  3. Entwicklung
  4. [Neuer Adapter] Proxmox VM
    6.5k
proxmox
486 Beiträge 75 Kommentatoren 175.4k Aufrufe 57 Beobachtet
  • David G.D David G.
    Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
    Mal nach ein paar Minuten, mL nach ein paar Stunden.
    Das war der Log vor dem letzten Crash.
    Jemand eine Idee?
    -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
    2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
    2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
    2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
    2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
    2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
    2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
    2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
    2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
    Ab hier kommt im Log nichts mehr mit Proxmox.
    Adapter v. 2.2.2
    Proxmox 8.3.1
    Admin: 6.12.0
    node: 18.19
    O/S: bookworm
    arteckA Offline
    arteckA Offline
    arteck
    #310
    @david-g poste mal den gesammten LOG..
    David G.D Eduard77E 2 Antworten Letzte Antwort
    • arteckA arteck
      David G.D Online
      David G.D Online
      David G.
      #311
      @arteck
      Den gesamten mit allen Adaptern oder nur mit proxmox.0?
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        #312
        @david-g gesamt
        • arteckA arteck
          @david-g gesamt
          David G.D Online
          David G.D Online
          David G.
          #313
          @arteck
          Das Log ist 13 MB groß.
          Wie darf ich es dir zukommen lassen? Darf hier nicht so viel hochladen.
          Das PW vom Proxmoxuser habe ich ersetzt. Habe gesehen, dass das im Klartext im Log steht.
          Hoffe, das machen die anderen Adapter nicht. Hab beim überfliegen nichts gesehen.
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            #314
            @david-g was läuft denn da ..13 mb .. alder.
            dann machmal ab 23 Uhr
            • arteckA arteck
              David G.D Online
              David G.D Online
              David G.
              #315
              @arteck
              Anbei:
              iobroker.2023-12-12.log
              Zur Loggröße:
              Am 12ten lief der Proxmoxadapter.
              Da schiebe ich das eindeutig mal auf diesen.......
              Stand aber glaube auch auf debug, da ich mal sehen wollte ich ich was finde warum er abstürzt.
              Grad aber nciht sicher, ob das am 12ten auch noch so war.
                @arteck
                Anbei:
                Zur Loggröße:
                arteckA Offline
                arteckA Offline
                arteck
                #316
                @david-g der startet neu.. und läuft danach.. nur warum der neu startet ??
                stell den mal auf debug,, dann ab der Zeile /das ist der start)
                bis nach abbruch posten
                ? David G.D 2 Antworten Letzte Antwort
                • arteckA arteck
                  #317
                  @arteck sagte in [Neuer Adapter] Proxmox VM:
                  Moin,
                  proxmox.0 steht doch schon auf Debug
                  2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Got terminate signal TERMINATE_YOURSELF
                  2023-12-12 23:12:03.174  - info: proxmox.0 (365461) terminating
                  2023-12-12 23:12:03.174  - info: proxmox.0 (365461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-12-12 23:12:03.303  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                  2023-12-12 23:12:03.676  - info: proxmox.0 (365461) terminating
                  2023-12-12 23:12:03.811  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-12-12 23:12:06.413  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395336
                  2023-12-12 23:12:06.842  - debug: proxmox.0 (395336) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-12-12 23:12:06.875  - debug: proxmox.0 (395336) Objects client ready ... initialize now
                  2023-12-12 23:12:06.919  - debug: proxmox.0 (395336) Objects create System PubSub Client
                  2023-12-12 23:12:06.920  - debug: proxmox.0 (395336) Objects create User PubSub Client
                  2023-12-12 23:12:06.981  - debug: proxmox.0 (395336) Objects client initialize lua scripts
                  2023-12-12 23:12:06.991  - debug: proxmox.0 (395336) Objects connected to redis: 127.0.0.1:9001
                  2023-12-12 23:12:07.024  - debug: proxmox.0 (395336) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-12-12 23:12:07.091  - debug: proxmox.0 (395336) States create System PubSub Client
                  2023-12-12 23:12:07.092  - debug: proxmox.0 (395336) States create User PubSub Client
                  2023-12-12 23:12:07.172  - debug: proxmox.0 (395336) States connected to redis: 127.0.0.1:9000
                  2023-12-12 23:12:07.548  - info: proxmox.0 (395336) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                  2023-12-12 23:12:07.562  - warn: proxmox.0 (395336) Using Proxmox API: https://192.168.99.58:8006/api2/json
                  2023-12-12 23:12:07.688  - debug: proxmox.0 (395336) received 200 response from /access/ticket?username=root@pam&password=%23********** with content: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                  2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) dataticket: {"data":{"username":"root@pam","cap":{"nodes":{"Sys.Syslog":1,"Sys.Audit":1,"Permissions.Modify":1,"Sys.PowerMgmt":1,"Sys.Modify":1,"Sys.Console":1,"Sys.Incoming":1},"mapping":{"Mapping.Audit":1,"Permissions.Modify":1,"Mapping.Modify":1,"Mapping.Use":1},"access":{"User.Modify":1,"Permissions.Modify":1,"Group.Allocate":1},"sdn":{"Permissions.Modify":1,"SDN.Allocate":1,"SDN.Audit":1,"SDN.Use":1},"vms":{"VM.Config.Cloudinit":1,"Permissions.Modify":1,"VM.Snapshot.Rollback":1,"VM.PowerMgmt":1,"VM.Config.CPU":1,"VM.Backup":1,"VM.Config.Network":1,"VM.Snapshot":1,"VM.Config.Disk":1,"VM.Migrate":1,"VM.Clone":1,"VM.Allocate":1,"VM.Config.HWType":1,"VM.Config.CDROM":1,"VM.Config.Options":1,"VM.Console":1,"VM.Audit":1,"VM.Config.Memory":1,"VM.Monitor":1},"storage":{"Datastore.AllocateTemplate":1,"Datastore.AllocateSpace":1,"Permissions.Modify":1,"Datastore.Allocate":1,"Datastore.Audit":1},"dc":{"Sys.Audit":1,"SDN.Allocate":1,"SDN.Audit":1,"Sys.Modify":1,"SDN.Use":1}},"CSRFPreventionToken":"6578DAB7:JMkHnQHWRxXqCzySEBJxywj2sHYusuv6MkJ24yFkFVM","ticket":"PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc80SYJA2X8Kpmm1qbRARgZg2PrrpS+0yOYfe0luY+X7Dho2c/L8Ukn5jskVoyiyAwhyPu1ZKT28sTPvcpIPdJ/2kNLEy6Nb+uR0XvUAA=="}}
                  2023-12-12 23:12:07.691  - debug: proxmox.0 (395336) Updating ticket to "PVE:root@pam:6578DAB7::Y/sZiRygHY6y5zMUWGFTFNBXL6krD62rJ93E3q7Gh9LP1Ww0usgQelwNcS2//vMf5kaVn5sMDvZyXAUFUyoxSionNJo1zg+Ry7KkuHC0kBN2toxxUZjTHaf/3emgrkasCyS1qR12lVB/+6Gc6Vq+eq+Gg+iqV1cdv/Uuv7k6rbg0D4c3Kdf0aCSAAZACRxf0uz3/LdZL2v6gEw7gTaPecjYqexKplEJDNYLRNLtw1D5P/Qc
                  Bernd
                  • arteckA arteck
                    David G.D Online
                    David G.D Online
                    David G.
                    #318
                    Die Zeile kommt ja im Log mehrmals vor. Sind also ein Paar Neustarts drinnen.
                    Debug hatte ich scheinbar noch eingestellt, wie @dp20eic schon gesehen hat.
                    Der Admin gibt mir keine Fehlermeldungen über einen regelmäßigen Absturz vom Adapter.
                    Er ist im Moment auch grün und lauft trotzdem nicht.
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #319
                      @david-g sagte in [Neuer Adapter] Proxmox VM:
                      und das erkennst du wodran ??
                      @dp20eic ja in dem schnippsel.. aber nicht in dem gepostetem langen LOG
                      • arteckA arteck
                        David G.D Online
                        David G.D Online
                        David G.
                        #320
                        Weil seit dem 12ten abends kein einziger DP aktualisiert wurde.
                        Ich stelle nochmal auf Debug und starte den Adapter neu.
                        Hatte ihn extra mal so gelassen.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #321
                          @david-g welche genau .. die DP werden nur aktualisiert wenn sich was geändert hat..also genau bitte
                          und diw ist der anfrage intervall eingestellt ?
                          • arteckA arteck
                            David G.D Online
                            David G.D Online
                            David G.
                            #322
                            @arteck
                            Anfangs hatte ich den Intervall auf 30sek.
                            Hab es dann auf 5min abgeändert um zu schauen ob der Intervall ggf zu schnell ist.
                            Kontrollieren tu ich es immer anhand der CPU Auslastung der iobroker VM, da sollte sich ja was tun...
                            Außerdem sehe ich es an der Tabelle meiner Backups. Sie Triggert auf Änderung des DPs.
                            Stand bis eben noch am 12.12., jetzt nach dem Neustart ist der 14.12 aktuell.
                            Hab mir grad mal ein kleines Skript geschrieben, damit ich sehe wann der Adapter aussteigt.
                            Abfrageintervall steht auf 2min.
                              @arteck
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              #323
                              @david-g ich habe das Problem auch schon paar Tage. Habe auch paar Downgrades des Proxmox Adapters ausprobiert. Ich baue erstmal einen Neustartzeitplan ein. Einmal täglich.
                              Grad fiel mir auf, dass der Adapter fast 2 Tage nix geliefert hatte. Nach einem Adapterneustart läuft es dann wieder:
                              Host: NUC8i3 mit Proxmox:
                              • Slave: Pi4
                              • lobomauL lobomau
                                David G.D Online
                                David G.D Online
                                David G.
                                #324
                                @lobomau
                                Dann bin ich ja nicht alleine.
                                  @lobomau
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #325
                                  Nein, bei mir auch.
                                  Ist mir erst jetzt aufgefallen.
                                  ° Fixer ---> iob fix
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #326
                                    Ob das evtl mit Proxmox 8 zu tun hat?
                                    Das Problem kann es ja noch nicht so lange geben.
                                    Das 8er ist ja recht "neu".
                                    Oder wurde am Adapter zuletzt auch viel überarbeitet?
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #327
                                      Nein, da bei mir noch 7.2-7 läuft.
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        #328
                                        @arteck
                                        Gestern Abend ist der Adapter wieder ausgestiegen.
                                        Hier die letzte Aktualisierung
                                        Das runtergadene Log ist (gepackt) 5 MB groß.
                                        Darf ich es dir mailen? Ka ob ich überall alle Passwörter finde. Dann muss ich es nicht hier hochladen.
                                        EDIT
                                        War das zuletzt nicht eine ähnliche Uhrzeit wo der Adapter zuletzt gelaufen ist?
                                          @arteck
                                          EDIT
                                          #329
                                          Moin,
                                          laut Deinem großen Log von gestern, war es 23:12 Uhr, wann machst Du denn ein Backup? Oder anders ausgedrückt, was läuft denn bei Dir um diese Uhrzeit?
                                          Kannst Du mal in die Logs der Maschine schauen, also nicht ioBroker, sondern Linux, entweder
                                          # sudo journalctl -g proxmox
                                          # sudo journalctl -g error
                                          Bernd
