  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
  • I Offline
    I Offline
    IceD112
    #73
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:03:49 up  2:09,  3 users,  load average: 0.90, 0.59, 0.37
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 20:03:49 CET
               Universal time: Sun 2023-11-26 19:03:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        709M        5.8G         35M        1.3G        6.9G
    Swap:            99M          0B         99M
    Total:          7.9G        709M        5.9G
             7812 M total memory
              709 M used memory
              880 M active memory
              894 M inactive memory
             5840 M free memory
               48 M buffer memory
             1212 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  4.7G   52G   9% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Sun Nov 26 17:54:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:90:AF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=49bd46ba-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov 26 17:54:45 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sun Nov 26 17:54:45 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sun Nov 26 17:54:46 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Nov 26 17:54:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Nov 26 17:54:46 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov 26 17:54:48 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    517M    /var/
    177M    /var/lib
    167M    /var/cache
    155M    /var/cache/apt
    123M    /var/lib/apt/lists
    Archived and active journals take up 72.0M in the file system.
    /opt/iobroker/backups:
    146M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    195M    /opt/iobroker/iobroker-data/
    152M    /opt/iobroker/iobroker-data/files
    74M     /opt/iobroker/iobroker-data/files/vis.0
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          "admin" not found
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
      system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
      system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
      system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 - disabled
      system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
      system.adapter.followthesun.0           : followthesun          : ioBroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 - disabled
      system.adapter.ham.0                    : ham                   : ioBroker                                 - disabled
      system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
      system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
      system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
      system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
      system.adapter.meross.0                 : meross                : ioBroker                                 - disabled
      system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Objects and States
    Objects:        34776
    States:         28751
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27429      4772/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26219      4772/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13720      517/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13659      556/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13719      517/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13661      556/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15633      477/dhcpcd
    udp        0      0 0.0.0.0:33021           0.0.0.0:*                           108        11761      398/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11870      590/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11759      398/avahi-daemon: r
    udp6       0      0 :::52181                :::*                                108        11762      398/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15713      477/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11760      398/avahi-daemon: r
    2023-11-26 20:03:32.511  - info: host.ioBroker iobroker npm-install: upload [19] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/982.png 982.png image/png
    2023-11-26 20:03:32.524  - info: host.ioBroker iobroker npm-install: upload [18] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/983.png 983.png image/png
    2023-11-26 20:03:32.539  - info: host.ioBroker iobroker npm-install: upload [17] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/984.png 984.png image/png
    2023-11-26 20:03:32.553  - info: host.ioBroker iobroker npm-install: upload [16] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/985.png 985.png image/png
    2023-11-26 20:03:32.566  - info: host.ioBroker iobroker npm-install: upload [15] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/986.png 986.png image/png
    2023-11-26 20:03:32.579  - info: host.ioBroker iobroker npm-install: upload [14] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/987.png 987.png image/png
    2023-11-26 20:03:32.592  - info: host.ioBroker iobroker npm-install: upload [13] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/988.png 988.png image/png
    2023-11-26 20:03:32.605  - info: host.ioBroker iobroker npm-install: upload [12] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/989.png 989.png image/png
    2023-11-26 20:03:32.618  - info: host.ioBroker iobroker npm-install: upload [11] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/99.png 99.png image/png
    2023-11-26 20:03:32.631  - info: host.ioBroker iobroker npm-install: upload [10] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/990.png 990.png image/png
    2023-11-26 20:03:32.645  - info: host.ioBroker iobroker npm-install: upload [9] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/991.png 991.png image/png
    2023-11-26 20:03:32.658  - info: host.ioBroker iobroker npm-install: upload [8] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/992.png 992.png image/png
    2023-11-26 20:03:32.671  - info: host.ioBroker iobroker npm-install: upload [7] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/993.png 993.png image/png
    2023-11-26 20:03:32.684  - info: host.ioBroker iobroker npm-install: upload [6] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/994.png 994.png image/png
    2023-11-26 20:03:32.697  - info: host.ioBroker iobroker npm-install: upload [5] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/995.png 995.png image/png
    2023-11-26 20:03:32.710  - info: host.ioBroker iobroker npm-install: upload [4] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/996.png 996.png image/png
    2023-11-26 20:03:32.723  - info: host.ioBroker iobroker npm-install: upload [3] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/997.png 997.png image/png
    2023-11-26 20:03:32.736  - info: host.ioBroker iobroker npm-install: upload [2] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/998.png 998.png image/png
    2023-11-26 20:03:32.749  - info: host.ioBroker iobroker npm-install: upload [1] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/999.png 999.png image/png
    2023-11-26 20:03:32.762  - info: host.ioBroker iobroker npm-install: upload [0] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/index.html index.html text/html
    2023-11-26 20:03:32.962  - info: host.ioBroker iobroker npm-install: host.ioBroker object system.adapter.icons-ultimate-png created/updated
    2023-11-26 20:03:34.178  - info: host.ioBroker iobroker npm-install: exit 0
    2023-11-26 20:03:35.179  - warn: host.ioBroker startInstance cannot find adapter "vis-icontwo@0.97.3". Try to install it... 1 attempt
    2023-11-26 20:03:35.179  - info: host.ioBroker iobroker install vis-icontwo@0.97.3 using installedFrom
    2023-11-26 20:03:40.041  - info: host.ioBroker iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-icontwo@0.97.3... (System call)
    iob diag has finished.
    Press any key for a summary
    • Marc BergM Marc Berg
      @iced112 sagte in Backup Größe ioBroker:
      also den VIS Adapter vor dem Wiederherstellen installieren?
      Ja, ist besser, da VIS sonst nicht läuft. Alternativ VIS down- und dann wieder upgraden, musst du mal suchen, gibt es etliche Threads zu.
      Kam grade zurück und die Wiederherstellung läut noch... ich glaub mit dem Backup tut sich nichts. Ich versuch noch ein anderes
      Das kann schon mal ein wenig dauern. Passen denn die js-controller Versionen von Quelle und Ziel zusammen?
      I Offline
      I Offline
      IceD112
      #74
      @marc-berg said in Backup Größe ioBroker:
      die sollten passen
      auf alt 5.0.16
      auf neu 5.0.16
      laut diag
      • I IceD112
        die sollten passen
        auf alt 5.0.16
        auf neu 5.0.16
        laut diag
        Marc BergM Online
        Marc BergM Online
        Marc Berg
        #75
        @iced112
        Admin Adapter läuft nicht, wie ich das sehe.
        iob start admin
        Logs?
        I 1 Antwort Letzte Antwort
          @iced112
          iob start admin
          Logs?
          I Offline
          I Offline
          IceD112
          schrieb am zuletzt editiert von IceD112
          #76
          @marc-berg
          ne, doch der läuft doch, aber
          iob start admin
          hat jetzt auch keine abhilfe geschaffen
          Vielleicht ist die Wiederherstellung schiefgelaufen?
          • I Offline
            I Offline
            IceD112
            #77
            kann ich die die auch mit nem Befehl über ssh nochmal neu versuchen?
            • Marc BergM Online
              Marc BergM Online
              Marc Berg
              #78
              verstehe ich jetzt nicht, muss mich aber jetzt auch erstmal ausklinken.
              • I IceD112
                @marc-berg
                iob start admin
                HomoranH Offline
                HomoranH Offline
                #79
                laut diag aber nicht.
                Hast du da was zusammengeschnitten?
                Adapter und Instanzen sind irgendwie komisch, auch die {1} immer wieder
                • I Offline
                  I Offline
                  IceD112
                  #80
                  @Homoran
                  hab jetzt mal über ssh einen restore gemacht
                  sudo iobroker restore 0
                  sudo iobroker start all
                  sudo iobroker start
                  sudo iobroker upload all
                  In der Konsole hat man gesehen, dass er sämtliche Instanzen und auch die VIS projekte aus dem Backup rein gespielt hat. Ich komm jetzt auch wieder auf den Admin aber die ganzem instanzen fehlen. Sieht eigentlich wie eine Neuinstallation aus😬
                  HomoranH DJMarc75D 2 Antworten Letzte Antwort
                  • I IceD112
                    @Homoran
                    sudo iobroker start
                    HomoranH Offline
                    HomoranH Offline
                    #81
                    @iced112 entweder nochmal iob diag oder iob list instances und iob list adapters
                    dass ein restore aber bis zu 1h dauern kann weisst du?
                    • I IceD112
                      @Homoran
                      sudo iobroker start
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #82
                      wo hast Du denn diese Befehle her ???
                      iobroker wird NIE mit sudo angefasst !!
                      Lehrling seit 1975 !!!
                      • DJMarc75D DJMarc75
                        I Offline
                        I Offline
                        IceD112
                        #83
                        @djmarc75
                        aus m Netz
                        @Homoran
                        pi@ioBroker:~ $ iob list instances
                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                        + instance is alive
                        pi@ioBroker:~ $ iob list adapters
                        system.adapter.admin                   : admin          - v6.10.1
                        system.adapter.backitup                : backitup       - v2.8.7
                        system.adapter.discovery               : discovery      - v4.2.0
                        pi@ioBroker:~ $
                        seltsam, dass er beim restore alles angezeigt hat. das verstehe ich nicht
                        • I IceD112
                          @djmarc75
                          aus m Netz
                          @Homoran
                          + instance is alive
                          pi@ioBroker:~ $
                          HomoranH Offline
                          HomoranH Offline
                          #84
                          @iced112
                          iob stop
                          iob fix
                          iob start
                          wenn es dann läuft iob diag
                          wo hast du das denn mit dem Restore und der 0 her?
                          Da sollte man den Dateinamen eingeben.
                            @iced112
                            iob stop
                            iob fix
                            iob start
                            I Offline
                            I Offline
                            IceD112
                            #85
                            von hier
                            https://www.smarthome-tricks.de/software-iobroker/manuelle-sicherung-von-iobroker/
                            ich versuch für heute mal noch ein letztes mal die Wiederherstellung über den Backitup Adapter
                            An der Stelle bleibt er aber immer stehen und geht nicht weiter.
                            Wenn das gleich nicht weiter läuft, werde ich morgen nochmal ein Backup vom alten machen und beim neuen Pi von vorne beginnen. Hab schon viereckige Augen
                            wenn die Wiederherstellung doch noch durch läuft, dann bekommst du das
                            iob diag
                            • I IceD112
                              von hier
                              iob diag
                              HomoranH Offline
                              HomoranH Offline
                              #86
                              hier werden jetzt erst die Adapter Stück für Stück neu gebaut.
                              Das dauert!
                              über SSH mit iob logs --watch kannst du sehen was passiert
                              • I Offline
                                I Offline
                                IceD112
                                #87
                                Nu warten bis der Lade-Kreis vom ioB aufhört? oder einfach neu laden?
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 21:52:36 up 21 min,  3 users,  load average: 1.83, 0.92, 0.49
                                CPU threads: 4
                                Current issues:
                                               Local time: Sun 2023-11-26 21:52:36 CET
                                           Universal time: Sun 2023-11-26 20:52:36 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.8G        655M        5.9G         35M        1.2G        7.0G
                                Swap:            99M          0B         99M
                                Total:          7.9G        655M        6.0G
                                         7812 M total memory
                                          656 M used memory
                                          829 M active memory
                                          857 M inactive memory
                                         5939 M free memory
                                           53 M buffer memory
                                         1163 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  4.9G   51G   9% /
                                [Sun Nov 26 21:30:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:90:AF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=49bd46ba-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): recovery complete
                                [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sun Nov 26 21:30:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sun Nov 26 21:30:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                575M    /var/
                                177M    /var/lib
                                167M    /var/cache
                                155M    /var/cache/apt
                                132M    /var/log
                                Archived and active journals take up 128.0M in the file system.
                                231M    /opt/iobroker/iobroker-data/
                                170M    /opt/iobroker/iobroker-data/files
                                43M     /opt/iobroker/iobroker-data/objects.jsonl
                                19M     /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Adapter State
                                + instance is alive
                                Adapter    "backitup"     : 2.9.4    , installed 2.9.4
                                Objects and States
                                Objects:        34776
                                States:         28760
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11072      554/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12713      515/cupsd
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18178      2241/iobroker.js-co
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18185      2241/iobroker.js-co
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          11074      554/sshd: /usr/sbin
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12712      515/cupsd
                                udp        0      0 0.0.0.0:36350           0.0.0.0:*                           108        13741      396/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      469/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15607      592/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13739      396/avahi-daemon: r
                                udp6       0      0 :::33105                :::*                                108        13742      396/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          16441      469/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        13740      396/avahi-daemon: r
                                2023-11-26 21:53:39.066  - info: host.ioBroker iobroker npm-install: upload [18] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_black_48dp.png social/ic_whatshot_black_48dp.png image/png
                                2023-11-26 21:53:39.302  - info: host.ioBroker iobroker npm-install: upload [17] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_white_12dp.png social/ic_whatshot_white_12dp.png image/png
                                2023-11-26 21:53:39.340  - info: host.ioBroker iobroker npm-install: upload [16] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_white_48dp.png social/ic_whatshot_white_48dp.png image/png
                                2023-11-26 21:53:39.361  - info: host.ioBroker iobroker npm-install: upload [15] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_black_24dp.png toggle/ic_check_box_black_24dp.png image/png
                                2023-11-26 21:53:39.381  - info: host.ioBroker iobroker npm-install: upload [14] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_outline_blank_black_24dp.png toggle/ic_check_box_outline_blank_black_24dp.png image/png
                                2023-11-26 21:53:39.424  - info: host.ioBroker iobroker npm-install: upload [13] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_outline_blank_white_24dp.png toggle/ic_check_box_outline_blank_white_24dp.png image/png
                                2023-11-26 21:53:39.444  - info: host.ioBroker iobroker npm-install: upload [12] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_white_24dp.png toggle/ic_check_box_white_24dp.png image/png
                                2023-11-26 21:53:39.465  - info: host.ioBroker iobroker npm-install: upload [11] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_indeterminate_check_box_black_24dp.png toggle/ic_indeterminate_check_box_black_24dp.png image/png
                                2023-11-26 21:53:39.489  - info: host.ioBroker iobroker npm-install: upload [10] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_indeterminate_check_box_white_24dp.png toggle/ic_indeterminate_check_box_white_24dp.png image/png
                                2023-11-26 21:53:39.516  - info: host.ioBroker iobroker npm-install: upload [9] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_off_black_24dp.png toggle/ic_radio_button_off_black_24dp.png image/png
                                2023-11-26 21:53:39.537  - info: host.ioBroker iobroker npm-install: upload [8] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_off_white_24dp.png toggle/ic_radio_button_off_white_24dp.png image/png
                                2023-11-26 21:53:39.561  - info: host.ioBroker iobroker npm-install: upload [7] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_on_black_24dp.png toggle/ic_radio_button_on_black_24dp.png image/png
                                2023-11-26 21:53:41.099  - info: host.ioBroker iobroker npm-install: upload [6] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_on_white_24dp.png toggle/ic_radio_button_on_white_24dp.png image/png
                                2023-11-26 21:53:41.141  - info: host.ioBroker iobroker npm-install: upload [5] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_black_48dp.png toggle/ic_star_black_48dp.png image/png
                                2023-11-26 21:53:41.167  - info: host.ioBroker iobroker npm-install: upload [4] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_half_black_48dp.png toggle/ic_star_half_black_48dp.png image/png
                                2023-11-26 21:53:41.210  - info: host.ioBroker iobroker npm-install: upload [3] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_half_white_48dp.png toggle/ic_star_half_white_48dp.png image/png
                                2023-11-26 21:53:41.234  - info: host.ioBroker iobroker npm-install: upload [2] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_outline_black_48dp.png toggle/ic_star_outline_black_48dp.png image/png
                                2023-11-26 21:53:41.257  - info: host.ioBroker iobroker npm-install: upload [1] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_outline_white_48dp.png toggle/ic_star_outline_white_48dp.png image/png
                                2023-11-26 21:53:41.282  - info: host.ioBroker iobroker npm-install: upload [0] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_white_48dp.png toggle/ic_star_white_48dp.png image/png
                                2023-11-26 21:53:41.517  - info: host.ioBroker iobroker npm-install: host.ioBroker object system.adapter.icons-material-png created/updated
                                2023-11-26 21:53:42.750  - info: host.ioBroker iobroker npm-install: exit 0
                                2023-11-26 21:53:43.752  - warn: host.ioBroker startInstance cannot find adapter "icons-mfd-png@1.1.0". Try to install it... 1 attempt
                                2023-11-26 21:53:43.752  - info: host.ioBroker iobroker install icons-mfd-png@1.1.0 using installedFrom
                                2023-11-26 21:53:48.294  - info: host.ioBroker iobroker npm-install: NPM version: 9.8.1
                                2023-11-26 21:53:48.298  - info: host.ioBroker iobroker npm-install: Installing iobroker.icons-mfd-png@1.1.0... (System call)
                                • I IceD112
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           7812 M total memory
                                            656 M used memory
                                            829 M active memory
                                           5939 M free memory
                                             53 M buffer memory
                                           1163 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  575M    /var/
                                  177M    /var/lib
                                  167M    /var/cache
                                  155M    /var/cache/apt
                                  132M    /var/log
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        34776
                                  States:         28760
                                  Pending Updates: 0
                                  HomoranH Offline
                                  HomoranH Offline
                                  #88
                                  @iced112 du liest schon was ich schreibe?
                                  @homoran sagte in Backup Größe ioBroker:
                                  Das dauert!
                                    Das dauert!
                                    I Offline
                                    I Offline
                                    IceD112
                                    #89
                                    @homoran said in Backup Größe ioBroker:
                                    sorry, hab ich überlesen
                                    Das dauert!
                                    also kann ich den PC eigentlich aus machen und pennen gehen :-) und morgen nochmal alles checken?
                                    • I IceD112
                                      Das dauert!
                                      CodierknechtC Offline
                                      Codierknecht
                                      #90
                                      @iced112
                                      also kann ich den PC eigentlich aus machen und pennen gehen 🙂 und morgen nochmal alles checken?
                                      Ja! Das macht der Pi auch alleine.
                                      ... und schalte den Desktop ab
                                      X-Server:       true
                                      Sowas hat auf 'nem Server nix zu suchen.
                                      HmIP|ZigBee|Tasmota|Unifi
                                      Zabbix Certified Specialist
                                      • I Offline
                                        I Offline
                                        IceD112
                                        #91
                                        Die Wiederherstellung hat - sagen wir mal - so semi funktioniert.
                                        Es wurden, soweit ich das überblicken kann, alle Objekte wieder hergestellt. Die Adapter sind auch eigentlich alle installiert aber die meisten Instanzen nicht. Wenn ich eine Instanz hinzufüge, dann erstellt er die Instanz.1 aber die .0, also die ursprüngliche Instanz kann ich nicht finden?
                                        • I IceD112
                                          HomoranH Offline
                                          HomoranH Offline
                                          #92
                                          @iced112 wie wär's mit zeigen?
