  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    6.7k
267 Beiträge 8 Kommentatoren 63.7k Aufrufe 8 Beobachtet
  • G Gismoh
    @crunchip
    und beim versuch ble im Webinterface wieder zu installieren:
    $ iobroker add ble --host ioBrokerVM
    NPM version: 9.8.1
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:1899) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T19_00_23_345Z-debug-0.log
    host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
    ERROR: Process exited with code 25
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #235
    @gismoh
    Sag mal ... was kapierst Du denn eigentlich nicht ?
    In Deinem alten, vergammeltem System DEINSTALLIERST Du bitte den BLE.
    Dann mach ein Backup per BACKITUP davon.
    Danach erstellst Du eine neue VM mit Debain.
    Dort dann iobroker installieren OHNE irgendwelchen Mist.
    DANN bitte das BackitUp vom "alten vergammelten System" welches ja dann OHNE BLE ist, zurückspielen.
    Lehrling seit 1975 !!!
    G Meister MopperM 2 Antworten Letzte Antwort
    -1
      @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
      gibt es diese Zeile nicht :
      gibt es sie jetzt?
      Gismoh
      #236
      @crunchip
      build_file_contents = open(build_file_path, encoding='utf-8').read()
      [ Das ist das einzige Auftreten ]
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
      • DJMarc75D DJMarc75
        @gismoh
        Gismoh
        #237
        @djmarc75
        Das Sze­na­rio mit dem deinstallierten ble hatten wir ja auch bereits durch, meine sicherlich 2 mal.
          @gismoh
          Meister MopperM Offline
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          #238
          @djmarc75 sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
          Ruhig Brauner, kann es sein, dass dies, trotz "bitte" , eine nicht gewaltfreie Kommunikation ist? 😉
          Proxmox und HA ...
          • G Gismoh
            @djmarc75
            #239
            @djmarc75
            Wobei ich nicht sicher bin ob du wirklich alles vom BLE entfernt hattest, oder nur die Instanz.
            Jetzt bleiben wir aber bei dem momentanen Szenario, damit es nicht wieder kreuz und quer geht.
            G 1 Antwort Letzte Antwort
              @djmarc75
              Gismoh
              schrieb am zuletzt editiert von Gismoh
              #240
              @homoran habe nun bereits die vm wieder gelöscht, um es erneut ohne ble einzuspielen.
              Edit, hatte Instanz und Adapter gelöscvht.
              • G Gismoh
                crunchipC Abwesend
                crunchipC Abwesend
                #241
                dann aber vor dem ble einspielen
                sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                  Gismoh
                  #242
                  @crunchip
                  okay.
                  Nebenbei, auf der alten Maschine konnte ich nach dem deinstallieren von ble, diesen adapter wieder ohne Probleme installieren - läuft dort.
                    #243
                    @crunchip wo ist denn der Unterschied?
                    ich verstehe den Fehler im log als Fehler/Problem vom npm.
                    Alt: arm v7 mit node v18, npm v9
                    Neu: amd64(??) node18, npm9
                    @Gismoh bitte bestätigen oder korrigieren
                    crunchipC G 2 Antworten Letzte Antwort
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #244
                      @homoran sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                      ja, aber es kommt die Meldung beim Versuch ble zu installieren
                      diese es aber auf dem neuen System gar nicht mehr gibt.
                      bzw war das bisher die Meldung
                      den jetzigen code 25 müsste man sich ja nochmal mit --debug ansehen, ob es immer noch die selbe Meldung ist oder jetzt was anderes, da er ja die Datei auf dem alten(U entfernen) vor dem backup bearbeitet hat
                        #245
                        aber irgendwoher kennt npm doch diesen part.
                        nutzt ein npm cache clean hier etwas?
                        im nagelneuen System wurde/konnte doch ble installiert (werden).
                        dann muss der Mist doch irgendwo im Backup sein.
                        Da ist aber nix von node und npm drin.
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #246
                          eben, aber nicht mit dem backup, das ist ja das seltsame
                            Gismoh
                            #247
                            Alt: ARMv7 Processor rev 3 (v7l), Node.js v18.18.2, NPM 9.8.1
                            Neu: Mist - habe noch keine Info Seite installiert ;)
                            aber x64 (i5-7500T)
                            Muss auch ersteinmal nen paar Stunden off - nicht nur mein Kopf qualmt ;)
                              #248
                              @crunchip sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                              siehe edit
                              • G Gismoh
                                aber x64 (i5-7500T)
                                #249
                                aber x64 (i5-7500T)
                                und das richtige Debian (AMD64 und nicht x86)?
                                  aber x64 (i5-7500T)
                                  Gismoh
                                  #250
                                  ja, amd64 (ble lief ja auch bereits auf einer neuinstallation - ohne Backup)
                                  Neu: Architektur x64, Node.js v18.18.2, NPM 9.8.1
                                  Backup ist auf Neuinstallation wieder eingespielt - aber noch nichts weiter gemacht.
                                  • G Gismoh
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #251
                                    @gismoh dann nun die Ausgabe von
                                    iob add ble --debug
                                      iob add ble --debug
                                      Gismoh
                                      #252
                                      @crunchip
                                      Sorry, erst nun, haben noch Besuch ;)
                                      idash@ioBrokerVM:~$ iob add ble --debug
                                      NPM version: 9.8.1
                                      npm ERR! code 1
                                      npm ERR! gyp info it worked if it ends with ok
                                      npm ERR! gyp info using node-gyp@7.1.2
                                      npm ERR! gyp info using node@18.18.2 | linux | x64
                                      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                      npm ERR! (node:5847) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                      npm ERR! gyp info spawn /usr/bin/python3
                                      npm ERR! gyp info spawn args [
                                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                                      npm ERR! gyp info spawn args   'binding.gyp',
                                      npm ERR! gyp info spawn args   '-f',
                                      npm ERR! gyp info spawn args   'make',
                                      npm ERR! gyp info spawn args   '-I',
                                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@abandonware/noble/build/config.gypi',
                                      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                                      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                                      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                                      npm ERR! gyp info spawn args   '-Dvisibility=default',
                                      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                                      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                                      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                                      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@abandonware/noble',
                                      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                                      npm ERR! gyp info spawn args   '--depth=.',
                                      npm ERR! gyp info spawn args   '--no-parallel',
                                      npm ERR! gyp info spawn args   '--generator-output',
                                      npm ERR! gyp info spawn args   'build',
                                      npm ERR! gyp info spawn args   '-Goutput_dir=.'
                                      npm ERR! gyp info spawn args ]
                                      npm ERR!                                             ^^^^^
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T22_12_49_072Z-debug-0.log
                                      npm ERR! code 1
                                      npm ERR!                                             ^^^^^
                                      Sieht irgendwie bekannt aus ;(
                                        iob add ble --debug
                                        Gismoh
                                        #253
                                        @crunchip
                                        Auch hier:
                                        idash@ioBrokerVM:~$ sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                        Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                                        in
                                        /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                        gibt es auch nun die entsprechende Zeile nicht.
                                        • G Gismoh
                                          @crunchip
                                          Auch hier:
                                          in
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #254
                                          @gismoh ich hab keine Ahnung was da bei dir falsch ist bzw aus deinem backup mitgeschleift wird.
                                          letzte Idee wäre, auf deiner neuen Installation, so wie sie jetzt ist, nodejs de/installieren und anschließend wenn der iobroker nach dem Start fertig gebaut ist, es nochmal mit dem ble Adapter probieren
                                          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian?_=1699766871988
