  3. Off Topic
  4. Proxmox
  5. proxmox - iobroker startet nicht mehr
    apollon77A
Geplant Angeheftet Gesperrt Verschoben Proxmox
58 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • D dos1973
    @dp20eic
    hier das iob diag, konnte das nicht sauber in code tags packen, daher hier als Anhang
    iob-diag
    Summary
    			v.2023-10-10
     Static hostname: pve-iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-12-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
    Installation: 		kvm
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	64
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.13.0
    			/usr/local/bin/node 		v18.18.0
    			/usr/local/bin/npm 		9.8.1
    			/usr/local/bin/npx 		9.8.1
    			/usr/local/bin/corepack 	0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:             16G        3.6G         12G        552K        991M         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        3.6G         13G
    Active iob-Instances: 	38
    ioBroker Core: 		js-controller 		5.0.12
    			admin 			6.10.1
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : pve-iobroker                             -  enabled, port: 8081, bind: 192.168.10.6, run as: admin
    + system.adapter.web.0                    : web                   : pve-iobroker                             -  enabled, port: 8082, bind: 192.168.10.6, run as: admin
    Objects: 		31131
    States: 		32406
    Size of iob-Database:
    36M	/opt/iobroker/iobroker-data/objects.jsonl
    28M	/opt/iobroker/iobroker-data/objects.json.migrated
    28M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    63M	/opt/iobroker/iobroker-data/states.jsonl
    8.4M	/opt/iobroker/iobroker-data/states.json.migrated
    8.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    das kann doch weg, backups sollten hier keine auflaufen, wie gesagt sind alle auf der NAS
    /opt/iobroker/backups:
    5.1G	/opt/iobroker/backups/
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @dos1973 sagte in proxmox - iobroker startet nicht mehr:
    Wenn das 'richtig' per Mount gemacht würde, dann wäre das Verzeichnis im nicht gemounteten Zustand leer.
    mount | sort
    sagt?
    D 2 Antworten Letzte Antwort
      mount | sort
      sagt?
      D
      D
      dos1973
      ein moment bitte, mach eben: iob nodejs-update
        mount | sort
        sagt?
        D
        D
        dos1973
        @thomas-braun sagte in proxmox - iobroker startet nicht mehr:
        mount | sort
        dos1973@pve-iobroker:/$ mount | sort
        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        /dev/sda1 on / type ext4 (rw,relatime,errors=remount-ro)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
        pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
        ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16051)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1598844k,mode=755,inode64)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1598840k,nr_inodes=399710,mode=700,uid=1000,gid=1000,inode64)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        udev on /dev type devtmpfs (rw,nosuid,relatime,size=7975172k,nr_inodes=1993793,mode=755,inode64)
        • D dos1973
          @dp20eic
          iob-diag
          Summary
          			v.2023-10-10
                   Chassis: vm 🖴
            Virtualization: kvm
          Installation: 		kvm
          Kernel: 		x86_64
          Userland: 		amd64
          User-ID: 		1000
          X-Server: 		false
          Please check
          MEMORY:
          Swap:           1.0G          0B        1.0G
          Total:           17G        3.6G         13G
          			admin 			6.10.1
          Objects type: jsonl
          States  type: jsonl
          Objects: 		31131
          States: 		32406
          Moin,
          wie hast Du das eingerichtet, so wie @Thomas-Braun sagte, als Mount oder schiebst Du die per FTP aufs NAS.
          Denn ich sehe da keinen Mount, vom NAS!
          Bernd
          • D dos1973
            mount | sort
            Thomas BraunT
            Thomas BraunT
            @dos1973
            Wenn du sicher bist, dass die Backups auf dem NAS liegen:
            rm /opt/iobroker/backups/*
            Und richte dir das Backup dann gescheit ein. Per NFS, zur Not per CIFS.
            Und dann richte das ookla-Repo richtig ein sowie ganz wichtig: Räum die krumme nodejs-Installation weg.
            Und lass die Finger von n, nvm oder sonstigen Tools zu nodejs.
              Moin,
              Bernd
              D
              D
              dos1973
              @dp20eic
              ich mach das backup direkt aus proxmox. dort habe ich mein nas verknüpft
              Thomas BraunT ? 2 Antworten Letzte Antwort
                @dos1973
                D
                D
                dos1973
                gelöscht, habe jetzt wieder 6GB frei.
                dos1973@pve-iobroker:/$ df -h
                Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                udev            7,7G       0  7,7G    0% /dev
                tmpfs           1,6G    528K  1,6G    1% /run
                /dev/sda1        19G     12G  6,0G   67% /
                tmpfs           7,7G       0  7,7G    0% /dev/shm
                tmpfs           5,0M       0  5,0M    0% /run/lock
                tmpfs           1,6G       0  1,6G    0% /run/user/1000
                • D dos1973
                  @dp20eic
                  Thomas BraunT
                  Thomas BraunT
                  Das ist kein gescheites Backup, das ist die 'Dampfwalzen'-Taktik. Vollkommener Overkill.
                  (Speicherplatz ist echt zu billig geworden.)
                  • D dos1973
                    @dp20eic
                    Moin,
                    wie hast Du das gemacht, zeig mal wie das bei Dir aussieht
                    Das was man da per CIFS, NFS mounten kann ist eigentlich nur für den PVE und die dazugehörigen Inhalte.
                    Oder meinst Du die VM Backups und nicht die ioBroker - BakitUp?
                    Bernd
                    P.S.: installier dir trotzdem mal ncdu und schau nach wo die Speicherfresser liegen.
                      Moin,
                      Bernd
                      D
                      D
                      dos1973
                      @dp20eic
                      Ich melde mich gleich mit ein paar Screenshot … musste mal Taxidienst spielen
                      • D dos1973
                        @dp20eic
                        Thomas BraunT
                        Thomas BraunT
                        @dos1973
                        Um eine Backup-Strategie kannst du dich kümmern, wenn das Ding wieder senkrecht steht.
                          D
                          D
                          dos1973
                          schrieb am zuletzt editiert von dos1973
                          ich habe das NAS im Proxmox eingebunden und führe um 5:30 via Proxmox automatisiert die Backupjobs aus
                          ich führe das jede Nacht aus und behalte die letzen 10 Dateien.
                          So ein File hat ca. 10-12GB: Ja, Platz habe ich auf der Nas mehr als genug, ;-)
                          aber mit dem backup bin ich ehrlich gesagt zufrieden, im Fall der Fälle habe ich mit ein paar Klicks das System in 5 min wiederhergestellt.
                          ich habe mir das hier und da online zusammengesucht... ich probiere aus und wenn es läuft Klasse, ansonsten müsste ich ja jedes mal ein Hilfe Thread starten...
                          • D dos1973
                            Thomas BraunT
                            Thomas BraunT
                            @dos1973
                            Ist denn der iobroker wieder auf dem Damm?
                            Repos gefixt? nodejs gefixt?
                            iob diag
                            sagt?
                            • D dos1973
                              Thomas BraunT
                              Thomas BraunT
                              Dann brauchst du ja keine Backups in /opt/iobroker/backups vorhalten.
                              Das ist ja dann alles doppelt.
                                iob stop
                                iob fix
                                iob nodejs-update
                                D
                                D
                                dos1973
                                iob stop
                                iob fix
                                iob nodejs-update
                                das klappt leider nicht.
                                ioBroker nodejs fixer 2023-10-13
                                Recommended nodejs-version is: 18.18.2
                                Checking your installation now. Please be patient!
                                Your current setup is:
                                /usr/bin/node 		v18.13.0
                                /usr/bin/npm 		9.2.0
                                /usr/bin/npx 		9.2.0
                                We found these nodejs versions available for installation:
                                nodejs:
                                  Installed: 18.13.0+dfsg1-1
                                  Candidate: 18.18.2-1nodesource1
                                  Version table:
                                     18.18.2-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                     18.18.1-1nodesource1 1001
                                     18.18.0-1nodesource1 1001
                                     18.17.1-1nodesource1 1001
                                     18.17.0-1nodesource1 1001
                                     18.16.1-1nodesource1 1001
                                     18.16.0-1nodesource1 1001
                                     18.15.0-1nodesource1 1001
                                     18.14.2-1nodesource1 1001
                                     18.14.1-1nodesource1 1001
                                     18.14.0-1nodesource1 1001
                                 *** 18.13.0+dfsg1-1 500
                                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                     18.13.0-1nodesource1 1001
                                     18.12.0-1nodesource1 1001
                                     18.11.0-1nodesource1 1001
                                     18.10.0-1nodesource1 1001
                                     18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                     18.8.0-1nodesource1 1001
                                     18.7.0-1nodesource1 1001
                                     18.6.0-1nodesource1 1001
                                     18.5.0-1nodesource1 1001
                                     18.4.0-1nodesource1 1001
                                     18.3.0-1nodesource1 1001
                                     18.2.0-1nodesource1 1001
                                     18.1.0-1nodesource1 1001
                                     18.0.0-1nodesource1 1001
                                Nothing to do - Your installation is using the correct paths.
                                You are running nodejs v18.13.0. Do you want to install recommended version 18.18.2?
                                Press <y> to continue or any other key to quit
                                Trying to update your installation now. Please be patient.
                                Virtualization: kvm
                                Waiting for ioBroker to shut down - Give me a minute...
                                *** These repos are active on your system:
                                Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                Hit:2 http://deb.debian.org/debian bookworm InRelease
                                Ign:4 https://ookla.bintray.com/debian generic InRelease
                                Err:4 https://ookla.bintray.com/debian generic InRelease
                                  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.214.194.113 443]
                                Reading package lists... Done
                                W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.214.194.113 443]
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                                Package: nodejs
                                Pin: origin deb.nodesource.com
                                Pin-Priority: 1001
                                *** These repos are active after the adjustments:
                                Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Ign:5 https://ookla.bintray.com/debian generic InRelease
                                Err:5 https://ookla.bintray.com/debian generic InRelease
                                  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.232.172.199 443]
                                W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 18.232.172.199 443]
                                Installing the recommended nodejs version now!
                                Installing the recommended nodejs version!
                                E: Broken packages
                                *** You need to manually restart your container/virtual machine now! ***
                                We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                                dos1973@pve-iobroker:~$ node -v
                                v18.13.0
                                er fragt ob ich auf 18.18.2 update, macht er aber nicht.
                                iob Diag zeigt weiterhin Fehler bei nodjs
                                *** NodeJS-Installation ***
                                /usr/bin/npm 		9.2.0
                                /usr/bin/npx 		9.2.0
                                • D dos1973
                                  iob stop
                                  iob fix
                                  iob nodejs-update
                                  /usr/bin/npm 		9.2.0
                                  /usr/bin/npx 		9.2.0
                                  nodejs:
                                    Version table:
                                  Virtualization: kvm
                                  Package: nodejs
                                  Pin-Priority: 1001
                                  E: Broken packages
                                  v18.13.0
                                  /usr/bin/npm 		9.2.0
                                  /usr/bin/npx 		9.2.0
                                  Thomas BraunT
                                  Thomas BraunT
                                  @dos1973
                                  iob stop
                                  sudo apt remove nodejs libnode* node-*
                                  sudo apt install nodejs
                                  iob start
                                  Und dann nochmal
                                  iob nodejs-update
                                    @dos1973
                                    iob stop
                                    iob start
                                    Und dann nochmal
                                    iob nodejs-update
                                    D
                                    D
                                    dos1973
                                    schaut jetzt gut aus, Danke
                                    /usr/bin/nodejs 	v18.18.2
                                    /usr/bin/node 		v18.18.2
                                    /usr/bin/npm 		9.8.1
                                    /usr/bin/npx 		9.8.1
                                    /usr/bin/corepack 	0.19.0
                                    das Fehl:11 https://ookla.bintray.com/debian generic InRelease
                                    habe ich hier gefunden und
                                    dos1973@pve-iobroker:/etc/apt/sources.list.d$ ls
                                    nodesource.list  speedtest.list
                                      GNU nano 7.2        speedtest.list
                                    #deb https://ookla.bintray.com/debian generic main
                                    • D dos1973
                                      /usr/bin/npm 		9.8.1
                                      /usr/bin/npx 		9.8.1
                                      Thomas BraunT
                                      Thomas BraunT
                                      speedtest.list
                                      Lösch die Datei. Das wird jetzt anders angelegt. Link hatte ich oben schon gepostet.
                                        speedtest.list
                                        D
                                        D
                                        dos1973
                                        ok, habe da jetzt auch
                                        nodesource.list  ookla_speedtest-cli.list
                                        # this file was generated by packagecloud.io for
                                        # the repository at https://packagecloud.io/ookla/speedtest-cli
                                        deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bookworm main
                                        deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bookworm main
                                        • D dos1973
                                          D
                                          D
                                          dos1973
                                          der Server sollte jetzt doch wieder laufen, noch eine Frage habe ich
                                          ich habe ja die 6GB Daten gelöscht, es es üblich dass mein iobroker 12GB groß ist?
                                          woher kamen die backups in dem order
                                          kommt das vom Backitup Adapter, hatte den überhaupt nicht auf dem Schirm.
                                          wäre das die Backup Strategie den Adapter zu nutzen?
                                          84.0k
