Einfach mal zeigen will….. :-) - Teil 1
Wie gesagt sind eigentlich alles Metro tiles, daher gebe ich dir mal zwei (wobei da echt keine großen Einstellungen drin sind)
Toggle, z.B. für die Lampen:
[{"tpl":"tplMetroTileToggle","data":{"oid":"","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","hover":"true","transform":"true","bg_class_false":"bg-dark","bg_class_true":"bg-steel","icon_class_false":"","icon_class_true":"","icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"bg-yellow","brand_bg_class_false":"","brand_bg_class_true":"","badge_top":"0","badge_left":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"label_false":"Deckenlampe","label_true":"Deckenlampe","icon_false":"/vis.0/main/img/Bild2.png","icon_true":"/vis.0/main/img/Bild2.png","name":"ArbZi Deckenlampe","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"483px","top":"322px","width":"150px","height":"150px"},"widgetSet":"metro"}]Navigationsbutton:
[{"tpl":"tplMetroTileNav","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","hover":"true","transform":"true","label":"Klima","bg_class":"bg-dark","bg_class_active":"bg-steel","badge_bg_class":"","badge_bg_class_active":"","badge_top":"0","badge_left":"0","icon_badge":"","brand_bg_class":"","brand_bg_class_active":"","icon_class":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"nav_view":"04_Klima","icon_src":"/vis.0/main/img/climate_transparent.png","icon_width":"50","icon_height":"50","icon_top":"39","icon_left":"41","select_current":false,"name":"climate_button","locked":true,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"0","top":"644px","width":"150px","height":"150px"},"widgetSet":"metro"}]ich glaube, es ist zielgerichteter wenn du einfach anfängst und dann, falls du irgendwo an Probleme stößt, dann zielgerichtet fragst, wie dieses oder jenes funktioniert. Wenn ich es dann weiß (oder jemand anderes) wirst du garantiert schnell Hilfe bekommen
@dtp:So sieht's aktuell bei mir aus.
Je nach Browser muss man zum Starten der Animation das gif anklicken.
Gruß,
Thorsten `
Hallo Thorsten,dein Vis finde ich echt super, hast du diese schon hochgeladen? Wie hast du das mit Viessmann Heizung realisiert ?
Gruß Oliver
Hi Oliver,
vielen Dank für die Blumen. Nee, hab ich noch nicht hochgeladen. Kann ich aber demnächst noch mal versuchen.
Das mit der Viessmann-Heizung ist schon eine etwas kompliziertere Sache. Kennst Du den http://forum.iobroker.net/viewtopic.php?f=23&t=3048#p27689 von blauholsten? Das ist schon mal eine gute Basis zusammen mit dem https://github.com/openv/openv/wiki.
Dank der freundlichen Mithilfe dieses Forums habe ich dann noch eine http://forum.iobroker.net/viewtopic.php?f=21&t=4199&p=40139p40139 realisieren können.
Gruß,
Thorsten
PS.: blauholsten hat mich noch um eine paar weitere Ideen zu seinem viessmann-Adapter gebeten. Es könnte also sein, dass sich da in der nächsten Zeit noch was tun wird.
ich fand das Thermostatwidget auch so super, dass ich es direkt nachbauen wollte.
Leider ist das Format der Knöpfe noch falsch und ich komme einfach nicht drauf, was fehlt.
Ich habe mir alle Nachrichten dazu durchgelesen, dazu finde ich leider nichts.
Ich hoffe, jemand kann mir nochmal einen Tip geben.
Bis dann
Christof
Ich hoffe, jemand kann mir nochmal einen Tip geben. `
HI,
ich glaube du hast noch nicht das richtige Thema in der View eingestellt.
zu finden unter
Eigenschaften –> View --> Thema.
Wenn ihr so schön dabei seid poste ich hier auch einmal meine VIS-Startoberfläche. Sicherlich beim ein oder anderen noch nicht zu Ende gedacht (> aber wird das überhaupt jemals "fertig"? ;) ), aber für uns im Moment sehr praktikabel. Wenn jemand Teile benötigt kann ich gerne einen Export zur Verfügung stellen. `
Wie bekommt man denn diese "Tabellen" hin mit den Rahmen und der versch. Hintergrundfarben der Zellen? Bspw. der Block "Stromelemente" ?
So sieht meines aktuell auf einem 7 Zoll Tablet aus. Uhrzeit ist so groß, damit man sie auch vom Sofa aus erkennt.
iobroker.png `
HalloIch habe mal eine Frage zu deinem Vis .
Es ist Echt Super, und ich möchte mir auch so etwas auf mein Tab 3 z
für die Wand basteln.
Leider bin ich noch ein totaler Anfänger in Sachen Vis.
Kann man nicht die Viso von dir auf mein ioBroker kopiren, so das ich nur noch die Gewerke usw von meiner ccu2 zuordnen muss.
Und wie ist das mit der Größe vom Tab, und wie bekomme ich die Viso darauf, wenn ich das ganze am PC Fertig mache.
Ich würde mich sehr freuen, wenn du mir mal etwas Helfen könntest.
Kann man nicht die Viso von dir auf mein ioBroker kopiren, so das ich nur noch die Gewerke usw von meiner ccu2 zuordnen muss. `
Du kannst jede View einzeln exportieren. Dazu gehst Du im Vis-Editor auf den Reiter "Views" und findest dann in der Zeile darunter (wo die View-Pulldown-Liste ist) einen Button "View exportieren". Damit öffnest Du ein Popup, in dem die ganze View als JSON zu sehen ist (ist automatisch alles schon markiert). Dies kopierst Du alles und führt es an selber Stelle bei Dir wieder ein (aber dann natürlich mit dem Button "View importieren"Das ganz ist übrigens auch in dieser Doku beschrieben (http://www.iobroker.net/docu/?page_id=2754&lang=de) ;)
Gruß,
Eric
> Wie bekommt man denn diese "Tabellen" hin mit den Rahmen und der versch. Hintergrundfarben der Zellen? Bspw. der Block "Stromelemente" ?Es sind nicht wirklich Tabellen sondern eine Box mit einer anderen Kopffarbe:
[{"tpl":"tplFrame","data":{"hm_id":65535,"digits":"","factor":1,"min":0,"max":1,"step":0.01,"title":"Stromelemente","title_color":"white","title_top":"3","title_left":"5","header_height":"25","header_color":"#067c9d","title_font":"arial","title_back":"","visibility-cond":"==","visibility-val":1,"name":"Rolladen-Box","comment":"","visibility-groups-action":"hide","filterkey":"Stromelemente","g_css_border":true,"g_gestures":false,"g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"10px","top":"389px","background-color":"rgba(255, 255, 255, 0.5)","width":"701px","height":"406px","color":"rgb(77, 77, 77)","text-shadow":"none","font-size":"14px","z-index":"0","overflow-x":"visible","border-width":"0px"},"widgetSet":"basic"}] -
Falls du, so wie ich, Wert auf transparente Hintergründe legst bei deinen Bildern, aber keine fancy Grafikprogramme hast:
die kannst du auch mit Powerpoint sehr schnell und einfach erzeugen. Einfach Bild reinziehen, unter "Format" "Transparente Farbe bestimmen", entsprechenden Teil des Hintergrunds (meist ja weiß oder schwarz) anklicken, rechtsklick aufs Bild, speichern als Grafik. Fertig.
die kannst du auch mit Powerpoint sehr schnell und einfach erzeugen. Einfach Bild reinziehen, unter "Format" "Transparente Farbe bestimmen", entsprechenden Teil des Hintergrunds (meist ja weiß oder schwarz) anklicken, rechtsklick aufs Bild, speichern als Grafik. Fertig. `
Ich kann paint.net empfehlen. -
Ich zeige auch mal, was ich gerade so fabriziert habe. Ich habe diesmal versucht die Bedienelemente etwas zu reduzieren, weil im automatisierten Haus eh kaum noch etwas "gedrückt" werden muss. (Und bei uns auch nicht gedrückt wird. Ich habe schon fünf Jahre mit Mediola gearbeitet und habe da schon manche Erfahrung sammeln können. Die Rolladen sind zum Beispiel auch nur in eine Richtung schaltbar, je nach dem ob sie oben oder unten sind. Vielleicht verzichte ich aus performance-gründen auch auf die Heizungs-bedienfelder und stelle das nur am PC ein. Ist alles noch nicht fertig, aber auf einem guten Weg.
Den Hauptbildschirm gibt es in hell für tagsüber und dunkel für abends (dann aber mit Rolladen statt Markise als Bedienelement). Die Warnungen sind auch noch nicht komplett fertig… Leider
Sieht sehr gut aus, schön einfach, vielleicht sollte man sich daran ein Beispiel nehmen und alles Button, die man ne Woche lang nicht anklickt, weiter nach hinten, in andere Views verschieben. Sowas steigert natürlich auch den WAF, frau findet sich dann leichter zurecht! :mrgreen:
Aber meine Frau ist von mir viel Technik gewöhnt, sie braucht sich nicht umstellen, wenn sie mal ans Tablet geht und was steuern will! :lol:
Enrico
filename="Screenshot_20171115-141948.png" index="4">~~
! filename="Screenshot_20171115-142032.png" index="3">~~
filename="Screenshot_20171115-141956.png" index="2">~~
filename="Screenshot_20171115-142326.png" index="1">~~
filename="Screenshot_20171115-142343.png" index="0">~~ ` Welche Wetter icon nutzt du?Gesendet von meinem Handy
