  3. Entwicklung
  4. [Neuer Adapter] Proxmox VM
    6.5k
proxmox
486 Beiträge 75 Kommentatoren 175.4k Aufrufe 57 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    #309
    Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
    Mal nach ein paar Minuten, mL nach ein paar Stunden.
    Das war der Log vor dem letzten Crash.
    Jemand eine Idee?
    -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
    2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
    2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
    2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
    2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
    2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
    2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
    2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
    Ab hier kommt im Log nichts mehr mit Proxmox.
    Adapter v. 2.2.2
    Proxmox 8.3.1
    Admin: 6.12.0
    node: 18.19
    O/S: bookworm
    • David G.D David G.
      Jemand eine Idee?
      Adapter v. 2.2.2
      Proxmox 8.3.1
      Admin: 6.12.0
      node: 18.19
      O/S: bookworm
      arteckA Offline
      arteckA Offline
      arteck
      #310
      @david-g poste mal den gesammten LOG..
      David G.D Eduard77E 2 Antworten Letzte Antwort
      • arteckA arteck
        David G.D Online
        David G.D Online
        David G.
        #311
        @arteck
        Den gesamten mit allen Adaptern oder nur mit proxmox.0?
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          #312
          @david-g gesamt
          • arteckA arteck
            @david-g gesamt
            David G.D Online
            David G.D Online
            David G.
            #313
            @arteck
            Das Log ist 13 MB groß.
            Wie darf ich es dir zukommen lassen? Darf hier nicht so viel hochladen.
            Das PW vom Proxmoxuser habe ich ersetzt. Habe gesehen, dass das im Klartext im Log steht.
            Hoffe, das machen die anderen Adapter nicht. Hab beim überfliegen nichts gesehen.
              @arteck
              arteckA Offline
              arteckA Offline
              arteck
              #314
              @david-g was läuft denn da ..13 mb .. alder.
              dann machmal ab 23 Uhr
              • arteckA arteck
                David G.D Online
                David G.D Online
                David G.
                #315
                @arteck
                Anbei:
                iobroker.2023-12-12.log
                Zur Loggröße:
                Am 12ten lief der Proxmoxadapter.
                Da schiebe ich das eindeutig mal auf diesen.......
                Stand aber glaube auch auf debug, da ich mal sehen wollte ich ich was finde warum er abstürzt.
                Grad aber nciht sicher, ob das am 12ten auch noch so war.
                  @arteck
                  Anbei:
                  Zur Loggröße:
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #316
                  @david-g der startet neu.. und läuft danach.. nur warum der neu startet ??
                  stell den mal auf debug,, dann ab der Zeile /das ist der start)
                  bis nach abbruch posten
                  ? David G.D 2 Antworten Letzte Antwort
                  • arteckA arteck
                    #317
                    @arteck sagte in [Neuer Adapter] Proxmox VM:
                    Moin,
                    proxmox.0 steht doch schon auf Debug
                    2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Got terminate signal TERMINATE_YOURSELF
                    2023-12-12 23:12:03.174  - info: proxmox.0 (365461) terminating
                    2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-12-12 23:12:03.303  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                    2023-12-12 23:12:03.676  - info: proxmox.0 (365461) terminating
                    2023-12-12 23:12:03.811  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-12-12 23:12:06.413  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395336
                    2023-12-12 23:12:06.842  - debug: proxmox.0 (395336) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2023-12-12 23:12:06.875  - debug: proxmox.0 (395336) Objects client ready ... initialize now
                    2023-12-12 23:12:06.919  - debug: proxmox.0 (395336) Objects create System PubSub Client
                    2023-12-12 23:12:06.920  - debug: proxmox.0 (395336) Objects create User PubSub Client
                    2023-12-12 23:12:06.981  - debug: proxmox.0 (395336) Objects client initialize lua scripts
                    2023-12-12 23:12:06.991  - debug: proxmox.0 (395336) Objects connected to redis: 127.0.0.1:9001
                    2023-12-12 23:12:07.024  - debug: proxmox.0 (395336) Redis States: Use Redis connection: 127.0.0.1:9000
                    2023-12-12 23:12:07.091  - debug: proxmox.0 (395336) States create System PubSub Client
                    2023-12-12 23:12:07.092  - debug: proxmox.0 (395336) States create User PubSub Client
                    2023-12-12 23:12:07.172  - debug: proxmox.0 (395336) States connected to redis: 127.0.0.1:9000
                    2023-12-12 23:12:07.548  - info: proxmox.0 (395336) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                    2023-12-12 23:12:07.562  - warn: proxmox.0 (395336) Using Proxmox API: https://192.168.99.58:8006/api2/json
                    2023-12-12 23:12:07.688  - debug: proxmox.0 (395336) received 200 response from /access/ticket?username=root@pam&password=%23********** with content: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                    2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) dataticket: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                    2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) Updating ticket to "PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc
                    Bernd
                    • arteckA arteck
                      David G.D Online
                      David G.D Online
                      David G.
                      #318
                      Die Zeile kommt ja im Log mehrmals vor. Sind also ein Paar Neustarts drinnen.
                      Debug hatte ich scheinbar noch eingestellt, wie @dp20eic schon gesehen hat.
                      Der Admin gibt mir keine Fehlermeldungen über einen regelmäßigen Absturz vom Adapter.
                      Er ist im Moment auch grün und lauft trotzdem nicht.
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #319
                        @david-g sagte in [Neuer Adapter] Proxmox VM:
                        und das erkennst du wodran ??
                        @dp20eic ja in dem schnippsel.. aber nicht in dem gepostetem langen LOG
                        • arteckA arteck
                          David G.D Online
                          David G.D Online
                          David G.
                          #320
                          Weil seit dem 12ten abends kein einziger DP aktualisiert wurde.
                          Ich stelle nochmal auf Debug und starte den Adapter neu.
                          Hatte ihn extra mal so gelassen.
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #321
                            @david-g welche genau .. die DP werden nur aktualisiert wenn sich was geändert hat..also genau bitte
                            und diw ist der anfrage intervall eingestellt ?
                            • arteckA arteck
                              David G.D Online
                              David G.D Online
                              David G.
                              #322
                              @arteck
                              Anfangs hatte ich den Intervall auf 30sek.
                              Hab es dann auf 5min abgeändert um zu schauen ob der Intervall ggf zu schnell ist.
                              Kontrollieren tu ich es immer anhand der CPU Auslastung der iobroker VM, da sollte sich ja was tun...
                              Außerdem sehe ich es an der Tabelle meiner Backups. Sie Triggert auf Änderung des DPs.
                              Stand bis eben noch am 12.12., jetzt nach dem Neustart ist der 14.12 aktuell.
                              Hab mir grad mal ein kleines Skript geschrieben, damit ich sehe wann der Adapter aussteigt.
                              Abfrageintervall steht auf 2min.
                                @arteck
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                #323
                                @david-g ich habe das Problem auch schon paar Tage. Habe auch paar Downgrades des Proxmox Adapters ausprobiert. Ich baue erstmal einen Neustartzeitplan ein. Einmal täglich.
                                Grad fiel mir auf, dass der Adapter fast 2 Tage nix geliefert hatte. Nach einem Adapterneustart läuft es dann wieder:
                                Host: NUC8i3 mit Proxmox:
                                • Slave: Pi4
                                • lobomauL lobomau
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #324
                                  @lobomau
                                  Dann bin ich ja nicht alleine.
                                    @lobomau
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #325
                                    Nein, bei mir auch.
                                    Ist mir erst jetzt aufgefallen.
                                    ° Fixer ---> iob fix
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      #326
                                      Ob das evtl mit Proxmox 8 zu tun hat?
                                      Das Problem kann es ja noch nicht so lange geben.
                                      Das 8er ist ja recht "neu".
                                      Oder wurde am Adapter zuletzt auch viel überarbeitet?
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #327
                                        Nein, da bei mir noch 7.2-7 läuft.
                                        • David G.D Online
                                          David G.D Online
                                          David G.
                                          #328
                                          @arteck
                                          Gestern Abend ist der Adapter wieder ausgestiegen.
                                          Hier die letzte Aktualisierung
                                          Das runtergadene Log ist (gepackt) 5 MB groß.
                                          Darf ich es dir mailen? Ka ob ich überall alle Passwörter finde. Dann muss ich es nicht hier hochladen.
                                          EDIT
                                          War das zuletzt nicht eine ähnliche Uhrzeit wo der Adapter zuletzt gelaufen ist?
