  4. Blockly Bausteine sendto fehlen[gelöst]
44 Beiträge 8 Kommentatoren 6.0k Aufrufe 6 Beobachtet
  • K Kellerkind-86
    @mcm57
    node -v18.17.1
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "synology"     : 3.0.0    , installed 3.0.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    @kellerkind-86 sagte in Blockly Bausteine sendto fehlen:
    node -v18.17.1
    Heb das auf 18.18.1
      node -v18.17.1
      Heb das auf 18.18.1
      Kellerkind-86
      ja. ich hatte das im iobroker schon gesehen.. hab dann ein update gemacht aber ich komme nicht höher
      nodejs is already the newest version (18.17.1-deb-1nodesource1).
      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
      Gruß Marcell
      • K Kellerkind-86
        @kellerkind-86
        Mach es mit dem Skript aus meiner Signatur.
          @kellerkind-86
          Kellerkind-86
          schrieb am zuletzt editiert von Kellerkind-86
          @thomas-braun said in Blockly Bausteine sendto fehlen:
                                  v.2023-10-10
           Static hostname: Iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.2.16-14-pve
              Architecture: x86-64
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Etc/UTC (UTC, +0000)
          User-ID:                1001
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                  /usr/bin/node           v18.18.1
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
          Recommended versions are nodejs 18.18.1 and npm 9.8.1
          MEMORY:
          Mem:            8.6G        1.7G        6.3G        114K        548M        6.8G
          Swap:           4.3G          0B        4.3G
          Total:           12G        1.7G         10G
          Active iob-Instances:   16
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.12
                                  admin                   6.10.1
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : Iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.web.1                    : web                   : Iobroker                                 - disabled, port: 20002, bind: 0.0.0.0, run as: admin
          Objects:                15026
          States:                 12717
          Size of iob-Database:
          17M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/states.jsonl
          vielleicht mal js adapter neu installieren ?
          Gruß Marcell
          • K Kellerkind-86
            Hardwaresystem: HP Prodesk 400 G3
            Arbeitsspeicher: 16GB
            Festplattenart: SSD
            Betriebssystem: Raspian
            Node-Version: 10.x.x
            Nodejs-Version: v18.17.1
            NPM-Version: 9.6.7
            Installationsart: Skript/Manuell
            Image genutzt: Ja
            Ort/Name der Imagedatei: Link
            ich wunder mich gerade warum meine bausteine zu sendto fehlen..
            habe auch schon hier gelesen aber der link der am ende kommt..der führt zu nichts.. da der fehler ja anscheinend schon etwas älter ist,gehe ich mal davon aus, dass es schon eine lösung dafür gibt.
            vorher hab ich die whatsapp- instanz installiert..jetzt aber wieder deinstalliert.
            GlasfaserG Offline
            GlasfaserG Offline
            mache mal
            iob upload all
            dann
            sudo reboot
            Wenn nicht ... dann nimm einen Browser im Inkognito Modus und öffne damit den Admin
            • GlasfaserG Glasfaser
              mache mal
              iob upload all
              dann
              sudo reboot
              Kellerkind-86
              @glasfaser
              hab ich ausgeführt.
              gleicher fehler.
              Gruß Marcell
              • K Kellerkind-86
                @glasfaser
                hab ich ausgeführt.
                gleicher fehler.
                GlasfaserG Offline
                GlasfaserG Offline
                gleicher fehler.
                Du zeigst das Skript von ganz oben ( vorhanden ) , erstelle mal bitte ein neues , was ist dann !?
                  gleicher fehler.
                  Kellerkind-86
                  @glasfaser said in Blockly Bausteine sendto fehlen:
                  gleicher fehler.
                  habe gerade auch mal ein backup von heute morgen ausgeführt.. auch gleicher fehler. 😕
                  Gruß Marcell
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    @kellerkind-86
                    zu deinem Fehler ... oben wie auch jetzt sieht man
                    also heißt das bei einem neu erstellten Script und dann bei der Auswahl sendto kommt nur iot
                      @kellerkind-86
                      Kellerkind-86
                      @glasfaser genau.. normal kommen da ja weit aus mehr.. alexa, telegram etc..pp
                      aber mir scheint als liegen da zwei übereinander..
                      bringt es nichts wenn ich den js adapter mal neuinstalliere ?
                      Gruß Marcell
                      • K Kellerkind-86
                        GlasfaserG Offline
                        GlasfaserG Offline
                        kannst du machen ...
                        Adapter stoppen , Instanz deinstallieren , dann den Adapter deinstallieren
                        Dann Adapter wieder installieren + Instanz
                          Kellerkind-86
                          @glasfaser leider nein...
                          mannoo
                          liegen da nicht zwei übereinander ?
                          Gruß Marcell
                          • K Kellerkind-86
                            mannoo
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @kellerkind-86
                            Dann bitte einen Browser nehmen , mit dem du noch nie ioBroker ( Admin ) geöffnet hast
                            • K Kellerkind-86
                              mannoo
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @kellerkind-86
                              Sieht aus wie ein Wetter Adapter oder was könnte das sein .. mit " des Tages " und Escapezeichen verwenden !?
                              EDIT
                              Escapezeichen ist von Telegram Adapter
                              • K Kellerkind-86
                                Festplattenart: SSD
                                NPM-Version: 9.6.7
                                Image genutzt: Ja
                                haus-automatisierungH Offline
                                @kellerkind-86
                                • Welche Version des JavaScript-Adapters?
                                • Entwickler-Console vom Browser öffnen und nach Fehlern schauen
                                Da macht eine Block-Definition in sendTo alles kaputt. Wahrscheinlich ein Bug eines Adapters.
                                📚 Meine Dokumentation
                                  @kellerkind-86
                                  EDIT
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  @glasfaser sagte in Blockly Bausteine sendto fehlen:
                                  getHistory müsste das sein
                                  Lehrling seit 1975 !!!
                                    GlasfaserG Offline
                                    @glasfaser
                                    Die sind überlappt
                                    • Telegram Adapter
                                    • iot Adapter
                                    • history
                                    EDIT
                                    @DJMarc75
                                    Jipp :) du warst schneller
                                      Kellerkind-86
                                      hab firefox installiert und hab dasselbe problem.
                                      @haus-automatisierung said in Blockly Bausteine sendto fehlen:
                                      js adapter - v7.1.4
                                      iobroker.admin@6.10.0
                                      instrument.ts:144 [2023-10-12T18:54:22.547Z] Try to connect
                                      instrument.ts:144 Stored version: , new version: 6.10.0
                                      instrument.ts:144 Connected: true
                                      instrument.ts:144 [ADAPTERS] getAdapters
                                      instrument.ts:144 [ADAPTERS] getAdaptersInfo
                                      github.com/iobroker-community-adapters/ioBroker.fakeroku/master/admin/fakeroku.png:1     Failed to load resource: the server responded with a status of 404 ()
                                      raw.githubusercontent.com/instalator/ioBroker.vis-players/master/admin/players.png:1     Failed to load resource: the server responded with a status of 404 ()
                                      bootstrap.jsx:26 iobroker.javascript@7.1.4 using theme "colored"
                                      Prompt.js:14
                                      Prompt.js:15 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
                                      Prompt.js:16 Help us to create open source project with reactJS!
                                      Prompt.js:17 See you :)
                                      socket.io.js:66 [2023-10-12T18:54:53.723Z] Try to connect
                                      sentry.iobroker.net/api/56/envelope/?sentry_key=504499a725eb4898930d3b9e9da95740&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.62.0:1     Failed to load resource: the server responded with a status of 403 ()
                                      instrument.ts:132 Detected custom blockly: enigma2
                                      instrument.ts:132 Detected custom blockly: iot
                                      instrument.ts:132 Detected custom blockly: telegram
                                      instrument.ts:132 Translation for word "Sends message via telegram" in "de" was ignored: existing = "Sendet eine Nachricht per telegram", new = Sendet Nachricht per Telegramm
                                      (anonymous) @ instrument.ts:132
                                      (anonymous) @ i18n.js:106
                                      value @ i18n.js:102
                                      (anonymous) @ index.jsx:143
                                      instrument.ts:132 Translation for word "You can use %s in the text to display current trigger value or %id to display the triggered object ID" in "de" was ignored: existing = "Sie können %s im Text verwenden, um den aktuellen Triggerwert anzuzeigen, %id, um die ausgelöste Objekt-ID zu verwenden, %name, um den ID-Namen des ausgelösten Objekts anzuzeigen, oder %old, um den alten Triggerwert zu verwenden", new = Sie können %s im Text verwenden, um den aktuellen Triggerwert anzuzeigen, oder %id, um die ID des ausgelösten Objekts anzuzeigen
                                      value @ i18n.js:102
                                      instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                      isSerializable @ blockly_compressed.js:631
                                      fieldToDom$$module$build$src$core$xml @ blockly_compressed.js:157
                                      allFieldsToDom$$module$build$src$core$xml @ blockly_compressed.js:157
                                      blockToDom$$module$build$src$core$xml @ blockly_compressed.js:158
                                      blockToDomWithXY$$module$build$src$core$xml @ blockly_compressed.js:156
                                      BlockCreate$$module$build$src$core$events$events_block_create @ blockly_compressed.js:575
                                      domToBlock$$module$build$src$core$xml @ blockly_compressed.js:173
                                      domToWorkspace$$module$build$src$core$xml @ blockly_compressed.js:167
                                      value @ BlocklyEditor.jsx:446
                                      (anonymous) @ BlocklyEditor.jsx:534
                                      f @ regeneratorRuntime.js:44
                                      (anonymous) @ regeneratorRuntime.js:128
                                      (anonymous) @ regeneratorRuntime.js:69
                                      r @ asyncToGenerator.js:3
                                      s @ asyncToGenerator.js:22
                                      blockToDom$$module$build$src$core$xml @ blockly_compressed.js:160
                                      blockToDom$$module$build$src$core$xml @ blockly_compressed.js:162
                                      saveFields$$module$build$src$core$serialization$blocks @ blockly_compressed.js:192
                                      save$$module$build$src$core$serialization$blocks @ blockly_compressed.js:187
                                      saveConnection$$module$build$src$core$serialization$blocks @ blockly_compressed.js:194
                                      saveInputBlocks$$module$build$src$core$serialization$blocks @ blockly_compressed.js:193
                                      save$$module$build$src$core$serialization$blocks @ blockly_compressed.js:188
                                      saveNextBlocks$$module$build$src$core$serialization$blocks @ blockly_compressed.js:194
                                      instrument.ts:132 Calling the Mutator constructor without passing the block it is attached to was deprecated in version 9 and will be deleted in version 10.
                                      Use the constructor by passing the list of subblocks and the block instance to attach the mutator to instead.
                                      instrument.ts:132 Calling the Icon constructor with a null block was deprecated in version 9 and will be deleted in version 10.
                                      Use a non-null block instead.
                                      2instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                      instrument.ts:132 Ignoring non-existent input TIMEOUT in block sendto_otherscript
                                      4instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                      instrument.ts:132 Ignoring non-existent input STEP in block sendto_gethistory
                                      helpers.ts:120 Uncaught TypeError: FieldDropdown options must not be an empty array.
                                          at validateOptions$$module$build$src$core$field_dropdown (blockly_compressed.js:280:166)
                                          at new FieldDropdown$$module$build$src$core$field_dropdown (blockly_compressed.js:658:697)
                                          at BlockSvg$$module$build$src$core$block_svg.init (blockly.js:70:26)
                                          at BlockSvg$$module$build$src$core$block_svg.doInit_ (blockly_compressed.js:761:485)
                                          at new BlockSvg$$module$build$src$core$block_svg (blockly_compressed.js:901:331)
                                          at WorkspaceSvg$$module$build$src$core$workspace_svg.newBlock (blockly_compressed.js:1662:91)
                                          at domToBlockHeadless$$module$build$src$core$xml (blockly_compressed.js:182:214)
                                          at domToBlock$$module$build$src$core$xml (blockly_compressed.js:172:140)
                                          at VerticalFlyout$$module$build$src$core$flyout_vertical.createFlyoutBlock_ (blockly_compressed.js:1395:468)
                                          at VerticalFlyout$$module$build$src$core$flyout_vertical.createFlyoutInfo_ (blockly_compressed.js:1393:495)
                                          at VerticalFlyout$$module$build$src$core$flyout_vertical.show (blockly_compressed.js:1392:267)
                                          at Toolbox$$module$build$src$core$toolbox$toolbox.updateFlyout_ (blockly_compressed.js:1626:387)
                                          at Toolbox$$module$build$src$core$toolbox$toolbox.setSelectedItem (blockly_compressed.js:1625:103)
                                          at Toolbox$$module$build$src$core$toolbox$toolbox.onClick_ (blockly_compressed.js:1614:97)
                                          at HTMLDivElement.g (blockly_compressed.js:133:151)
                                          at HTMLDivElement.a (helpers.ts:98:1)
                                      ist das gemeint ?
                                      Gruß Marcell
                                      • K Kellerkind-86
                                        js adapter - v7.1.4
                                        Prompt.js:14
                                        value @ i18n.js:102
                                        value @ i18n.js:102
                                        ist das gemeint ?
                                        CodierknechtC Offline
                                        Codierknecht
                                        @Kellerkind-86
                                        Ab Zeile 772 sieht das nicht wirklich gut aus.
                                        HmIP|ZigBee|Tasmota|Unifi
                                        Zabbix Certified Specialist
                                          GlasfaserG Offline
                                          Ein Backup hast du ja !
                                          De und Installiere mal den History Adapter ,
