  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    apollon77A
267 Beiträge 8 Kommentatoren 75.6k Aufrufe 8 Beobachtet
  • G Gismoh
    Hab nun das frische Backup vom alten Rechner in die VM eingespielt, selbe Meldung:
    $ iobroker add ble --host ioBrokerVM
    NPM version: 9.8.1
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:7872) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T15_18_34_692Z-debug-0.log
    host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
    ERROR: Process exited with code 25
    Setze nun den ioBroker nochmal neu auf, und versuche es erneut.
    Edit:
    die Datei exestiert hier nun nicht, und in der
    /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
    gibt es den Abschnitt:
    build_file_contents = open(build_file_path, 'rU').read()
    nicht.
    So, wie geschrieben mache mich an die Neuinstallation von ioBroker und versuche es dann dort erneut.
    G
    G
    Gismoh
    #219
    direkt nach Neuinstallation vom ioBroker erhalte ich:
    admin.0
    	2023-11-11 16:47:58.173	error	Cannot update news: TypeError: newNews.forEach is not a function
    admin.0
    	2023-11-11 16:45:00.404	error	Cannot update news: TypeError: newNews.forEach is not a function
    admin.0
    	2023-11-11 16:45:00.245	warn	Active repository "stable" cannot be read
    admin.0
    	2023-11-11 16:45:00.244	warn	Repository cannot be read: Active repo - stable
    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
    • G Gismoh
      admin.0
      admin.0
      admin.0
      admin.0
      #220
      @gismoh klingt nach Netzwerkproblemen
      G 1 Antwort Letzte Antwort
        G
        G
        Gismoh
        schrieb am zuletzt editiert von Gismoh
        #221
        ioBroker hat er allerdings ohne Probleme gezogen.
        Nach Neustart noch:
        admin.0
        	2023-11-11 16:57:49.251	error	Cannot update news: TypeError: newNews.forEach is not a function
        G HomoranH 2 Antworten Letzte Antwort
        • G Gismoh
          Nach Neustart noch:
          admin.0
          G
          G
          Gismoh
          #222
          @gismoh
          Dann spiel ich nun mal das Backup ein. Die VM habe ich davor gesichert.
          • G Gismoh
            Nach Neustart noch:
            admin.0
            #223
            @gismoh die Suche findet da was
            https://forum.iobroker.net/search?term=Cannot update news%3A TypeError%3A newNews.forEach is not function&in=titlesposts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
              G
              G
              Gismoh
              #224
              Merci, sehe ich mir nach der laufenden backup einspielung an.
              • G Gismoh
                #225
                @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                scheint harmlos zu sein.
                ignorieren!
                  ignorieren!
                  G
                  G
                  Gismoh
                  #226
                  mal etwas beruhigendes ;) ^^
                  • G Gismoh
                    G
                    G
                    Gismoh
                    #227
                    meldung von iob Logs --watch
                    8.1
                    2023-11-11 17:13:59.827  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.pi-hole@1.3.6... (System call)
                    2023-11-11 17:14:05.911  - info: host.ioBrokerVM iobroker npm-install: added 14 packages in 6s
                    2023-11-11 17:14:05.913  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:14:05.914  - info: host.ioBrokerVM iobroker npm-install: 127 packages are looking for funding
                    2023-11-11 17:14:05.914  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:14:05.938  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pi-hole@1.3.6
                    2023-11-11 17:14:06.020  - info: host.ioBrokerVM iobroker npm-install: upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                    2023-11-11 17:14:06.027  - info: host.ioBrokerVM iobroker npm-install: upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
                    2023-11-11 17:14:06.031  - info: host.ioBrokerVM iobroker npm-install: upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
                    2023-11-11 17:14:06.035  - info: host.ioBrokerVM iobroker npm-install: upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
                    2023-11-11 17:14:06.039  - info: host.ioBrokerVM iobroker npm-install: upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
                    2023-11-11 17:14:06.049  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pi-hole created/updated
                    2023-11-11 17:14:07.120  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:14:08.121  - warn: host.ioBrokerVM startInstance cannot find adapter "pvforecast@2.9.0". Try to install it... 1 attempt
                    2023-11-11 17:14:08.122  - info: host.ioBrokerVM iobroker install pvforecast@2.9.0 using installedFrom
                    2023-11-11 17:14:09.780  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:14:09.781  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.pvforecast@2.9.0... (System call)
                    2023-11-11 17:14:15.811  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 6s
                    2023-11-11 17:14:15.812  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:14:15.812  - info: host.ioBrokerVM iobroker npm-install: 127 packages are looking for funding
                    2023-11-11 17:14:15.813  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:14:15.837  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pvforecast@2.9.0
                    2023-11-11 17:14:15.911  - info: host.ioBrokerVM iobroker npm-install: upload [14] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2023-11-11 17:14:15.918  - info: host.ioBrokerVM iobroker npm-install: upload [13] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2023-11-11 17:14:15.922  - info: host.ioBrokerVM iobroker npm-install: upload [12] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2023-11-11 17:14:15.925  - info: host.ioBrokerVM iobroker npm-install: upload [11] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2023-11-11 17:14:15.929  - info: host.ioBrokerVM iobroker npm-install: upload [10] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2023-11-11 17:14:15.932  - info: host.ioBrokerVM iobroker npm-install: upload [9] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2023-11-11 17:14:15.936  - info: host.ioBrokerVM iobroker npm-install: upload [8] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2023-11-11 17:14:15.939  - info: host.ioBrokerVM iobroker npm-install: upload [7] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2023-11-11 17:14:15.943  - info: host.ioBrokerVM iobroker npm-install: upload [6] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2023-11-11 17:14:15.947  - info: host.ioBrokerVM iobroker npm-install: upload [5] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    2023-11-11 17:14:15.950  - info: host.ioBrokerVM iobroker npm-install: upload [4] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2023-11-11 17:14:15.953  - info: host.ioBrokerVM iobroker npm-install: upload [3] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/img/Azimuth.png img/Azimuth.png image/png
                    2023-11-11 17:14:15.958  - info: host.ioBrokerVM iobroker npm-install: upload [2] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/jsonConfig.json jsonConfig.json application/json
                    2023-11-11 17:14:15.961  - info: host.ioBrokerVM iobroker npm-install: upload [1] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/pvforecast.png pvforecast.png image/png
                    2023-11-11 17:14:15.965  - info: host.ioBrokerVM iobroker npm-install: upload [0] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/style.css style.css text/css
                    2023-11-11 17:14:16.060  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pvforecast created/updated
                    2023-11-11 17:14:17.125  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:14:18.126  - warn: host.ioBrokerVM startInstance cannot find adapter "smartcontrol@2.0.1". Try to install it... 1 attempt
                    2023-11-11 17:14:18.126  - info: host.ioBrokerVM iobroker install smartcontrol@2.0.1 using installedFrom
                    2023-11-11 17:14:19.760  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:14:19.761  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.smartcontrol@2.0.1... (System call)
                    2023-11-11 17:14:25.267  - info: host.ioBrokerVM iobroker npm-install: added 17 packages in 5s
                    2023-11-11 17:14:25.268  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                    2023-11-11 17:14:25.268  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:14:25.290  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter smartcontrol@2.0.1
                    2023-11-11 17:14:25.364  - info: host.ioBrokerVM iobroker npm-install: upload [81] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/admin.d.ts admin.d.ts video/mp2t
                    2023-11-11 17:14:25.371  - info: host.ioBrokerVM iobroker npm-install: upload [80] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/check_box-24px.svg doc-md/img/check_box-24px.svg image/svg+xml
                    2023-11-11 17:14:25.407  - info: host.ioBrokerVM iobroker npm-install: upload [70] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/table-zones_select-target-devices-overwrite.gif doc-md/img/table-zones_select-target-devices-overwrite.gif image/gif
                    2023-11-11 17:14:25.437  - info: host.ioBrokerVM iobroker npm-install: upload [60] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-target-devices_de.md doc-md/table-target-devices_de.md text/markdown
                    2023-11-11 17:14:25.466  - info: host.ioBrokerVM iobroker npm-install: upload [50] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-trigger-times_de.md doc-md/table-trigger-times_de.md text/markdown
                    2023-11-11 17:14:25.497  - info: host.ioBrokerVM iobroker npm-install: upload [40] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/fancytree/skin-lion/vline-rtl.gif fancytree/skin-lion/vline-rtl.gif image/gif
                    2023-11-11 17:14:25.527  - info: host.ioBrokerVM iobroker npm-install: upload [30] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2023-11-11 17:14:25.556  - info: host.ioBrokerVM iobroker npm-install: upload [20] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-target-devices.png img/option-screenshots/tab-target-devices.png image/png
                    2023-11-11 17:14:25.563  - info: host.ioBrokerVM iobroker npm-install: upload [19] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-motion.png img/option-screenshots/tab-triggers-motion.png image/png
                    2023-11-11 17:14:25.567  - info: host.ioBrokerVM iobroker npm-install: upload [18] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-other.png img/option-screenshots/tab-triggers-other.png image/png
                    2023-11-11 17:14:25.570  - info: host.ioBrokerVM iobroker npm-install: upload [17] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-time.png img/option-screenshots/tab-triggers-time.png image/png
                    2023-11-11 17:14:25.573  - info: host.ioBrokerVM iobroker npm-install: upload [16] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones-execution.png img/option-screenshots/tab-zones-execution.png image/png
                    2023-11-11 17:14:25.577  - info: host.ioBrokerVM iobroker npm-install: upload [15] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones.png img/option-screenshots/tab-zones.png image/png
                    2023-11-11 17:14:25.580  - info: host.ioBrokerVM iobroker npm-install: upload [14] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/sc_always.png img/sc_always.png image/png
                    2023-11-11 17:14:25.583  - info: host.ioBrokerVM iobroker npm-install: upload [13] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/select-target-devices-overwrite.gif img/select-target-devices-overwrite.gif image/gif
                    2023-11-11 17:14:25.586  - info: host.ioBrokerVM iobroker npm-install: upload [12] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options1.gif img/smartControl_options1.gif image/gif
                    2023-11-11 17:14:25.620  - info: host.ioBrokerVM iobroker npm-install: upload [11] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown.gif img/smartControl_options_dropdown.gif image/gif
                    2023-11-11 17:14:25.623  - info: host.ioBrokerVM iobroker npm-install: upload [10] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown_2.gif img/smartControl_options_dropdown_2.gif image/gif
                    2023-11-11 17:14:25.628  - info: host.ioBrokerVM iobroker npm-install: upload [9] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.html index_m.html text/html
                    2023-11-11 17:14:25.632  - info: host.ioBrokerVM iobroker npm-install: upload [8] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.js index_m.js application/javascript
                    2023-11-11 17:14:25.637  - info: host.ioBrokerVM iobroker npm-install: upload [7] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol-banner.png smartcontrol-banner.png image/png
                    2023-11-11 17:14:25.641  - info: host.ioBrokerVM iobroker npm-install: upload [6] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol.png smartcontrol.png image/png
                    2023-11-11 17:14:25.647  - info: host.ioBrokerVM iobroker npm-install: upload [5] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/style.css style.css text/css
                    2023-11-11 17:14:25.651  - info: host.ioBrokerVM iobroker npm-install: upload [4] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/tsconfig.json tsconfig.json application/json
                    2023-11-11 17:14:25.655  - info: host.ioBrokerVM iobroker npm-install: upload [3] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/words.js words.js application/javascript
                    2023-11-11 17:14:25.662  - info: host.ioBrokerVM iobroker npm-install: upload [2] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/readme.txt zero-md/readme.txt text/plain
                    2023-11-11 17:14:25.665  - info: host.ioBrokerVM iobroker npm-install: upload [1] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/webcomponents-loader.min.js zero-md/webcomponents-loader.min.js application/javascript
                    2023-11-11 17:14:25.668  - info: host.ioBrokerVM iobroker npm-install: upload [0] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/zero-md.min.js.js zero-md/zero-md.min.js.js application/javascript
                    2023-11-11 17:14:25.793  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.smartcontrol created/updated
                    2023-11-11 17:14:26.865  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:14:27.865  - warn: host.ioBrokerVM startInstance cannot find adapter "socketio@6.5.5". Try to install it... 1 attempt
                    2023-11-11 17:14:27.865  - info: host.ioBrokerVM iobroker install socketio@6.5.5 using installedFrom
                    2023-11-11 17:14:29.568  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:14:29.569  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.socketio@6.5.5... (System call)
                    2023-11-11 17:14:37.103  - info: host.ioBrokerVM iobroker npm-install: added 40 packages in 7s
                    2023-11-11 17:14:37.104  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:14:37.105  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                    2023-11-11 17:14:37.106  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:14:37.130  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter socketio@6.5.5
                    2023-11-11 17:14:37.202  - info: host.ioBrokerVM iobroker npm-install: upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2023-11-11 17:14:37.210  - info: host.ioBrokerVM iobroker npm-install: upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2023-11-11 17:14:37.213  - info: host.ioBrokerVM iobroker npm-install: upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2023-11-11 17:14:37.216  - info: host.ioBrokerVM iobroker npm-install: upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2023-11-11 17:14:37.219  - info: host.ioBrokerVM iobroker npm-install: upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2023-11-11 17:14:37.223  - info: host.ioBrokerVM iobroker npm-install: upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2023-11-11 17:14:37.226  - info: host.ioBrokerVM iobroker npm-install: upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2023-11-11 17:14:37.230  - info: host.ioBrokerVM iobroker npm-install: upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2023-11-11 17:14:37.233  - info: host.ioBrokerVM iobroker npm-install: upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2023-11-11 17:14:37.237  - info: host.ioBrokerVM iobroker npm-install: upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2023-11-11 17:14:37.240  - info: host.ioBrokerVM iobroker npm-install: upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                    2023-11-11 17:14:37.243  - info: host.ioBrokerVM iobroker npm-install: upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                    2023-11-11 17:14:37.400  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.socketio created/updated
                    2023-11-11 17:14:38.463  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:14:39.463  - warn: host.ioBrokerVM startInstance cannot find adapter "tado@0.4.11". Try to install it... 1 attempt
                    2023-11-11 17:14:39.464  - info: host.ioBrokerVM iobroker install tado@0.4.11 using installedFrom
                    2023-11-11 17:14:41.100  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:14:41.102  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tado@0.4.11... (System call)
                    2023-11-11 17:14:57.158  - info: host.ioBrokerVM iobroker npm-install: added 26 packages in 16s
                    2023-11-11 17:14:57.159  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:14:57.160  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                    2023-11-11 17:14:57.161  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:14:57.185  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tado@0.4.11
                    2023-11-11 17:14:57.257  - info: host.ioBrokerVM iobroker npm-install: upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
                    2023-11-11 17:14:57.265  - info: host.ioBrokerVM iobroker npm-install: upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
                    2023-11-11 17:14:57.269  - info: host.ioBrokerVM iobroker npm-install: upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
                    2023-11-11 17:14:57.272  - info: host.ioBrokerVM iobroker npm-install: upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
                    2023-11-11 17:14:57.276  - info: host.ioBrokerVM iobroker npm-install: upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
                    2023-11-11 17:14:57.280  - info: host.ioBrokerVM iobroker npm-install: upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
                    2023-11-11 17:14:57.284  - info: host.ioBrokerVM iobroker npm-install: upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
                    2023-11-11 17:14:57.385  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tado created/updated
                    2023-11-11 17:14:58.462  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:14:59.462  - warn: host.ioBrokerVM startInstance cannot find adapter "tibberlink@1.4.2". Try to install it... 1 attempt
                    2023-11-11 17:14:59.463  - info: host.ioBrokerVM iobroker install tibberlink@1.4.2 using installedFrom
                    2023-11-11 17:15:01.138  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:01.140  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tibberlink@1.4.2... (System call)
                    2023-11-11 17:15:05.889  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:15:05.910  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tibberlink@1.4.2
                    2023-11-11 17:15:05.996  - info: host.ioBrokerVM iobroker npm-install: upload [13] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/calculatorStates.png calculatorStates.png image/png
                    2023-11-11 17:15:06.004  - info: host.ioBrokerVM iobroker npm-install: upload [12] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2023-11-11 17:15:06.008  - info: host.ioBrokerVM iobroker npm-install: upload [11] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2023-11-11 17:15:06.011  - info: host.ioBrokerVM iobroker npm-install: upload [10] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2023-11-11 17:15:06.014  - info: host.ioBrokerVM iobroker npm-install: upload [9] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2023-11-11 17:15:06.018  - info: host.ioBrokerVM iobroker npm-install: upload [8] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2023-11-11 17:15:06.022  - info: host.ioBrokerVM iobroker npm-install: upload [7] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2023-11-11 17:15:06.025  - info: host.ioBrokerVM iobroker npm-install: upload [6] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2023-11-11 17:15:06.029  - info: host.ioBrokerVM iobroker npm-install: upload [5] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2023-11-11 17:15:06.033  - info: host.ioBrokerVM iobroker npm-install: upload [4] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2023-11-11 17:15:06.036  - info: host.ioBrokerVM iobroker npm-install: upload [3] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    2023-11-11 17:15:06.039  - info: host.ioBrokerVM iobroker npm-install: upload [2] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2023-11-11 17:15:06.043  - info: host.ioBrokerVM iobroker npm-install: upload [1] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/jsonConfig.json jsonConfig.json application/json
                    2023-11-11 17:15:06.047  - info: host.ioBrokerVM iobroker npm-install: upload [0] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/tibberlink.png tibberlink.png image/png
                    2023-11-11 17:15:06.147  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tibberlink created/updated
                    2023-11-11 17:15:07.209  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:08.210  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-hqwidgets@1.4.0". Try to install it... 1 attempt
                    2023-11-11 17:15:08.210  - info: host.ioBrokerVM iobroker install vis-hqwidgets@1.4.0 using installedFrom
                    2023-11-11 17:15:09.860  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:09.862  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-hqwidgets@1.4.0... (System call)
                    2023-11-11 17:15:14.292  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:15:14.315  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-hqwidgets@1.4.0
                    2023-11-11 17:15:14.389  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                    2023-11-11 17:15:14.396  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                    2023-11-11 17:15:14.401  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                    2023-11-11 17:15:14.522  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-hqwidgets created/updated
                    2023-11-11 17:15:15.588  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:16.588  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-jqui-mfd@1.0.12". Try to install it... 1 attempt
                    2023-11-11 17:15:16.588  - info: host.ioBrokerVM iobroker install vis-jqui-mfd@1.0.12 using installedFrom
                    2023-11-11 17:15:18.232  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:18.233  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
                    2023-11-11 17:15:22.716  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:15:22.716  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:15:22.736  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-jqui-mfd@1.0.12
                    2023-11-11 17:15:22.805  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                    2023-11-11 17:15:22.814  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                    2023-11-11 17:15:22.935  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-jqui-mfd created/updated
                    2023-11-11 17:15:22.987  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.vis-jqui-mfd.0"
                    2023-11-11 17:15:24.004  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:25.005  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
                    2023-11-11 17:15:25.005  - info: host.ioBrokerVM iobroker install vis-material-advanced@1.7.4 using installedFrom
                    2023-11-11 17:15:26.630  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:26.631  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
                    2023-11-11 17:15:31.351  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                    2023-11-11 17:15:31.352  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                    2023-11-11 17:15:31.352  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:15:31.373  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-material-advanced@1.7.4
                    2023-11-11 17:15:31.442  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
                    2023-11-11 17:15:31.450  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
                    2023-11-11 17:15:31.454  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
                    2023-11-11 17:15:31.573  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-material-advanced created/updated
                    2023-11-11 17:15:32.637  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:33.637  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-metro@1.2.0". Try to install it... 1 attempt
                    2023-11-11 17:15:33.638  - info: host.ioBrokerVM iobroker install vis-metro@1.2.0 using installedFrom
                    2023-11-11 17:15:35.325  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:35.325  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-metro@1.2.0... (System call)
                    2023-11-11 17:15:39.798  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 4s
                    2023-11-11 17:15:39.800  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:15:39.801  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                    2023-11-11 17:15:39.802  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                    2023-11-11 17:15:39.825  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-metro@1.2.0
                    2023-11-11 17:15:39.895  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                    2023-11-11 17:15:39.902  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                    2023-11-11 17:15:39.906  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                    2023-11-11 17:15:40.026  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-metro created/updated
                    2023-11-11 17:15:41.089  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:42.090  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
                    2023-11-11 17:15:42.090  - info: host.ioBrokerVM iobroker install vis-timeandweather@1.2.2 using installedFrom
                    2023-11-11 17:15:43.727  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:43.729  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-timeandweather@1.2.2... (System call)
                    2023-11-11 17:15:48.208  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:15:48.227  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-timeandweather@1.2.2
                    2023-11-11 17:15:48.296  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                    2023-11-11 17:15:48.303  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                    2023-11-11 17:15:48.308  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                    2023-11-11 17:15:48.426  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                    2023-11-11 17:15:49.488  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:15:50.490  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                    2023-11-11 17:15:50.490  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                    2023-11-11 17:15:52.164  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:15:52.164  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                    2023-11-11 17:15:56.598  - info: vis.0 (5148) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                    2023-11-11 17:15:56.799  - info: vis.0 (5148) vis license is OK.
                    2023-11-11 17:15:57.006  - error: vis.0 (5148) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-11-11 17:15:57.006  - error: vis.0 (5148) unhandled promise rejection: Not exists
                    2023-11-11 17:15:57.007  - error: vis.0 (5148) Error: Not exists
                        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                        at process.processImmediate (node:internal/timers:478:21)
                    2023-11-11 17:15:57.007  - error: vis.0 (5148) Not exists
                    2023-11-11 17:15:57.511  - info: vis.0 (5148) terminating
                    2023-11-11 17:15:57.511  - warn: vis.0 (5148) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-11-11 17:15:58.189  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_15_52_466Z-debug-0.log
                    2023-11-11 17:15:58.190  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                    2023-11-11 17:15:59.209  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:16:00.210  - warn: host.ioBrokerVM startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                    2023-11-11 17:16:00.210  - info: host.ioBrokerVM iobroker install web@6.1.10 using installedFrom
                    2023-11-11 17:16:01.907  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:16:01.909  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                    2023-11-11 17:16:07.455  - info: host.ioBrokerVM iobroker npm-install: added 7 packages in 5s149 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:16:07.476  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@6.1.10
                    2023-11-11 17:16:07.549  - info: host.ioBrokerVM iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                    2023-11-11 17:16:23.135  - info: host.ioBrokerVM iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                    2023-11-11 17:16:23.170  - info: host.ioBrokerVM iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                    2023-11-11 17:16:23.199  - info: host.ioBrokerVM iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                    2023-11-11 17:16:23.229  - info: host.ioBrokerVM iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                    2023-11-11 17:16:23.260  - info: host.ioBrokerVM iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                    2023-11-11 17:16:23.293  - info: host.ioBrokerVM iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                    2023-11-11 17:16:23.324  - info: host.ioBrokerVM iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                    2023-11-11 17:16:23.356  - info: host.ioBrokerVM iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                    2023-11-11 17:16:23.389  - info: host.ioBrokerVM iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                    2023-11-11 17:16:23.392  - info: host.ioBrokerVM iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                    2023-11-11 17:16:23.396  - info: host.ioBrokerVM iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                    2023-11-11 17:16:23.400  - info: host.ioBrokerVM iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                    2023-11-11 17:16:23.404  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                    2023-11-11 17:16:23.407  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                    2023-11-11 17:16:23.411  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                    2023-11-11 17:16:23.414  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                    2023-11-11 17:16:23.419  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                    2023-11-11 17:16:23.423  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                    2023-11-11 17:16:23.426  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                    2023-11-11 17:16:23.430  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                    2023-11-11 17:16:23.434  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                    2023-11-11 17:16:23.438  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                    2023-11-11 17:16:23.442  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                    2023-11-11 17:16:23.445  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                    2023-11-11 17:16:23.448  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                    2023-11-11 17:16:23.452  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                    2023-11-11 17:16:23.456  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                    2023-11-11 17:16:23.459  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                    2023-11-11 17:16:23.462  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                    2023-11-11 17:16:23.535  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                    2023-11-11 17:16:23.675  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                    2023-11-11 17:16:23.845  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                    2023-11-11 17:16:24.009  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                    2023-11-11 17:16:24.181  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                    2023-11-11 17:16:24.347  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                    2023-11-11 17:16:24.554  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                    2023-11-11 17:16:24.604  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                    2023-11-11 17:16:24.648  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                    2023-11-11 17:16:24.685  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                    2023-11-11 17:16:24.722  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                    2023-11-11 17:16:24.771  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                    2023-11-11 17:16:24.809  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                    2023-11-11 17:16:24.848  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                    2023-11-11 17:16:24.889  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                    2023-11-11 17:16:24.894  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                    2023-11-11 17:16:24.899  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                    2023-11-11 17:16:24.903  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                    2023-11-11 17:16:24.908  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                    2023-11-11 17:16:24.926  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                    2023-11-11 17:16:24.937  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                    2023-11-11 17:16:24.943  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                    2023-11-11 17:16:24.947  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                    2023-11-11 17:16:24.953  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                    2023-11-11 17:16:24.957  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                    2023-11-11 17:16:24.964  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                    2023-11-11 17:16:24.971  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                    2023-11-11 17:16:24.976  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                    2023-11-11 17:16:24.982  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                    2023-11-11 17:16:24.988  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                    2023-11-11 17:16:24.994  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                    2023-11-11 17:16:25.010  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                    2023-11-11 17:16:25.021  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                    2023-11-11 17:16:25.026  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                    2023-11-11 17:16:25.030  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                    2023-11-11 17:16:25.138  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                    2023-11-11 17:16:26.329  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:16:27.330  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.4". Try to install it... 1 attempt
                    2023-11-11 17:16:27.330  - info: host.ioBrokerVM iobroker install worx@2.3.4 using installedFrom
                    2023-11-11 17:16:29.978  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:16:29.979  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.4... (System call)
                    2023-11-11 17:16:40.115  - info: host.ioBrokerVM iobroker npm-install:
                    2023-11-11 17:16:40.115  - info: host.ioBrokerVM iobroker npm-install: added 41 packages in 10s151 packages are looking for funding  run `npm fund` for details
                    2023-11-11 17:16:40.138  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.4
                    2023-11-11 17:16:40.217  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2023-11-11 17:16:40.225  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2023-11-11 17:16:40.228  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2023-11-11 17:16:40.232  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2023-11-11 17:16:40.235  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2023-11-11 17:16:40.238  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2023-11-11 17:16:40.242  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2023-11-11 17:16:40.246  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2023-11-11 17:16:40.249  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2023-11-11 17:16:40.253  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    2023-11-11 17:16:40.257  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2023-11-11 17:16:40.260  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                    2023-11-11 17:16:40.263  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                    2023-11-11 17:16:40.267  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                    2023-11-11 17:16:40.384  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                    2023-11-11 17:16:41.447  - info: host.ioBrokerVM iobroker npm-install: exit 0
                    2023-11-11 17:16:42.448  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 2 attempt
                    2023-11-11 17:16:42.448  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedFrom
                    2023-11-11 17:16:44.138  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:16:44.139  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.ble@0.13.4... (System call)
                    2023-11-11 17:16:48.497  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5476) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_16_44_448Z-debug-0.log
                    2023-11-11 17:16:48.498  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                    2023-11-11 17:16:49.517  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:16:50.518  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                    2023-11-11 17:16:50.518  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                    2023-11-11 17:16:52.168  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                    2023-11-11 17:16:56.119  - info: vis.0 (5549) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                    2023-11-11 17:16:56.361  - info: vis.0 (5549) vis license is OK.
                    2023-11-11 17:16:56.658  - error: vis.0 (5549) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-11-11 17:16:56.659  - error: vis.0 (5549) unhandled promise rejection: Not exists
                    2023-11-11 17:16:56.659  - error: vis.0 (5549) Error: Not exists
                    2023-11-11 17:16:56.660  - error: vis.0 (5549) Not exists
                    2023-11-11 17:16:57.162  - info: vis.0 (5549) terminating
                    2023-11-11 17:16:57.163  - warn: vis.0 (5549) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-11-11 17:16:57.826  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_16_52_460Z-debug-0.log
                    2023-11-11 17:16:57.827  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                    2023-11-11 17:16:58.842  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:16:59.843  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 3 attempt
                    2023-11-11 17:16:59.843  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedVersion
                    2023-11-11 17:17:01.548  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:17:01.548  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.ble@0.13.4... (System call)
                    2023-11-11 17:17:04.839  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5677) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_01_863Z-debug-0.log
                    2023-11-11 17:17:04.840  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                    2023-11-11 17:17:05.861  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:17:06.862  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                    2023-11-11 17:17:06.863  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                    2023-11-11 17:17:08.546  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:17:08.547  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                    2023-11-11 17:17:12.514  - info: vis.0 (5750) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                    2023-11-11 17:17:12.699  - info: vis.0 (5750) vis license is OK.
                    2023-11-11 17:17:12.868  - error: vis.0 (5750) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-11-11 17:17:12.868  - error: vis.0 (5750) unhandled promise rejection: Not exists
                    2023-11-11 17:17:12.869  - error: vis.0 (5750) Error: Not exists
                    2023-11-11 17:17:12.869  - error: vis.0 (5750) Not exists
                    2023-11-11 17:17:13.374  - info: vis.0 (5750) terminating
                    2023-11-11 17:17:13.375  - warn: vis.0 (5750) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-11-11 17:17:14.030  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_08_856Z-debug-0.log
                    2023-11-11 17:17:14.031  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                    2023-11-11 17:17:15.048  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:17:16.048  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 4 attempt
                    2023-11-11 17:17:16.048  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedVersion
                    2023-11-11 17:17:17.772  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.ble@0.13.4... (System call)
                    2023-11-11 17:17:21.050  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5875) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_18_077Z-debug-0.log
                    2023-11-11 17:17:21.051  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                    2023-11-11 17:17:22.067  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:17:23.069  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                    2023-11-11 17:17:23.069  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                    2023-11-11 17:17:24.737  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                    2023-11-11 17:17:24.739  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                    2023-11-11 17:17:28.830  - info: vis.0 (5948) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                    2023-11-11 17:17:29.018  - info: vis.0 (5948) vis license is OK.
                    2023-11-11 17:17:29.183  - error: vis.0 (5948) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-11-11 17:17:29.184  - error: vis.0 (5948) unhandled promise rejection: Not exists
                    2023-11-11 17:17:29.184  - error: vis.0 (5948) Error: Not exists
                    2023-11-11 17:17:29.185  - error: vis.0 (5948) Not exists
                    2023-11-11 17:17:29.689  - info: vis.0 (5948) terminating
                    2023-11-11 17:17:29.690  - warn: vis.0 (5948) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-11-11 17:17:30.363  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_25_048Z-debug-0.log
                    2023-11-11 17:17:30.364  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                    2023-11-11 17:17:31.380  - info: host.ioBrokerVM iobroker npm-install: exit 25
                    2023-11-11 17:17:32.381  - error: host.ioBrokerVM Cannot download and install adapter "ble@0.13.4". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                    2023-11-11 17:17:32.884  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
                    • G Gismoh
                      meldung von iob Logs --watch
                      8.1
                      2023-11-11 17:13:59.827  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.pi-hole@1.3.6... (System call)
                      2023-11-11 17:14:05.911  - info: host.ioBrokerVM iobroker npm-install: added 14 packages in 6s
                      2023-11-11 17:14:05.913  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:14:05.914  - info: host.ioBrokerVM iobroker npm-install: 127 packages are looking for funding
                      2023-11-11 17:14:05.914  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:14:05.938  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pi-hole@1.3.6
                      2023-11-11 17:14:06.020  - info: host.ioBrokerVM iobroker npm-install: upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                      2023-11-11 17:14:06.027  - info: host.ioBrokerVM iobroker npm-install: upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
                      2023-11-11 17:14:06.031  - info: host.ioBrokerVM iobroker npm-install: upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
                      2023-11-11 17:14:06.035  - info: host.ioBrokerVM iobroker npm-install: upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
                      2023-11-11 17:14:06.039  - info: host.ioBrokerVM iobroker npm-install: upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
                      2023-11-11 17:14:06.049  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pi-hole created/updated
                      2023-11-11 17:14:07.120  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:14:08.121  - warn: host.ioBrokerVM startInstance cannot find adapter "pvforecast@2.9.0". Try to install it... 1 attempt
                      2023-11-11 17:14:08.122  - info: host.ioBrokerVM iobroker install pvforecast@2.9.0 using installedFrom
                      2023-11-11 17:14:09.780  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:14:09.781  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.pvforecast@2.9.0... (System call)
                      2023-11-11 17:14:15.811  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 6s
                      2023-11-11 17:14:15.812  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:14:15.812  - info: host.ioBrokerVM iobroker npm-install: 127 packages are looking for funding
                      2023-11-11 17:14:15.813  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:14:15.837  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pvforecast@2.9.0
                      2023-11-11 17:14:15.911  - info: host.ioBrokerVM iobroker npm-install: upload [14] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-11-11 17:14:15.918  - info: host.ioBrokerVM iobroker npm-install: upload [13] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-11-11 17:14:15.922  - info: host.ioBrokerVM iobroker npm-install: upload [12] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-11-11 17:14:15.925  - info: host.ioBrokerVM iobroker npm-install: upload [11] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-11-11 17:14:15.929  - info: host.ioBrokerVM iobroker npm-install: upload [10] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-11-11 17:14:15.932  - info: host.ioBrokerVM iobroker npm-install: upload [9] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-11-11 17:14:15.936  - info: host.ioBrokerVM iobroker npm-install: upload [8] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-11-11 17:14:15.939  - info: host.ioBrokerVM iobroker npm-install: upload [7] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-11-11 17:14:15.943  - info: host.ioBrokerVM iobroker npm-install: upload [6] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-11-11 17:14:15.947  - info: host.ioBrokerVM iobroker npm-install: upload [5] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      2023-11-11 17:14:15.950  - info: host.ioBrokerVM iobroker npm-install: upload [4] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-11-11 17:14:15.953  - info: host.ioBrokerVM iobroker npm-install: upload [3] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/img/Azimuth.png img/Azimuth.png image/png
                      2023-11-11 17:14:15.958  - info: host.ioBrokerVM iobroker npm-install: upload [2] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/jsonConfig.json jsonConfig.json application/json
                      2023-11-11 17:14:15.961  - info: host.ioBrokerVM iobroker npm-install: upload [1] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/pvforecast.png pvforecast.png image/png
                      2023-11-11 17:14:15.965  - info: host.ioBrokerVM iobroker npm-install: upload [0] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/style.css style.css text/css
                      2023-11-11 17:14:16.060  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pvforecast created/updated
                      2023-11-11 17:14:17.125  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:14:18.126  - warn: host.ioBrokerVM startInstance cannot find adapter "smartcontrol@2.0.1". Try to install it... 1 attempt
                      2023-11-11 17:14:18.126  - info: host.ioBrokerVM iobroker install smartcontrol@2.0.1 using installedFrom
                      2023-11-11 17:14:19.760  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:14:19.761  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.smartcontrol@2.0.1... (System call)
                      2023-11-11 17:14:25.267  - info: host.ioBrokerVM iobroker npm-install: added 17 packages in 5s
                      2023-11-11 17:14:25.268  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                      2023-11-11 17:14:25.268  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:14:25.290  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter smartcontrol@2.0.1
                      2023-11-11 17:14:25.364  - info: host.ioBrokerVM iobroker npm-install: upload [81] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/admin.d.ts admin.d.ts video/mp2t
                      2023-11-11 17:14:25.371  - info: host.ioBrokerVM iobroker npm-install: upload [80] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/check_box-24px.svg doc-md/img/check_box-24px.svg image/svg+xml
                      2023-11-11 17:14:25.407  - info: host.ioBrokerVM iobroker npm-install: upload [70] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/table-zones_select-target-devices-overwrite.gif doc-md/img/table-zones_select-target-devices-overwrite.gif image/gif
                      2023-11-11 17:14:25.437  - info: host.ioBrokerVM iobroker npm-install: upload [60] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-target-devices_de.md doc-md/table-target-devices_de.md text/markdown
                      2023-11-11 17:14:25.466  - info: host.ioBrokerVM iobroker npm-install: upload [50] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-trigger-times_de.md doc-md/table-trigger-times_de.md text/markdown
                      2023-11-11 17:14:25.497  - info: host.ioBrokerVM iobroker npm-install: upload [40] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/fancytree/skin-lion/vline-rtl.gif fancytree/skin-lion/vline-rtl.gif image/gif
                      2023-11-11 17:14:25.527  - info: host.ioBrokerVM iobroker npm-install: upload [30] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-11-11 17:14:25.556  - info: host.ioBrokerVM iobroker npm-install: upload [20] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-target-devices.png img/option-screenshots/tab-target-devices.png image/png
                      2023-11-11 17:14:25.563  - info: host.ioBrokerVM iobroker npm-install: upload [19] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-motion.png img/option-screenshots/tab-triggers-motion.png image/png
                      2023-11-11 17:14:25.567  - info: host.ioBrokerVM iobroker npm-install: upload [18] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-other.png img/option-screenshots/tab-triggers-other.png image/png
                      2023-11-11 17:14:25.570  - info: host.ioBrokerVM iobroker npm-install: upload [17] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-time.png img/option-screenshots/tab-triggers-time.png image/png
                      2023-11-11 17:14:25.573  - info: host.ioBrokerVM iobroker npm-install: upload [16] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones-execution.png img/option-screenshots/tab-zones-execution.png image/png
                      2023-11-11 17:14:25.577  - info: host.ioBrokerVM iobroker npm-install: upload [15] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones.png img/option-screenshots/tab-zones.png image/png
                      2023-11-11 17:14:25.580  - info: host.ioBrokerVM iobroker npm-install: upload [14] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/sc_always.png img/sc_always.png image/png
                      2023-11-11 17:14:25.583  - info: host.ioBrokerVM iobroker npm-install: upload [13] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/select-target-devices-overwrite.gif img/select-target-devices-overwrite.gif image/gif
                      2023-11-11 17:14:25.586  - info: host.ioBrokerVM iobroker npm-install: upload [12] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options1.gif img/smartControl_options1.gif image/gif
                      2023-11-11 17:14:25.620  - info: host.ioBrokerVM iobroker npm-install: upload [11] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown.gif img/smartControl_options_dropdown.gif image/gif
                      2023-11-11 17:14:25.623  - info: host.ioBrokerVM iobroker npm-install: upload [10] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown_2.gif img/smartControl_options_dropdown_2.gif image/gif
                      2023-11-11 17:14:25.628  - info: host.ioBrokerVM iobroker npm-install: upload [9] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.html index_m.html text/html
                      2023-11-11 17:14:25.632  - info: host.ioBrokerVM iobroker npm-install: upload [8] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.js index_m.js application/javascript
                      2023-11-11 17:14:25.637  - info: host.ioBrokerVM iobroker npm-install: upload [7] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol-banner.png smartcontrol-banner.png image/png
                      2023-11-11 17:14:25.641  - info: host.ioBrokerVM iobroker npm-install: upload [6] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol.png smartcontrol.png image/png
                      2023-11-11 17:14:25.647  - info: host.ioBrokerVM iobroker npm-install: upload [5] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/style.css style.css text/css
                      2023-11-11 17:14:25.651  - info: host.ioBrokerVM iobroker npm-install: upload [4] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/tsconfig.json tsconfig.json application/json
                      2023-11-11 17:14:25.655  - info: host.ioBrokerVM iobroker npm-install: upload [3] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/words.js words.js application/javascript
                      2023-11-11 17:14:25.662  - info: host.ioBrokerVM iobroker npm-install: upload [2] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/readme.txt zero-md/readme.txt text/plain
                      2023-11-11 17:14:25.665  - info: host.ioBrokerVM iobroker npm-install: upload [1] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/webcomponents-loader.min.js zero-md/webcomponents-loader.min.js application/javascript
                      2023-11-11 17:14:25.668  - info: host.ioBrokerVM iobroker npm-install: upload [0] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/zero-md.min.js.js zero-md/zero-md.min.js.js application/javascript
                      2023-11-11 17:14:25.793  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.smartcontrol created/updated
                      2023-11-11 17:14:26.865  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:14:27.865  - warn: host.ioBrokerVM startInstance cannot find adapter "socketio@6.5.5". Try to install it... 1 attempt
                      2023-11-11 17:14:27.865  - info: host.ioBrokerVM iobroker install socketio@6.5.5 using installedFrom
                      2023-11-11 17:14:29.568  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:14:29.569  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.socketio@6.5.5... (System call)
                      2023-11-11 17:14:37.103  - info: host.ioBrokerVM iobroker npm-install: added 40 packages in 7s
                      2023-11-11 17:14:37.104  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:14:37.105  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                      2023-11-11 17:14:37.106  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:14:37.130  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter socketio@6.5.5
                      2023-11-11 17:14:37.202  - info: host.ioBrokerVM iobroker npm-install: upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-11-11 17:14:37.210  - info: host.ioBrokerVM iobroker npm-install: upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-11-11 17:14:37.213  - info: host.ioBrokerVM iobroker npm-install: upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-11-11 17:14:37.216  - info: host.ioBrokerVM iobroker npm-install: upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-11-11 17:14:37.219  - info: host.ioBrokerVM iobroker npm-install: upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-11-11 17:14:37.223  - info: host.ioBrokerVM iobroker npm-install: upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-11-11 17:14:37.226  - info: host.ioBrokerVM iobroker npm-install: upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-11-11 17:14:37.230  - info: host.ioBrokerVM iobroker npm-install: upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-11-11 17:14:37.233  - info: host.ioBrokerVM iobroker npm-install: upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-11-11 17:14:37.237  - info: host.ioBrokerVM iobroker npm-install: upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-11-11 17:14:37.240  - info: host.ioBrokerVM iobroker npm-install: upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                      2023-11-11 17:14:37.243  - info: host.ioBrokerVM iobroker npm-install: upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                      2023-11-11 17:14:37.400  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.socketio created/updated
                      2023-11-11 17:14:38.463  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:14:39.463  - warn: host.ioBrokerVM startInstance cannot find adapter "tado@0.4.11". Try to install it... 1 attempt
                      2023-11-11 17:14:39.464  - info: host.ioBrokerVM iobroker install tado@0.4.11 using installedFrom
                      2023-11-11 17:14:41.100  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:14:41.102  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tado@0.4.11... (System call)
                      2023-11-11 17:14:57.158  - info: host.ioBrokerVM iobroker npm-install: added 26 packages in 16s
                      2023-11-11 17:14:57.159  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:14:57.160  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                      2023-11-11 17:14:57.161  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:14:57.185  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tado@0.4.11
                      2023-11-11 17:14:57.257  - info: host.ioBrokerVM iobroker npm-install: upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
                      2023-11-11 17:14:57.265  - info: host.ioBrokerVM iobroker npm-install: upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
                      2023-11-11 17:14:57.269  - info: host.ioBrokerVM iobroker npm-install: upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
                      2023-11-11 17:14:57.272  - info: host.ioBrokerVM iobroker npm-install: upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
                      2023-11-11 17:14:57.276  - info: host.ioBrokerVM iobroker npm-install: upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
                      2023-11-11 17:14:57.280  - info: host.ioBrokerVM iobroker npm-install: upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
                      2023-11-11 17:14:57.284  - info: host.ioBrokerVM iobroker npm-install: upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
                      2023-11-11 17:14:57.385  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tado created/updated
                      2023-11-11 17:14:58.462  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:14:59.462  - warn: host.ioBrokerVM startInstance cannot find adapter "tibberlink@1.4.2". Try to install it... 1 attempt
                      2023-11-11 17:14:59.463  - info: host.ioBrokerVM iobroker install tibberlink@1.4.2 using installedFrom
                      2023-11-11 17:15:01.138  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:01.140  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tibberlink@1.4.2... (System call)
                      2023-11-11 17:15:05.889  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:15:05.910  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tibberlink@1.4.2
                      2023-11-11 17:15:05.996  - info: host.ioBrokerVM iobroker npm-install: upload [13] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/calculatorStates.png calculatorStates.png image/png
                      2023-11-11 17:15:06.004  - info: host.ioBrokerVM iobroker npm-install: upload [12] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-11-11 17:15:06.008  - info: host.ioBrokerVM iobroker npm-install: upload [11] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-11-11 17:15:06.011  - info: host.ioBrokerVM iobroker npm-install: upload [10] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-11-11 17:15:06.014  - info: host.ioBrokerVM iobroker npm-install: upload [9] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-11-11 17:15:06.018  - info: host.ioBrokerVM iobroker npm-install: upload [8] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-11-11 17:15:06.022  - info: host.ioBrokerVM iobroker npm-install: upload [7] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-11-11 17:15:06.025  - info: host.ioBrokerVM iobroker npm-install: upload [6] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-11-11 17:15:06.029  - info: host.ioBrokerVM iobroker npm-install: upload [5] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-11-11 17:15:06.033  - info: host.ioBrokerVM iobroker npm-install: upload [4] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-11-11 17:15:06.036  - info: host.ioBrokerVM iobroker npm-install: upload [3] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      2023-11-11 17:15:06.039  - info: host.ioBrokerVM iobroker npm-install: upload [2] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-11-11 17:15:06.043  - info: host.ioBrokerVM iobroker npm-install: upload [1] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/jsonConfig.json jsonConfig.json application/json
                      2023-11-11 17:15:06.047  - info: host.ioBrokerVM iobroker npm-install: upload [0] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/tibberlink.png tibberlink.png image/png
                      2023-11-11 17:15:06.147  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tibberlink created/updated
                      2023-11-11 17:15:07.209  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:08.210  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-hqwidgets@1.4.0". Try to install it... 1 attempt
                      2023-11-11 17:15:08.210  - info: host.ioBrokerVM iobroker install vis-hqwidgets@1.4.0 using installedFrom
                      2023-11-11 17:15:09.860  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:09.862  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-hqwidgets@1.4.0... (System call)
                      2023-11-11 17:15:14.292  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:15:14.315  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-hqwidgets@1.4.0
                      2023-11-11 17:15:14.389  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                      2023-11-11 17:15:14.396  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                      2023-11-11 17:15:14.401  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                      2023-11-11 17:15:14.522  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-hqwidgets created/updated
                      2023-11-11 17:15:15.588  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:16.588  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-jqui-mfd@1.0.12". Try to install it... 1 attempt
                      2023-11-11 17:15:16.588  - info: host.ioBrokerVM iobroker install vis-jqui-mfd@1.0.12 using installedFrom
                      2023-11-11 17:15:18.232  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:18.233  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
                      2023-11-11 17:15:22.716  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:15:22.716  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:15:22.736  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-jqui-mfd@1.0.12
                      2023-11-11 17:15:22.805  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                      2023-11-11 17:15:22.814  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                      2023-11-11 17:15:22.935  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-jqui-mfd created/updated
                      2023-11-11 17:15:22.987  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.vis-jqui-mfd.0"
                      2023-11-11 17:15:24.004  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:25.005  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
                      2023-11-11 17:15:25.005  - info: host.ioBrokerVM iobroker install vis-material-advanced@1.7.4 using installedFrom
                      2023-11-11 17:15:26.630  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:26.631  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
                      2023-11-11 17:15:31.351  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                      2023-11-11 17:15:31.352  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                      2023-11-11 17:15:31.352  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:15:31.373  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-material-advanced@1.7.4
                      2023-11-11 17:15:31.442  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
                      2023-11-11 17:15:31.450  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
                      2023-11-11 17:15:31.454  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
                      2023-11-11 17:15:31.573  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-material-advanced created/updated
                      2023-11-11 17:15:32.637  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:33.637  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-metro@1.2.0". Try to install it... 1 attempt
                      2023-11-11 17:15:33.638  - info: host.ioBrokerVM iobroker install vis-metro@1.2.0 using installedFrom
                      2023-11-11 17:15:35.325  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:35.325  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-metro@1.2.0... (System call)
                      2023-11-11 17:15:39.798  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 4s
                      2023-11-11 17:15:39.800  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:15:39.801  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                      2023-11-11 17:15:39.802  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                      2023-11-11 17:15:39.825  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-metro@1.2.0
                      2023-11-11 17:15:39.895  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                      2023-11-11 17:15:39.902  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                      2023-11-11 17:15:39.906  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                      2023-11-11 17:15:40.026  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-metro created/updated
                      2023-11-11 17:15:41.089  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:42.090  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
                      2023-11-11 17:15:42.090  - info: host.ioBrokerVM iobroker install vis-timeandweather@1.2.2 using installedFrom
                      2023-11-11 17:15:43.727  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:43.729  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-timeandweather@1.2.2... (System call)
                      2023-11-11 17:15:48.208  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:15:48.227  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-timeandweather@1.2.2
                      2023-11-11 17:15:48.296  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                      2023-11-11 17:15:48.303  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                      2023-11-11 17:15:48.308  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                      2023-11-11 17:15:48.426  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                      2023-11-11 17:15:49.488  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:15:50.490  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                      2023-11-11 17:15:50.490  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                      2023-11-11 17:15:52.164  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:15:52.164  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                      2023-11-11 17:15:56.598  - info: vis.0 (5148) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                      2023-11-11 17:15:56.799  - info: vis.0 (5148) vis license is OK.
                      2023-11-11 17:15:57.006  - error: vis.0 (5148) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-11-11 17:15:57.006  - error: vis.0 (5148) unhandled promise rejection: Not exists
                      2023-11-11 17:15:57.007  - error: vis.0 (5148) Error: Not exists
                          at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                          at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                          at process.processImmediate (node:internal/timers:478:21)
                      2023-11-11 17:15:57.007  - error: vis.0 (5148) Not exists
                      2023-11-11 17:15:57.511  - info: vis.0 (5148) terminating
                      2023-11-11 17:15:57.511  - warn: vis.0 (5148) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-11 17:15:58.189  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_15_52_466Z-debug-0.log
                      2023-11-11 17:15:58.190  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                      2023-11-11 17:15:59.209  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:16:00.210  - warn: host.ioBrokerVM startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                      2023-11-11 17:16:00.210  - info: host.ioBrokerVM iobroker install web@6.1.10 using installedFrom
                      2023-11-11 17:16:01.907  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:16:01.909  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                      2023-11-11 17:16:07.455  - info: host.ioBrokerVM iobroker npm-install: added 7 packages in 5s149 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:16:07.476  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@6.1.10
                      2023-11-11 17:16:07.549  - info: host.ioBrokerVM iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                      2023-11-11 17:16:23.135  - info: host.ioBrokerVM iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                      2023-11-11 17:16:23.170  - info: host.ioBrokerVM iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                      2023-11-11 17:16:23.199  - info: host.ioBrokerVM iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                      2023-11-11 17:16:23.229  - info: host.ioBrokerVM iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                      2023-11-11 17:16:23.260  - info: host.ioBrokerVM iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                      2023-11-11 17:16:23.293  - info: host.ioBrokerVM iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                      2023-11-11 17:16:23.324  - info: host.ioBrokerVM iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                      2023-11-11 17:16:23.356  - info: host.ioBrokerVM iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                      2023-11-11 17:16:23.389  - info: host.ioBrokerVM iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                      2023-11-11 17:16:23.392  - info: host.ioBrokerVM iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                      2023-11-11 17:16:23.396  - info: host.ioBrokerVM iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                      2023-11-11 17:16:23.400  - info: host.ioBrokerVM iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                      2023-11-11 17:16:23.404  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                      2023-11-11 17:16:23.407  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                      2023-11-11 17:16:23.411  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                      2023-11-11 17:16:23.414  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                      2023-11-11 17:16:23.419  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                      2023-11-11 17:16:23.423  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                      2023-11-11 17:16:23.426  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                      2023-11-11 17:16:23.430  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                      2023-11-11 17:16:23.434  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                      2023-11-11 17:16:23.438  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                      2023-11-11 17:16:23.442  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                      2023-11-11 17:16:23.445  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                      2023-11-11 17:16:23.448  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                      2023-11-11 17:16:23.452  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                      2023-11-11 17:16:23.456  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                      2023-11-11 17:16:23.459  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                      2023-11-11 17:16:23.462  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                      2023-11-11 17:16:23.535  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                      2023-11-11 17:16:23.675  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                      2023-11-11 17:16:23.845  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                      2023-11-11 17:16:24.009  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                      2023-11-11 17:16:24.181  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                      2023-11-11 17:16:24.347  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                      2023-11-11 17:16:24.554  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                      2023-11-11 17:16:24.604  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                      2023-11-11 17:16:24.648  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                      2023-11-11 17:16:24.685  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                      2023-11-11 17:16:24.722  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                      2023-11-11 17:16:24.771  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                      2023-11-11 17:16:24.809  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                      2023-11-11 17:16:24.848  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                      2023-11-11 17:16:24.889  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                      2023-11-11 17:16:24.894  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                      2023-11-11 17:16:24.899  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                      2023-11-11 17:16:24.903  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                      2023-11-11 17:16:24.908  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                      2023-11-11 17:16:24.926  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                      2023-11-11 17:16:24.937  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                      2023-11-11 17:16:24.943  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                      2023-11-11 17:16:24.947  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                      2023-11-11 17:16:24.953  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                      2023-11-11 17:16:24.957  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                      2023-11-11 17:16:24.964  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                      2023-11-11 17:16:24.971  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                      2023-11-11 17:16:24.976  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                      2023-11-11 17:16:24.982  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                      2023-11-11 17:16:24.988  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                      2023-11-11 17:16:24.994  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                      2023-11-11 17:16:25.010  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                      2023-11-11 17:16:25.021  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                      2023-11-11 17:16:25.026  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                      2023-11-11 17:16:25.030  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                      2023-11-11 17:16:25.138  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                      2023-11-11 17:16:26.329  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:16:27.330  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.4". Try to install it... 1 attempt
                      2023-11-11 17:16:27.330  - info: host.ioBrokerVM iobroker install worx@2.3.4 using installedFrom
                      2023-11-11 17:16:29.978  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:16:29.979  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.4... (System call)
                      2023-11-11 17:16:40.115  - info: host.ioBrokerVM iobroker npm-install:
                      2023-11-11 17:16:40.115  - info: host.ioBrokerVM iobroker npm-install: added 41 packages in 10s151 packages are looking for funding  run `npm fund` for details
                      2023-11-11 17:16:40.138  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.4
                      2023-11-11 17:16:40.217  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-11-11 17:16:40.225  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-11-11 17:16:40.228  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-11-11 17:16:40.232  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-11-11 17:16:40.235  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-11-11 17:16:40.238  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-11-11 17:16:40.242  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-11-11 17:16:40.246  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-11-11 17:16:40.249  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-11-11 17:16:40.253  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      2023-11-11 17:16:40.257  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-11-11 17:16:40.260  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                      2023-11-11 17:16:40.263  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                      2023-11-11 17:16:40.267  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                      2023-11-11 17:16:40.384  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                      2023-11-11 17:16:41.447  - info: host.ioBrokerVM iobroker npm-install: exit 0
                      2023-11-11 17:16:42.448  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 2 attempt
                      2023-11-11 17:16:42.448  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedFrom
                      2023-11-11 17:16:44.138  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:16:44.139  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.ble@0.13.4... (System call)
                      2023-11-11 17:16:48.497  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5476) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_16_44_448Z-debug-0.log
                      2023-11-11 17:16:48.498  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                      2023-11-11 17:16:49.517  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:16:50.518  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                      2023-11-11 17:16:50.518  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                      2023-11-11 17:16:52.168  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                      2023-11-11 17:16:56.119  - info: vis.0 (5549) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                      2023-11-11 17:16:56.361  - info: vis.0 (5549) vis license is OK.
                      2023-11-11 17:16:56.658  - error: vis.0 (5549) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-11-11 17:16:56.659  - error: vis.0 (5549) unhandled promise rejection: Not exists
                      2023-11-11 17:16:56.659  - error: vis.0 (5549) Error: Not exists
                      2023-11-11 17:16:56.660  - error: vis.0 (5549) Not exists
                      2023-11-11 17:16:57.162  - info: vis.0 (5549) terminating
                      2023-11-11 17:16:57.163  - warn: vis.0 (5549) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-11 17:16:57.826  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_16_52_460Z-debug-0.log
                      2023-11-11 17:16:57.827  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                      2023-11-11 17:16:58.842  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:16:59.843  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 3 attempt
                      2023-11-11 17:16:59.843  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedVersion
                      2023-11-11 17:17:01.548  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:17:01.548  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.ble@0.13.4... (System call)
                      2023-11-11 17:17:04.839  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5677) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_01_863Z-debug-0.log
                      2023-11-11 17:17:04.840  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                      2023-11-11 17:17:05.861  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:17:06.862  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                      2023-11-11 17:17:06.863  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                      2023-11-11 17:17:08.546  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:17:08.547  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                      2023-11-11 17:17:12.514  - info: vis.0 (5750) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                      2023-11-11 17:17:12.699  - info: vis.0 (5750) vis license is OK.
                      2023-11-11 17:17:12.868  - error: vis.0 (5750) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-11-11 17:17:12.868  - error: vis.0 (5750) unhandled promise rejection: Not exists
                      2023-11-11 17:17:12.869  - error: vis.0 (5750) Error: Not exists
                      2023-11-11 17:17:12.869  - error: vis.0 (5750) Not exists
                      2023-11-11 17:17:13.374  - info: vis.0 (5750) terminating
                      2023-11-11 17:17:13.375  - warn: vis.0 (5750) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-11 17:17:14.030  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_08_856Z-debug-0.log
                      2023-11-11 17:17:14.031  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                      2023-11-11 17:17:15.048  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:17:16.048  - warn: host.ioBrokerVM startInstance cannot find adapter "ble@0.13.4". Try to install it... 4 attempt
                      2023-11-11 17:17:16.048  - info: host.ioBrokerVM iobroker install ble@0.13.4 using installedVersion
                      2023-11-11 17:17:17.772  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.ble@0.13.4... (System call)
                      2023-11-11 17:17:21.050  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:5875) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_18_077Z-debug-0.log
                      2023-11-11 17:17:21.051  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                      2023-11-11 17:17:22.067  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:17:23.069  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                      2023-11-11 17:17:23.069  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                      2023-11-11 17:17:24.737  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                      2023-11-11 17:17:24.739  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                      2023-11-11 17:17:28.830  - info: vis.0 (5948) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                      2023-11-11 17:17:29.018  - info: vis.0 (5948) vis license is OK.
                      2023-11-11 17:17:29.183  - error: vis.0 (5948) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-11-11 17:17:29.184  - error: vis.0 (5948) unhandled promise rejection: Not exists
                      2023-11-11 17:17:29.184  - error: vis.0 (5948) Error: Not exists
                      2023-11-11 17:17:29.185  - error: vis.0 (5948) Not exists
                      2023-11-11 17:17:29.689  - info: vis.0 (5948) terminating
                      2023-11-11 17:17:29.690  - warn: vis.0 (5948) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-11 17:17:30.363  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T16_17_25_048Z-debug-0.log
                      2023-11-11 17:17:30.364  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                      2023-11-11 17:17:31.380  - info: host.ioBrokerVM iobroker npm-install: exit 25
                      2023-11-11 17:17:32.381  - error: host.ioBrokerVM Cannot download and install adapter "ble@0.13.4". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                      2023-11-11 17:17:32.884  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                      #228
                      @gismoh jetzt werden die Adapter aus dem backup neu gebaut.
                      Füße stillhalten!
                        Füße stillhalten!
                        #229
                        @homoran sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                        Füße stillhalten!
                        Moin,
                        braucht er nicht, im Log stand schon, das er BLE nicht bauen konnte
                        Bernd
                          Füße stillhalten!
                          Moin,
                          Bernd
                          #230
                          @dp20eic sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                          braucht er nicht
                          kommt drauf an
                          wenn er noch alles andere bauen will, sollte das erst fertig werden, bevor er sich mit ble auseinander setzt.
                          Möglicherweise muss erst alles auf die aktuellen Versionen, passend zum OS und node, gehoben werden.
                          Ichvweiss auch nicht ob noble & co. installiert sind.
                          • G Gismoh
                            @crunchip
                            in der
                            Habe ich das "U" ein mal entfernen können.
                            In der
                            /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                            habe ich diese Zeile
                            build_file_contents = open(build_file_path, 'rU').read()
                            oder
                            build_file_contents = open(build_file_path, 'r').read()
                            nicht gefunden.
                            Edit: dann mache ich nun noch mal Sicherung und spiele die erst in der "frühen" iobroker installation ein, und evtl. danach in einer neu aufgesetzten.
                            crunchipC
                            crunchipC
                            Developer Global Moderator Most Active Forum Testing
                            #231
                            @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                            in der
                            und danach ein backup, das du dann auf eine neue VM gespielt hast?
                            und nun hast du wieder den selben Fehler!?
                            gibt es denn nun diese Datei im neuen System?
                            sollte er installieren
                            sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                            G 2 Antworten Letzte Antwort
                              in der
                              G
                              G
                              Gismoh
                              #232
                              @crunchip
                              jo, sieht nach dem selben Fehler aus.
                              Diese Datei gibt es schon mal nicht.
                              Und in dieser:
                              gibt es diese Zeile nicht :
                              Versuche gleich noch den nächsten Schritt...
                              idash@ioBrokersudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-binp2-bin
                              libudev-dev ist schon die neueste Version (252.17-1~deb12u1).
                              libcap2-bin ist schon die neueste Version (1:2.66-4).
                              Die folgenden zusätzlichen Pakete werden installiert:
                                alsa-topology-conf alsa-ucm-conf libasound2 libasound2-data libbluetooth3
                                libdw1
                              Vorgeschlagene Pakete:
                                bluez-cups bluez-obexd bluez-meshd pulseaudio-module-bluetooth
                                libasound2-plugins alsa-utils
                              Die folgenden NEUEN Pakete werden installiert:
                                alsa-topology-conf alsa-ucm-conf bluetooth bluez libasound2 libasound2-data
                                libbluetooth-dev libbluetooth3 libdw1
                              0 aktualisiert, 9 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 2.278 kB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 8.717 kB Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] J
                              Holen:1 http://deb.debian.org/debian bookworm/main amd64 libasound2-data all 1.2.8-1 [20,5 kB]
                              Holen:2 http://deb.debian.org/debian bookworm/main amd64 libasound2 amd64 1.2.8-1+b1 [362 kB]
                              Holen:3 http://deb.debian.org/debian bookworm/main amd64 libdw1 amd64 0.188-2.1 [235 kB]
                              Holen:4 http://deb.debian.org/debian bookworm/main amd64 bluez amd64 5.66-1 [1.155 kB]
                              Holen:5 http://deb.debian.org/debian bookworm/main amd64 alsa-topology-conf all 1.2.5.1-2 [15,2 kB]
                              Holen:6 http://deb.debian.org/debian bookworm/main amd64 alsa-ucm-conf all 1.2.8-1 [51,7 kB]
                              Holen:7 http://deb.debian.org/debian bookworm/main amd64 bluetooth all 5.66-1 [38,7 kB]
                              Holen:8 http://deb.debian.org/debian bookworm/main amd64 libbluetooth3 amd64 5.66-1 [107 kB]
                              Holen:9 http://deb.debian.org/debian bookworm/main amd64 libbluetooth-dev amd64 5.66-1 [293 kB]
                              Es wurden 2.278 kB in 0 s geholt (6.226 kB/s).
                              Vormals nicht ausgewähltes Paket libasound2-data wird gewählt.
                              (Lese Datenbank ... 47755 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../0-libasound2-data_1.2.8-1_all.deb ...
                              Entpacken von libasound2-data (1.2.8-1) ...
                              Vormals nicht ausgewähltes Paket libasound2:amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../1-libasound2_1.2.8-1+b1_amd64.deb ...
                              Entpacken von libasound2:amd64 (1.2.8-1+b1) ...
                              Vormals nicht ausgewähltes Paket libdw1:amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../2-libdw1_0.188-2.1_amd64.deb ...
                              Entpacken von libdw1:amd64 (0.188-2.1) ...
                              Vormals nicht ausgewähltes Paket bluez wird gewählt.
                              Vorbereitung zum Entpacken von .../3-bluez_5.66-1_amd64.deb ...
                              Entpacken von bluez (5.66-1) ...
                              Vormals nicht ausgewähltes Paket alsa-topology-conf wird gewählt.
                              Vorbereitung zum Entpacken von .../4-alsa-topology-conf_1.2.5.1-2_all.deb ...
                              Entpacken von alsa-topology-conf (1.2.5.1-2) ...
                              Vormals nicht ausgewähltes Paket alsa-ucm-conf wird gewählt.
                              Vorbereitung zum Entpacken von .../5-alsa-ucm-conf_1.2.8-1_all.deb ...
                              Entpacken von alsa-ucm-conf (1.2.8-1) ...
                              Vormals nicht ausgewähltes Paket bluetooth wird gewählt.
                              Vorbereitung zum Entpacken von .../6-bluetooth_5.66-1_all.deb ...
                              Entpacken von bluetooth (5.66-1) ...
                              Vormals nicht ausgewähltes Paket libbluetooth3:amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../7-libbluetooth3_5.66-1_amd64.deb ...
                              Entpacken von libbluetooth3:amd64 (5.66-1) ...
                              Vormals nicht ausgewähltes Paket libbluetooth-dev:amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../8-libbluetooth-dev_5.66-1_amd64.deb ...
                              Entpacken von libbluetooth-dev:amd64 (5.66-1) ...
                              libdw1:amd64 (0.188-2.1) wird eingerichtet ...
                              libasound2-data (1.2.8-1) wird eingerichtet ...
                              alsa-topology-conf (1.2.5.1-2) wird eingerichtet ...
                              libbluetooth3:amd64 (5.66-1) wird eingerichtet ...
                              libasound2:amd64 (1.2.8-1+b1) wird eingerichtet ...
                              alsa-ucm-conf (1.2.8-1) wird eingerichtet ...
                              bluez (5.66-1) wird eingerichtet ...
                              Created symlink /etc/systemd/system/dbus-org.bluez.service → /lib/systemd/system/bluetooth.service.
                              Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service → /lib/systemd/system/bluetooth.service.
                              libbluetooth-dev:amd64 (5.66-1) wird eingerichtet ...
                              bluetooth (5.66-1) wird eingerichtet ...
                              Trigger für man-db (2.11.2-2) werden verarbeitet ...
                              Trigger für dbus (1.14.10-1~deb12u1) werden verarbeitet ...
                              Trigger für libc-bin (2.36-9+deb12u3) werden verarbeitet ...
                              idash@ioBrokerVM:~$
                              ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
                                in der
                                G
                                G
                                Gismoh
                                #233
                                @crunchip
                                und beim versuch ble im Webinterface wieder zu installieren:
                                $ iobroker add ble --host ioBrokerVM
                                NPM version: 9.8.1
                                npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:1899) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T19_00_23_345Z-debug-0.log
                                ERROR: Process exited with code 25
                                • G Gismoh
                                  @crunchip
                                  Und in dieser:
                                    libdw1
                                  idash@ioBrokerVM:~$
                                  crunchipC
                                  crunchipC
                                  #234
                                  gibt es sie jetzt?
                                  G 1 Antwort Letzte Antwort
                                  • G Gismoh
                                    @crunchip
                                    NPM version: 9.8.1
                                    DJMarc75D
                                    DJMarc75D
                                    DJMarc75
                                    #235
                                    @gismoh
                                    Sag mal ... was kapierst Du denn eigentlich nicht ?
                                    In Deinem alten, vergammeltem System DEINSTALLIERST Du bitte den BLE.
                                    Dann mach ein Backup per BACKITUP davon.
                                    Danach erstellst Du eine neue VM mit Debain.
                                    Dort dann iobroker installieren OHNE irgendwelchen Mist.
                                    DANN bitte das BackitUp vom "alten vergammelten System" welches ja dann OHNE BLE ist, zurückspielen.
                                    Lehrling seit 1975 !!!
                                    G Meister MopperM 2 Antworten Letzte Antwort
                                    -1
                                      gibt es sie jetzt?
                                      G
                                      G
                                      Gismoh
                                      #236
                                      @crunchip
                                      build_file_contents = open(build_file_path, encoding='utf-8').read()
                                      [ Das ist das einzige Auftreten ]
                                      • DJMarc75D DJMarc75
                                        @gismoh
                                        G
                                        G
                                        Gismoh
                                        #237
                                        @djmarc75
                                        Das Sze­na­rio mit dem deinstallierten ble hatten wir ja auch bereits durch, meine sicherlich 2 mal.
                                          @gismoh
                                          Meister MopperM
                                          Meister MopperM
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          #238
                                          @djmarc75 sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                          Ruhig Brauner, kann es sein, dass dies, trotz "bitte" , eine nicht gewaltfreie Kommunikation ist? 😉
                                          Proxmox und HA ...
                                          84.0k
