[Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
Hab das Problem mit uwz headline & description erstmal gelöst, bis ich mir über die Übersetzungen klar bin.
Adapter Version ist jetzt 0.2.1
@ticaki
Adapter läuft schon mal
, von ZAMG kommt ein warning:2023-09-25 11:07:00.439 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3142396 2023-09-25 11:07:01.326 - debug: weather-warnings.0 (3142396) Redis Objects: Use Redis connection: 0.0.0.0:9001 2023-09-25 11:07:01.362 - debug: weather-warnings.0 (3142396) Objects client ready ... initialize now 2023-09-25 11:07:01.366 - debug: weather-warnings.0 (3142396) Objects create System PubSub Client 2023-09-25 11:07:01.367 - debug: weather-warnings.0 (3142396) Objects create User PubSub Client 2023-09-25 11:07:01.470 - debug: weather-warnings.0 (3142396) Objects client initialize lua scripts 2023-09-25 11:07:01.476 - debug: weather-warnings.0 (3142396) Objects connected to redis: 0.0.0.0:9001 2023-09-25 11:07:01.526 - debug: weather-warnings.0 (3142396) Redis States: Use Redis connection: 0.0.0.0:9000 2023-09-25 11:07:01.614 - debug: weather-warnings.0 (3142396) States create System PubSub Client 2023-09-25 11:07:01.614 - debug: weather-warnings.0 (3142396) States create User PubSub Client 2023-09-25 11:07:01.715 - debug: weather-warnings.0 (3142396) States connected to redis: 0.0.0.0:9000 2023-09-25 11:07:02.043 - info: weather-warnings.0 (3142396) starting. Version 0.2.0 (non-npm: ticaki/ioBroker.weather-warnings#caa88c5a0b04e09dce451f7eb79f3035e502e8bc) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12 2023-09-25 11:07:02.060 - info: weather-warnings.0 (3142396) Refresh Interval: 15 minutes 2023-09-25 11:07:06.096 - info: weather-warnings.0 (3142396) ZAMG activated. Retrieve data. 2023-09-25 11:07:06.098 - info: weather-warnings.0 (3142396) UWZ activated. Retrieve data. 2023-09-25 11:07:06.273 - warn: weather-warnings.0 (3142396) [zamg-48.333444483766975,14.6258983209036] Warn(21) axios error for zamgService url: https://warnungen.zamg.at/wsapp/api/getWarningsForCoords?lon=48.333444483766975&lat=14.62589832090361&lang=de 2023-09-25 11:07:06.930 - debug: weather-warnings.0 (3142396) [uwz-UWZAT00754] Got 0 warnings from server 2023-09-25 11:07:07.431 - debug: weather-warnings.0 (3142396) [Provider Controller] send 0 messages.Hab bei ZAMG die "Position aus Systemeinstellungen" gewählt
Edit: ... und hier noch die DP´s:
@ticaki
@latzi
Sei so gut und mach das nochmal mit debug, da müsste bei der warnung der http link sein- vielleicht sind die coordinaten verdreht oder zuviele Dezimalstellen.... Oder ich mache es selbst, hab ja alle infos die ich brauche.EDIT: Jap falsch herum
EDIT2: Nochmal bitteEDIT3: die beschreibung zum testmode im State is falsch - ein Restart bewirkt garnichts.
@ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
Bei mir installierte Version:
0.2.0-alpha.0 -
0.2.0-alpha.0@sigi234
Ich bin am versuchen das release ans laufen zu bekommen, und wenns dann läuft gebe ich die aktuelle Version nochmal bekannt. Ändere gerade zu schnell zu viele Kleinigkeiten damit das läuft. Und ich muß die Version zurück setzten damit ein neue Lauf dann auf 0.2.1 endet :) -
So mal kein grundsätzlicher Fehler im Release Script - Version sollte jetzt bei
v0.2.1-alpha.0
bleiben und auch auf der Github Seite angezeigt werden.
v0.2.1-alpha.0
@latzi
Astrein, log ist sauber
2023-09-25 12:07:24.280 - info: host.ioBroker "system.adapter.weather-warnings.0" enabled 2023-09-25 12:07:24.384 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3270054 2023-09-25 12:07:25.232 - debug: weather-warnings.0 (3270054) Redis Objects: Use Redis connection: 0.0.0.0:9001 2023-09-25 12:07:25.270 - debug: weather-warnings.0 (3270054) Objects client ready ... initialize now 2023-09-25 12:07:25.271 - debug: weather-warnings.0 (3270054) Objects create System PubSub Client 2023-09-25 12:07:25.272 - debug: weather-warnings.0 (3270054) Objects create User PubSub Client 2023-09-25 12:07:25.373 - debug: weather-warnings.0 (3270054) Objects client initialize lua scripts 2023-09-25 12:07:25.392 - debug: weather-warnings.0 (3270054) Objects connected to redis: 0.0.0.0:9001 2023-09-25 12:07:25.466 - debug: weather-warnings.0 (3270054) Redis States: Use Redis connection: 0.0.0.0:9000 2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create System PubSub Client 2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create User PubSub Client 2023-09-25 12:07:25.660 - debug: weather-warnings.0 (3270054) States connected to redis: 0.0.0.0:9000 2023-09-25 12:07:25.949 - info: weather-warnings.0 (3270054) starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12 2023-09-25 12:07:25.975 - info: weather-warnings.0 (3270054) Refresh Interval: 15 minutes 2023-09-25 12:07:30.132 - info: weather-warnings.0 (3270054) ZAMG activated. Retrieve data. 2023-09-25 12:07:30.139 - info: weather-warnings.0 (3270054) UWZ activated. Retrieve data. 2023-09-25 12:07:30.340 - debug: weather-warnings.0 (3270054) [zamg-48.333444483766975,14.6258983209036] Got 0 warnings from server 2023-09-25 12:07:30.973 - debug: weather-warnings.0 (3270054) [uwz-UWZAT00754] Got 0 warnings from server 2023-09-25 12:07:31.474 - debug: weather-warnings.0 (3270054) [Provider Controller] send 0 messages. -
2023-09-25 12:07:24.280 - info: host.ioBroker "system.adapter.weather-warnings.0" enabled 2023-09-25 12:07:24.384 - info: host.ioBroker instance system.adapter.weather-warnings.0 started with pid 3270054 2023-09-25 12:07:25.232 - debug: weather-warnings.0 (3270054) Redis Objects: Use Redis connection: 0.0.0.0:9001 2023-09-25 12:07:25.270 - debug: weather-warnings.0 (3270054) Objects client ready ... initialize now 2023-09-25 12:07:25.271 - debug: weather-warnings.0 (3270054) Objects create System PubSub Client 2023-09-25 12:07:25.272 - debug: weather-warnings.0 (3270054) Objects create User PubSub Client 2023-09-25 12:07:25.373 - debug: weather-warnings.0 (3270054) Objects client initialize lua scripts 2023-09-25 12:07:25.392 - debug: weather-warnings.0 (3270054) Objects connected to redis: 0.0.0.0:9001 2023-09-25 12:07:25.466 - debug: weather-warnings.0 (3270054) Redis States: Use Redis connection: 0.0.0.0:9000 2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create System PubSub Client 2023-09-25 12:07:25.550 - debug: weather-warnings.0 (3270054) States create User PubSub Client 2023-09-25 12:07:25.660 - debug: weather-warnings.0 (3270054) States connected to redis: 0.0.0.0:9000 2023-09-25 12:07:25.949 - info: weather-warnings.0 (3270054) starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12 2023-09-25 12:07:25.975 - info: weather-warnings.0 (3270054) Refresh Interval: 15 minutes 2023-09-25 12:07:30.132 - info: weather-warnings.0 (3270054) ZAMG activated. Retrieve data. 2023-09-25 12:07:30.139 - info: weather-warnings.0 (3270054) UWZ activated. Retrieve data. 2023-09-25 12:07:30.340 - debug: weather-warnings.0 (3270054) [zamg-48.333444483766975,14.6258983209036] Got 0 warnings from server 2023-09-25 12:07:30.973 - debug: weather-warnings.0 (3270054) [uwz-UWZAT00754] Got 0 warnings from server 2023-09-25 12:07:31.474 - debug: weather-warnings.0 (3270054) [Provider Controller] send 0 messages.@latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
Jupp, Testmode:
weather-warnings.0 2023-09-25 12:09:05.816 debug [Provider Controller] send 4 messages. weather-warnings.0 2023-09-25 12:09:05.314 debug [uwz-UWZUWZAT00XXX] Got 2 warnings from server weather-warnings.0 2023-09-25 12:09:04.310 debug [zamg-XX.XXXXXX,XX.XXXXXX] Got 2 warnings from server weather-warnings.0 2023-09-25 12:09:04.308 info UWZ activated. Retrieve data. weather-warnings.0 2023-09-25 12:09:04.305 info ZAMG activated. Retrieve data. weather-warnings.0 2023-09-25 12:09:00.283 info Refresh Interval: 5 minutes weather-warnings.0 2023-09-25 12:09:00.272 info starting. Version 0.2.1-alpha.0 (non-npm: ticaki/ioBroker.weather-warnings#4e8409b213a9545cdba6133ad72f45707aa8da91) in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.18.0, js-controller: 5.0.12 -
Cool
Wenn ihr mal ne Zamg Warnung habt würde ich mich über ne PM mit den coordinaten freuen, hab da nur 1 und die hab ich dann halt kopiert um fehler mit mehreren Meldungen zu finden, aber echte Unterschiedliche zu haben wäre schon besser.
@ticaki
Wenn ich den "testmode" aktiviere, werden die DP´s erzeugt, Adapter wird jedoch gelb ohne Auffälligkeiten im debug-log, nehme ich ihn wieder raus bleibt der Adapter grün@latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
@ticaki
Wenn ich den "testmode" aktiviere, werden die DP´s erzeugt, Adapter wird jedoch gelb ohne Auffälligkeiten im debug-log, nehme ich ihn wieder raus bleibt der Adapter grünDito
Zum Adapter:
Vorweg: Der ist weder fertig, noch kann er Nachrichten verschicken. Man kann sich angucken wo die reise hingeht. Vor 0.4.0 wird der extrem weit hinter dem Skript zurück liegen.
v0.2.0 Alpha
Nur per benutzerdefiniertem Github-install
https://github.com/ticaki/ioBroker.weather-warnings
Verbesserungsvorschläge und Fehler bitte auch dort als Issue anlegen. Form ist mir wurscht, Sprachen: Deutsch Englisch.
Bekannter Fehler: Deutsch und English sind überall gemischt - wenn ich mir klar bin, wie ich das alles am besten übersetzte und einbaue wird sich das ändern.
Liste der aktuellen Funktionen:
- DWD/UWZ/ZAMG Datenabruf. Konfigurierbar über Admin.
- Update Intervall einstellbar.
- DWD/UWZ Stellt formatierte Daten zur Verfügung (ZAMG hab ich ganz vergessen einzubauen an der Stelle)
- Selbst formulierbare Meldungen werden in States geschrieben.
- Doppelte Nachrichten werden ausgefiltert, solange sie offensichtlich doppelt sind.
- Es gibt einen Testmodus - dabei ist der Adapter "offline" und wird so auch angezeigt.
formatedKeys: Die Datenpunkte darunter kann man in eigenen Meldungen verwenden.
Was braucht ihr noch an Daten?
messages: Darunter befinden sich die Mitteilungen die ihr im Admin unter Template/Vorlage (ka ob schon übersetzt) einrichten könnt.
warning: drunter sind alle Daten die vom Dienst geliefert werden.
Unter den Info Ordnern seht ihr ob der Adapter/der Dienst beim letzten Zugriff online war.
Im Admin/Template
In der Tablelle schreibt ihr ins erste Feld einen Bezeichung die sich als state später unter Message erzeugt wird, also keine Punkte oder Leerzeichen.
In das zweite Feld kommt eure Formatierung. Zur Zeit hab ich folgende Datenpunkte vorbereitet:starttime?: string; // Start Uhrzeit HH:MM startdate?: string; // Start Datum DD.MM endtime?: string; // Endzeitpunkt enddate?: string; // Enddatum startdayofweek?: string; // Start Tag der Woche enddayofweek?: string; // End Tag der Woche headline?: string; // Schlagzeile description?: string; // Beschreibung weathertext?: string; // nur Zamg wetterbeschreibender Text ceiling?: string; // max höhe altitude?: string; // min höhe warnlevelname?: string; // Farbe des Levels text warnlevelnumber?: string; // Levelhöhe warnlevelcolor?: string; // RGB im Hexformat warntypename?: string; // gelieferter Warntype location?: string; // gelieferte Location (meinst Unsinn)Eine formatierte Nachricht könnte dann z.B. vorerst so aussehen:
Warnung: ${warntypename} am ${startdayofweek} um ${starttime} Stufe: ${warnlevelname}warntypename wird demnächst weider die alten deutschen Namen ausgeben. Muß mir da um die Übersetzen noch Gedanken machen, das gilt übrigends für alle was aktuell english ist. Da die Dienste recht viele Sprachen ausgeben, werde ich da nicht mehr nur bei Deutsch bleiben.
EDIT ich baue noch ZAMG für die Benutzerdefinierten Nachrichten ein. dauert wohl ne stunde.
Zum Adapter:
Gelb bedeutet keine Verbindung zum Server. Bzw. Es wurden beim letzten Verbindungsversuch keine Daten geliefert. Der Testmodus umgeht das alles und da keine Daten geliefert wurden geht der Adapter auf gelb. Im Testmodus werden nicht Daten vom Server geladen, sondern aus einer lokalen Datei.
Damit ihr direkt erkennt, dass der nicht im Online Modus ist.
Dachte das wäre sinnvoll das man nicht aus versehen den Testmodus an hat und sich über den Warnungsspam wundert. Die Testwarnungen werden mit zufälligen start und endzeiten versehen und wenn sie abgelaufen sind wieder erneuert.
EDIT: Soweit ich das verstanden habe: Rot kommt vom controller, Gelb bedeutet der Adapter hat info.connection im root auf false gesetzt.
Zum Adapter:
@ticaki
So OK für mich -
Zum Adapter:
Noch zusätzlich anzumerken ist, dass wenn kein Dienst daten liefert, geht der Adapter ebenfalls auf Gelb. Also alle Server down (unwahrscheinlich) oder keine Internetverbindung.
@ticaki
kleine Anregung: wäre es vielleicht sinnvoll einen eigenen Thread zu eröffnen, damit die Adapterentwicklung losgelöst vom script ist?@latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
@ticaki
kleine Anregung: wäre es vielleicht sinnvoll einen eigenen Thread zu eröffnen, damit die Adapterentwicklung losgelöst vom script ist?Ja schon, jedoch bis gestern hatte ich nur nen verbuggten Vorentwurf. Heute sieht der dann doch schon etwas funktionaler aus. Denkste er wäre schon soweit das man dazu nen Thread aufmachen?
@ticaki
@ticaki
Ja unter Kategorie Tester
@ticaki
