  4. Node-Red
  5. Node Red Tasmota und Switsch
    6.4k
34 Beiträge 2 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • J JosefThal
    @mickym was ist besser
    JosefThal
    @josefthal [
    "id": "f884ce11d9d7f084",
    "type": "tab",
    "label": "Flow 7",
    "disabled": false,
    "info": "",
    "env": []
    "id": "50abe2e8af7541c0",
    "type": "debug",
    "z": "f884ce11d9d7f084",
    "name": "debug 45",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "false",
    "statusVal": "",
    "statusType": "auto",
    "x": 940,
    "y": 400,
    "wires": []
    "id": "2ae715d42c837120",
    "type": "debug",
    "name": "debug 46",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 660,
    "y": 300,
    "wires": []
    "id": "1d78f8b2a54f18bd",
    "type": "debug",
    "name": "debug 47",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 760,
    "y": 200,
    "wires": []
    "id": "4b419759b1939781",
    "type": "mqtt in",
    "name": "",
    "topic": "tele/Tasmota_test2/SENSOR",
    "qos": "0",
    "datatype": "json",
    "broker": "b84a725bf6dd8e6b",
    "nl": false,
    "rap": true,
    "rh": 0,
    "inputs": 0,
    "x": 160,
    "y": 200,
    "wires": [
    "1d78f8b2a54f18bd",
    "5767de948061f591",
    "4fe0cb071a28c291"
    "id": "3f94cadf66b7c243",
    "type": "debug",
    "name": "debug 48",
    "active": false,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 820,
    "y": 740,
    "wires": []
    "id": "85752b032892a0bf",
    "type": "mqtt in",
    "name": "",
    "topic": "tele/Tasmota_test2/SENSOR ",
    "qos": "0",
    "datatype": "utf8",
    "nl": false,
    "rap": true,
    "rh": 0,
    "inputs": 0,
    "x": 200,
    "y": 780,
    "wires": [
    "3f94cadf66b7c243",
    "a4c8f372f7e5208d"
    "id": "a4c8f372f7e5208d",
    "type": "change",
    "name": "Strom Filter",
    "rules": [
    "t": "set",
    "p": "payload.Switch1",
    "pt": "msg",
    "to": "on",
    "tot": "str"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 690,
    "y": 800,
    "wires": [
    "62298753547437f4"
    "id": "62298753547437f4",
    "type": "debug",
    "name": "debug 49",
    "active": false,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 940,
    "y": 820,
    "wires": []
    "id": "5d69362e4fbdf5e3",
    "type": "mqtt out",
    "name": "",
    "topic": "cmnd/Tasmota_test2/POWER1",
    "qos": "",
    "retain": "",
    "respTopic": "",
    "contentType": "",
    "userProps": "",
    "correl": "",
    "expiry": "",
    "x": 630,
    "y": 560,
    "wires": []
    "id": "3407d481c1a27b47",
    "type": "Tasmota Sensor",
    "broker": "7a7b311bf649aa87",
    "device": "Tasmota_test2",
    "name": "",
    "outputs": 1,
    "uidisabler": false,
    "fullTopic": "",
    "cmndPrefix": "",
    "statPrefix": "",
    "telePrefix": "",
    "qos": 1,
    "retain": false,
    "rules": [],
    "outputTopic": "",
    "x": 220,
    "y": 80,
    "wires": [
    "dc357bf80dd84722"
    "id": "4a52a2c387ec9267",
    "type": "debug",
    "name": "debug 50",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 940,
    "y": 460,
    "wires": []
    "id": "dc357bf80dd84722",
    "type": "debug",
    "name": "debug 51",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 420,
    "y": 20,
    "wires": []
    "id": "8edf93019b1dda14",
    "type": "debug",
    "name": "debug 52",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 760,
    "y": 240,
    "wires": []
    "id": "2ae5cbaad2be8669",
    "type": "inject",
    "name": "",
    "props": [
    "p": "payload"
    "p": "topic",
    "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "off",
    "payloadType": "str",
    "x": 190,
    "y": 580,
    "wires": [
    "5d69362e4fbdf5e3"
    "id": "fe76fb3e70ee4cd1",
    "type": "inject",
    "name": "",
    "props": [
    "p": "payload"
    "p": "topic",
    "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "on",
    "x": 190,
    "y": 620,
    "wires": [
    "5d69362e4fbdf5e3"
    "id": "5767de948061f591",
    "type": "switch",
    "name": "",
    "property": "payload.Switch1",
    "propertyType": "msg",
    "rules": [
    "t": "eq",
    "v": "on",
    "vt": "str"
    "checkall": "true",
    "repair": false,
    "outputs": 1,
    "x": 450,
    "y": 300,
    "wires": [
    "2ae715d42c837120"
    "id": "970c70446706d958",
    "type": "debug",
    "name": "debug 55",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 660,
    "y": 360,
    "wires": []
    "id": "4fe0cb071a28c291",
    "type": "switch",
    "name": "",
    "rules": [
    "t": "eq",
    "v": "off",
    "vt": "str"
    "checkall": "true",
    "repair": false,
    "outputs": 1,
    "x": 450,
    "y": 360,
    "wires": [
    "970c70446706d958"
    "id": "b84a725bf6dd8e6b",
    "type": "mqtt-broker",
    "name": "CerboGX",
    "broker": "192.168.178.35",
    "port": "1883",
    "clientid": "",
    "autoConnect": true,
    "usetls": false,
    "protocolVersion": "4",
    "keepalive": "60",
    "cleansession": true,
    "birthTopic": "",
    "birthQos": "0",
    "birthPayload": "",
    "birthMsg": {},
    "closeTopic": "",
    "closeQos": "0",
    "closePayload": "",
    "closeMsg": {},
    "willTopic": "",
    "willQos": "0",
    "willPayload": "",
    "willMsg": {},
    "userProps": "",
    "sessionExpiry": ""
    "id": "7a7b311bf649aa87",
    "type": "tasmota-mqtt-broker",
    "name": "",
    "broker": "localhost",
    "port": "1883",
    "clientid": "",
    "usetls": false,
    "keepalive": "60",
    • J JosefThal
      @josefthal [
      "type": "tab",
      "label": "Flow 7",
      "disabled": false,
      "info": "",
      "env": []
      "type": "debug",
      "name": "debug 45",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 940,
      "y": 400,
      "wires": []
      "type": "debug",
      "name": "debug 46",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 660,
      "y": 300,
      "wires": []
      "type": "debug",
      "name": "debug 47",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 760,
      "y": 200,
      "wires": []
      "type": "mqtt in",
      "name": "",
      "qos": "0",
      "datatype": "json",
      "nl": false,
      "rap": true,
      "rh": 0,
      "inputs": 0,
      "x": 160,
      "y": 200,
      "wires": [
      "1d78f8b2a54f18bd",
      "5767de948061f591",
      "4fe0cb071a28c291"
      "type": "debug",
      "name": "debug 48",
      "active": false,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 820,
      "y": 740,
      "wires": []
      "type": "mqtt in",
      "name": "",
      "qos": "0",
      "datatype": "utf8",
      "nl": false,
      "rap": true,
      "rh": 0,
      "inputs": 0,
      "x": 200,
      "y": 780,
      "wires": [
      "3f94cadf66b7c243",
      "a4c8f372f7e5208d"
      "type": "change",
      "rules": [
      "t": "set",
      "pt": "msg",
      "to": "on",
      "tot": "str"
      "action": "",
      "property": "",
      "from": "",
      "to": "",
      "reg": false,
      "x": 690,
      "y": 800,
      "wires": [
      "62298753547437f4"
      "type": "debug",
      "name": "debug 49",
      "active": false,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 940,
      "y": 820,
      "wires": []
      "type": "mqtt out",
      "name": "",
      "qos": "",
      "retain": "",
      "respTopic": "",
      "contentType": "",
      "userProps": "",
      "correl": "",
      "expiry": "",
      "x": 630,
      "y": 560,
      "wires": []
      "name": "",
      "outputs": 1,
      "fullTopic": "",
      "cmndPrefix": "",
      "statPrefix": "",
      "telePrefix": "",
      "qos": 1,
      "retain": false,
      "rules": [],
      "outputTopic": "",
      "x": 220,
      "y": 80,
      "wires": [
      "dc357bf80dd84722"
      "type": "debug",
      "name": "debug 50",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 940,
      "y": 460,
      "wires": []
      "type": "debug",
      "name": "debug 51",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 420,
      "y": 20,
      "wires": []
      "type": "debug",
      "name": "debug 52",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 760,
      "y": 240,
      "wires": []
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "off",
      "x": 190,
      "y": 580,
      "wires": [
      "5d69362e4fbdf5e3"
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "on",
      "x": 190,
      "y": 620,
      "wires": [
      "5d69362e4fbdf5e3"
      "type": "switch",
      "name": "",
      "rules": [
      "t": "eq",
      "v": "on",
      "vt": "str"
      "checkall": "true",
      "repair": false,
      "outputs": 1,
      "x": 450,
      "y": 300,
      "wires": [
      "2ae715d42c837120"
      "type": "debug",
      "name": "debug 55",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 660,
      "y": 360,
      "wires": []
      "type": "switch",
      "name": "",
      "rules": [
      "t": "eq",
      "v": "off",
      "vt": "str"
      "checkall": "true",
      "repair": false,
      "outputs": 1,
      "x": 450,
      "y": 360,
      "wires": [
      "970c70446706d958"
      "name": "CerboGX",
      "port": "1883",
      "clientid": "",
      "usetls": false,
      "keepalive": "60",
      "birthTopic": "",
      "birthQos": "0",
      "birthPayload": "",
      "birthMsg": {},
      "closeTopic": "",
      "closeQos": "0",
      "closePayload": "",
      "closeMsg": {},
      "willTopic": "",
      "willQos": "0",
      "willPayload": "",
      "willMsg": {},
      "userProps": "",
      "sessionExpiry": ""
      "name": "",
      "port": "1883",
      "clientid": "",
      "usetls": false,
      "keepalive": "60",
      mickymM Offline
      mickymM Offline
      mickym
      @josefthal Damit kann man nichts anfangen. Bitte immer in CodeTags einstellen und ggf. mit Spoiler:
      code_text
      Den Code hier direkt einzustellen - ist nicht importierbar - da das vom Browser interpretiert wird
      • mickymM mickym
        code_text
        JosefThal
        @mickym ```
        "type": "tab",
        "label": "Flow 7",
        "disabled": false,
        "info": "",
        "env": []
        "type": "debug",
        "name": "debug 45",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 940,
        "y": 400,
        "wires": []
        "type": "debug",
        "name": "debug 46",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 660,
        "y": 300,
        "wires": []
        "type": "debug",
        "name": "debug 47",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 760,
        "y": 200,
        "wires": []
        "type": "mqtt in",
        "name": "",
        "qos": "0",
        "datatype": "json",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 160,
        "y": 200,
        "wires": [
        "1d78f8b2a54f18bd",
        "5767de948061f591",
        "4fe0cb071a28c291"
        "type": "debug",
        "name": "debug 48",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 820,
        "y": 740,
        "wires": []
        "type": "mqtt in",
        "name": "",
        "qos": "0",
        "datatype": "utf8",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 200,
        "y": 780,
        "wires": [
        "3f94cadf66b7c243",
        "a4c8f372f7e5208d"
        "type": "change",
        "rules": [
        "t": "set",
        "pt": "msg",
        "to": "on",
        "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 690,
        "y": 800,
        "wires": [
        "62298753547437f4"
        "type": "debug",
        "name": "debug 49",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 940,
        "y": 820,
        "wires": []
        "type": "mqtt out",
        "name": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 630,
        "y": 560,
        "wires": []
        "name": "",
        "outputs": 1,
        "fullTopic": "",
        "cmndPrefix": "",
        "statPrefix": "",
        "telePrefix": "",
        "qos": 1,
        "retain": false,
        "rules": [],
        "outputTopic": "",
        "x": 220,
        "y": 80,
        "wires": [
        "dc357bf80dd84722"
        "type": "debug",
        "name": "debug 50",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 940,
        "y": 460,
        "wires": []
        "type": "debug",
        "name": "debug 51",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 420,
        "y": 20,
        "wires": []
        "type": "debug",
        "name": "debug 52",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 760,
        "y": 240,
        "wires": []
        "type": "inject",
        "name": "",
        "props": [
        "p": "payload"
        "p": "topic",
        "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "off",
        "x": 190,
        "y": 580,
        "wires": [
        "5d69362e4fbdf5e3"
        "type": "inject",
        "name": "",
        "props": [
        "p": "payload"
        "p": "topic",
        "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "on",
        "x": 190,
        "y": 620,
        "wires": [
        "5d69362e4fbdf5e3"
        "type": "switch",
        "name": "",
        "rules": [
        "t": "eq",
        "v": "on",
        "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 450,
        "y": 300,
        "wires": [
        "2ae715d42c837120"
        "type": "debug",
        "name": "debug 55",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 660,
        "y": 360,
        "wires": []
        "type": "switch",
        "name": "",
        "rules": [
        "t": "eq",
        "v": "off",
        "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 450,
        "y": 360,
        "wires": [
        "970c70446706d958"
        "name": "CerboGX",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "name": "",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        • J JosefThal
          @mickym ```
          "type": "tab",
          "label": "Flow 7",
          "disabled": false,
          "info": "",
          "env": []
          "type": "debug",
          "name": "debug 45",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 400,
          "wires": []
          "type": "debug",
          "name": "debug 46",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 660,
          "y": 300,
          "wires": []
          "type": "debug",
          "name": "debug 47",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 760,
          "y": 200,
          "wires": []
          "type": "mqtt in",
          "name": "",
          "qos": "0",
          "datatype": "json",
          "nl": false,
          "rap": true,
          "rh": 0,
          "inputs": 0,
          "x": 160,
          "y": 200,
          "wires": [
          "1d78f8b2a54f18bd",
          "5767de948061f591",
          "4fe0cb071a28c291"
          "type": "debug",
          "name": "debug 48",
          "active": false,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 820,
          "y": 740,
          "wires": []
          "type": "mqtt in",
          "name": "",
          "qos": "0",
          "datatype": "utf8",
          "nl": false,
          "rap": true,
          "rh": 0,
          "inputs": 0,
          "x": 200,
          "y": 780,
          "wires": [
          "3f94cadf66b7c243",
          "a4c8f372f7e5208d"
          "type": "change",
          "rules": [
          "t": "set",
          "pt": "msg",
          "to": "on",
          "tot": "str"
          "action": "",
          "property": "",
          "from": "",
          "to": "",
          "reg": false,
          "x": 690,
          "y": 800,
          "wires": [
          "62298753547437f4"
          "type": "debug",
          "name": "debug 49",
          "active": false,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 820,
          "wires": []
          "type": "mqtt out",
          "name": "",
          "qos": "",
          "retain": "",
          "respTopic": "",
          "contentType": "",
          "userProps": "",
          "correl": "",
          "expiry": "",
          "x": 630,
          "y": 560,
          "wires": []
          "name": "",
          "outputs": 1,
          "fullTopic": "",
          "cmndPrefix": "",
          "statPrefix": "",
          "telePrefix": "",
          "qos": 1,
          "retain": false,
          "rules": [],
          "outputTopic": "",
          "x": 220,
          "y": 80,
          "wires": [
          "dc357bf80dd84722"
          "type": "debug",
          "name": "debug 50",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 940,
          "y": 460,
          "wires": []
          "type": "debug",
          "name": "debug 51",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 420,
          "y": 20,
          "wires": []
          "type": "debug",
          "name": "debug 52",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 760,
          "y": 240,
          "wires": []
          "type": "inject",
          "name": "",
          "props": [
          "p": "payload"
          "p": "topic",
          "vt": "str"
          "repeat": "",
          "crontab": "",
          "once": false,
          "onceDelay": 0.1,
          "topic": "",
          "payload": "off",
          "x": 190,
          "y": 580,
          "wires": [
          "5d69362e4fbdf5e3"
          "type": "inject",
          "name": "",
          "props": [
          "p": "payload"
          "p": "topic",
          "vt": "str"
          "repeat": "",
          "crontab": "",
          "once": false,
          "onceDelay": 0.1,
          "topic": "",
          "payload": "on",
          "x": 190,
          "y": 620,
          "wires": [
          "5d69362e4fbdf5e3"
          "type": "switch",
          "name": "",
          "rules": [
          "t": "eq",
          "v": "on",
          "vt": "str"
          "checkall": "true",
          "repair": false,
          "outputs": 1,
          "x": 450,
          "y": 300,
          "wires": [
          "2ae715d42c837120"
          "type": "debug",
          "name": "debug 55",
          "active": true,
          "tosidebar": true,
          "console": false,
          "tostatus": false,
          "statusVal": "",
          "x": 660,
          "y": 360,
          "wires": []
          "type": "switch",
          "name": "",
          "rules": [
          "t": "eq",
          "v": "off",
          "vt": "str"
          "checkall": "true",
          "repair": false,
          "outputs": 1,
          "x": 450,
          "y": 360,
          "wires": [
          "970c70446706d958"
          "name": "CerboGX",
          "port": "1883",
          "clientid": "",
          "usetls": false,
          "keepalive": "60",
          "birthTopic": "",
          "birthQos": "0",
          "birthPayload": "",
          "birthMsg": {},
          "closeTopic": "",
          "closeQos": "0",
          "closePayload": "",
          "closeMsg": {},
          "willTopic": "",
          "willQos": "0",
          "willPayload": "",
          "willMsg": {},
          "userProps": "",
          "sessionExpiry": ""
          "name": "",
          "port": "1883",
          "clientid": "",
          "usetls": false,
          "keepalive": "60",
          mickymM Offline
          mickymM Offline
          mickym
          @josefthal Nein in codetags - die ''' müssen in einer extra Zeile stehen
          code_text
          • mickymM mickym
            code_text
            JosefThal
            @mickym flows(3).json
            • J JosefThal
              JosefThal
              @josefthal
              hoffe es geht so
              bin einfach zu dof ( ICH )
              • J JosefThal
                @josefthal
                hoffe es geht so
                mickymM Offline
                mickymM Offline
                mickym
                @josefthal Ja geht schon - ich hab Dir aber doch hier einen Vorschlag zum Import eingestellt: https://forum.iobroker.net/post/1053445
                • mickymM Offline
                  mickymM Offline
                  mickym
                  @josefthal sagte in Node Red Tasmota und Switsch:
                  So zu Deinen Fehler die ich sehe
                  Die Eigenschaft ist richtig, aber Du musst auf Groß-und Kleinschreibung achten. Es kommt - auf der KONSOLE ein "ON" und kein "on".
                  Dann brauchst Du dafür keine 2 switch Nodes - sondern ein mit 2 Ausgängen.
                  Bei der Eingabe ist tasmota nicht case-sensitiv - das heißt wird automatisch verstanden.
                  Aber wie gesagt ich hab Dir einen Vorschlag unten geschickt.
                  • mickymM mickym
                    JosefThal
                    @mickym Danke
                    hat ein fehler beim Übertragen gegeben groß und kleinschreibung
                    sensor muß Groß sein SENSOR
                    und dann ging es
                    und ich Spiele und Lesen ca 2 wochen rum
                    und du machst es in 30 S
                    • J JosefThal
                      @mickym Danke
                      und dann ging es
                      mickymM Offline
                      mickymM Offline
                      mickym
                      Mit etwas Übung schaffst Du das auch. ;)
                      • mickymM mickym
                        JosefThal
                        @mickym Danke
                        • J Offline
                          JosefThal
                          benötige noch mal euer hilfe
                          es geht soweit ,die batterie über 91 % voll schaltet er eine wenn er unter 71 % ist schaltet er aus.
                          wenn ich den taster Starten ( Manuel ) geht es aber wenn die Batterie runter geht ( z.b. 50 % auf 49 % ) schaltet der Timer aus obwohl die zeit nicht abgelaufen ist
                          hab schon versucht eine undglied einzusetzt geht nicht
                                 "id": "e4aa7e9b9fb405d9",
                                 "type": "tab",
                                 "label": "Tasmota Test1",
                                 "disabled": false,
                                 "info": "",
                                 "env": []
                                 "id": "74f2d76bc3ce958f",
                                 "type": "junction",
                                 "z": "e4aa7e9b9fb405d9",
                                 "x": 1060,
                                 "y": 480,
                                 "wires": [
                                 "id": "e5c4d789e94d350e",
                                 "type": "debug",
                                 "name": "debug 81",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1040,
                                 "y": 160,
                                 "wires": []
                                 "id": "7cf3622b17046eee",
                                 "type": "change",
                                 "name": "Spannung",
                                 "rules": [
                                         "t": "move",
                                         "p": "payload.ENERGY.Voltage",
                                         "pt": "msg",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 580,
                                 "y": 160,
                                 "wires": [
                                         "e5c4d789e94d350e",
                                         "a10b8a367682404e"
                                 "id": "a10b8a367682404e",
                                 "type": "ui_gauge",
                                 "name": "",
                                 "group": "04d5298db5344c1e",
                                 "order": 1,
                                 "width": 0,
                                 "height": 0,
                                 "gtype": "gage",
                                 "title": "volt Test 1",
                                 "label": "units",
                                 "format": "{{value}}",
                                 "min": 0,
                                 "max": "240",
                                 "colors": [
                                     "#ff0000",
                                     "#ffff00",
                                     "#008000"
                                 "seg1": "200",
                                 "seg2": "220",
                                 "x": 760,
                                 "y": 160,
                                 "wires": []
                                 "id": "77456c5a3405fff3",
                                 "type": "debug",
                                 "name": "debug 82",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 440,
                                 "y": 100,
                                 "wires": []
                                 "id": "89e9cf65394790da",
                                 "type": "change",
                                 "rules": [
                                         "t": "move",
                                         "p": "payload.ENERGY.Current[1]",
                                         "pt": "msg",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 570,
                                 "y": 200,
                                 "wires": [
                                         "e60c46e0c106e4dc"
                                 "id": "318a5c613a88c769",
                                 "type": "debug",
                                 "name": "debug 83",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1040,
                                 "y": 200,
                                 "wires": []
                                 "id": "401d1fdd51ecce14",
                                 "type": "victron-input-battery",
                                 "service": "com.victronenergy.battery.socketcan_can1",
                                 "path": "/Soc",
                                 "serviceObj": {
                                     "name": "Pylontech battery"
                                 "pathObj": {
                                     "path": "/Soc",
                                     "type": "float",
                                     "name": "State of charge (%)"
                                 "initial": "",
                                 "name": "",
                                 "onlyChanges": false,
                                 "x": 190,
                                 "y": 340,
                                 "wires": [
                                         "6ddde74da4bb9545"
                                 "id": "5369f8cb591ac34d",
                                 "type": "switch",
                                 "name": "",
                                 "property": "payload",
                                 "rules": [
                                         "t": "gt",
                                         "v": "91",
                                         "vt": "num"
                                         "t": "lt",
                                         "v": "70",
                                         "vt": "num"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 210,
                                 "y": 500,
                                 "wires": [
                                         "e5fea5b934a2efc7",
                                         "b9ed6599cf70de74"
                                         "5012c46291e78a77",
                                         "cbe9c595bb01b81e"
                                 "id": "f237aa09ab50cbd7",
                                 "type": "debug",
                                 "name": "debug 84",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "payload",
                                 "targetType": "msg",
                                 "statusVal": "",
                                 "x": 720,
                                 "y": 1020,
                                 "wires": []
                                 "id": "5d01b124055bea37",
                                 "type": "debug",
                                 "name": "State Of Charge",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1100,
                                 "y": 360,
                                 "wires": []
                                 "id": "6ddde74da4bb9545",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "StateOfCharge",
                                         "pt": "global",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 560,
                                 "y": 340,
                                 "wires": [
                                         "5d01b124055bea37",
                                         "52e26a73c3b27f6e",
                                         "50eb11e95ce1c4f3"
                                 "id": "bd97fddd9dcd4646",
                                 "type": "ui_slider",
                                 "name": "",
                                 "label": "0 bis 100  test 1eingang",
                                 "tooltip": "",
                                 "order": 3,
                                 "width": 0,
                                 "height": 0,
                                 "passthru": true,
                                 "outs": "all",
                                 "topic": "topic",
                                 "topicType": "msg",
                                 "min": 0,
                                 "max": "100",
                                 "step": 1,
                                 "x": 120,
                                 "y": 760,
                                 "wires": [
                                         "1b2e513f58f2960b",
                                         "5369f8cb591ac34d"
                                 "id": "1b2e513f58f2960b",
                                 "type": "ui_gauge",
                                 "name": "",
                                 "order": 4,
                                 "width": 0,
                                 "height": 0,
                                 "gtype": "gage",
                                 "title": "0 bis 100   test 1 Ausgang",
                                 "label": "Batterie",
                                 "min": 0,
                                 "max": "100",
                                 "colors": [
                                     "#ff0000",
                                     "#e6e600",
                                     "#00ff00"
                                 "seg1": "",
                                 "seg2": "",
                                 "x": 490,
                                 "y": 760,
                                 "wires": []
                                 "id": "0d5525e74b9b0109",
                                 "type": "debug",
                                 "name": "debug 86",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 680,
                                 "y": 580,
                                 "wires": []
                                 "id": "73f440c9fc6e840c",
                                 "type": "debug",
                                 "name": "debug 87",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1060,
                                 "y": 280,
                                 "wires": []
                                 "id": "6ebf1c2b99b260a0",
                                 "type": "debug",
                                 "name": "debug 88",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 920,
                                 "y": 880,
                                 "wires": []
                                 "id": "99db0d2dae9eefe5",
                                 "type": "change",
                                 "name": "Strom power",
                                 "rules": [
                                         "t": "move",
                                         "pt": "msg",
                                         "to": "payload",
                                         "tot": "msg"
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "on",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 570,
                                 "y": 280,
                                 "wires": [
                                         "ec8f88403a3d804a"
                                 "id": "d6f7d9277bab1b46",
                                 "type": "ui_chart",
                                 "name": "",
                                 "group": "a9d0f0d6dc0f0a7e",
                                 "order": 1,
                                 "width": 0,
                                 "height": 0,
                                 "label": "1Strom Test1",
                                 "chartType": "bar",
                                 "legend": "true",
                                 "xformat": "HH:mm:ss",
                                 "interpolate": "linear",
                                 "nodata": "",
                                 "dot": false,
                                 "ymin": "",
                                 "ymax": "",
                                 "removeOlder": 1,
                                 "removeOlderPoints": "",
                                 "removeOlderUnit": "3600",
                                 "cutout": 0,
                                 "useOneColor": false,
                                 "useUTC": false,
                                 "colors": [
                                     "#1f77b4",
                                     "#aec7e8",
                                     "#ff7f0e",
                                     "#2ca02c",
                                     "#98df8a",
                                     "#d62728",
                                     "#ff9896",
                                     "#9467bd",
                                     "#c5b0d5"
                                 "outputs": 1,
                                 "useDifferentColor": false,
                                 "x": 770,
                                 "y": 240,
                                 "wires": [
                                         "eba281a8c7d862c3"
                                 "id": "eba281a8c7d862c3",
                                 "type": "debug",
                                 "name": "debug 89",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1060,
                                 "y": 240,
                                 "wires": []
                                 "id": "f5252ff2d2f5e5c1",
                                 "type": "change",
                                 "rules": [
                                         "t": "move",
                                         "p": "payload.ENERGY.Current[0]",
                                         "pt": "msg",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 570,
                                 "y": 240,
                                 "wires": [
                                         "d6f7d9277bab1b46"
                                 "id": "e60c46e0c106e4dc",
                                 "type": "ui_chart",
                                 "name": "",
                                 "order": 5,
                                 "width": 0,
                                 "height": 0,
                                 "label": "Strom Test1",
                                 "chartType": "bar",
                                 "legend": "false",
                                 "nodata": "",
                                 "dot": false,
                                 "ymin": "",
                                 "ymax": "",
                                 "removeOlder": 1,
                                 "cutout": 0,
                                 "useUTC": false,
                                 "colors": [
                                     "#1f77b4",
                                     "#aec7e8",
                                     "#ff7f0e",
                                     "#2ca02c",
                                     "#98df8a",
                                     "#d62728",
                                     "#ff9896",
                                     "#9467bd",
                                     "#c5b0d5"
                                 "outputs": 1,
                                 "x": 770,
                                 "y": 200,
                                 "wires": [
                                         "318a5c613a88c769"
                                 "id": "e5fea5b934a2efc7",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "ON",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 630,
                                 "y": 480,
                                 "wires": [
                                         "a3ff7d845272b908",
                                         "d00e1f649acb16f3"
                                 "id": "7dd91967b9ae0e11",
                                 "device": "Tasmota_test1",
                                 "name": "",
                                 "outputs": 1,
                                 "fullTopic": "",
                                 "cmndPrefix": "",
                                 "statPrefix": "",
                                 "telePrefix": "",
                                 "qos": 1,
                                 "retain": false,
                                 "rules": [],
                                 "outputTopic": "",
                                 "x": 240,
                                 "y": 140,
                                 "wires": [
                                         "99db0d2dae9eefe5",
                                         "f5252ff2d2f5e5c1",
                                         "89e9cf65394790da",
                                         "7cf3622b17046eee",
                                         "77456c5a3405fff3"
                                 "id": "ec8f88403a3d804a",
                                 "type": "ui_chart",
                                 "name": "",
                                 "order": 6,
                                 "width": 0,
                                 "height": 0,
                                 "label": "Pauer Test1",
                                 "chartType": "bar",
                                 "legend": "true",
                                 "nodata": "",
                                 "dot": false,
                                 "ymin": "",
                                 "ymax": "",
                                 "removeOlder": 1,
                                 "cutout": 0,
                                 "useUTC": false,
                                 "colors": [
                                     "#1f77b4",
                                     "#aec7e8",
                                     "#ff7f0e",
                                     "#2ca02c",
                                     "#98df8a",
                                     "#d62728",
                                     "#ff9896",
                                     "#9467bd",
                                     "#c5b0d5"
                                 "outputs": 1,
                                 "x": 770,
                                 "y": 280,
                                 "wires": [
                                         "73f440c9fc6e840c"
                                 "id": "d00e1f649acb16f3",
                                 "type": "mqtt out",
                                 "name": "",
                                 "topic": "cmnd/Tasmota_test1/POWER1",
                                 "qos": "",
                                 "retain": "",
                                 "respTopic": "",
                                 "contentType": "",
                                 "userProps": "",
                                 "correl": "",
                                 "expiry": "",
                                 "x": 1530,
                                 "y": 500,
                                 "wires": []
                                 "id": "d9062f21b1c4fdaf",
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "eq",
                                         "v": "ON",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 1,
                                 "x": 470,
                                 "y": 1020,
                                 "wires": [
                                         "b22e13f626cd98a3",
                                         "f237aa09ab50cbd7"
                                 "id": "56a67d7f80182ecc",
                                 "type": "mqtt in",
                                 "name": "",
                                 "topic": "tele/Tasmota_test1/SENSOR",
                                 "qos": "0",
                                 "datatype": "json",
                                 "nl": false,
                                 "rap": true,
                                 "rh": 0,
                                 "inputs": 0,
                                 "x": 190,
                                 "y": 980,
                                 "wires": [
                                         "d9062f21b1c4fdaf",
                                         "a79580173aa2a19f"
                                 "id": "b22e13f626cd98a3",
                                 "type": "trigger",
                                 "name": "",
                                 "op1": "ON",
                                 "op2": "OFF",
                                 "op1type": "str",
                                 "op2type": "str",
                                 "duration": "12",
                                 "extend": false,
                                 "overrideDelay": true,
                                 "units": "s",
                                 "reset": "",
                                 "bytopic": "all",
                                 "topic": "topic",
                                 "outputs": 1,
                                 "x": 630,
                                 "y": 880,
                                 "wires": [
                                         "6ebf1c2b99b260a0",
                                         "d00e1f649acb16f3"
                                 "id": "a3ff7d845272b908",
                                 "type": "debug",
                                 "name": "debug 98",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 620,
                                 "y": 420,
                                 "wires": []
                                 "id": "a79580173aa2a19f",
                                 "type": "debug",
                                 "name": "debug 100",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 430,
                                 "y": 900,
                                 "wires": []
                                 "id": "52e26a73c3b27f6e",
                                 "type": "ui_text",
                                 "group": "71e172fc8641b4f7",
                                 "order": 6,
                                 "width": 6,
                                 "height": 1,
                                 "name": "",
                                 "label": "Batterie test 1",
                                 "format": "{{msg.payload}}",
                                 "layout": "row-spread",
                                 "x": 830,
                                 "y": 380,
                                 "wires": []
                                 "id": "50eb11e95ce1c4f3",
                                 "type": "ui_gauge",
                                 "name": "",
                                 "order": 2,
                                 "width": 0,
                                 "height": 0,
                                 "gtype": "gage",
                                 "title": "Batterie Test 1",
                                 "label": "units",
                                 "min": 0,
                                 "max": "100",
                                 "colors": [
                                     "#ff0000",
                                     "#ffff00",
                                     "#008000"
                                 "seg1": "30",
                                 "seg2": "75",
                                 "x": 840,
                                 "y": 420,
                                 "wires": []
                                 "id": "5012c46291e78a77",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "OFF",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 630,
                                 "y": 520,
                                 "wires": [
                                         "0d5525e74b9b0109",
                                         "d00e1f649acb16f3"
                                 "id": "b9ed6599cf70de74",
                                 "type": "debug",
                                 "name": "debug 101",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 390,
                                 "y": 440,
                                 "wires": []
                                 "id": "cbe9c595bb01b81e",
                                 "type": "debug",
                                 "name": "debug 102",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 370,
                                 "y": 600,
                                 "wires": []
                                 "id": "934a40174dc661ef",
                                 "type": "function",
                                 "name": "function 1",
                                 "func": "\nreturn msg;",
                                 "outputs": 1,
                                 "noerr": 0,
                                 "initialize": "",
                                 "finalize": "",
                                 "libs": [],
                                 "x": 1340,
                                 "y": 240,
                                 "wires": [
                                 "id": "04d5298db5344c1e",
                                 "type": "ui_group",
                                 "name": "Group 4",
                                 "tab": "12a65f5c2118623e",
                                 "order": 3,
                                 "disp": true,
                                 "width": 6
                                 "id": "a9d0f0d6dc0f0a7e",
                                 "type": "ui_group",
                                 "name": "Default",
                                 "order": 4,
                                 "disp": true,
                                 "width": 6,
                                 "collapse": false
                                 "name": "",
                                 "port": "1883",
                                 "clientid": "",
                                 "usetls": false,
                                 "keepalive": "60",
                                 "name": "CerboGX",
                                 "port": "1883",
                                 "clientid": "",
                                 "usetls": false,
                                 "keepalive": "60",
                                 "birthTopic": "",
                                 "birthQos": "0",
                                 "birthPayload": "",
                                 "birthMsg": {},
                                 "closeTopic": "",
                                 "closeQos": "0",
                                 "closePayload": "",
                                 "closeMsg": {},
                                 "willTopic": "",
                                 "willQos": "0",
                                 "willPayload": "",
                                 "willMsg": {},
                                 "userProps": "",
                                 "sessionExpiry": ""
                                 "id": "71e172fc8641b4f7",
                                 "type": "ui_group",
                                 "name": "Stapler ",
                                 "order": 1,
                                 "disp": true,
                                 "width": "6",
                                 "collapse": false
                                 "id": "12a65f5c2118623e",
                                 "type": "ui_tab",
                                 "name": "Home",
                                 "icon": "dashboard",
                                 "order": 2,
                                 "disabled": false,
                                 "hidden": false
                          • J JosefThal
                                   "type": "tab",
                                   "disabled": false,
                                   "info": "",
                                   "env": []
                                   "type": "junction",
                                   "x": 1060,
                                   "y": 480,
                                   "wires": [
                                   "type": "debug",
                                   "name": "debug 81",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 160,
                                   "wires": []
                                   "type": "change",
                                   "name": "Spannung",
                                   "rules": [
                                           "t": "move",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 580,
                                   "y": 160,
                                   "wires": [
                                           "e5c4d789e94d350e",
                                           "a10b8a367682404e"
                                   "type": "ui_gauge",
                                   "name": "",
                                   "order": 1,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "label": "units",
                                   "min": 0,
                                   "max": "240",
                                   "colors": [
                                       "#ff0000",
                                       "#ffff00",
                                       "#008000"
                                   "seg1": "200",
                                   "seg2": "220",
                                   "x": 760,
                                   "y": 160,
                                   "wires": []
                                   "type": "debug",
                                   "name": "debug 82",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 440,
                                   "y": 100,
                                   "wires": []
                                   "type": "change",
                                   "rules": [
                                           "t": "move",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 200,
                                   "wires": [
                                           "e60c46e0c106e4dc"
                                   "type": "debug",
                                   "name": "debug 83",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 200,
                                   "wires": []
                                   "path": "/Soc",
                                   "serviceObj": {
                                   "pathObj": {
                                       "path": "/Soc",
                                       "type": "float",
                                   "initial": "",
                                   "name": "",
                                   "x": 190,
                                   "y": 340,
                                   "wires": [
                                           "6ddde74da4bb9545"
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "gt",
                                           "v": "91",
                                           "vt": "num"
                                           "t": "lt",
                                           "v": "70",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 210,
                                   "y": 500,
                                   "wires": [
                                           "e5fea5b934a2efc7",
                                           "b9ed6599cf70de74"
                                           "5012c46291e78a77",
                                           "cbe9c595bb01b81e"
                                   "type": "debug",
                                   "name": "debug 84",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 720,
                                   "y": 1020,
                                   "wires": []
                                   "type": "debug",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1100,
                                   "y": 360,
                                   "wires": []
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "pt": "global",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 560,
                                   "y": 340,
                                   "wires": [
                                           "5d01b124055bea37",
                                           "52e26a73c3b27f6e",
                                           "50eb11e95ce1c4f3"
                                   "name": "",
                                   "tooltip": "",
                                   "order": 3,
                                   "width": 0,
                                   "height": 0,
                                   "passthru": true,
                                   "outs": "all",
                                   "topic": "topic",
                                   "topicType": "msg",
                                   "min": 0,
                                   "max": "100",
                                   "step": 1,
                                   "x": 120,
                                   "y": 760,
                                   "wires": [
                                           "1b2e513f58f2960b",
                                           "5369f8cb591ac34d"
                                   "type": "ui_gauge",
                                   "name": "",
                                   "order": 4,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "min": 0,
                                   "max": "100",
                                   "colors": [
                                       "#ff0000",
                                       "#e6e600",
                                       "#00ff00"
                                   "seg1": "",
                                   "seg2": "",
                                   "x": 490,
                                   "y": 760,
                                   "wires": []
                                   "type": "debug",
                                   "name": "debug 86",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 680,
                                   "y": 580,
                                   "wires": []
                                   "type": "debug",
                                   "name": "debug 87",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1060,
                                   "y": 280,
                                   "wires": []
                                   "type": "debug",
                                   "name": "debug 88",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 920,
                                   "y": 880,
                                   "wires": []
                                   "type": "change",
                                   "rules": [
                                           "t": "move",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "on",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 280,
                                   "wires": [
                                           "ec8f88403a3d804a"
                                   "type": "ui_chart",
                                   "name": "",
                                   "order": 1,
                                   "width": 0,
                                   "height": 0,
                                   "chartType": "bar",
                                   "legend": "true",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "cutout": 0,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "x": 770,
                                   "y": 240,
                                   "wires": [
                                           "eba281a8c7d862c3"
                                   "type": "debug",
                                   "name": "debug 89",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1060,
                                   "y": 240,
                                   "wires": []
                                   "type": "change",
                                   "rules": [
                                           "t": "move",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 240,
                                   "wires": [
                                           "d6f7d9277bab1b46"
                                   "type": "ui_chart",
                                   "name": "",
                                   "order": 5,
                                   "width": 0,
                                   "height": 0,
                                   "chartType": "bar",
                                   "legend": "false",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "cutout": 0,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "x": 770,
                                   "y": 200,
                                   "wires": [
                                           "318a5c613a88c769"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "ON",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 630,
                                   "y": 480,
                                   "wires": [
                                           "a3ff7d845272b908",
                                           "d00e1f649acb16f3"
                                   "name": "",
                                   "outputs": 1,
                                   "fullTopic": "",
                                   "cmndPrefix": "",
                                   "statPrefix": "",
                                   "telePrefix": "",
                                   "qos": 1,
                                   "retain": false,
                                   "rules": [],
                                   "outputTopic": "",
                                   "x": 240,
                                   "y": 140,
                                   "wires": [
                                           "99db0d2dae9eefe5",
                                           "f5252ff2d2f5e5c1",
                                           "89e9cf65394790da",
                                           "7cf3622b17046eee",
                                           "77456c5a3405fff3"
                                   "type": "ui_chart",
                                   "name": "",
                                   "order": 6,
                                   "width": 0,
                                   "height": 0,
                                   "chartType": "bar",
                                   "legend": "true",
                                   "nodata": "",
                                   "dot": false,
                                   "ymin": "",
                                   "ymax": "",
                                   "removeOlder": 1,
                                   "cutout": 0,
                                   "useUTC": false,
                                   "colors": [
                                       "#1f77b4",
                                       "#aec7e8",
                                       "#ff7f0e",
                                       "#2ca02c",
                                       "#98df8a",
                                       "#d62728",
                                       "#ff9896",
                                       "#9467bd",
                                       "#c5b0d5"
                                   "outputs": 1,
                                   "x": 770,
                                   "y": 280,
                                   "wires": [
                                           "73f440c9fc6e840c"
                                   "type": "mqtt out",
                                   "name": "",
                                   "qos": "",
                                   "retain": "",
                                   "respTopic": "",
                                   "contentType": "",
                                   "userProps": "",
                                   "correl": "",
                                   "expiry": "",
                                   "x": 1530,
                                   "y": 500,
                                   "wires": []
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "eq",
                                           "v": "ON",
                                           "vt": "str"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 1,
                                   "x": 470,
                                   "y": 1020,
                                   "wires": [
                                           "b22e13f626cd98a3",
                                           "f237aa09ab50cbd7"
                                   "type": "mqtt in",
                                   "name": "",
                                   "qos": "0",
                                   "datatype": "json",
                                   "nl": false,
                                   "rap": true,
                                   "rh": 0,
                                   "inputs": 0,
                                   "x": 190,
                                   "y": 980,
                                   "wires": [
                                           "d9062f21b1c4fdaf",
                                           "a79580173aa2a19f"
                                   "type": "trigger",
                                   "name": "",
                                   "op1": "ON",
                                   "op2": "OFF",
                                   "op1type": "str",
                                   "op2type": "str",
                                   "duration": "12",
                                   "extend": false,
                                   "units": "s",
                                   "reset": "",
                                   "bytopic": "all",
                                   "topic": "topic",
                                   "outputs": 1,
                                   "x": 630,
                                   "y": 880,
                                   "wires": [
                                           "6ebf1c2b99b260a0",
                                           "d00e1f649acb16f3"
                                   "type": "debug",
                                   "name": "debug 98",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 620,
                                   "y": 420,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 430,
                                   "y": 900,
                                   "wires": []
                                   "type": "ui_text",
                                   "order": 6,
                                   "width": 6,
                                   "height": 1,
                                   "name": "",
                                   "x": 830,
                                   "y": 380,
                                   "wires": []
                                   "type": "ui_gauge",
                                   "name": "",
                                   "order": 2,
                                   "width": 0,
                                   "height": 0,
                                   "gtype": "gage",
                                   "label": "units",
                                   "min": 0,
                                   "max": "100",
                                   "colors": [
                                       "#ff0000",
                                       "#ffff00",
                                       "#008000"
                                   "seg1": "30",
                                   "seg2": "75",
                                   "x": 840,
                                   "y": 420,
                                   "wires": []
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "OFF",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 630,
                                   "y": 520,
                                   "wires": [
                                           "0d5525e74b9b0109",
                                           "d00e1f649acb16f3"
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 390,
                                   "y": 440,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 370,
                                   "y": 600,
                                   "wires": []
                                   "type": "function",
                                   "outputs": 1,
                                   "noerr": 0,
                                   "initialize": "",
                                   "finalize": "",
                                   "libs": [],
                                   "x": 1340,
                                   "y": 240,
                                   "wires": [
                                   "type": "ui_group",
                                   "name": "Group 4",
                                   "order": 3,
                                   "disp": true,
                                   "width": 6
                                   "type": "ui_group",
                                   "name": "Default",
                                   "order": 4,
                                   "disp": true,
                                   "width": 6,
                                   "collapse": false
                                   "name": "",
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "name": "CerboGX",
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "birthTopic": "",
                                   "birthQos": "0",
                                   "birthPayload": "",
                                   "birthMsg": {},
                                   "closeTopic": "",
                                   "closeQos": "0",
                                   "closePayload": "",
                                   "closeMsg": {},
                                   "willTopic": "",
                                   "willQos": "0",
                                   "willPayload": "",
                                   "willMsg": {},
                                   "userProps": "",
                                   "sessionExpiry": ""
                                   "type": "ui_group",
                                   "name": "Stapler ",
                                   "order": 1,
                                   "disp": true,
                                   "width": "6",
                                   "collapse": false
                                   "type": "ui_tab",
                                   "name": "Home",
                                   "order": 2,
                                   "disabled": false,
                                   "hidden": false
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @josefthal Verstehe zwar nicht wie das gehen Soll, ausser der Tasmota Sensor gibt längere Zeit kein ON Signal.
                            Du hast doch nur EINE externe Quelle in Deinem Flow - der selbstständig schalten kann? (ROT markiert).
                            Bist Du Dir denn sicher, dass das Ganze was mit dem NodeRedFlow zu tun hat?
                            • mickymM mickym
                              JosefThal
                              @mickym wichtig s.url
                              • J Offline
                                JosefThal
                                • mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @josefthal Wie ich sagte - der Flow kann nur von dem unterne Kasten automatisch schalten, das siehst Du doch an der debug Node 55
                                  • mickymM Offline
                                    mickymM Offline
                                    mickym
                                    Grundsätzlich ist es jedoch so, um Dir allgemein zu helfen. Du brauchste keine UND Node oder so einen Schmarn. Wenn Du willst das ein Flow an einer Stelle unterbrochen wird, machst Du eine SwitchNode rein und prüfst dort auf den Zustand einer Flowvariablen.
                                    Diese Flowvariable kannst Du an anderer Stelle setzen - egal durch was.
                                    • mickymM mickym
                                      JosefThal
                                      @mickym [
                                      "id": "c38eca0b6d0feb3e",
                                      "type": "tab",
                                      "label": "Flow 2",
                                      "disabled": false,
                                      "info": "",
                                      "env": []
                                      "id": "1e1408fe355f5f7c",
                                      "type": "mqtt in",
                                      "z": "c38eca0b6d0feb3e",
                                      "name": "",
                                      "qos": "0",
                                      "datatype": "json",
                                      "nl": false,
                                      "rap": true,
                                      "rh": 0,
                                      "inputs": 0,
                                      "x": 240,
                                      "y": 260,
                                      "wires": [
                                      "99a27f412cc4724b"
                                      "id": "99a27f412cc4724b",
                                      "type": "change",
                                      "rules": [
                                      "t": "move",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "on",
                                      "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 530,
                                      "y": 260,
                                      "wires": [
                                      "e4734f30a2286602"
                                      "id": "e4734f30a2286602",
                                      "type": "debug",
                                      "name": "debug 113",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 760,
                                      "y": 260,
                                      "wires": []
                                      "name": "CerboGX",
                                      "port": "1883",
                                      "clientid": "",
                                      "usetls": false,
                                      "keepalive": "60",
                                      "birthTopic": "",
                                      "birthQos": "0",
                                      "birthPayload": "",
                                      "birthMsg": {},
                                      "closeTopic": "",
                                      "closeQos": "0",
                                      "closePayload": "",
                                      "closeMsg": {},
                                      "willTopic": "",
                                      "willQos": "0",
                                      "willPayload": "",
                                      "willMsg": {},
                                      "userProps": "",
                                      "sessionExpiry": ""
                                      • J JosefThal
                                        @mickym [
                                        "type": "tab",
                                        "label": "Flow 2",
                                        "disabled": false,
                                        "info": "",
                                        "env": []
                                        "type": "mqtt in",
                                        "name": "",
                                        "qos": "0",
                                        "datatype": "json",
                                        "nl": false,
                                        "rap": true,
                                        "rh": 0,
                                        "inputs": 0,
                                        "x": 240,
                                        "y": 260,
                                        "wires": [
                                        "99a27f412cc4724b"
                                        "type": "change",
                                        "rules": [
                                        "t": "move",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 530,
                                        "y": 260,
                                        "wires": [
                                        "e4734f30a2286602"
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "statusVal": "",
                                        "x": 760,
                                        "y": 260,
                                        "wires": []
                                        "name": "CerboGX",
                                        "port": "1883",
                                        "clientid": "",
                                        "usetls": false,
                                        "keepalive": "60",
                                        "birthTopic": "",
                                        "birthQos": "0",
                                        "birthPayload": "",
                                        "birthMsg": {},
                                        "closeTopic": "",
                                        "closeQos": "0",
                                        "closePayload": "",
                                        "closeMsg": {},
                                        "willTopic": "",
                                        "willQos": "0",
                                        "willPayload": "",
                                        "willMsg": {},
                                        "userProps": "",
                                        "sessionExpiry": ""
                                        JosefThal
                                        • J Offline
                                          JosefThal
                                          da habe ich noch einen Fehler aber komme nicht drauf wie ich es hin bekommen
                                          das signal mus erst einmal für 2 sekunden anlegen das es durchgeschaltet wird wenn es unter 2 Sekunden anlegt soll nicht pasieren
