  4. VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam
30 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • N novregen
    reicht dir die Zusammenfassung ?
                         v.2023-06-20
       Static hostname: raspberrypi-td-2
             Icon name: computer
            Machine ID:
               Boot ID:
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/London (BST, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        304M        6.8G        1.0M        675M        7.4G
    Swap:            99M          0B         99M
    Total:          7.9G        304M        6.9G
    Active iob-Instances:   2
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi-td-2                         -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    Objects:                80
    States:                 60
    Size of iob-Database:
    7.7M    /opt/iobroker/iobroker-data/objects.jsonl
    480K    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    @novregen
    Aber das die Zeitzone nicht richtig ist sieht man auch hier schon.
      @novregen
      Nein, die Langfassung ist gefragt.
      N Offline
      N Offline
      novregen
      Skript v.2023-06-20
      *** BASE SYSTEM ***
               Icon name: computer
              Machine ID:
                 Boot ID:
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       21:00:36 up 36 min,  1 user,  load average: 0.10, 0.26, 0.20
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=55.5'C
      volt=0.9160V
      *** Time and Time Zones ***
                     Local time: Sat 2023-09-23 21:00:36 BST
                 Universal time: Sat 2023-09-23 20:00:36 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      td
      /home/td
      td adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        307M        6.8G        1.0M        675M        7.4G
      Swap:            99M          0B         99M
      Total:          7.9G        307M        6.9G
               7811 M total memory
                308 M used memory
                434 M active memory
                440 M inactive memory
               6827 M free memory
                 33 M buffer memory
                642 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      235G  2.6G  223G   2% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Sat Sep 23 20:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B7:E1:7F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7aac356f-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Sep 23 20:24:25 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Sep 23 20:24:25 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Sep 23 20:24:26 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      493M    /var/
      180M    /var/cache
      174M    /var/cache/apt
      147M    /var/lib
      122M    /var/lib/apt/lists
      Archived and active journals take up 64.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      23M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.10.1
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
      Objects and States
      Objects:        80
      States:         60
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12626      562/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15366      531/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2047       531/iobroker.js-con
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12628      562/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17088      979/io.admin.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12114      750/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1970       419/avahi-daemon: r
      udp        0      0 0.0.0.0:54511           0.0.0.0:*                           108        1972       419/avahi-daemon: r
      udp6       0      0 :::36722                :::*                                108        1973       419/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15407      750/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        1971       419/avahi-daemon: r
      2023-09-23 20:19:11.497  - info: host.raspberrypi-td-2 connected to Objects and States
      2023-09-23 20:19:11.525  - info: host.raspberrypi-td-2 Node.js version has changed from unknown to 18.17.1
      2023-09-23 20:19:11.574  - info: host.raspberrypi-td-2 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2023-09-23 20:19:11.592  - info: host.raspberrypi-td-2 added notifications configuration of host
      2023-09-23 20:19:12.013  - info: host.raspberrypi-td-2  no instances found
      2023-09-23 20:19:12.014  - info: host.raspberrypi-td-2 no instances found
      2023-09-23 20:19:12.246  - info: host.raspberrypi-td-2 Created UUID:
      2023-09-23 20:24:11.881  - info: host.raspberrypi-td-2 received SIGTERM
      2023-09-23 20:24:11.935  - info: host.raspberrypi-td-2 terminated
      2023-09-23 20:24:20.514  - info: host.raspberrypi-td-2 iobroker.js-controller version 4.0.24 js-controller starting
      2023-09-23 20:24:20.520  - info: host.raspberrypi-td-2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-09-23 20:24:20.522  - info: host.raspberrypi-td-2 hostname: raspberrypi-td-2, node: v18.17.1
      2023-09-23 20:24:20.522  - info: host.raspberrypi-td-2 ip addresses:
      2023-09-23 20:24:21.159  - info: host.raspberrypi-td-2 connected to Objects and States
      2023-09-23 20:24:21.200  - info: host.raspberrypi-td-2 added notifications configuration of host
      2023-09-23 20:24:21.809  - info: host.raspberrypi-td-2  no instances found
      2023-09-23 20:24:21.810  - info: host.raspberrypi-td-2 no instances found
      2023-09-23 20:40:45.922  - info: host.raspberrypi-td-2 instance system.adapter.admin.0 started with pid 979
      2023-09-23 20:40:48.400  - info: admin.0 (979) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 4.0.24
      2023-09-23 20:40:48.458  - info: admin.0 (979) requesting all objects
      2023-09-23 20:40:49.063  - info: admin.0 (979) received all objects
      2023-09-23 20:40:49.335  - info: admin.0 (979) socket.io server listening on port 8081
      2023-09-23 20:40:49.339  - info: admin.0 (979) http server listening on port 8081
      2023-09-23 20:40:49.339  - info: admin.0 (979) Use link "http://127.0.0.1:8081" to configure.
      2023-09-23 20:41:30.049  - info: admin.0 (979) ==> Connected system.user.admin from ::ffff:192.168.0.155
      • N novregen
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
                Machine ID:
                   Boot ID:
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=55.5'C
        volt=0.9160V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        td
        /home/td
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                  308 M used memory
                  434 M active memory
                 6827 M free memory
                   33 M buffer memory
                  642 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        493M    /var/
        180M    /var/cache
        174M    /var/cache/apt
        147M    /var/lib
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        80
        States:         60
        Pending Updates: 0
        @novregen sagte in VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam:
        Wenn ich das richtig sehe läuft der ioBroker nur unter der ipv6-Adresse.
        Warum auch immer.
        N 1 Antwort Letzte Antwort
          Warum auch immer.
          N Offline
          N Offline
          novregen
          das war ja schon die Ausgabe nachdem ich admin nachinstalliert hatte.
          Hier nochmal die Ausgabe nachdem ich Backitup Restore versucht haben. Kann es sein, das Backup und Neuinstallation zu verschieden sind ? Das Backup habe ich diesmal sogar lokal hinterlegt.
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                   Icon name: computer
                  Machine ID:
                     Boot ID:
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
           21:15:36 up 51 min,  1 user,  load average: 0.28, 0.41, 0.32
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=57.4'C
          volt=0.9160V
                         Local time: Sat 2023-09-23 21:15:36 BST
                     Universal time: Sat 2023-09-23 20:15:36 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          td
          /home/td
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        145M        6.6G        1.0M        1.0G        7.5G
          Swap:            99M          0B         99M
          Total:          7.9G        145M        6.7G
                   7811 M total memory
                    145 M used memory
                    306 M active memory
                    764 M inactive memory
                   6616 M free memory
                     38 M buffer memory
                   1010 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      235G  2.7G  223G   2% /
          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
          /var:
          536M    /var/
          180M    /var/cache
          174M    /var/cache/apt
          147M    /var/lib
          Archived and active journals take up 96.0M in the file system.
          101M    /opt/iobroker/backups/
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          "admin" not found
          Adapter State
          + instance is alive
          Objects and States
          Objects:        40
          States:         25
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23383      3556/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23376      3556/iobroker.js-co
          2023-09-23 21:12:48.424  - info: admin.0 (979) terminating http server on port 8081
          2023-09-23 21:12:48.425  - info: host.raspberrypi-td-2 stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-09-23 21:12:48.426  - info: host.raspberrypi-td-2 stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-09-23 21:12:48.428  - info: backitup.0 (3433) cleaned everything up...
          2023-09-23 21:12:48.439  - info: backitup.0 (3433) Got terminate signal TERMINATE_YOURSELF
          2023-09-23 21:12:48.441  - info: admin.0 (979) Got terminate signal TERMINATE_YOURSELF
          2023-09-23 21:12:48.446  - info: host.raspberrypi-td-2 stopInstance system.adapter.admin.0 send kill signal
          2023-09-23 21:12:48.448  - info: admin.0 (979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-09-23 21:12:48.448  - info: host.raspberrypi-td-2 stopInstance system.adapter.backitup.0 send kill signal
          2023-09-23 21:12:48.489  - info: backitup.0 (3433) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-09-23 21:12:48.994  - info: host.raspberrypi-td-2 instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-09-23 21:12:49.043  - info: host.raspberrypi-td-2 instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-09-23 21:12:49.043  - info: host.raspberrypi-td-2 All instances are stopped.
          2023-09-23 21:12:49.263  - info: host.raspberrypi-td-2 terminated
          2023-09-23 21:13:57.342  - info: host.raspberrypi-td-2 iobroker.js-controller version 4.0.24 js-controller starting
          2023-09-23 21:13:57.347  - info: host.raspberrypi-td-2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-09-23 21:13:57.348  - info: host.raspberrypi-td-2 hostname: raspberrypi-td-2, node: v18.17.1
          2023-09-23 21:13:57.349  - info: host.raspberrypi-td-2 ip addresses: 192.168.0.xx
          2023-09-23 21:13:58.070  - info: host.raspberrypi-td-2 connected to Objects and States
          2023-09-23 21:13:58.098  - info: host.raspberrypi-td-2 Node.js version has changed from unknown to 18.17.1
          2023-09-23 21:13:58.148  - info: host.raspberrypi-td-2 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
          2023-09-23 21:13:58.165  - info: host.raspberrypi-td-2 added notifications configuration of host
          2023-09-23 21:13:58.588  - info: host.raspberrypi-td-2  no instances found
          2023-09-23 21:13:58.589  - info: host.raspberrypi-td-2 no instances found
          2023-09-23 21:13:58.821  - info: host.raspberrypi-td-2 Created UUID: 30a9f509-f5ff-8a47-dccb-7dae55f78690
          N GlasfaserG HomoranH 3 Antworten Letzte Antwort
          • N novregen
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                     Icon name: computer
                    Machine ID:
                       Boot ID:
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=57.4'C
            volt=0.9160V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            td
            /home/td
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                      145 M used memory
                      306 M active memory
                     6616 M free memory
                       38 M buffer memory
                     1010 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            536M    /var/
            180M    /var/cache
            174M    /var/cache/apt
            147M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Adapter State
            + instance is alive
            Objects and States
            Objects:        40
            States:         25
            Pending Updates: 0
            N Offline
            N Offline
            novregen
            nach Backitup Restore Versuch kein Admin mehr und auch nichts wiederhergestellt
            td@raspberrypi-td-2:/opt/iobroker $ iobroker start admin
            Cannot find any instances of "admin"!
            • N novregen
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                       Icon name: computer
                      Machine ID:
                         Boot ID:
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=57.4'C
              volt=0.9160V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              td
              /home/td
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7811 M total memory
                        145 M used memory
                        306 M active memory
                       6616 M free memory
                         38 M buffer memory
                       1010 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              536M    /var/
              180M    /var/cache
              174M    /var/cache/apt
              147M    /var/lib
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Adapter State
              + instance is alive
              Objects and States
              Objects:        40
              States:         25
              Pending Updates: 0
              GlasfaserG Offline
              GlasfaserG Offline
              Hast du das Log nicht vollständig !´?
              Im Screenshot fehlt viel !
              • N novregen
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                        Machine ID:
                           Boot ID:
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=57.4'C
                volt=0.9160V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                td
                /home/td
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7811 M total memory
                          145 M used memory
                          306 M active memory
                         6616 M free memory
                           38 M buffer memory
                         1010 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                536M    /var/
                180M    /var/cache
                174M    /var/cache/apt
                147M    /var/lib
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Adapter State
                + instance is alive
                Objects and States
                Objects:        40
                States:         25
                Pending Updates: 0
                dann sollte es eine Meldung geben.
                Wie unterschiedlich sind die denn?
                  N Offline
                  N Offline
                  novregen
                  Das war die Ausgabe vom alten Pi
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Architecture    : armv7l
                  Docker          : false
                  Distributor ID: Raspbian
                  Description:    Raspbian GNU/Linux 10 (buster)
                  Release:        10
                  Codename:       buster
                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                   20:22:18 up 14 days,  3:38,  2 users,  load average: 0.91, 0.85, 0.77
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=62.3'C
                  volt=0.8500V
                                 Local time: Sun 2023-06-25 20:22:19 CEST
                             Universal time: Sun 2023-06-25 18:22:19 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           7.9G        2.8G        1.2G        241M        3.8G        5.2G
                  Swap:           99M         13M         86M
                  Total:         8.0G        2.9G        1.3G
                           7897 M total memory
                           2849 M used memory
                            911 M active memory
                           5502 M inactive memory
                           1226 M free memory
                            204 M buffer memory
                           3616 M swap cache
                             99 M total swap
                             13 M used swap
                             86 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G   25G  3.4G  88% /
                  devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                  tmpfs          tmpfs     3.9G  254M  3.7G   7% /run
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                  /dev/sda1      vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                  [Sun Jun 11 16:43:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:B7:E1:7F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=t        tyS0,115200 console=tty1 root=PARTUUID=0794ac31-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): INFO: recovery required on readonly f        ilesystem
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): write access will be enabled during r        ecovery
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): 8 orphan inodes deleted
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): recovery complete
                  [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null)
                  [Sun Jun 11 16:43:20 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                  [Sun Jun 11 16:43:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                  |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,io        charset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  707M    /var/
                  329M    /var/cache
                  317M    /var/cache/apt
                  258M    /var/cache/apt/archives
                  221M    /var/lib
                  Archived and active journals take up 253.4M in the file system.
                  17G     /opt/iobroker/backups/
                  1.1G    /opt/iobroker/iobroker-data/
                  540M    /opt/iobroker/iobroker-data/files
                  181M    /opt/iobroker/iobroker-data/files/vis.0
                  170M    /opt/iobroker/iobroker-data/backup-objects
                  78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                  181M    /opt/iobroker/iobroker-data/states.jsonl
                  35M     /opt/iobroker/iobroker-data/objects.jsonl
                  20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.m        ap
                  19M     /opt/iobroker/iobroker-data/objects.json.migrated
                  19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  /usr/bin/nodejs         v16.20.0
                  /usr/bin/node           v16.20.0
                  /usr/bin/npm            8.19.4
                  /usr/bin/npx            8.19.4
                  nodejs:
                    Installed: 16.20.0-deb-1nodesource1
                    Candidate: 16.20.1-deb-1nodesource1
                    Version table:
                       16.20.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                   *** 16.20.0-deb-1nodesource1 100
                       10.24.0~dfsg-1~deb10u3 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  js-controller:  5.0.4
                  admin:          6.4.3
                  javascript:     7.0.3
                  Adapters from github:   3
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 192.168.0.50, run as: admin
                  + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                    system.adapter.birthdays.0              : birthdays             : raspberrypi4                             -  enabled
                    system.adapter.bydhvs.0                 : bydhvs                : raspberrypi4                             - disabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4                             -  enabled
                  + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi4                             -  enabled
                  + system.adapter.fronius.0                : fronius               : raspberrypi4                             -  enabled
                  + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                  + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
                  + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi4                             -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi4                             - disabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi4                             -  enabled, port: 8086
                  + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                  + system.adapter.lovelace.0               : lovelace              : raspberrypi4                             -  enabled, port: 8091, bind: 192.168.0.50, run as: admin
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4                             -  enabled, port: 1883, bind: 192.168.0.50
                  + system.adapter.parser.0                 : parser                : raspberrypi4                             -  enabled
                  + system.adapter.pollenflug.0             : pollenflug            : raspberrypi4                             -  enabled
                  + system.adapter.pvforecast.0             : pvforecast            : raspberrypi4                             -  enabled
                  + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
                  + system.adapter.smartgarden.0            : smartgarden           : raspberrypi4                             -  enabled
                  + system.adapter.smartmeter.0             : smartmeter            : raspberrypi4                             -  enabled
                  + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4                             -  enabled
                  + system.adapter.statistics.0             : statistics            : raspberrypi4                             -  enabled
                    system.adapter.synology.0               : synology              : raspberrypi4                             - disabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4                             -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi4                             -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
                    system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi4                             -  enabled
                  + system.adapter.upnp.0                   : upnp                  : raspberrypi4                             -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi4                             - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
                    system.adapter.vis-history.0            : vis-history           : raspberrypi4                             - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                    system.adapter.vis-players.0            : vis-players           : raspberrypi4                             - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                  + system.adapter.vw-connect.0             : vw-connect            : raspberrypi4                             -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             -  enabled
                  + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Active repo(s): beta
                  Used repository: beta
                  Adapter    "admin"        : 6.5.9    , installed 6.4.3  [Updatable]
                  Adapter    "backitup"     : 2.6.23   , installed 2.6.17 [Updatable]
                  Adapter    "birthdays"    : 2.3.1    , installed 2.2.1  [Updatable]
                  Adapter    "bydhvs"       : 1.4.0    , installed 1.4.0
                  Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                  Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                  Adapter    "fronius"      : 2.0.1    , installed 1.1.3  [Updatable]
                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                  Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                  Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
                  Adapter    "hue"          : 3.9.3    , installed 3.7.1  [Updatable]
                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                  Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                  Adapter    "javascript"   : 7.1.1    , installed 7.0.3  [Updatable]
                  Controller "js-controller": 5.0.5    , installed 5.0.4  [Updatable]
                  Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                  Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                  Adapter    "parser"       : 2.0.5    , installed 1.3.2  [Updatable]
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "pvforecast"   : 2.7.1    , installed 2.6.0  [Updatable]
                  Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                  Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                  Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                  Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                  Adapter    "squeezeboxrpc": 1.3.10   , installed 1.3.10
                  Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                  Adapter    "synology"     : 2.1.13   , installed 2.1.13
                  Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.1  [Updatable]
                  Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vw-connect"   : 0.0.71   , installed 0.0.67 [Updatable]
                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter    "web"          : 5.5.3    , installed 5.5.3
                  Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                  Adapter    "ws"           : 2.3.6    , installed 2.3.6
                  Objects and States
                  Objects:        32959
                  States:         27495
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Get:4 https://repos.influxdata.com/debian buster InRelease [7038 B]
                  Err:4 https://repos.influxdata.com/debian buster InRelease
                  Fetched 7038 B in 1s (6057 B/s)
                  Pending Updates: 83
                  tcp        0      0 192.168.x.xx:2001       0.0.0.0:*               LISTEN      1001       2105323    6141/io.hm-rpc.0
                  tcp        0      0 192.168.x.xx:8081       0.0.0.0:*               LISTEN      1001       2103984    6020/io.admin.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15335      583/sshd
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4146706    24341/cupsd
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17405      528/influxd
                  tcp        0      0 192.168.x.xx:2010       0.0.0.0:*               LISTEN      1001       2108466    6182/io.hm-rpc.1
                  tcp        0      0 192.168.x.xx:8091       0.0.0.0:*               LISTEN      1001       2112006    7093/io.lovelace.0
                  tcp        0      0 192.168.x.xx:1883       0.0.0.0:*               LISTEN      1001       2104314    6251/io.mqtt.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2105173    6002/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2105166    6002/iobroker.js-co
                  tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          19944      393/node
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4423902    14478/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        20148      528/influxd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15337      583/sshd
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4146705    24341/cupsd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      110        20614      526/grafana-server
                  tcp6       0      0 :::61991                :::*                    LISTEN      1001       2107382    6565/io.harmony.0
                  tcp6       0      0 :::3500                 :::*                    LISTEN      0          19953      393/node
                  tcp6       0      0 :::3501                 :::*                    LISTEN      1001       4367805    10302/io.sonos.0
                  tcp6       0      0 :::3502                 :::*                    LISTEN      0          4367126    393/node
                  udp        0      0 0.0.0.0:48084           0.0.0.0:*                           1001       2108300    7074/io.upnp.0
                  udp        0      0 0.0.0.0:44513           0.0.0.0:*                           108        17454      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       2107383    6565/io.harmony.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17705      489/dhcpcd
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          4147878    24343/cups-browsed
                  udp        0      0 192.168.x.xx:5353       0.0.0.0:*                           1001       2107551    6189/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17452      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2110895    7074/io.upnp.0
                  udp6       0      0 :::546                  :::*                                0          17840      489/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        17453      391/avahi-daemon: r
                  udp6       0      0 :::50417                :::*                                108        17455      391/avahi-daemon: r
                  2023-06-25 20:21:12.320  - info: smartmeter.0 (6171) Received 22 values, 15 updated
                  2023-06-25 20:21:12.379  - debug: statistics.0 (6379) [STATE CHANGE] new abs max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.386  - debug: statistics.0 (6379) [STATE CHANGE] new day max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.393  - debug: statistics.0 (6379) [STATE CHANGE] new week max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.401  - debug: statistics.0 (6379) [STATE CHANGE] new month max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.407  - debug: statistics.0 (6379) [STATE CHANGE] new quarter max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.413  - debug: statistics.0 (6379) [STATE CHANGE] new year max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                  2023-06-25 20:21:12.413  - debug: statistics.0 (6379) [EXECUTING] sum delta smartmeter.0.1-0:2_8_0__255.value
                  2023-06-25 20:21:12.465  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.15Min on 0.0006 to 0.0011
                  2023-06-25 20:21:12.470  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.hour on 0.0006 to 0.0025
                  2023-06-25 20:21:12.476  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.day on 0.0006 to 29.081
                  2023-06-25 20:21:12.481  - debug: statistics.0 (6379) [STATE CHANGE] ======================= statistics.0.temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.day =======================
                  2023-06-25 20:21:12.481  - debug: statistics.0 (6379) [STATE CHANGE] stateChange => 29.081
                  2023-06-25 20:21:12.482  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.week on 0.0006 to 131.1018
                  2023-06-25 20:21:12.490  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.month on 0.0006 to 581.5877
                  2023-06-25 20:21:12.495  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.quarter on 0.0006 to 1564.6761
                  2023-06-25 20:21:12.501  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.year on 0.0006 to 1712.8164
                  2023-06-25 20:21:12.506  - debug: statistics.0 (6379) [EXECUTING] minmax smartmeter.0.1-0:2_8_0__255.value
                  2023-06-25 20:21:12.507  - debug: statistics.0 (6379) [STATE CHANGE] new last for "temp.minmax.smartmeter.0.1-0:2_8_0__255.value.last: 3778.228
                  2023-06-25 20:21:12.517  - debug: statistics.0 (6379) [STATE CHANGE] new abs max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  2023-06-25 20:21:12.524  - debug: statistics.0 (6379) [STATE CHANGE] new day max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  2023-06-25 20:21:12.529  - debug: statistics.0 (6379) [STATE CHANGE] new week max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  2023-06-25 20:21:12.535  - debug: statistics.0 (6379) [STATE CHANGE] new month max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  2023-06-25 20:21:12.541  - debug: statistics.0 (6379) [STATE CHANGE] new quarter max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  2023-06-25 20:21:12.546  - debug: statistics.0 (6379) [STATE CHANGE] new year max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                  • GlasfaserG Glasfaser
                    N Offline
                    N Offline
                    novregen
                    @glasfaser - leider habe ich nicht mehr, danach Kreisverkehr und keine Rückmeldung mehr. hier noch ein Screenshot vom Anfang von einem vorherigen Versuch, dort lag das Backup noch nicht lokal.
                    • N novregen
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        10
                      Codename:       buster
                      VERSION_ID="10"
                      ID=raspbian
                      ID_LIKE=debian
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=62.3'C
                      volt=0.8500V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           99M         13M         86M
                               7897 M total memory
                               2849 M used memory
                                911 M active memory
                               1226 M free memory
                                204 M buffer memory
                               3616 M swap cache
                                 99 M total swap
                                 13 M used swap
                                 86 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      707M    /var/
                      329M    /var/cache
                      317M    /var/cache/apt
                      221M    /var/lib
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.4.3
                      javascript:     7.0.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        32959
                      States:         27495
                      Pending Updates: 83
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Ahh ..
                      Bei der Neuinstallation solltest du
                      erstmal updaten
                      dann dein Restore !
                      • N novregen
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @novregen
                        Lese mal ;)
                          @novregen
                          Lese mal ;)
                          @glasfaser das war die gesuchte Meldung
                          @homoran sagte in VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam:
                            N Offline
                            N Offline
                            novregen
                            ist jetzt aktuell und das Restore sieht schon etwas anders aus, allerdings steht in den meisten Zeilen cannot restore.
                            Mal sehen ob da noch was vernünftiges bei rum kommt.
                            • N novregen
                              N Offline
                              N Offline
                              novregen
                              Jetzt habe ich wieder Kreisverkehr und iobroker ist wieder nicht erreichbar....
                              • N novregen
                                N Offline
                                N Offline
                                novregen
                                Ich mache morgen weiter, das macht mir zu viel schlechte Laune.
                                • N novregen
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Immer langsam .. das bekommen wir schon hin.
                                  Was mich nur Wundert , das dein System Uralt war und du nicht regelmäßich ein Update auch bei den Adaptern gemacht hast
                                  und dann auch noch mit BETA gespielt hast !?
                                    N Offline
                                    N Offline
                                    novregen
                                    @glasfaser
                                    ja gebe ich dir recht, das ich das nur sehr amateurhaft gemacht habe.
                                    Was ist denn jetzt das bessere - hier noch wieder versuchen auf dem Raspb4 - 8gb es zum laufen zu bringen.
                                    (habe zwei SSDs - stecke gleich die alte wieder dran somit ist erstmal nichts verloren)
                                    oder auf dem Beelink N5095 - 8 GB weiter zu machen. Proxmox läuft da und Homeassisten (testweise) - iobroker Maschine läuft dort auch, dann muss ich da auch mal gucken wegen dem js-controller und wie ich das Backup dort rauf kriege. Und wie man dann den Smartmeter USB tty dort durch bekommt.
                                    • N novregen
                                      @glasfaser
                                      N Offline
                                      N Offline
                                      novregen
                                      Ich bin jetzt nochmal in ruhe dabei gegangen und die Backitup Sicherung ist mit ok durchgelaufen, jetzt scheint es einige Zeit zu dauern, bis alle Adapter wieder drauf sind.
                                      Wie muss ich denn bzgl. Grafana und influxdb vorgehen ? Gesichert habe ich die auch über Backitup aber generell muss ich die ja bestimmt auch einmal neu installieren über putty/Konsole ? Oder
