  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 100.1k Aufrufe 56 Beobachtet
    DPO99
    #254
    Habe zzt. massive Probleme mit dem Adapter (keine Ahnung ob das an Renault liegt):
    Häufig dies:
    2023-10-11 05:02:43.315 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:12:43.315 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:12:49.314 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:12:56.475 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:13:02.429 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:32:43.277 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:32:49.244 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:32:54.440 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:33:00.376 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:33:07.039 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:42:43.248 - warn: renault.0 (1266) Renault Server error: 500
    2023-10-11 07:42:48.539 - warn: renault.0 (1266) Renault Server error: 500
    Heute dies:
    2023-10-12 05:00:00.746 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/XXX/battery-status?country=de
    2023-10-12 05:00:00.753 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:00:28.786 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/battery-inhibition-status?country=de
    2023-10-12 05:00:28.788 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:00:56.824 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/cockpit?country=de
    2023-10-12 05:00:56.825 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:01:15.863 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/XXX/cockpit?country=de
    2023-10-12 05:01:15.864 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:01:34.902 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/charge-mode?country=de
    2023-10-12 05:01:34.902 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:01:53.936 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/hvac-status?country=de
    2023-10-12 05:01:53.937 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:02:12.979 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/hvac-settings?country=de
    2023-10-12 05:02:12.979 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    2023-10-12 05:02:32.014 - error: renault.0 (42410) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/XXX/charging-settings?country=de
    2023-10-12 05:02:32.015 - error: renault.0 (42410) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
    Beim Aufruf der API krieg ich im Browser diese Meldung:
    {"error":"missing_authorization","error_description":"Missing API Key header"}
      kohli-vie
      schrieb am zuletzt editiert von kohli-vie
      #255
      erledigt, hab wohl zuviel herumgelöscht etc gg
      nach dem erneuten anlernen des autos in der handy-app kommen jetzt die daten
      vielleicht hat jemand einen tip:
      ich habe unseren Dacia Spring nun eingebunden, adapter version 0.0.21
      anscheinend wird das fahrzeug grundsätzlich ja erkannt, es sind jede menge daten da.
      aber eigentlich nur konfigurationsdaten
      daten wie akkustand und so kommen keine
      ich habe den loglevel erhöht und zb folgende fehler gefunden (so axios fehler sind einige mehr):
      renault.0 2023-10-13 22:58:35.604 debug AxiosError: Request failed with status code 500
      renault.0 2023-10-13 22:58:35.604 info Feature not found for UU1xxx. Ignore charge-mode for updates.
      renault.0 2023-10-13 22:58:35.263 debug {"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
      renault.0 2023-10-13 22:58:35.263 debug AxiosError: Request failed with status code 500
      renault.0 2023-10-13 22:58:35.263 info Feature not found for UU1xxx. Ignore cockpitv2 for updates.
      renault.0 2023-10-13 22:58:34.933 debug {"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
      renault.0 2023-10-13 22:58:34.933 debug AxiosError: Request failed with status code 500
      renault.0 2023-10-13 22:58:34.933 info Feature not found for UU1xxx. Ignore cockpit for updates.
        DPO99
        #256
        Heute wieder massive Probleme:
        2023-10-21 15:29:03.916 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/battery-status?country=de
        2023-10-21 15:29:03.918 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:29:25.950 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/battery-inhibition-status?country=de
        2023-10-21 15:29:25.950 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:29:47.981 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/cockpit?country=de
        2023-10-21 15:29:47.982 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:30:10.014 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/cockpit?country=de
        2023-10-21 15:30:10.014 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:30:32.044 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charge-mode?country=de
        2023-10-21 15:30:32.045 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:30:54.077 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-status?country=de
        2023-10-21 15:30:54.077 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:31:10.102 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-settings?country=de
        2023-10-21 15:31:10.103 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:31:26.135 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charging-settings?country=de
        2023-10-21 15:31:26.136 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:31:48.166 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charges?start=1970-01-01&end=2023-10-21&country=de
        2023-10-21 15:31:48.166 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:32:10.201 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/location?country=de
        2023-10-21 15:32:10.201 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:49:06.919 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/battery-status?country=de
        2023-10-21 15:49:06.920 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:49:34.955 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/battery-inhibition-status?country=de
        2023-10-21 15:49:34.955 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:50:02.992 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/cockpit?country=de
        2023-10-21 15:50:02.993 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:50:31.033 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v2/cars/xxxx/cockpit?country=de
        2023-10-21 15:50:31.033 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:50:59.072 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charge-mode?country=de
        2023-10-21 15:50:59.073 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:51:27.109 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-status?country=de
        2023-10-21 15:51:27.109 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:51:55.144 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/hvac-settings?country=de
        2023-10-21 15:51:55.144 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:52:23.180 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charging-settings?country=de
        2023-10-21 15:52:23.180 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:52:51.255 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/charges?start=1970-01-01&end=2023-10-21&country=de
        2023-10-21 15:52:51.256 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:53:19.290 - error: renault.0 (196348) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/69d7a7c4-d94a-464f-9273-3a7c040b569a/kamereon/kca/car-adapter/v1/cars/xxxx/location?country=de
        2023-10-21 15:53:19.291 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN api-wired-prod-1-euw1.wrd-aws.com
        2023-10-21 15:54:06.731 - error: renault.0 (196348) refresh token failed
        2023-10-21 15:54:06.732 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN accounts.eu1.gigya.com
        2023-10-21 15:54:06.732 - error: renault.0 (196348) Start relogin in 1min
        2023-10-21 15:55:34.772 - error: renault.0 (196348) Error: getaddrinfo EAI_AGAIN accounts.eu1.gigya.com
        2023-10-21 15:55:34.772 - error: renault.0 (196348) No session found for this account
        @tombox wird der Adapter noch supported?
        • D DPO99
          tombox
          #257
          @dpo99 Ja aber das sind server Fehler wenn die nicht dauerhaft auftreten bitte bei Renault beschweren
          • T tombox
            DPO99
            #258
            @tombox
            Das reicht mir als Antwort danke! :) Wollte nur sichergehen, dass ich wirklich nichts dran ändern kann.
              DPO99
              #259
              @tombox
              Aktuell erhalte ich diese Fehler, was bedeutet das denn?
              renault.0 2023-11-08 13:52:36.968	error {"errors":[{"errorCode":"11.06.00.02","errorMessage":"Unable to find the default routing configuration."}],"error_reference":"rrt-07a88291a254fbd95-a-eu-18202-14547622-1"}
              renault.0 2023-11-08 13:52:36.967	error	AxiosError: Request failed with status code 500
              renault.0 2023-11-08 13:52:36.966	error	Error while getting account
              H 1 Antwort Letzte Antwort
              • D DPO99
                @tombox
                HansJochen
                #260
                @dpo99
                Ich bekomme diese 500er Meldungen auch etwa stündlich, machmal auch 10 Mal in einer Minute. Ich habe die 0.21 von Github installiert, damit sind es keine Fehler, sondern Warnungen. Das eigentliche Problem mag bei Renault liegen - offenbar kommen die Meldungen ja von deren Server. Ich habe aber den Eindruck, dass trotz der ständigen Warnungen alle Änderungen auf Fahrzeugseite zeitnah im Adapter aktualisiert werden. @tombox, wenn der Server so unzuverlässig ist, reicht vielleicht auch eine Info anstatt einer Warnung. Bei der Gelegenheit: Danke für den coolen Adapter! Der ist so viel besser als dieser ganze App-Zirkus von Renault.
                  TheGulOfDedra
                  #261
                  seit Samstag haben wir einen Kangoo III - 2023 mit easy link.
                  Bis gestern lief der Adapter 0.21 gut - ein wenig zeitverzögert - aber er lief.
                  Am Nachmittag hat er dann die Arbeit eingestellt - der Adapter wird grün angezeigt, aber die Daten kommen nicht. In der Renault App sind die Daten aktuell.
                  Im Log sehe ich keine Einträge für den Adapter.
                  Hat das noch jemand, gibt es etwas was ich beachten muss? Das Intervall stand auf 10 Minuten.
                  Vielen Dank für jeden Tipp
                  • T TheGulOfDedra
                    tombox
                    #262
                    @thegulofdedra Einfach mal im debug log mode laufen lassen um zu sehen was der adapter bekommt
                    • T tombox
                      TheGulOfDedra
                      #263
                      @tombox Habe ich - und nun - nun habe ich wieder Daten. Total seltsam... Gibt es ein Maximum pro Tag?
                        TheGulOfDedra
                        #264
                        Also anscheinend hört der Adapter nachmittags auf zu funktionieren - war gestern Nachmittag wieder so - heute geht er einfach wieder.
                        Gibt es ein Limit an Anfragen pro Tag die das System "verträgt"? Der default Eintrag ist ja bei 10 Minuten - habe es nun mal auf 20 gestellt.
                        • T TheGulOfDedra
                          HansJochen
                          #265
                          @thegulofdedra
                          Möglicherweise löst Du mit der App zu viele Anfragen aus. Ich rufe über den Adapter mit 10 Minuten Intervallen ab, das funktioniert bis auf die 500er Warnungen vom Server ohne Probleme. Die Daten kommen rund um die Uhr. Die App habe ich aber wieder deinstalliert. Ich hatte sie nur anfangs gebraucht, weil der Server sonst nur langweilige Daten geliefert hatte (den Kram unter general, aber beispielsweise nicht den battery-status).
                          • MichaelScM Offline
                            MichaelScM Offline
                            MichaelSc
                            #266
                            Die VIN unserer Megane sehe ich in den renault-Datenpunkten.
                            Aber beispielsweise den Kilometerstand / Mileage: Die steht auf irgendeinem alten Anfangswert.
                            Was kann man da tun?
                            iOBroker (and the other stuff) on a Proxmox Installation on an Intel NUC10.
                            IoT: Discarded Zigbee-System and all the hardware related to Zigbee; replaced with HomeMatic IP - very reliable.
                            • MichaelScM MichaelSc
                              tombox
                              #267
                              @michaelsc Sicher das du im korrekten Objekt nachschaust
                                MichaelScM Offline
                                MichaelSc
                                #268
                                ja, @tombox, hier:
                                Das ist die "neue Megane". VIN passt.
                                Die Datenpunkte der "alten ZOE" stehen darüber, die ZOE haben wir aber abgegeben.
                                  ja, @tombox, hier:
                                  tombox
                                  #269
                                  @michaelsc bei general steht auch nicht Wird nicht aktualisiert eher unter cockpit schauen
                                    MichaelScM Offline
                                    MichaelSc
                                    #270
                                    "Cockpit"-Datenpunkte gibt es leider nicht, trotz Suche in den Objekten.
                                    Was kann ich tun?
                                      Was kann ich tun?
                                      tombox
                                      #271
                                      @michaelsc debug log via mail tombox2020@gmail.com
                                      MichaelScM 1 Antwort Letzte Antwort
                                      • T tombox
                                        MichaelScM Offline
                                        MichaelScM Offline
                                        MichaelSc
                                        #272
                                        @tombox said in Test Adapter renault v0.0.x für myRenault und myDacia:
                                        thanks...
                                        • set log level to "debug" (formerly: error)
                                        • restart of adapter
                                        • extracted "renault"-lines from log
                                          thanks...
                                          MichaelScM Offline
                                          MichaelScM Offline
                                          MichaelSc
                                          schrieb am zuletzt editiert von MichaelSc
                                          #273
                                          @tombox: Mail returned error...
                                          " This mail has been blocked because the sender is unauthenticated."
                                          How to amend this?
                                          Während der Zustellung Ihrer Nachricht an diese E-Mail-Adresse ist ein Problem aufgetreten. Versuchen Sie, die Nachricht noch mal zu senden. Wenn das Problem weiterhin besteht, wenden Sie sich an Ihren E-Mail-Administrator.
                                          Die folgende Organisation hat Ihre Nachricht abgelehnt: gmail-smtp-in.l.google.com.
                                          T JLegJ 2 Antworten Letzte Antwort
