type "string" but received type "number"
          Spenden
          • arteckA Offline
            arteckA Offline
            arteck
            #297
            isch guck später nach
            • arteckA arteck
              #298
              @arteck sagte in [Neuer Adapter] Proxmox VM:
              ... wenn du schon dabei bist... hier kam gerade waehrend des Backups des LXC, indem iobroker laeuft, diese Errors:
              2023-10-27 12:26:58.713  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:26:58.714  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:26:58.832  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
              2023-10-27 12:26:58.669  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: unlocked
              2023-10-27 12:27:01.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
              2023-10-27 12:27:01.121  - info: sonoff.0 (640) Client [S5V-4] connection closed: closed
              2023-10-27 12:27:02.964  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Querying lock battery state: failed
              2023-10-27 12:27:03.716  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:08.116  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading config. Result: failed
              2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:09.061  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402429044_5996
              2023-10-27 12:27:11.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
              2023-10-27 12:27:12.460  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading advanced config. Result: failed
              2023-10-27 12:27:13.721  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:21.064  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
              2023-10-27 12:27:23.725  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:31.066  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
              2023-10-27 12:27:32.385  - info: mqtt.1 (1223) Client [Presence1221] connection closed: timeout
              2023-10-27 12:27:33.730  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:43.734  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:48.735  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:48.736  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:53.738  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:27:56.752  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
              2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:02.713  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402482713_3323
              2023-10-27 12:28:03.321  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: unlocked
              2023-10-27 12:28:03.742  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:13.746  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:17.676  - warn: synochat.0 (5912) Attempt to send message '8b032070-74b3-11ee-8289-9fa88030d194' failed due to too fast sending sequence: 'create post too fast' > Delaying the message for 1 second/s...
              2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:23.750  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:33.753  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:41.532  - info: mqtt.1 (1223) Client [Presence1220] connection closed: timeout
              2023-10-27 12:28:43.758  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:48.890  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
              2023-10-27 12:28:53.762  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:01.064  - info: mqtt.1 (1223) Client [Presence1222] connection closed: timeout
              2023-10-27 12:29:02.932  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
              2023-10-27 12:29:03.766  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:29:07.889  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: unlocked
              2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:13.229  - info: mqtt.1 (1223) Client [Presence1220] connected with secret 1698402553186_4082
              2023-10-27 12:29:13.771  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:29:16.778  - info: bluelink.0 (1435) Read new update for KMHKR81AFNU011963 directly from the car
              2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:21.407  - info: sonoff.0 (640) Client [nx4519-1] reconnected. Old secret 1698388565136_7187. New secret 1698402561404_1831
              2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends publish. Ignore! Actual secret is 1698402561404_1831
              2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends pingreq. Ignore! Actual secret is 1698402561404_1831
              2023-10-27 12:29:21.889  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402561878_5954
              2023-10-27 12:29:23.775  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:31.327  - info: mqtt.1 (1223) Client [Presence1222] connected with secret 1698402571314_8823
              2023-10-27 12:29:32.379  - info: tuya.0 (788) 30530530c45bbedb673e: Connect locally to device
              2023-10-27 12:29:32.380  - info: tuya.0 (788) 30530530c45bbedb673e Init with IP=10.1.12.106, Key=>':x*F6`S#`J14cF, Version=3.3
              2023-10-27 12:29:33.779  - error: proxmox.0 (78860) Unable to update ticket: -1
              2023-10-27 12:29:37.865  - info: bluelink.0 (1435) Update for KMHKR81AFNU011963 successfull
              2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
              2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
                arteckA Offline
                arteckA Offline
                arteck
                #299
                @ilovegym sagte in [Neuer Adapter] Proxmox VM:
                da ist der storage nicht da.. und da du nur 1 node hast oder nur angegeben hast, kann der nicht switchen
                früher war die meldung unterdrückt
                • arteckA arteck
                  #300
                  @arteck
                  ja, weil er gerade am backup schreiben ist.. hmmpff d.h. die Meldung kommt jetzt immer, wenn ich ein Backup mache in Proxmox.. ? mit dem LXC.. ?
                  Kann man da das Timeout hoeher setzen.. fuer den Fehler? er kommt genau einmal, wie im Logfile, dann ist wieder ruhe..
                  • arteckA arteck
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #301
                    Danke, funktioniert wieder.
                    ° Fixer ---> iob fix
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #302
                      @ilovegym dann guckemal jetzt
                      • arteckA arteck
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #303
                        @arteck
                        habe auch von git installiert.
                        Bitte noch überprüfen:
                        maxmem wird bei den Objekten nicht aktualisiert.
                        sowohl dies:
                        als auch dies:
                        Danke.
                        • bahnuhrB bahnuhr
                          @arteck
                          sowohl dies:
                          als auch dies:
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #304
                          @bahnuhr
                          vm :
                          doch..die maschiene muss aber laufen..
                          node schau ich noch
                          das ist die einstellung
                          • arteckA arteck
                            @bahnuhr
                            vm :
                            node schau ich noch
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #305
                            @arteck
                            Na klar ist die Maschine an.
                            Und ja, der DP wird bei start der Instanz aktualisiert.
                            Aber dann nicht mehr.
                            Die anderen DP von mem werden dagegen regelmäßig (so alle 30 Sek.) aktualisiert.
                            Danke.
                            arteckA ? 2 Antworten Letzte Antwort
                            • bahnuhrB bahnuhr
                              @arteck
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #306
                              @bahnuhr guckmal jetzt
                              ausserdem macht der nur eine Aktualisierung wenn sich was geändert hat...
                              • bahnuhrB bahnuhr
                                @arteck
                                #307
                                @bahnuhr sagte in [Neuer Adapter] Proxmox VM:
                                Moin,
                                max Mem. ist ja eher ein statischer Wert, der sich nicht laufend ändert, wohin gegen Mem. sich zur Laufzeit schon veränder, Du muss mal mit der Einstellung von MaxMem, spielen und dann schauen, ob die Änderung angezeigt wird.
                                Bernd
                                • David G.D Online
                                  David G.D Online
                                  David G.
                                  #308
                                  Neulich ist ja ein DP mit einer JSON der die Backups beinhaltet in den Adapter gekommen.
                                  Ich habe da mal eine kleine Tabelle für meine Visu für gemacht.
                                  Ist die Unterste Tabelle im ersten Post
                                  https://forum.iobroker.net/topic/59661/zusammenstellung-meiner-tabellen?_=1701274643122
                                  Edit:
                                  @Meistertr
                                  Wie oft wird die Datei mit den Infos über die Backups aktualisiert?
                                  Durch die Tabelle habe ich jetzt gemerkt, dass es Teilweise Stunden braucht, bis ich aktuelle Daten bekomme.
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #309
                                    Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
                                    Mal nach ein paar Minuten, mL nach ein paar Stunden.
                                    Das war der Log vor dem letzten Crash.
                                    Jemand eine Idee?
                                    -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
                                    2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
                                    2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
                                    2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
                                    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
                                    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                                    2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
                                    2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
                                    2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                                    2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
                                    Ab hier kommt im Log nichts mehr mit Proxmox.
                                    Adapter v. 2.2.2
                                    Proxmox 8.3.1
                                    Admin: 6.12.0
                                    node: 18.19
                                    O/S: bookworm
                                    • David G.D David G.
                                      Jemand eine Idee?
                                      Adapter v. 2.2.2
                                      Proxmox 8.3.1
                                      Admin: 6.12.0
                                      node: 18.19
                                      O/S: bookworm
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #310
                                      @david-g poste mal den gesammten LOG..
                                      David G.D Eduard77E 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #311
                                        @arteck
                                        Den gesamten mit allen Adaptern oder nur mit proxmox.0?
                                          @arteck
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #312
                                          @david-g gesamt
