  3. Einsteigerfragen
  4. Installation
  5. Wie führe ich ein sauberes Updates durch?
52 Beiträge 5 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • P philipp_lappe
    @thomas-braun said in Wie führe ich ein sauberes Updates durch?:
    @philipp_lappe
    Die Hardware ist zu schwach für einen sinnvollen Betrieb, würde ich voraussagen.
    iob update
    iob upgrade self --debug
    sagt?
    pi@homepi_phil:~ $ iob upgrade self --debug
    Update js-controller from @4.0.24 to @5.0.12
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.19.4
    Installing iobroker.js-controller@5.0.12... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/alcalzone-shared
    npm ERR! dest /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alcalzone-shared' -> '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'
    npm ERR!     /home/iobroker/.npm/_logs/2023-11-12T21_31_05_268Z-debug-0.log
    host.homepi_phil Cannot install iobroker.js-controller@5.0.12: 217
    @philipp_lappe
    iob stop
    iob fix
    iob upgrade all
    P 1 Antwort Letzte Antwort
      @philipp_lappe
      iob stop
      iob fix
      iob upgrade all
      philipp_lappe
      @philipp_lappe
      iob stop
      iob fix
      iob upgrade all
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.19.4
      npm ERR! path /opt/iobroker/node_modules/acme-http-01-standalone
      npm ERR! dest /opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acme-http-01-standalone' -> '/opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK'
      npm ERR!     /home/iobroker/.npm/_logs/2023-11-12T22_09_46_524Z-debug-0.log
      da_WoodyD HomoranH 2 Antworten Letzte Antwort
      • P philipp_lappe
        @philipp_lappe
        iob stop
        iob fix
        iob upgrade all
        Stopped Objects DB
        Stopped States DB
        NPM version: 8.19.4
        npm ERR! errno -39
        da_WoodyD Online
        da_WoodyD Online
        @philipp_lappe bitte, setz deine logs in 3b78940c-63e7-4156-b8fc-6d42ca860f0d-grafik.png
        • P philipp_lappe
          @philipp_lappe
          iob stop
          iob fix
          iob upgrade all
          Stopped Objects DB
          Stopped States DB
          NPM version: 8.19.4
          npm ERR! errno -39
          @philipp_lappe sagte in Wie führe ich ein sauberes Updates durch?:
          und die anderen Ausgaben?
            philipp_lappe
            pi@homepi_phil:~ $ iob stop
            pi@homepi_phil:~ $
            pi@homepi_phil:~ $ iob fix
            library: loaded
            Library version=2023-10-13
                Welcome to the ioBroker installation fixer!
                Script version: 2023-10-13
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
            Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
            Err:3 http://raspbian.raspberrypi.org/raspbian stretch Release
              404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
            Get:4 https://download.docker.com/linux/raspbian stretch InRelease [31.1 kB]
            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:7 https://deb.nodesource.com/node_16.x stretch InRelease
            Reading package lists... Done
            E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
                Checking ioBroker user and directory permissions (2/5)
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@homepi_phil:~ $
            pi@homepi_phil:~ $ iob upgrade all
            This upgrade of "yahka" will introduce the following changes:
            -> 1.0.3:
            Corrected empty device list with rebuild
            -> 1.0.1:
            we ensured controller 5 compatibility
            Formatting
            -> 0.17.0:
            Added AVAHI advertiser as default and updated HomeKit Library to improve performance and stability
            -> 0.14.0:
            Updated HomeKit Library
            -> 0.13.2:
            Fixed crashes due to changes in used HomeKit Library
            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to upgrade yahka from @0.13.1 to @1.0.3 now? [(y)es, (n)o]: No upgrade of "yahka" desired.
            This upgrade of "text2command" will at least introduce the following changes:
            -> 3.0.2:
            Corrected link from admin
            -> 3.0.1:
            Corrected many GUI errors
            -> 2.3.1:
            Migrated GUI to v5
            Would you like to upgrade text2command from @2.3.0 to @3.0.2 now? [(y)es, (n)o]: y
            Update text2command from @2.3.0 to @3.0.2
            NPM version: 8.19.4
            Installing iobroker.text2command@3.0.2... (System call)
            host.homepi_phil Cannot install iobroker.text2command@3.0.2: 244
            Stopped Objects DB
            Stopped States DB
            NPM version: 8.19.4
            npm ERR! errno -39
            • P philipp_lappe
              pi@homepi_phil:~ $
              library: loaded
              Done.
              Autostart enabled!
              pi@homepi_phil:~ $
              -> 1.0.3:
              -> 1.0.1:
              Formatting
              -> 0.17.0:
              -> 0.14.0:
              -> 0.13.2:
              -> 3.0.2:
              -> 3.0.1:
              -> 2.3.1:
              Migrated GUI to v5
              NPM version: 8.19.4
              Stopped Objects DB
              Stopped States DB
              NPM version: 8.19.4
              npm ERR! errno -39
              Ernsthaft?
              Ansonsten jede Menge Fehler, der Fixer ist nicht durchgelaufen,
              Kein Wunder dass nichts gefixt wurde
              • P philipp_lappe
                pi@homepi_phil:~ $
                library: loaded
                Done.
                Autostart enabled!
                pi@homepi_phil:~ $
                -> 1.0.3:
                -> 1.0.1:
                Formatting
                -> 0.17.0:
                -> 0.14.0:
                -> 0.13.2:
                -> 3.0.2:
                -> 3.0.1:
                -> 2.3.1:
                Migrated GUI to v5
                NPM version: 8.19.4
                Stopped Objects DB
                Stopped States DB
                NPM version: 8.19.4
                npm ERR! errno -39
                Ist ja auch schon Quark...
                Schmeiß die bullseye-Quelle raus und reinstalliere nodejs in passender Version.
                  philipp_lappe
                  In /etc/apt/sources.list ist nur die stretch Quelle drin. Also kein Plan wo und wie ich die falschen Quellen löschen kann.
                  Irgendwann war das System down und dann hatte ich aus lauter Verzweiflung jede Menge probiert und verutlich Chaos angerichtet.
                  Es wäre vermutlich doch besser alles von Grund auf neu aufzusetzen oder?
                  • P philipp_lappe
                    Das ohnehin. Aber ich würde den Umzug mit einem Backup aus einem halbwegs aktuellen ioBroker machen.
                    Ist nämlich wesentlich einfacher.
                    cat /etc/apt/sources.list.d/node*
                    sagt?
                      sagt?
                      philipp_lappe
                      sagt?
                      pi@homepi_phil:~ $ cat /etc/apt/sources.list.d/node*
                      #node 16
                      deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      #node 18
                      deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                      deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye maindeb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                      deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x stretch main
                      • P philipp_lappe
                        sagt?
                        #node 16
                        #node 18
                        @philipp_lappe
                        Da hast du die falschen Einträge. Lösch den ganzen node18 und bullseye - Kram raus, es gibt kein node18 für stretch.
                        Also alles bis auf die letzte Zeile raus.
                        Dann
                        iob stop
                        sudo apt update
                        sudo apt install --reinstall nodejs
                          @philipp_lappe
                          Dann
                          iob stop
                          sudo apt update
                          philipp_lappe
                          @philipp_lappe
                          Dann
                          iob stop
                          sudo apt update
                          Wenn ich sources.list öffne ist dort nur eine Quelle.
                          • P philipp_lappe
                            @philipp_lappe
                            Dann
                            iob stop
                            sudo apt update
                            @philipp_lappe
                            Das ist ja auch eine andere Datei. Die nodesource.list liegt hier
                            sudo nano /etc/apt/sources.list.d/nodesource.list
                              @philipp_lappe
                              philipp_lappe
                              @philipp_lappe
                              Ich habe alle Einträge bis auf den letzten entfernt, aber trotzdem werden die noch angezeigt. Reboot habe ich auch schon versucht.
                              pi@homepi_phil:~ $ sudo apt update
                              Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
                              Ign:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                              Hit:5 https://deb.nodesource.com/node_16.x stretch InRelease
                              • P philipp_lappe
                                @philipp_lappe
                                Nö, jetzt gibt es nur einen 'Hit' für nodesource.
                                Die anderen Einträge kommen daher, das der Reste der Welt den 'stretch' halt schon längst zu Grabe getragen hat. Jetzt den --reinstall wie oben schon beschrieben.
                                  philipp_lappe
                                  Leider klappt es nicht.
                                  pi@homepi_phil:sudo apt update
                                  pi@homepi_phil:~ $ sudo apt install --reinstall nodejs
                                  Building dependency tree
                                  Reinstallation of nodejs is not possible, it cannot be downloaded.
                                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  • P philipp_lappe
                                    @philipp_lappe
                                    apt policy nodejs
                                    sagt?
                                      @philipp_lappe
                                      apt policy nodejs
                                      sagt?
                                      philipp_lappe
                                      apt policy nodejs
                                      pi@homepi_phil:~ $ apt policy nodejs
                                      nodejs:
                                        Installed: 16.20.0-deb-1nodesource1
                                        Candidate: 16.20.0-deb-1nodesource1
                                        Version table:
                                       *** 16.20.0-deb-1nodesource1 100
                                           8.11.1~dfsg-2~bpo9+1 500
                                              500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                           4.8.2~dfsg-1 500
                                              500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                                      • P philipp_lappe
                                        apt policy nodejs
                                        nodejs:
                                          Version table:
                                             4.8.2~dfsg-1 500
                                        @philipp_lappe
                                        Ja, dann hat nodesource die Pakete 'schon' vom Server gelöscht.
                                        Das ist auch der Grund, warum es immer schwierig ist, längst abgekündigte Versionen bei Laune zu halten.
                                        Dann versuch mit dem Backup basierend auf dem alten Stand um zuziehen.
                                        Musst du halt im neuen System entsprchende Klimmzüge machen (js-controller auf 4.0.24 drücken usw.)
                                          @philipp_lappe
                                          philipp_lappe
                                          Okay, danke für deine Unterstützung.
                                          Welchen Vorteil genau habe ich denn dadurch, wenn ich mit dem alten Backup arbeite?
                                          Glücklicherweise ist mein System realtaiv klein. Ich habe nur Sonoff und Shelly Devices und auf iobroker läuft yahka und Telegram.
                                          Also alles komplett neu machen ist zwar bestimmt ein Tag Arbeit, aber wenn das besser ist dann würde ich es in Angriff nehmen.
                                          Oder bekomme ich das auch wieder sauber, wenn ich mit dem Backup arbeite? Also was meinst du mit Klimmzügen?
                                          Gibt es für solch einen Umzug eine gute Anleitung an die ich mich halten kann?
                                          Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
