  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 515.2k Aufrufe 93 Beobachtet
  • F Flatlander
    @rene55 Here they are:
    00
    Log-Größe: 68.0 KB
    Zeit
    Nachricht
    deyeidc.0
    	2023-10-18 14:39:04.709	debug	checkUserData is ready
    deyeidc.0
    	2023-10-18 14:39:04.708	debug	Sync time set to 60000 ms
    deyeidc.0
    	2023-10-18 14:39:04.707	debug	IP address [192.168.2.109] seems to be valid.
    deyeidc.0
    	2023-10-18 14:39:04.670	info	starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.deyeidc, node: v18.17.1, js-controller: 5.0.12
    deyeidc.0
    	2023-10-18 14:39:04.475	debug	States connected to redis: 127.0.0.1:9000
    deyeidc.0
    	2023-10-18 14:39:04.417	debug	States create User PubSub Client
    deyeidc.0
    	2023-10-18 14:39:04.416	debug	States create System PubSub Client
    deyeidc.0
    	2023-10-18 14:39:04.402	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    deyeidc.0
    	2023-10-18 14:39:04.253	debug	Objects connected to redis: 127.0.0.1:9001
    deyeidc.0
    	2023-10-18 14:39:04.249	debug	Objects client initialize lua scripts
    deyeidc.0
    	2023-10-18 14:39:04.220	debug	Objects create User PubSub Client
    deyeidc.0
    	2023-10-18 14:39:04.220	debug	Objects create System PubSub Client
    deyeidc.0
    	2023-10-18 14:39:04.218	debug	Objects client ready ... initialize now
    deyeidc.0
    	2023-10-18 14:39:04.192	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.DellE6400
    	2023-10-18 14:39:03.439	info	instance system.adapter.deyeidc.0 started with pid 13205
    host.DellE6400
    	2023-10-18 14:39:03.368	info	"system.adapter.deyeidc.0" enabled
    host.DellE6400
    	2023-10-18 14:38:56.691	info	instance system.adapter.deyeidc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    deyeidc.0
    	2023-10-18 14:38:56.631	info	terminating
    host.DellE6400
    	2023-10-18 14:38:56.165	info	stopInstance system.adapter.deyeidc.0 send kill signal
    deyeidc.0
    	2023-10-18 14:38:56.129	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    deyeidc.0
    	2023-10-18 14:38:56.128	info	terminating
    deyeidc.0
    	2023-10-18 14:38:56.127	debug	[onUnload] cleaned everything up...
    deyeidc.0
    	2023-10-18 14:38:56.126	info	Got terminate signal TERMINATE_YOURSELF
    host.DellE6400
    	2023-10-18 14:38:56.121	info	stopInstance system.adapter.deyeidc.0 (force=false, process=true)
    host.DellE6400
    	2023-10-18 14:38:56.120	info	"system.adapter.deyeidc.0" disabled
    Rene55R Online
    Rene55R Online
    Rene55
    #650
    @flatlander Hmm. irgendwer oder was killt deine Instanz: stopInstance system.adapter.deyeidc.0 send kill signal
    F 1 Antwort Letzte Antwort
    • Rene55R Rene55
      Flatlander
      #651
      @rene55 Ich denke, das war ich, als ist die Instanz gestoppt und wieder gestartet habe.
      Ein paar Sekundenspäter kommt dann:
      und ab dann bekomme ich keine Medlung stopInstance mehr.
      • F Flatlander
        Rene55R Online
        Rene55R Online
        Rene55
        #652
        @flatlander Ja das kann sein. Aber ich werde bei dir immer ratloser .😖
        • Rene55R Rene55
          Flatlander
          #653
          @rene55 Auch wenn's kein Trost ist: Habe gerade auf dem Systemmonitor nachgesehen: der Prozess 13205 (deyeidc) läuft...
          • F Flatlander
            @rene55 Ja, ich habe das html-fenster: config_hide offen.
            Rico Sander
            schrieb am zuletzt editiert von Rico Sander
            #654
            @flatlander sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
            Bitte mal einen screenshot von dem Fenster.
            Und was sagen die 'Device Information' unter /index_cn.html
            Wenns nicht geht, wie man will
            - muss mans tun, wie man kann.
            F 2 Antworten Letzte Antwort
            • R Rico Sander
              Flatlander
              #655
              @pi-ter Bitte schön:
              • R Rico Sander
                Flatlander
                #656
                @pi-ter Hier die Device info:
                -Device information
                Device serial number 4175546573
                Firmware version MW3_16U_5406_1.57
                Wireless AP mode
                Enable
                SSID
                AP_4175546573
                IP address
                10.10.100.254
                MAC address
                EC:FD:F8:7C:AD:20
                Wireless STA mode
                Enable
                Router SSID Toms_Huette
                Signal Quality 100%
                IP address 192.168.x.xxx
                MAC address E8:FD:F8:7C:AD:20
                Habe ich überprüft, solsteht es auch in den Einstellungen des deyeidc.
                • F Flatlander
                  Rico Sander
                  #657
                  @flatlander
                  OK, da bin ich raus...
                  Das sieht bei mir unter 'advanced/access point' ganz anders aus.
                  Was sagen die 'Device Information' unter /index_cn.html ?
                  Edit: Ok, Du warst schneller :-)
                  • R Rico Sander
                    @flatlander
                    Flatlander
                    #658
                    @pi-ter Unter Advanced Accessoint setting steht dann noch:
                    Network Mode = 11bgn
                    SSID = AP_4755xxxx
                    Select channel = autoselect.
                    Desweiteren noch LAN settings:
                    Ist mir nur nicht klar wessen. Meines ist es nicht.
                    • F Flatlander
                      SSID = AP_4755xxxx
                      Rene55R Online
                      Rene55R Online
                      Rene55
                      #659
                      @flatlander Ich habe den Adapter eben einer "chemischen Reinigung" unterzogen ☺ . An alle, die momentan Probleme mit dem Relais oder dem RangeError haben, können bitte die aktuelle Version direkt von Github installieren. Ob dir das mit deinen besonderen Problemen (Danke auch an pi-ter) hilft, kann ich nicht sagen.
                      Aber Versuch macht kluch.
                      • Rene55R Rene55
                        Flatlander
                        #660
                        @rene55 Na dann schaun mer mal.
                        • L Offline
                          lesiflo
                          #661
                          @rene55 Hab ich hier gefunden: link text
                          Hatte ich schon so gemacht. Geht wohl leider auch nur auslesen.
                          • L lesiflo
                            Rene55R Online
                            Rene55R Online
                            Rene55
                            #662
                            @lesiflo Was hattest du den genau vor bzw. gemacht?
                            L 1 Antwort Letzte Antwort
                            • Rene55R Rene55
                              lesiflo
                              #663
                              @rene55 said in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                              Ich betreibe den Deye-WR zusammen mit einen Zendure SolarFlow Speicher, bei dem man über mqtt aktuell nur Daten
                              auslesen kann. Meine Idee war, das ich abhängig vom aktuellen Verbrauch und des Akkustandes über iobroker die Ausgangsleistung des WR regeln kann wieviel Strom in Netz gehen darf. Das geht zwar auch über den SolarFlow allerdings nur statisch über Zeiten oder mit zusätzlicher Hardware wie den Shelly Pro 3EM.
                              • L lesiflo
                                Rene55R Online
                                Rene55R Online
                                Rene55
                                #664
                                @lesiflo Danke für die Erklärung. So etwas mit Zwischenspeicher schwebt mir auch vor. Ist der Zendure empfehlenswert?
                                Also ich nutze diesen Wert nur zur Reduzierung der Leistung im Sommer, wenn ich in Urlaub bin. Dann wird weniger Verbraucht und auch weniger Eingespeist. Das ist also höchstens 4 x im Jahr - davon wird der WR wohl keinen Schaden nehmen. Dauerndes Regeln zieht ein dauerndes Schreiben auf das EEPROM nach sich. Wie oft man das machen kann weiß wohl keiner. Nur ich möchte nicht schuld sein, wenn nach gewisser Zeit der WR defekt ist.
                                • Rene55R Rene55
                                  Flatlander
                                  #665
                                  @rene55 Hallo Rene, hat mein Problem leider nicht gelöst. Habe in der Zwischenzeit folgenden Eintrag von jlopez77 bei github gefunden: "The inverter is not fast enough to answer, you can get timeouts if you query it too often."
                                  Da ich ja immer die Fehlermeldung ETIMEDOUT bekomme frage ich mich, ob mein Deye nicht besonders langsam ist. Kann man im deyeidc diesen timeout einstellen ?
                                  • F Flatlander
                                    Rene55R Online
                                    Rene55R Online
                                    Rene55
                                    #666
                                    @flatlander Ich kann mir nicht vorestellen, dass du ein besonders langsames Exemplar hast. Bei einer Abfragerate von einer Minute hatte ich bisher noch keine ETIMEOUT. Den bekomme ich nur, wenn der WR nicht erreichbar ist z.B. bei Dunkelheit. Du kannst dem ja entgegenwirken indem due die Abfragerate höher stellst. Bei dir muss es was anderes sein - so einen hartnäckigen Fall hatte ich bisher noch nicht,
                                    • Rene55R Rene55
                                      lesiflo
                                      schrieb am zuletzt editiert von lesiflo
                                      #667
                                      Bisher macht er das was er kann recht zuverlässig. Ich habe mich mich für den SolarFlow entschieden weil er erweiterbar ist und man später nur die Akku's tauschen muss und nicht gleich das ganze Gerät wie z.B. beim Anker Solix. Da ich noch eine große 7 kW PV Anlage (ohne Speicher) habe nutze das ganze zusammen mit dem Balkonkraftwerk primär nur zum Strom speichern. Tagsüber speichern, Abends und Nachts entladen.
                                      • L lesiflo
                                        Rene55R Online
                                        Rene55R Online
                                        Rene55
                                        #668
                                        @lesiflo Nochmals Danke, dann habe ich eine Richtung, in die ich mich orientieren kann.
                                        P 1 Antwort Letzte Antwort
                                        • Rene55R Rene55
                                          Pino72
                                          schrieb am zuletzt editiert von Pino72
                                          #669
                                          @rene55
                                          Hatte nach der Installation der Relay Box die Out of Range Fehler, mit dem update auf 0.0.13 sind die jetzt erst mal weg. Danke!
                                          wobei sehe gerade nicht ganz, sie kommen sehr viel seltener ;-)
                                          deyeidc.0
                                          	2023-10-20 11:13:37.397	error	TypeError: Cannot read properties of undefined (reading 'registerStart')
                                          deyeidc.0
                                          	2023-10-20 09:27:25.156	error	RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 7. Received 11
                                          deyeidc.0
                                          	2023-10-20 09:27:24.708	error	RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 7. Received 11
                                          deyeidc.0
                                          	2023-10-20 08:06:35.950	error	TypeError: Cannot read properties of undefined (reading 'registerStart')
