  4. Blockly Bausteine sendto fehlen[gelöst]
44 Beiträge 8 Kommentatoren 6.0k Aufrufe 6 Beobachtet
    Kellerkind-86
    @mcm57
    node -v18.17.1
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "synology"     : 3.0.0    , installed 3.0.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Gruß Marcell
    • K Kellerkind-86
      @mcm57
      node -v18.17.1
      @kellerkind-86 sagte in Blockly Bausteine sendto fehlen:
      node -v18.17.1
      Heb das auf 18.18.1
        node -v18.17.1
        Heb das auf 18.18.1
        Kellerkind-86
        ja. ich hatte das im iobroker schon gesehen.. hab dann ein update gemacht aber ich komme nicht höher
        nodejs is already the newest version (18.17.1-deb-1nodesource1).
        0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
        Gruß Marcell
        • K Kellerkind-86
          @kellerkind-86
          Mach es mit dem Skript aus meiner Signatur.
            @kellerkind-86
            Kellerkind-86
            schrieb am zuletzt editiert von Kellerkind-86
            @thomas-braun said in Blockly Bausteine sendto fehlen:
                                    v.2023-10-10
             Static hostname: Iobroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.2.16-14-pve
                Architecture: x86-64
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            Timezone:               Etc/UTC (UTC, +0000)
            User-ID:                1001
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                    /usr/bin/node           v18.18.1
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    /usr/bin/corepack       0.19.0
            Recommended versions are nodejs 18.18.1 and npm 9.8.1
            MEMORY:
            Mem:            8.6G        1.7G        6.3G        114K        548M        6.8G
            Swap:           4.3G          0B        4.3G
            Total:           12G        1.7G         10G
            Active iob-Instances:   16
            Active repo(s): stable
            ioBroker Core:          js-controller           5.0.12
                                    admin                   6.10.1
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.web.0                    : web                   : Iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.web.1                    : web                   : Iobroker                                 - disabled, port: 20002, bind: 0.0.0.0, run as: admin
            Objects:                15026
            States:                 12717
            Size of iob-Database:
            17M     /opt/iobroker/iobroker-data/objects.jsonl
            22M     /opt/iobroker/iobroker-data/states.jsonl
            vielleicht mal js adapter neu installieren ?
            Gruß Marcell
            • K Kellerkind-86
              Hardwaresystem: HP Prodesk 400 G3
              Arbeitsspeicher: 16GB
              Festplattenart: SSD
              Betriebssystem: Raspian
              Node-Version: 10.x.x
              Nodejs-Version: v18.17.1
              NPM-Version: 9.6.7
              Installationsart: Skript/Manuell
              Image genutzt: Ja
              Ort/Name der Imagedatei: Link
              ich wunder mich gerade warum meine bausteine zu sendto fehlen..
              habe auch schon hier gelesen aber der link der am ende kommt..der führt zu nichts.. da der fehler ja anscheinend schon etwas älter ist,gehe ich mal davon aus, dass es schon eine lösung dafür gibt.
              vorher hab ich die whatsapp- instanz installiert..jetzt aber wieder deinstalliert.
              GlasfaserG Offline
              GlasfaserG Offline
              mache mal
              iob upload all
              dann
              sudo reboot
              Wenn nicht ... dann nimm einen Browser im Inkognito Modus und öffne damit den Admin
              • GlasfaserG Glasfaser
                mache mal
                iob upload all
                dann
                sudo reboot
                Kellerkind-86
                @glasfaser
                hab ich ausgeführt.
                gleicher fehler.
                Gruß Marcell
                • K Kellerkind-86
                  @glasfaser
                  hab ich ausgeführt.
                  gleicher fehler.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  gleicher fehler.
                  Du zeigst das Skript von ganz oben ( vorhanden ) , erstelle mal bitte ein neues , was ist dann !?
                    gleicher fehler.
                    Kellerkind-86
                    @glasfaser said in Blockly Bausteine sendto fehlen:
                    gleicher fehler.
                    habe gerade auch mal ein backup von heute morgen ausgeführt.. auch gleicher fehler. 😕
                    Gruß Marcell
                    • GlasfaserG Offline
                      GlasfaserG Offline
                      @kellerkind-86
                      zu deinem Fehler ... oben wie auch jetzt sieht man
                      also heißt das bei einem neu erstellten Script und dann bei der Auswahl sendto kommt nur iot
                        @kellerkind-86
                        Kellerkind-86
                        @glasfaser genau.. normal kommen da ja weit aus mehr.. alexa, telegram etc..pp
                        aber mir scheint als liegen da zwei übereinander..
                        bringt es nichts wenn ich den js adapter mal neuinstalliere ?
                        Gruß Marcell
                        • K Kellerkind-86
                          GlasfaserG Offline
                          GlasfaserG Offline
                          kannst du machen ...
                          Adapter stoppen , Instanz deinstallieren , dann den Adapter deinstallieren
                          Dann Adapter wieder installieren + Instanz
                            Kellerkind-86
                            @glasfaser leider nein...
                            mannoo
                            liegen da nicht zwei übereinander ?
                            Gruß Marcell
                            • K Kellerkind-86
                              mannoo
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @kellerkind-86
                              Dann bitte einen Browser nehmen , mit dem du noch nie ioBroker ( Admin ) geöffnet hast
                              • K Kellerkind-86
                                mannoo
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @kellerkind-86
                                Sieht aus wie ein Wetter Adapter oder was könnte das sein .. mit " des Tages " und Escapezeichen verwenden !?
                                EDIT
                                Escapezeichen ist von Telegram Adapter
                                • K Kellerkind-86
                                  Festplattenart: SSD
                                  NPM-Version: 9.6.7
                                  Image genutzt: Ja
                                  haus-automatisierungH Offline
                                  @kellerkind-86
                                  • Welche Version des JavaScript-Adapters?
                                  • Entwickler-Console vom Browser öffnen und nach Fehlern schauen
                                  Da macht eine Block-Definition in sendTo alles kaputt. Wahrscheinlich ein Bug eines Adapters.
                                  📚 Meine Dokumentation
                                    @kellerkind-86
                                    EDIT
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @glasfaser sagte in Blockly Bausteine sendto fehlen:
                                    getHistory müsste das sein
                                    Lehrling seit 1975 !!!
                                      GlasfaserG Offline
                                      @glasfaser
                                      Die sind überlappt
                                      • Telegram Adapter
                                      • iot Adapter
                                      • history
                                      EDIT
                                      @DJMarc75
                                      Jipp :) du warst schneller
                                        Kellerkind-86
                                        hab firefox installiert und hab dasselbe problem.
                                        @haus-automatisierung said in Blockly Bausteine sendto fehlen:
                                        js adapter - v7.1.4
                                        iobroker.admin@6.10.0
                                        instrument.ts:144 [2023-10-12T18:54:22.547Z] Try to connect
                                        instrument.ts:144 Stored version: , new version: 6.10.0
                                        instrument.ts:144 Connected: true
                                        instrument.ts:144 [ADAPTERS] getAdapters
                                        instrument.ts:144 [ADAPTERS] getAdaptersInfo
                                        github.com/iobroker-community-adapters/ioBroker.fakeroku/master/admin/fakeroku.png:1     Failed to load resource: the server responded with a status of 404 ()
                                        raw.githubusercontent.com/instalator/ioBroker.vis-players/master/admin/players.png:1     Failed to load resource: the server responded with a status of 404 ()
                                        bootstrap.jsx:26 iobroker.javascript@7.1.4 using theme "colored"
                                        Prompt.js:14
                                        Prompt.js:15 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
                                        Prompt.js:16 Help us to create open source project with reactJS!
                                        Prompt.js:17 See you :)
                                        socket.io.js:66 [2023-10-12T18:54:53.723Z] Try to connect
                                        sentry.iobroker.net/api/56/envelope/?sentry_key=504499a725eb4898930d3b9e9da95740&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.62.0:1     Failed to load resource: the server responded with a status of 403 ()
                                        instrument.ts:132 Detected custom blockly: enigma2
                                        instrument.ts:132 Detected custom blockly: iot
                                        instrument.ts:132 Detected custom blockly: telegram
                                        instrument.ts:132 Translation for word "Sends message via telegram" in "de" was ignored: existing = "Sendet eine Nachricht per telegram", new = Sendet Nachricht per Telegramm
                                        (anonymous) @ instrument.ts:132
                                        (anonymous) @ i18n.js:106
                                        value @ i18n.js:102
                                        (anonymous) @ index.jsx:143
                                        instrument.ts:132 Translation for word "You can use %s in the text to display current trigger value or %id to display the triggered object ID" in "de" was ignored: existing = "Sie können %s im Text verwenden, um den aktuellen Triggerwert anzuzeigen, %id, um die ausgelöste Objekt-ID zu verwenden, %name, um den ID-Namen des ausgelösten Objekts anzuzeigen, oder %old, um den alten Triggerwert zu verwenden", new = Sie können %s im Text verwenden, um den aktuellen Triggerwert anzuzeigen, oder %id, um die ID des ausgelösten Objekts anzuzeigen
                                        value @ i18n.js:102
                                        instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                        isSerializable @ blockly_compressed.js:631
                                        fieldToDom$$module$build$src$core$xml @ blockly_compressed.js:157
                                        allFieldsToDom$$module$build$src$core$xml @ blockly_compressed.js:157
                                        blockToDom$$module$build$src$core$xml @ blockly_compressed.js:158
                                        blockToDomWithXY$$module$build$src$core$xml @ blockly_compressed.js:156
                                        BlockCreate$$module$build$src$core$events$events_block_create @ blockly_compressed.js:575
                                        domToBlock$$module$build$src$core$xml @ blockly_compressed.js:173
                                        domToWorkspace$$module$build$src$core$xml @ blockly_compressed.js:167
                                        value @ BlocklyEditor.jsx:446
                                        (anonymous) @ BlocklyEditor.jsx:534
                                        f @ regeneratorRuntime.js:44
                                        (anonymous) @ regeneratorRuntime.js:128
                                        (anonymous) @ regeneratorRuntime.js:69
                                        r @ asyncToGenerator.js:3
                                        s @ asyncToGenerator.js:22
                                        blockToDom$$module$build$src$core$xml @ blockly_compressed.js:160
                                        blockToDom$$module$build$src$core$xml @ blockly_compressed.js:162
                                        saveFields$$module$build$src$core$serialization$blocks @ blockly_compressed.js:192
                                        save$$module$build$src$core$serialization$blocks @ blockly_compressed.js:187
                                        saveConnection$$module$build$src$core$serialization$blocks @ blockly_compressed.js:194
                                        saveInputBlocks$$module$build$src$core$serialization$blocks @ blockly_compressed.js:193
                                        save$$module$build$src$core$serialization$blocks @ blockly_compressed.js:188
                                        saveNextBlocks$$module$build$src$core$serialization$blocks @ blockly_compressed.js:194
                                        instrument.ts:132 Calling the Mutator constructor without passing the block it is attached to was deprecated in version 9 and will be deleted in version 10.
                                        Use the constructor by passing the list of subblocks and the block instance to attach the mutator to instead.
                                        instrument.ts:132 Calling the Icon constructor with a null block was deprecated in version 9 and will be deleted in version 10.
                                        Use a non-null block instead.
                                        2instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                        instrument.ts:132 Ignoring non-existent input TIMEOUT in block sendto_otherscript
                                        4instrument.ts:132 Detected an editable field that was not serializable. Please define SERIALIZABLE property as true on all editable custom fields. Proceeding with serialization.
                                        instrument.ts:132 Ignoring non-existent input STEP in block sendto_gethistory
                                        helpers.ts:120 Uncaught TypeError: FieldDropdown options must not be an empty array.
                                            at validateOptions$$module$build$src$core$field_dropdown (blockly_compressed.js:280:166)
                                            at new FieldDropdown$$module$build$src$core$field_dropdown (blockly_compressed.js:658:697)
                                            at BlockSvg$$module$build$src$core$block_svg.init (blockly.js:70:26)
                                            at BlockSvg$$module$build$src$core$block_svg.doInit_ (blockly_compressed.js:761:485)
                                            at new BlockSvg$$module$build$src$core$block_svg (blockly_compressed.js:901:331)
                                            at WorkspaceSvg$$module$build$src$core$workspace_svg.newBlock (blockly_compressed.js:1662:91)
                                            at domToBlockHeadless$$module$build$src$core$xml (blockly_compressed.js:182:214)
                                            at domToBlock$$module$build$src$core$xml (blockly_compressed.js:172:140)
                                            at VerticalFlyout$$module$build$src$core$flyout_vertical.createFlyoutBlock_ (blockly_compressed.js:1395:468)
                                            at VerticalFlyout$$module$build$src$core$flyout_vertical.createFlyoutInfo_ (blockly_compressed.js:1393:495)
                                            at VerticalFlyout$$module$build$src$core$flyout_vertical.show (blockly_compressed.js:1392:267)
                                            at Toolbox$$module$build$src$core$toolbox$toolbox.updateFlyout_ (blockly_compressed.js:1626:387)
                                            at Toolbox$$module$build$src$core$toolbox$toolbox.setSelectedItem (blockly_compressed.js:1625:103)
                                            at Toolbox$$module$build$src$core$toolbox$toolbox.onClick_ (blockly_compressed.js:1614:97)
                                            at HTMLDivElement.g (blockly_compressed.js:133:151)
                                            at HTMLDivElement.a (helpers.ts:98:1)
                                        ist das gemeint ?
                                        Gruß Marcell
                                        • K Kellerkind-86
                                          js adapter - v7.1.4
                                          Prompt.js:14
                                          value @ i18n.js:102
                                          value @ i18n.js:102
                                          ist das gemeint ?
                                          CodierknechtC Offline
                                          Codierknecht
                                          @Kellerkind-86
                                          Ab Zeile 772 sieht das nicht wirklich gut aus.
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
