  4. JavaScript
  5. ecoflow-connector-Script zur dynamischen Leistungsanpassung
1.7k Beiträge 124 Kommentatoren 963.5k Aufrufe 127 Beobachtet
    Milchbeck
    schrieb am zuletzt editiert von Milchbeck
    #509
    2023-09-26 00:13:21.945 - info: admin.0 (163) <== Disconnect system.user.admin from ::ffff:192.168.178.202 admin
    2023-09-26 00:30:09.737 - info: admin.0 (163) ==> Connected system.user.admin from ::ffff:192.168.178.202
    2023-09-26 00:30:15.729 - info: admin.0 (163) <== Disconnect system.user.admin from ::ffff:192.168.178.202 admin
    2023-09-26 01:10:03.397 - info: history.0 (11304) Delete old history "/opt/iobroker/iobroker-data/history/20230923/history.0_userdata.0.ecoflow.RealPower.json"
    2023-09-26 01:10:03.412 - info: history.0 (11304) Delete old history dir "/opt/iobroker/iobroker-data/history/20230923"
    2023-09-26 07:47:03.200 - error: javascript.0 (426153) Error in callback: TypeError: (Hausstrom + Einspeisung).toFixed is not a function
    2023-09-26 07:47:03.217 - error: javascript.0 (426153) at Object. (script.js.Ecoflow_25_09_2023:2404:68)
    2023-09-26 07:47:03.217 - error: javascript.0 (426153) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
    2023-09-26 07:47:03.217 - error: javascript.0 (426153) at listOnTimeout (node:internal/timers:569:17)
    2023-09-26 07:47:03.217 - error: javascript.0 (426153) at processTimers (node:internal/timers:512:7)
    2023-09-26 08:07:54.337 - warn: deyeidc.0 (432547) ControlCode faulty!: Data may be corrupt, therefore discarded
    2023-09-26 08:21:47.096 - info: admin.0 (163) ==> Connected system.user.admin from ::ffff:192.168.178.168
    2023-09-26 08:23:59.033 - info: admin.0 (163) <== Disconnect system.user.admin from ::ffff:192.168.178.168 admin
    2023-09-26 08:24:13.596 - info: admin.0 (163) ==> Connected system.user.admin from ::ffff:192.168.178.168
    2023-09-26 08:24:31.860 - info: admin.0 (163) ==> Connected system.user.admin from ::ffff:192.168.178.168
    2023-09-26 08:25:05.772 - info: admin.0 (163) <== Disconnect system.user.admin from ::ffff:192.168.178.168 javascript
    2023-09-26 08:25:05.773 - info: admin.0 (163) <== Disconnect system.user.admin from ::ffff:192.168.178.168 admin
    2023-09-26 08:25:39.752 - info: admin.0 (163) ==> Connected system.user.admin from ::ffff:192.168.178.168
    Das kommt immer wieder bin jetzt erstmal wieder zurück zum vorherigen Script
    W 1 Antwort Letzte Antwort
    • M Milchbeck
      W Offline
      W Offline
      Waly_de
      schrieb am zuletzt editiert von Waly_de
      #510
      @milchbeck also ich vermute ja das es mit dem 0_userdata.0.ecoflow.AdditionalPowerSum zusammen hängt
      hast du einen Deye Konfiguriert bei AdditionalPower ? Lass das mal testweise weg. (es reicht wenn du die ID änderst z.B. aus
      mach mal
        MaRa
        schrieb am zuletzt editiert von MaRa
        #511
        Danke für das Skript :)
        Ich habe die neuste Version mal ausprobiert, bekomme aber folgende Fehlermeldungen:
        javascript.0
        2023-09-26 09:38:10.163	error	at processTimers (node:internal/timers:512:7)
        javascript.0
        2023-09-26 09:38:10.163	error	at listOnTimeout (node:internal/timers:569:17)
        javascript.0
        2023-09-26 09:38:10.163	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2757:34)
        javascript.0
        2023-09-26 09:38:10.163	error	at Object.<anonymous> (script.js.Dynamisches_Einspeisen09:2404:68)
        javascript.0
        2023-09-26 09:38:10.162	error	Error in callback: TypeError: (Hausstrom + Einspeisung).toFixed is not a function
        Kann mir da jemand helfen, warum das so ist?
        Folgende Werte bekomme ich von HomeAssistant:
        SmartmeterID: "hass.0.entities.sensor.scb_home_power.state",
        AdditionalPower: [                                     // Wenn es weitere Wechselrichter gibt, die in IOBroker erfasst werden, können diese hier Angelegt werden
                //############# Diesen Abschnitt für jedes einzelne Gerät anlegen ################
                    name: "Kostal_WR",                       // Beliebiger Name
                    id: "hass.0.entities.sensor.scb_ac_power.state"       // Der Objektpfad zu dem Leistungswert in Watt (W)
        Habe in der Instanz JavaScript mqtt und protoburfjs installiert.
        • M MaRa
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          W Offline
          W Offline
          Waly_de
          #512
          @mara
          ok bitte diese neue Version Installieren:
          ecoflow-connector_v1142.txt
          und das Object :
          Löschen.
          Changelog:
            • (1.1.4.2) 26.09.2023
            • BugFix
            • Neuer Parameter: Zusatzpower_Offset: Zusatzpower startet ab einer Batterieladeleistung von MaxPower - Zusatzpower_Offset
          • W Waly_de
            @mara
            und das Object :
            Löschen.
            Changelog:
              • BugFix
            MaRa
            #513
            @waly_de said in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
            Was mir aktuell aufgefallen ist:
            Stromverbrauchen aktuell sind 300W
            Wechselrichter meiner Haupt-PV-Anlage gibt aktuell 5000W ins Hausnetz
            Der PowerStream versucht dennoch mit 300W dagegenzuhalten und den Hausverbrauch auf 0 zu setzen.
            Meines Erachtens nach hätte der PS auf 0 gestellt werden müssen, da die 5000W durch die Haupt Anlange ausreichen.
            Oder habe ich da einen Gedankenfehler?
            P 1 Antwort Letzte Antwort
            • M MaRa
              Ponti92
              #514
              @mara sollte normal auf 0 gestellt werden außer die PS ist im Zusatzeinspeisemodus.
              Dabei wird schrittweise der Bedarf erhöht, sobald der PS bei ca. 600W angekommen ist. (Siehe meine Kommentare oben)
              Zeigt dein Smart Meter denn einen negativen Wert an, wenn die große Anlage den Bedarf und mehr deckt?
              • P Ponti92
                MaRa
                #515
                @ponti92 said in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
                Welche Option ist das im Skript?
                Ha, hab ein Fehler bei mir gefunden. Der dumme sitzt ja meist vor dem Bildschirm. War eine falscher Sensor, den ich eingetragen hatte.
                  Milchbeck
                  #516
                  So hab das neue Script jetzt mal am laufen es scheint zu funktionieren 🤩 v1142
                    Milchbeck
                    #517
                    Kann es sein oder täusche ich mich, das Echtzeit einspeichern funktioniert präziser?
                      kaiausBrieselang
                      #518
                      ich bekomme es einfach nicht so richtig zum laufen.
                      script.js.Dynamische_Anpassung_1142: PowerStream [PowerStream] Batteriestand unter Limit:10% (0%). Limitiere Einspeiseleistung auf: 150W
                      Obwohl die Battterie (D2M) bei 54% ist scheint er sie nicht richtig abzurufen :-(
                      Ändere ich auf "hasbat" auf false, dann gibt er die vollen 600W ab, also scheint die Kommunikation zu funktionieren.
                      hat jemand eine Idee?
                      • K kaiausBrieselang
                        kaiausBrieselang
                        #519
                        @kaiausbrieselang
                        auch unter:
                        0_userdata.0.ecoflow.app_1589636683427278850_Rxxxxxxxx_thing_property_set
                        writeables
                        ist alles auf 0
                          @kaiausbrieselang
                          auch unter:
                          writeables
                          ist alles auf 0
                          W Offline
                          W Offline
                          Waly_de
                          #520
                          @kaiausbrieselang sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
                          @kaiausbrieselang
                          auch unter:
                          writeables
                          ist alles auf 0
                          Was zeigt denn die App an, wenn du die Einstellungen des PS aufrufst. Wenn Du es in der Nacht versuchst, wenn der Powerstream schläft, kann das auch passieren das 0 angezeigt wird.
                          (ich gehe davon aus, das Deine D2M direkt mit der PS verbunden ist.)
                          Writables werden nur angelegt. Werte können erst bei Änderung angezeigt werden. Ändere etwas in der App während das Script online ist und das Ergebnis sollte auch in den Writeables zu sehen sein.
                          K 2 Antworten Letzte Antwort
                          • W Waly_de
                            @kaiausbrieselang
                            auch unter:
                            writeables
                            ist alles auf 0
                            kaiausBrieselang
                            #521
                            @waly_de
                            vielen Dank für deine schnelle Antwort.
                            Ich wusste nicht, welche von den vielen Infos zur Fehlereingrenzung relevant sind.
                            Also, die D2M ist direkt über Port2 mit dem PS verbunden. Am Port1 des D2M hängt (zur Zeit) nichts.
                            Solarpanele sind im Moment gar nicht angeschlossen (weder am PS noch am D2M).
                            Der Akku wird per Überschuss über eine Homematic Steckdose geladen, wenn genügend vorhanden ist.
                            Der Akku hat im Moment 65% und wird in der App beim PS angezeigt.
                            Einstellungen in der APP beim PS:
                            Modus: Stromversorgung Priorisieren
                            Bedarf: 0W
                            Lade/entladegrenzwert: 0%-100% (habe ich beim D2M so aktuell eingestellt und wurde so auch vom PS übernommen).
                            Im Script:
                            name: "PowerStream",                        // beliebiger Namen
                                        MaxPower: 600,                              // Der höchstmögliche Wert in Watt für die Einspeiseleistung
                                        subscribe: true,                            // "true": Alle Daten für dieses Gerät werden angefragt. "false": Es werden keine Statusdaten abgefragt
                                        typ: "PS",                                  // Welches Gerät ist es: Powerstrem:"PS"; DeltaMax:"DM"; Delta2: "D2" ; Delta2 Max: "D2M"; SmartPlug: "SM"; Andere: "NA"
                                        // Parameter an hier nur für PowerStream.
                                        regulation: true,                           // "true": Dieser PowerStream soll vom Script reguliert werden
                                        RegulationOffPower: -1,                     // Wird die Regulation per State abgestellt, wird die Einspeiseleistung des ersten Powerstreams auf diesen Wert gesetzt (-1 = keine Änderung, -2 = Batterie Priomodus)
                                        hasBat: true,                               // "true": Eine Batterie ist angeschlossen. Nur für PowerStream relevant.
                                        battPozOn: 99, battPozOff: 94,              // Wenn die Batterie bei battPozOn ist, Einspeisung auf MaxPower. Bei BattPozOff Normalbetrieb
                                        battOnSwitchPrio: true,                    // "true": Bei battPozOn wird in den Batterie-Prioritätsmodus gewechselt
                                        prioOffOnDemand: 0,                        // Wattwert des Bedarfs, bei dem zurück in den Strom-Priomodus gechaltet wird. 0 für kein Rückschalten.
                                        lowBatLimitPozOn: 10, lowBatLimitPozOff: 40,// Bei Unterschreiten der Batterieladung von "lowBatLimitPozOn" % ist die maximale Einspeiseleistung auf
                                        lowBatLimit: 150,
                            und
                                        typ: "D2M",
                                        subscribe: true,
                            als Quelle für den Stromzähler habe ich einen von Homematic
                            SmartmeterID: "hm-rpc.0.MEQ0381279.1.IEC_POWER",     // State, der den aktuellen Gesamtverbrauch in Watt anzeigt
                            Der Zeigt Bezugsleistung in W an. Bei Überschuss ist der Wert negativ
                            Im Moment ist es so, dass der PS nichts ans Haus abgibt. Aber wegen der Sonne auch Überschuss herrscht.
                            Einspeisen des Überschusses läuft nicht über das Script (bisher).
                            Das Protokoll des IOBroker zeigt:
                            javascript.0
                            2023-09-27 14:58:21.007	info	script.js.Dynamische_Anpassung_1142: Adresse: app_1589636683427278850_R351xxxxxxxx_thing_property_set
                            javascript.0
                            2023-09-27 14:58:21.007	info	script.js.Dynamische_Anpassung_1142: Unbekannter Delta2Max Set Befehl: {"params":{},"from":"iOS","lang":"de-de","id":"500855464","moduleSn":"R351xxxxxxx","moduleType":1,"operateType":"getAllTaskCfg","version":"1.0"}
                            javascript.0
                            2023-09-27 14:58:20.899	info	script.js.Dynamische_Anpassung_1142: Adresse: app_1589636683427278850_R351xxxxxxx_thing_property_set
                            javascript.0
                            2023-09-27 14:58:20.899	info	script.js.Dynamische_Anpassung_1142: Unbekannter Delta2Max Set Befehl: {"params":{},"from":"iOS","lang":"de-de","id":"500692123","moduleSn":"R351xxxxxxx","moduleType":1,"operateType":"getAllTaskCfg","version":"1.0"}
                            Und vorhin beim Starten des Scriptes:
                            Ich hatte vermutet, des Batteriestand bei den Writeables zu finden.
                            Habe wie von dir vorgeschlagen, mal was am D2M verändert (USB angeschaltet) und du hast recht, der Wert ändert sich von 0 auf 1.
                            Aber unabhängih von den writeables muss ich noch irgendwo einen Fehler haben.
                            Ist nur schwer zu testen, wenn die Sonne scheint 🙄 🕶
                            gruß Kai
                            • R Offline
                              resilient
                              schrieb am zuletzt editiert von resilient
                              #522
                              ich habe jetzt auch mal das Script ausprobiert und bekomme keine gute Regelung hin.
                              Meine Konfiguration 2 PS mit jeweils einem Speicher dran. Das Problem ist das er eigentlich viel zu lange zu viel einpeist, so als ob er den Sollwert nicht auf die 2 PS verteilt.
                              Ist an meiner Konfiguration was verkehrt oder hat das Script ein Problem mit dieser Konfiguration? Irgendwelche Ideen?
                              So sieht es aktuell: Oben die Gesamteinpeisung der beides PS und unten wie lange er zuviel einpeist obwohl die Batterien noch nicht voll sind.
                              meine config: hab eigentlich fast alles auf default parametrierung
                              Nach Analyse des Diagramms denke ich, das Problem folgendes obwohl der PS die Batterie gefüllt und voll einspeist und der andere PS noch nicht seine Batterie gefüllt hat speist er immer noch konstant ca. 160w ein und somit entsteht der großer Überschuss... Kann ich das irgendwo anpassen in der Konfiguration?
                              Viele Grüße,
                              • W Waly_de
                                @kaiausbrieselang
                                auch unter:
                                writeables
                                ist alles auf 0
                                kaiausBrieselang
                                #523
                                @waly_de
                                kaum wartet man einige Zeit, wird auch ein Batteriestand erkannt.
                                	script.js.Dynamische_Anpassung_1142: PowerStream [PowerStream] Batteriestand ist jetzt über Limit:40% (64%). Maximale Einspeisung wieder bei: 600W
                                Ich bin erstmal glücklich und beobachte weiter deine tolle Arbeit.
                                Danke!
                                  @waly_de
                                  Danke!
                                  Ponti92
                                  #524
                                  @kaiausbrieselang ja bei mir ist das ähnlich, dass der batteriestand nur selten aktualisiert wird und manchmal auch auf 0 springt.
                                    Milchbeck
                                    #525
                                    Also bei mir läuft alles wie erwartet auch das wenn alles voll geladen ist wird was die Solar Zellen hergeben eingespeist 🤙 super Arbeit 👍🙏🏼🙌🏼
                                    R 1 Antwort Letzte Antwort
                                    • R resilient
                                      Viele Grüße,
                                      W Offline
                                      W Offline
                                      Waly_de
                                      #526
                                      @resilient sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
                                      hast Du SmartPlugs im Einsatz?
                                      • W Waly_de
                                        resilient
                                        #527
                                        @waly_de
                                        Nein, keine Smart Plugs.
                                        • G Offline
                                          Golf GTI
                                          schrieb am zuletzt editiert von Golf GTI
                                          #528
                                          Einen schönen Guten Abend
                                          hab da mal eine fage was hat es mit der Überschuss Ladung zu tun?
                                          dieser daten punkt taucht bei mir nirgends auf slowChgP
                                          // Überschuss Ladung:
                                          ExcessCharge: false, //
                                          ExcessChargePowerID: "0_userdata.0.ecoflow.app_xxxxxxxxxxxxxxxxxxxx_DAxxxxxxxxxxxxxxxxxx_thing_property_set.writeables.slowChgPower",
                                          ExcessChargeSwitchID: "hm-rpc.3.xxxxxxxxxxxxxxxxxx.3.STATE",
                                          ExcessChargeSwitchOn: true,
                                          ExcessChargeSwitchOff: false,
                                          ExcessChargeSwitchMin: 10,
                                          ExcessChargeMaxPower: 1500,
                                          ExcessChargeStartPower: 50,
                                          ExcessChargeStartPowerDurationMin: 5,
                                          A W 2 Antworten Letzte Antwort
