  4. Kein iobroker Backup mehr über BackitUp Adapter
112 Beiträge 6 Kommentatoren 14.0k Aufrufe 4 Beobachtet
  • L Laser
    @marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
    ls /var/lib/influxdb2
    otto@raspberrypi:~ $ ls /var/lib/influxdb2
    ls: cannot open directory '/var/lib/influxdb2': Permission denied
    otto@raspberrypi:~ $ sudo ls /var/lib/influxdb2
    influxd.bolt
    simatecS Offline
    simatecS Offline
    simatec
    #85
    @laser Zeige mal die Rechte dazu
    sudo ls -lah /var/lib/influxdb2
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    L Marc BergM 2 Antworten Letzte Antwort
    • simatecS simatec
      Laser
      schrieb am zuletzt editiert von Laser
      #86
      @simatec sagte in Kein iobroker Backup mehr über BackitUp Adapter:
      otto@raspberrypi:~ $ sudo ls -lah /var/lib/influxdb2
      total 24K
      drwx------  2 root root 4.0K Nov 20 16:16 .
      drwxr-xr-x 30 root root 4.0K Nov 20 16:16 ..
      -rw-------  1 root root  16K Nov 20 16:16 influxd.bolt
      Hilft das weiter?
      otto@raspberrypi:~ $ sudo service influxdb status
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: active (running) since Mon 2023-11-20 16:18:14 CET; 5min ago
             Docs: https://docs.influxdata.com/influxdb/
          Process: 160456 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
         Main PID: 160457 (influxd)
            Tasks: 11 (limit: 8754)
              CPU: 25.211s
           CGroup: /system.slice/influxdb.service
                   └─160457 /usr/bin/influxd
      Nov 20 16:22:29 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:22:29.456805Z lvl=error msg="api error encountered" log_id=0lcKo5TW000 handler=session error="unauthorized access"
      Nov 20 16:22:34 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:22:34.531661Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:22:44 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:22:44.540406Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:22:46 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:22:46.522636Z lvl=error msg="api error encountered" log_id=0lcKo5TW000 handler=session error="unauthorized access"
      Nov 20 16:22:54 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:22:54.547785Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:23:04 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:23:04.556455Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:23:14 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:23:14.563884Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:23:24 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:23:24.570846Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:23:34 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:23:34.578017Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      Nov 20 16:23:44 raspberrypi influxd-systemd-start.sh[160457]: ts=2023-11-20T15:23:44.584759Z lvl=info msg=Unauthorized log_id=0lcKo5TW000 error="authorization not found"
      • simatecS simatec
        Marc BergM Online
        Marc BergM Online
        Marc Berg
        #87
        und bitte
        sudo ls -lah /etc/influxdb2
        L 1 Antwort Letzte Antwort
        • Marc BergM Marc Berg
          und bitte
          Laser
          #88
          @marc-berg
          otto@raspberrypi:~ $ sudo ls -lah /etc/influxdb2
          ls: cannot access '/etc/influxdb2': No such file or directory
          • L Laser
            @marc-berg
            Marc BergM Online
            Marc BergM Online
            Marc Berg
            #89
            @laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
            Dein Datenverzeichnis für die InfluxDB liegt irgendwo anders, als normal. Versuch mal noch
              Laser
              #90
              @marc-berg
              otto@raspberrypi:/etc $ ls -lah /var/lib/influxdb
              ls: cannot open directory '/var/lib/influxdb': Permission denied
              otto@raspberrypi:/etc $ sudo ls -lah /var/lib/influxdb
              total 296K
              drwxr-x---  4 influxdb influxdb 4.0K Nov 20 16:18 .
              drwxr-x---  3 influxdb influxdb 4.0K May 30 13:44 .cache
              drwxr-x---  5 influxdb influxdb 4.0K May 30 14:02 engine
              -rw-------  1 influxdb influxdb 256K Nov 20 16:18 influxd.bolt
              -rw-r-----  1 influxdb influxdb    7 Nov 20 16:18 influxd.pid
              -rw-r-----  1 influxdb influxdb 120K May 30 13:44 influxd.sqlite
              otto@raspberrypi:/etc $ sudo ls -lah /etc/influxdb
              total 16K
              drwxr-xr-x  2 root root 4.0K Nov 18 18:07 .
              drwxr-xr-x 89 root root 4.0K Nov 18 18:07 ..
              -rw-r--r--  1 root root   86 May 30 13:44 config.toml
              -rw-r--r--  1 root root   86 Nov 18 18:07 config.toml.defaults
              • L Laser
                @marc-berg
                total 296K
                total 16K
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                #91
                @laser
                Okay, dann hast du wahrscheinlich mal ein Update von V1 gemacht. Also:
                influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
                  @laser
                  Laser
                  #92
                  Ja, habe mal upgedatet!
                  DerBefehl auch als "sudo"?
                  otto@raspberrypi:/etc $ influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
                  Error: stat /var/lib/influxdb/influxd.bolt: permission denied
                  See 'influxd -h' for help
                  otto@raspberrypi:/etc $ sudo influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
                  2023-11-20T15:32:46.060743Z     info    Resources opened        {"log_id": "0lcLduR0000", "system": "bolt-kvstore", "path": "/var/lib/influxdb/influxd.bolt"}
                  ID                      User Name       User ID                 Description                                     Token        Permissions
                  0b485bd1c75e4000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1685530468858        zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
                  0c26fdf572986000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1700471139713        oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
                  0c2731d6a8bd8000        iobroker        0b4721cca3305000        iobroker                                        Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
                  0c27485709bd8000        iobroker        0b4721cca3305000        neuer iobroker token                            Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
                  0c27568e5bacd000        iobroker        0b4721cca3305000        iobroker's Recovery Token                       7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==        [read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
                  otto@r
                  simatecS Marc BergM 2 Antworten Letzte Antwort
                  • L Laser
                    otto@r
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #93
                    @laser
                    influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
                    • L Laser
                      otto@r
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      #94
                      @laser
                      Heureka!
                      Jetzt nochmal den
                      influx auth list -t 12345 --json
                      Befehl mit dem zuletzt noch vorhandenen Token.
                      EDIT: vorher die DB wieder starten
                        @laser
                        Heureka!
                        Jetzt nochmal den
                        Laser
                        #95
                        @marc-berg soll ich den Token neu anlegen, oder den zuletzt notierten verwenden?
                        influx auth list -t Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg== --json
                        • L Laser
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #96
                          @laser Habe ich doch oben geschrieben
                          https://forum.iobroker.net/post/1083546
                          • simatecS simatec
                            Laser
                            #97
                            @simatec
                            also:
                            otto@raspberrypi:/etc $ influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
                                            "id": "0b485bd1c75e4000",
                                            "description": "onboarding-cliWizard-token-1685530468858",
                                            "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==",
                                            "status": "active",
                                            "userName": "iobroker",
                                            "userID": "0b4721cca3305000",
                                            "permissions": [
                                                    "read:orgs/56ed5fe7a100c804/annotations",
                                                    "write:orgs/56ed5fe7a100c804/annotations",
                                                    "read:orgs/56ed5fe7a100c804/authorizations",
                                                    "write:orgs/56ed5fe7a100c804/authorizations",
                                                    "read:orgs/56ed5fe7a100c804/buckets",
                                                    "write:orgs/56ed5fe7a100c804/buckets",
                                                    "read:orgs/56ed5fe7a100c804/checks",
                                                    "write:orgs/56ed5fe7a100c804/checks",
                                                    "read:orgs/56ed5fe7a100c804/dashboards",
                                                    "write:orgs/56ed5fe7a100c804/dashboards",
                                                    "read:orgs/56ed5fe7a100c804/dbrp",
                                                    "write:orgs/56ed5fe7a100c804/dbrp",
                                                    "read:orgs/56ed5fe7a100c804/documents",
                                                    "write:orgs/56ed5fe7a100c804/documents",
                                                    "read:orgs/56ed5fe7a100c804/labels",
                                                    "write:orgs/56ed5fe7a100c804/labels",
                                                    "read:orgs/56ed5fe7a100c804/notebooks",
                                                    "write:orgs/56ed5fe7a100c804/notebooks",
                                                    "read:orgs/56ed5fe7a100c804/notificationEndpoints",
                                                    "write:orgs/56ed5fe7a100c804/notificationEndpoints",
                                                    "read:orgs/56ed5fe7a100c804/notificationRules",
                                                    "write:orgs/56ed5fe7a100c804/notificationRules",
                                                    "read:/orgs/56ed5fe7a100c804",
                                                    "read:orgs/56ed5fe7a100c804/remotes",
                                                    "write:orgs/56ed5fe7a100c804/remotes",
                                                    "read:orgs/56ed5fe7a100c804/replications",
                                                    "write:orgs/56ed5fe7a100c804/replications",
                                                    "read:orgs/56ed5fe7a100c804/scrapers",
                                                    "write:orgs/56ed5fe7a100c804/scrapers",
                                                    "read:orgs/56ed5fe7a100c804/secrets",
                                                    "write:orgs/56ed5fe7a100c804/secrets",
                                                    "read:orgs/56ed5fe7a100c804/sources",
                                                    "write:orgs/56ed5fe7a100c804/sources",
                                                    "read:orgs/56ed5fe7a100c804/tasks",
                                                    "write:orgs/56ed5fe7a100c804/tasks",
                                                    "read:orgs/56ed5fe7a100c804/telegrafs",
                                                    "write:orgs/56ed5fe7a100c804/telegrafs",
                                                    "read:/users/0b4721cca3305000",
                                                    "write:/users/0b4721cca3305000",
                                                    "read:orgs/56ed5fe7a100c804/variables",
                                                    "write:orgs/56ed5fe7a100c804/variables",
                                                    "read:orgs/56ed5fe7a100c804/views",
                                                    "write:orgs/56ed5fe7a100c804/views"
                                            "id": "0c26fdf572986000",
                                            "description": "onboarding-cliWizard-token-1700471139713",
                                            "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==",
                                            "status": "active",
                                            "permissions": [
                                            "id": "0c2731d6a8bd8000",
                                            "description": "iobroker",
                                            "token": "Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==",
                                            "status": "active",
                                            "permissions": [
                                            "id": "0c27485709bd8000",
                                            "description": "neuer iobroker token",
                                            "token": "Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==",
                                            "status": "active",
                                            "permissions": [
                                            "id": "0c27568e5bacd000",
                                            "description": "iobroker's Recovery Token",
                                            "token": "7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==",
                                            "status": "active",
                                            "permissions": [
                                                    "read:/authorizations",
                                                    "write:/authorizations",
                                                    "read:/buckets",
                                                    "write:/buckets",
                                                    "read:/dashboards",
                                                    "write:/dashboards",
                                                    "read:/orgs",
                                                    "write:/orgs",
                                                    "read:/sources",
                                                    "write:/sources",
                                                    "read:/tasks",
                                                    "write:/tasks",
                                                    "read:/telegrafs",
                                                    "write:/telegrafs",
                                                    "read:/users",
                                                    "write:/users",
                                                    "read:/variables",
                                                    "write:/variables",
                                                    "read:/scrapers",
                                                    "write:/scrapers",
                                                    "read:/secrets",
                                                    "write:/secrets",
                                                    "read:/labels",
                                                    "write:/labels",
                                                    "read:/views",
                                                    "write:/views",
                                                    "read:/documents",
                                                    "write:/documents",
                                                    "read:/notificationRules",
                                                    "write:/notificationRules",
                                                    "read:/notificationEndpoints",
                                                    "write:/notificationEndpoints",
                                                    "read:/checks",
                                                    "write:/checks",
                                                    "read:/dbrp",
                                                    "write:/dbrp",
                                                    "read:/notebooks",
                                                    "write:/notebooks",
                                                    "read:/annotations",
                                                    "write:/annotations",
                                                    "read:/remotes",
                                                    "write:/remotes",
                                                    "read:/replications",
                                                    "write:/replications"
                            Marc BergM simatecS 2 Antworten Letzte Antwort
                            • L Laser
                              @simatec
                              also:
                                              "status": "active",
                                              "permissions": [
                                              "status": "active",
                                              "permissions": [
                                              "status": "active",
                                              "permissions": [
                                              "status": "active",
                                              "permissions": [
                                              "status": "active",
                                              "permissions": [
                                                      "read:/buckets",
                                                      "write:/buckets",
                                                      "read:/dashboards",
                                                      "read:/orgs",
                                                      "write:/orgs",
                                                      "read:/sources",
                                                      "write:/sources",
                                                      "read:/tasks",
                                                      "write:/tasks",
                                                      "read:/telegrafs",
                                                      "write:/telegrafs",
                                                      "read:/users",
                                                      "write:/users",
                                                      "read:/variables",
                                                      "write:/variables",
                                                      "read:/scrapers",
                                                      "write:/scrapers",
                                                      "read:/secrets",
                                                      "write:/secrets",
                                                      "read:/labels",
                                                      "write:/labels",
                                                      "read:/views",
                                                      "write:/views",
                                                      "read:/documents",
                                                      "write:/documents",
                                                      "read:/checks",
                                                      "write:/checks",
                                                      "read:/dbrp",
                                                      "write:/dbrp",
                                                      "read:/notebooks",
                                                      "write:/notebooks",
                                                      "read:/remotes",
                                                      "write:/remotes",
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              #98
                              Jetzt ist es NICHT MEHR der erste Eintrag, sondern der letzte:
                              "iobroker's Recovery Token", das ist jetzt dein neuer Operator Token:
                              Nicht wieder löschen.
                              • L Laser
                                @simatec
                                also:
                                                "status": "active",
                                                "permissions": [
                                                "status": "active",
                                                "permissions": [
                                                "status": "active",
                                                "permissions": [
                                                "status": "active",
                                                "permissions": [
                                                "status": "active",
                                                "permissions": [
                                                        "read:/buckets",
                                                        "write:/buckets",
                                                        "read:/dashboards",
                                                        "read:/orgs",
                                                        "write:/orgs",
                                                        "read:/sources",
                                                        "write:/sources",
                                                        "read:/tasks",
                                                        "write:/tasks",
                                                        "read:/telegrafs",
                                                        "write:/telegrafs",
                                                        "read:/users",
                                                        "write:/users",
                                                        "read:/variables",
                                                        "write:/variables",
                                                        "read:/scrapers",
                                                        "write:/scrapers",
                                                        "read:/secrets",
                                                        "write:/secrets",
                                                        "read:/labels",
                                                        "write:/labels",
                                                        "read:/views",
                                                        "write:/views",
                                                        "read:/documents",
                                                        "write:/documents",
                                                        "read:/checks",
                                                        "write:/checks",
                                                        "read:/dbrp",
                                                        "write:/dbrp",
                                                        "read:/notebooks",
                                                        "write:/notebooks",
                                                        "read:/remotes",
                                                        "write:/remotes",
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #99
                                @laser Der letzte ist der Operator Token
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #100
                                  @marc-berg Ich schreib da mal ein Wiki Eintrag zu... Der externe Link ist ja tot...
                                  • simatecS simatec
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    #101
                                    Ich habe ne Copy von der Seite, falls interessant.
                                    • simatecS simatec
                                      Laser
                                      #102
                                      @simatec Mein Gott, nun der Letzte- wie soll das ein Normalo kapieren?
                                      Jetzt läuft der Testbefehl auf der Konsole erst mal an.
                                      • L Laser
                                        Marc BergM Online
                                        Marc BergM Online
                                        Marc Berg
                                        #103
                                        Wenn der Löschfinger nicht so locker sitzt, bleibt es ewig der erste Eintrag ... :-)
                                          Laser
                                          #104
                                          @marc-berg Den Löschfinger hatte ich lange im Griff. Aber dann kam der vermeintliche Ordnungssinn hervor!
                                          Der Backupbefehl auf der Konsole läuft erst mal. Wenn der fertig ist, mache ich das über BackItUp.
                                          oder kann man das gefahrlos mit "strg C" abbrechen?
