  3. Einsteigerfragen
  4. Installation
  5. Wie führe ich ein sauberes Updates durch?
52 Beiträge 5 Kommentatoren 8.9k Aufrufe 4 Beobachtet
    @philipp_lappe sagte in Wie führe ich ein sauberes Updates durch?:
    iob upgrade self --debug
    und die anderen Ausgaben?
    philipp_lappe
    pi@homepi_phil:~ $ iob stop
    pi@homepi_phil:~ $
    pi@homepi_phil:~ $ iob fix
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installation fixer!
        Script version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
    Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
    Err:3 http://raspbian.raspberrypi.org/raspbian stretch Release
      404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
    Get:4 https://download.docker.com/linux/raspbian stretch InRelease [31.1 kB]
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_16.x stretch InRelease
    Reading package lists... Done
    E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@homepi_phil:~ $
    pi@homepi_phil:~ $ iob upgrade all
    This upgrade of "yahka" will introduce the following changes:
    -> 1.0.3:
    Corrected empty device list with rebuild
    -> 1.0.1:
    we ensured controller 5 compatibility
    Formatting
    -> 0.17.0:
    Added AVAHI advertiser as default and updated HomeKit Library to improve performance and stability
    -> 0.14.0:
    Updated HomeKit Library
    -> 0.13.2:
    Fixed crashes due to changes in used HomeKit Library
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade yahka from @0.13.1 to @1.0.3 now? [(y)es, (n)o]: No upgrade of "yahka" desired.
    This upgrade of "text2command" will at least introduce the following changes:
    -> 3.0.2:
    Corrected link from admin
    -> 3.0.1:
    Corrected many GUI errors
    -> 2.3.1:
    Migrated GUI to v5
    Would you like to upgrade text2command from @2.3.0 to @3.0.2 now? [(y)es, (n)o]: y
    Update text2command from @2.3.0 to @3.0.2
    NPM version: 8.19.4
    Installing iobroker.text2command@3.0.2... (System call)
    host.homepi_phil Cannot install iobroker.text2command@3.0.2: 244
    pi@homepi_phil:~ $ iob upgrade self --debug
    Update js-controller from @4.0.24 to @5.0.12
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.19.4
    Installing iobroker.js-controller@5.0.12... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/acme-http-01-standalone
    npm ERR! dest /opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acme-http-01-standalone' -> '/opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK'
    npm ERR!     /home/iobroker/.npm/_logs/2023-11-12T22_09_46_524Z-debug-0.log
    host.homepi_phil Cannot install iobroker.js-controller@5.0.12: 217
    • P philipp_lappe
      pi@homepi_phil:~ $
      library: loaded
      Done.
      Autostart enabled!
      pi@homepi_phil:~ $
      -> 1.0.3:
      -> 1.0.1:
      Formatting
      -> 0.17.0:
      -> 0.14.0:
      -> 0.13.2:
      -> 3.0.2:
      -> 3.0.1:
      -> 2.3.1:
      Migrated GUI to v5
      NPM version: 8.19.4
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.19.4
      npm ERR! errno -39
      Ernsthaft?
      Ansonsten jede Menge Fehler, der Fixer ist nicht durchgelaufen,
      Kein Wunder dass nichts gefixt wurde
      • P philipp_lappe
        pi@homepi_phil:~ $
        library: loaded
        Done.
        Autostart enabled!
        pi@homepi_phil:~ $
        -> 1.0.3:
        -> 1.0.1:
        Formatting
        -> 0.17.0:
        -> 0.14.0:
        -> 0.13.2:
        -> 3.0.2:
        -> 3.0.1:
        -> 2.3.1:
        Migrated GUI to v5
        NPM version: 8.19.4
        Stopped Objects DB
        Stopped States DB
        NPM version: 8.19.4
        npm ERR! errno -39
        Ist ja auch schon Quark...
        Schmeiß die bullseye-Quelle raus und reinstalliere nodejs in passender Version.
        P 1 Antwort Letzte Antwort
          philipp_lappe
          @thomas-braun said in Wie führe ich ein sauberes Updates durch?:
          In /etc/apt/sources.list ist nur die stretch Quelle drin. Also kein Plan wo und wie ich die falschen Quellen löschen kann.
          Irgendwann war das System down und dann hatte ich aus lauter Verzweiflung jede Menge probiert und verutlich Chaos angerichtet.
          Es wäre vermutlich doch besser alles von Grund auf neu aufzusetzen oder?
          • P philipp_lappe
            Das ohnehin. Aber ich würde den Umzug mit einem Backup aus einem halbwegs aktuellen ioBroker machen.
            Ist nämlich wesentlich einfacher.
            cat /etc/apt/sources.list.d/node*
            sagt?
              sagt?
              philipp_lappe
              sagt?
              pi@homepi_phil:~ $ cat /etc/apt/sources.list.d/node*
              #node 16
              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
              #node 18
              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye maindeb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
              • P philipp_lappe
                sagt?
                #node 16
                #node 18
                @philipp_lappe
                Da hast du die falschen Einträge. Lösch den ganzen node18 und bullseye - Kram raus, es gibt kein node18 für stretch.
                Also alles bis auf die letzte Zeile raus.
                Dann
                iob stop
                sudo apt update
                sudo apt install --reinstall nodejs
                  @philipp_lappe
                  Dann
                  iob stop
                  sudo apt update
                  philipp_lappe
                  @philipp_lappe
                  Dann
                  iob stop
                  sudo apt update
                  Wenn ich sources.list öffne ist dort nur eine Quelle.
                  • P philipp_lappe
                    @philipp_lappe
                    Dann
                    iob stop
                    sudo apt update
                    @philipp_lappe
                    Das ist ja auch eine andere Datei. Die nodesource.list liegt hier
                    sudo nano /etc/apt/sources.list.d/nodesource.list
                      @philipp_lappe
                      philipp_lappe
                      @philipp_lappe
                      Ich habe alle Einträge bis auf den letzten entfernt, aber trotzdem werden die noch angezeigt. Reboot habe ich auch schon versucht.
                      pi@homepi_phil:~ $ sudo apt update
                      Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                      Ign:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                      Hit:5 https://deb.nodesource.com/node_16.x stretch InRelease
                      • P philipp_lappe
                        @philipp_lappe
                        Nö, jetzt gibt es nur einen 'Hit' für nodesource.
                        Die anderen Einträge kommen daher, das der Reste der Welt den 'stretch' halt schon längst zu Grabe getragen hat. Jetzt den --reinstall wie oben schon beschrieben.
                          philipp_lappe
                          Leider klappt es nicht.
                          pi@homepi_phil:sudo apt update
                          pi@homepi_phil:~ $ sudo apt install --reinstall nodejs
                          Building dependency tree
                          Reinstallation of nodejs is not possible, it cannot be downloaded.
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          • P philipp_lappe
                            @philipp_lappe
                            apt policy nodejs
                            sagt?
                              @philipp_lappe
                              apt policy nodejs
                              sagt?
                              philipp_lappe
                              apt policy nodejs
                              pi@homepi_phil:~ $ apt policy nodejs
                              nodejs:
                                Installed: 16.20.0-deb-1nodesource1
                                Candidate: 16.20.0-deb-1nodesource1
                                Version table:
                               *** 16.20.0-deb-1nodesource1 100
                                   8.11.1~dfsg-2~bpo9+1 500
                                      500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                   4.8.2~dfsg-1 500
                                      500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                              • P philipp_lappe
                                apt policy nodejs
                                nodejs:
                                  Version table:
                                     4.8.2~dfsg-1 500
                                @philipp_lappe
                                Ja, dann hat nodesource die Pakete 'schon' vom Server gelöscht.
                                Das ist auch der Grund, warum es immer schwierig ist, längst abgekündigte Versionen bei Laune zu halten.
                                Dann versuch mit dem Backup basierend auf dem alten Stand um zuziehen.
                                Musst du halt im neuen System entsprchende Klimmzüge machen (js-controller auf 4.0.24 drücken usw.)
                                  @philipp_lappe
                                  philipp_lappe
                                  Okay, danke für deine Unterstützung.
                                  Welchen Vorteil genau habe ich denn dadurch, wenn ich mit dem alten Backup arbeite?
                                  Glücklicherweise ist mein System realtaiv klein. Ich habe nur Sonoff und Shelly Devices und auf iobroker läuft yahka und Telegram.
                                  Also alles komplett neu machen ist zwar bestimmt ein Tag Arbeit, aber wenn das besser ist dann würde ich es in Angriff nehmen.
                                  Oder bekomme ich das auch wieder sauber, wenn ich mit dem Backup arbeite? Also was meinst du mit Klimmzügen?
                                  Gibt es für solch einen Umzug eine gute Anleitung an die ich mich halten kann?
                                  Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
                                  • P philipp_lappe
                                    Keinen. Es ist nur komplizierter, weil ein frisch neu hingezauberter ioBroker mit js-controller 5 daherkommt, aber nix mit Backups aus der 4er-Version anfangen kann. Da muss man den 5er auf 4 drücken und kann dann erst versuchen ein Backup einzuspielen.
                                    • P philipp_lappe
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      @philipp_lappe ich würde den Tag Arbeit in kauf nehmen. Spart nerven...
                                        philipp_lappe
                                        Jetzt wollte ich mit dem Aufsetzen des neuen Systems anfangen und laufe schon bei der Installation von iobroker in einen Fehler. (Anderer Pi und frische SD-Karte)
                                        curl -sLf https://iobroker.net/install.sh | bash -
                                        library: loaded
                                            Welcome to the ioBroker installer!
                                            Installer version: 2023-10-13
                                            Installing prerequisites (1/4)
                                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Node.js not found. Installing...
                                        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                        E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
                                        File '/etc/apt/keyrings/nodesource.gpg' exists. Overwrite? (y/N) y
                                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                                        Cannot install Node.js! Please install it manually.
                                        • P philipp_lappe
                                          library: loaded
                                          was hast du denn gemacht?
                                          was ist da passiert?
