  4. VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam
30 Beiträge 4 Kommentatoren 4.3k Aufrufe 4 Beobachtet
    @novregen
    Nein, die Langfassung ist gefragt.
    N Offline
    N Offline
    novregen
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: raspberrypi-td-2
             Icon name: computer
            Machine ID:
               Boot ID:
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:00:36 up 36 min,  1 user,  load average: 0.10, 0.26, 0.20
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=55.5'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Sat 2023-09-23 21:00:36 BST
               Universal time: Sat 2023-09-23 20:00:36 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    td
    /home/td
    td adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        307M        6.8G        1.0M        675M        7.4G
    Swap:            99M          0B         99M
    Total:          7.9G        307M        6.9G
             7811 M total memory
              308 M used memory
              434 M active memory
              440 M inactive memory
             6827 M free memory
               33 M buffer memory
              642 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      235G  2.6G  223G   2% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Sat Sep 23 20:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B7:E1:7F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7aac356f-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Sep 23 20:24:25 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Sep 23 20:24:25 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Sep 23 20:24:26 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    493M    /var/
    180M    /var/cache
    174M    /var/cache/apt
    147M    /var/lib
    122M    /var/lib/apt/lists
    Archived and active journals take up 64.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    23M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    7.7M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.10.1
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi-td-2                         -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Objects and States
    Objects:        80
    States:         60
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12626      562/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15366      531/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2047       531/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12628      562/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17088      979/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12114      750/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1970       419/avahi-daemon: r
    udp        0      0 0.0.0.0:54511           0.0.0.0:*                           108        1972       419/avahi-daemon: r
    udp6       0      0 :::36722                :::*                                108        1973       419/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15407      750/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1971       419/avahi-daemon: r
    2023-09-23 20:19:11.497  - info: host.raspberrypi-td-2 connected to Objects and States
    2023-09-23 20:19:11.525  - info: host.raspberrypi-td-2 Node.js version has changed from unknown to 18.17.1
    2023-09-23 20:19:11.574  - info: host.raspberrypi-td-2 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-09-23 20:19:11.592  - info: host.raspberrypi-td-2 added notifications configuration of host
    2023-09-23 20:19:12.013  - info: host.raspberrypi-td-2  no instances found
    2023-09-23 20:19:12.014  - info: host.raspberrypi-td-2 no instances found
    2023-09-23 20:19:12.246  - info: host.raspberrypi-td-2 Created UUID:
    2023-09-23 20:24:11.881  - info: host.raspberrypi-td-2 received SIGTERM
    2023-09-23 20:24:11.935  - info: host.raspberrypi-td-2 terminated
    2023-09-23 20:24:20.514  - info: host.raspberrypi-td-2 iobroker.js-controller version 4.0.24 js-controller starting
    2023-09-23 20:24:20.520  - info: host.raspberrypi-td-2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-09-23 20:24:20.522  - info: host.raspberrypi-td-2 hostname: raspberrypi-td-2, node: v18.17.1
    2023-09-23 20:24:20.522  - info: host.raspberrypi-td-2 ip addresses:
    2023-09-23 20:24:21.159  - info: host.raspberrypi-td-2 connected to Objects and States
    2023-09-23 20:24:21.200  - info: host.raspberrypi-td-2 added notifications configuration of host
    2023-09-23 20:24:21.809  - info: host.raspberrypi-td-2  no instances found
    2023-09-23 20:24:21.810  - info: host.raspberrypi-td-2 no instances found
    2023-09-23 20:40:45.922  - info: host.raspberrypi-td-2 instance system.adapter.admin.0 started with pid 979
    2023-09-23 20:40:48.400  - info: admin.0 (979) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 4.0.24
    2023-09-23 20:40:48.458  - info: admin.0 (979) requesting all objects
    2023-09-23 20:40:49.063  - info: admin.0 (979) received all objects
    2023-09-23 20:40:49.335  - info: admin.0 (979) socket.io server listening on port 8081
    2023-09-23 20:40:49.339  - info: admin.0 (979) http server listening on port 8081
    2023-09-23 20:40:49.339  - info: admin.0 (979) Use link "http://127.0.0.1:8081" to configure.
    2023-09-23 20:41:30.049  - info: admin.0 (979) ==> Connected system.user.admin from ::ffff:192.168.0.155
    • N novregen
      Skript v.2023-06-20
      *** BASE SYSTEM ***
               Icon name: computer
              Machine ID:
                 Boot ID:
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=55.5'C
      volt=0.9160V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      td
      /home/td
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
                308 M used memory
                434 M active memory
               6827 M free memory
                 33 M buffer memory
                642 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      493M    /var/
      180M    /var/cache
      174M    /var/cache/apt
      147M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        80
      States:         60
      Pending Updates: 0
      @novregen sagte in VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam:
      Wenn ich das richtig sehe läuft der ioBroker nur unter der ipv6-Adresse.
      Warum auch immer.
      N 1 Antwort Letzte Antwort
        Warum auch immer.
        N Offline
        N Offline
        novregen
        das war ja schon die Ausgabe nachdem ich admin nachinstalliert hatte.
        Hier nochmal die Ausgabe nachdem ich Backitup Restore versucht haben. Kann es sein, das Backup und Neuinstallation zu verschieden sind ? Das Backup habe ich diesmal sogar lokal hinterlegt.
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
                Machine ID:
                   Boot ID:
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
         21:15:36 up 51 min,  1 user,  load average: 0.28, 0.41, 0.32
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=57.4'C
        volt=0.9160V
                       Local time: Sat 2023-09-23 21:15:36 BST
                   Universal time: Sat 2023-09-23 20:15:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        td
        /home/td
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        145M        6.6G        1.0M        1.0G        7.5G
        Swap:            99M          0B         99M
        Total:          7.9G        145M        6.7G
                 7811 M total memory
                  145 M used memory
                  306 M active memory
                  764 M inactive memory
                 6616 M free memory
                   38 M buffer memory
                 1010 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      235G  2.7G  223G   2% /
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /var:
        536M    /var/
        180M    /var/cache
        174M    /var/cache/apt
        147M    /var/lib
        Archived and active journals take up 96.0M in the file system.
        101M    /opt/iobroker/backups/
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          "admin" not found
        Adapter State
        + instance is alive
        Objects and States
        Objects:        40
        States:         25
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Pending Updates: 0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23383      3556/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23376      3556/iobroker.js-co
        2023-09-23 21:12:48.424  - info: admin.0 (979) terminating http server on port 8081
        2023-09-23 21:12:48.425  - info: host.raspberrypi-td-2 stopInstance system.adapter.admin.0 (force=false, process=true)
        2023-09-23 21:12:48.426  - info: host.raspberrypi-td-2 stopInstance system.adapter.backitup.0 (force=false, process=true)
        2023-09-23 21:12:48.428  - info: backitup.0 (3433) cleaned everything up...
        2023-09-23 21:12:48.439  - info: backitup.0 (3433) Got terminate signal TERMINATE_YOURSELF
        2023-09-23 21:12:48.441  - info: admin.0 (979) Got terminate signal TERMINATE_YOURSELF
        2023-09-23 21:12:48.446  - info: host.raspberrypi-td-2 stopInstance system.adapter.admin.0 send kill signal
        2023-09-23 21:12:48.448  - info: admin.0 (979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-23 21:12:48.448  - info: host.raspberrypi-td-2 stopInstance system.adapter.backitup.0 send kill signal
        2023-09-23 21:12:48.489  - info: backitup.0 (3433) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-23 21:12:48.994  - info: host.raspberrypi-td-2 instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-09-23 21:12:49.043  - info: host.raspberrypi-td-2 instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-09-23 21:12:49.043  - info: host.raspberrypi-td-2 All instances are stopped.
        2023-09-23 21:12:49.263  - info: host.raspberrypi-td-2 terminated
        2023-09-23 21:13:57.342  - info: host.raspberrypi-td-2 iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-23 21:13:57.347  - info: host.raspberrypi-td-2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-23 21:13:57.348  - info: host.raspberrypi-td-2 hostname: raspberrypi-td-2, node: v18.17.1
        2023-09-23 21:13:57.349  - info: host.raspberrypi-td-2 ip addresses: 192.168.0.xx
        2023-09-23 21:13:58.070  - info: host.raspberrypi-td-2 connected to Objects and States
        2023-09-23 21:13:58.098  - info: host.raspberrypi-td-2 Node.js version has changed from unknown to 18.17.1
        2023-09-23 21:13:58.148  - info: host.raspberrypi-td-2 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2023-09-23 21:13:58.165  - info: host.raspberrypi-td-2 added notifications configuration of host
        2023-09-23 21:13:58.588  - info: host.raspberrypi-td-2  no instances found
        2023-09-23 21:13:58.589  - info: host.raspberrypi-td-2 no instances found
        2023-09-23 21:13:58.821  - info: host.raspberrypi-td-2 Created UUID: 30a9f509-f5ff-8a47-dccb-7dae55f78690
        N GlasfaserG HomoranH 3 Antworten Letzte Antwort
        • N novregen
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                   Icon name: computer
                  Machine ID:
                     Boot ID:
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=57.4'C
          volt=0.9160V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          td
          /home/td
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7811 M total memory
                    145 M used memory
                    306 M active memory
                   6616 M free memory
                     38 M buffer memory
                   1010 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          536M    /var/
          180M    /var/cache
          174M    /var/cache/apt
          147M    /var/lib
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Adapter State
          + instance is alive
          Objects and States
          Objects:        40
          States:         25
          Pending Updates: 0
          N Offline
          N Offline
          novregen
          nach Backitup Restore Versuch kein Admin mehr und auch nichts wiederhergestellt
          td@raspberrypi-td-2:/opt/iobroker $ iobroker start admin
          Cannot find any instances of "admin"!
          • N novregen
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                     Icon name: computer
                    Machine ID:
                       Boot ID:
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=57.4'C
            volt=0.9160V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            td
            /home/td
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                      145 M used memory
                      306 M active memory
                     6616 M free memory
                       38 M buffer memory
                     1010 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            536M    /var/
            180M    /var/cache
            174M    /var/cache/apt
            147M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Adapter State
            + instance is alive
            Objects and States
            Objects:        40
            States:         25
            Pending Updates: 0
            GlasfaserG Offline
            GlasfaserG Offline
            Hast du das Log nicht vollständig !´?
            Im Screenshot fehlt viel !
            • N novregen
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                       Icon name: computer
                      Machine ID:
                         Boot ID:
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=57.4'C
              volt=0.9160V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              td
              /home/td
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7811 M total memory
                        145 M used memory
                        306 M active memory
                       6616 M free memory
                         38 M buffer memory
                       1010 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              536M    /var/
              180M    /var/cache
              174M    /var/cache/apt
              147M    /var/lib
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Adapter State
              + instance is alive
              Objects and States
              Objects:        40
              States:         25
              Pending Updates: 0
              dann sollte es eine Meldung geben.
              Wie unterschiedlich sind die denn?
                N Offline
                N Offline
                novregen
                Das war die Ausgabe vom alten Pi
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Architecture    : armv7l
                Docker          : false
                Distributor ID: Raspbian
                Description:    Raspbian GNU/Linux 10 (buster)
                Release:        10
                Codename:       buster
                PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="10"
                VERSION="10 (buster)"
                VERSION_CODENAME=buster
                ID=raspbian
                ID_LIKE=debian
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                 20:22:18 up 14 days,  3:38,  2 users,  load average: 0.91, 0.85, 0.77
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=62.3'C
                volt=0.8500V
                               Local time: Sun 2023-06-25 20:22:19 CEST
                           Universal time: Sun 2023-06-25 18:22:19 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.9G        2.8G        1.2G        241M        3.8G        5.2G
                Swap:           99M         13M         86M
                Total:         8.0G        2.9G        1.3G
                         7897 M total memory
                         2849 M used memory
                          911 M active memory
                         5502 M inactive memory
                         1226 M free memory
                          204 M buffer memory
                         3616 M swap cache
                           99 M total swap
                           13 M used swap
                           86 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       29G   25G  3.4G  88% /
                devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                tmpfs          tmpfs     3.9G  254M  3.7G   7% /run
                tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                /dev/sda1      vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                [Sun Jun 11 16:43:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:B7:E1:7F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=t        tyS0,115200 console=tty1 root=PARTUUID=0794ac31-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): INFO: recovery required on readonly f        ilesystem
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): write access will be enabled during r        ecovery
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): 8 orphan inodes deleted
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): recovery complete
                [Sun Jun 11 16:43:20 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null)
                [Sun Jun 11 16:43:20 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                [Sun Jun 11 16:43:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,io        charset=ascii,shortname=mixed,errors=remount-ro
                /var:
                707M    /var/
                329M    /var/cache
                317M    /var/cache/apt
                258M    /var/cache/apt/archives
                221M    /var/lib
                Archived and active journals take up 253.4M in the file system.
                17G     /opt/iobroker/backups/
                1.1G    /opt/iobroker/iobroker-data/
                540M    /opt/iobroker/iobroker-data/files
                181M    /opt/iobroker/iobroker-data/files/vis.0
                170M    /opt/iobroker/iobroker-data/backup-objects
                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                181M    /opt/iobroker/iobroker-data/states.jsonl
                35M     /opt/iobroker/iobroker-data/objects.jsonl
                20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.m        ap
                19M     /opt/iobroker/iobroker-data/objects.json.migrated
                19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                /usr/bin/nodejs         v16.20.0
                /usr/bin/node           v16.20.0
                /usr/bin/npm            8.19.4
                /usr/bin/npx            8.19.4
                nodejs:
                  Installed: 16.20.0-deb-1nodesource1
                  Candidate: 16.20.1-deb-1nodesource1
                  Version table:
                     16.20.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                 *** 16.20.0-deb-1nodesource1 100
                     10.24.0~dfsg-1~deb10u3 500
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                js-controller:  5.0.4
                admin:          6.4.3
                javascript:     7.0.3
                Adapters from github:   3
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 192.168.0.50, run as: admin
                + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                  system.adapter.birthdays.0              : birthdays             : raspberrypi4                             -  enabled
                  system.adapter.bydhvs.0                 : bydhvs                : raspberrypi4                             - disabled
                  system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
                  system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4                             -  enabled
                + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi4                             -  enabled
                + system.adapter.fronius.0                : fronius               : raspberrypi4                             -  enabled
                + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
                + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
                  system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                  system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi4                             -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi4                             - disabled
                + system.adapter.influxdb.0               : influxdb              : raspberrypi4                             -  enabled, port: 8086
                + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                + system.adapter.lovelace.0               : lovelace              : raspberrypi4                             -  enabled, port: 8091, bind: 192.168.0.50, run as: admin
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4                             -  enabled, port: 1883, bind: 192.168.0.50
                + system.adapter.parser.0                 : parser                : raspberrypi4                             -  enabled
                + system.adapter.pollenflug.0             : pollenflug            : raspberrypi4                             -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : raspberrypi4                             -  enabled
                + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
                + system.adapter.smartgarden.0            : smartgarden           : raspberrypi4                             -  enabled
                + system.adapter.smartmeter.0             : smartmeter            : raspberrypi4                             -  enabled
                + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
                + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4                             -  enabled
                + system.adapter.statistics.0             : statistics            : raspberrypi4                             -  enabled
                  system.adapter.synology.0               : synology              : raspberrypi4                             - disabled, port: 5000
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4                             -  enabled
                + system.adapter.telegram.0               : telegram              : raspberrypi4                             -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
                  system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi4                             -  enabled
                + system.adapter.upnp.0                   : upnp                  : raspberrypi4                             -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi4                             - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi4                             - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                  system.adapter.vis-players.0            : vis-players           : raspberrypi4                             - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
                  system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                + system.adapter.vw-connect.0             : vw-connect            : raspberrypi4                             -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             -  enabled
                + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                Active repo(s): beta
                Used repository: beta
                Adapter    "admin"        : 6.5.9    , installed 6.4.3  [Updatable]
                Adapter    "backitup"     : 2.6.23   , installed 2.6.17 [Updatable]
                Adapter    "birthdays"    : 2.3.1    , installed 2.2.1  [Updatable]
                Adapter    "bydhvs"       : 1.4.0    , installed 1.4.0
                Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                Adapter    "fronius"      : 2.0.1    , installed 1.1.3  [Updatable]
                Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                Adapter    "history"      : 2.2.4    , installed 2.2.4
                Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
                Adapter    "hue"          : 3.9.3    , installed 3.7.1  [Updatable]
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                Adapter    "javascript"   : 7.1.1    , installed 7.0.3  [Updatable]
                Controller "js-controller": 5.0.5    , installed 5.0.4  [Updatable]
                Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                Adapter    "parser"       : 2.0.5    , installed 1.3.2  [Updatable]
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "pvforecast"   : 2.7.1    , installed 2.6.0  [Updatable]
                Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "squeezeboxrpc": 1.3.10   , installed 1.3.10
                Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                Adapter    "synology"     : 2.1.13   , installed 2.1.13
                Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.1  [Updatable]
                Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                Adapter    "vw-connect"   : 0.0.71   , installed 0.0.67 [Updatable]
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "web"          : 5.5.3    , installed 5.5.3
                Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "ws"           : 2.3.6    , installed 2.3.6
                Objects and States
                Objects:        32959
                States:         27495
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                Get:4 https://repos.influxdata.com/debian buster InRelease [7038 B]
                Err:4 https://repos.influxdata.com/debian buster InRelease
                Fetched 7038 B in 1s (6057 B/s)
                Pending Updates: 83
                tcp        0      0 192.168.x.xx:2001       0.0.0.0:*               LISTEN      1001       2105323    6141/io.hm-rpc.0
                tcp        0      0 192.168.x.xx:8081       0.0.0.0:*               LISTEN      1001       2103984    6020/io.admin.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15335      583/sshd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4146706    24341/cupsd
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17405      528/influxd
                tcp        0      0 192.168.x.xx:2010       0.0.0.0:*               LISTEN      1001       2108466    6182/io.hm-rpc.1
                tcp        0      0 192.168.x.xx:8091       0.0.0.0:*               LISTEN      1001       2112006    7093/io.lovelace.0
                tcp        0      0 192.168.x.xx:1883       0.0.0.0:*               LISTEN      1001       2104314    6251/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2105173    6002/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2105166    6002/iobroker.js-co
                tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          19944      393/node
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4423902    14478/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        20148      528/influxd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15337      583/sshd
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4146705    24341/cupsd
                tcp6       0      0 :::3000                 :::*                    LISTEN      110        20614      526/grafana-server
                tcp6       0      0 :::61991                :::*                    LISTEN      1001       2107382    6565/io.harmony.0
                tcp6       0      0 :::3500                 :::*                    LISTEN      0          19953      393/node
                tcp6       0      0 :::3501                 :::*                    LISTEN      1001       4367805    10302/io.sonos.0
                tcp6       0      0 :::3502                 :::*                    LISTEN      0          4367126    393/node
                udp        0      0 0.0.0.0:48084           0.0.0.0:*                           1001       2108300    7074/io.upnp.0
                udp        0      0 0.0.0.0:44513           0.0.0.0:*                           108        17454      391/avahi-daemon: r
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       2107383    6565/io.harmony.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17705      489/dhcpcd
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          4147878    24343/cups-browsed
                udp        0      0 192.168.x.xx:5353       0.0.0.0:*                           1001       2107551    6189/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17452      391/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2110895    7074/io.upnp.0
                udp6       0      0 :::546                  :::*                                0          17840      489/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        17453      391/avahi-daemon: r
                udp6       0      0 :::50417                :::*                                108        17455      391/avahi-daemon: r
                2023-06-25 20:21:12.320  - info: smartmeter.0 (6171) Received 22 values, 15 updated
                2023-06-25 20:21:12.379  - debug: statistics.0 (6379) [STATE CHANGE] new abs max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.386  - debug: statistics.0 (6379) [STATE CHANGE] new day max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.393  - debug: statistics.0 (6379) [STATE CHANGE] new week max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.401  - debug: statistics.0 (6379) [STATE CHANGE] new month max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.407  - debug: statistics.0 (6379) [STATE CHANGE] new quarter max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.413  - debug: statistics.0 (6379) [STATE CHANGE] new year max for "smartmeter.0.1-0:1_8_0__255.value: 3525.2411
                2023-06-25 20:21:12.413  - debug: statistics.0 (6379) [EXECUTING] sum delta smartmeter.0.1-0:2_8_0__255.value
                2023-06-25 20:21:12.465  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.15Min on 0.0006 to 0.0011
                2023-06-25 20:21:12.470  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.hour on 0.0006 to 0.0025
                2023-06-25 20:21:12.476  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.day on 0.0006 to 29.081
                2023-06-25 20:21:12.481  - debug: statistics.0 (6379) [STATE CHANGE] ======================= statistics.0.temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.day =======================
                2023-06-25 20:21:12.481  - debug: statistics.0 (6379) [STATE CHANGE] stateChange => 29.081
                2023-06-25 20:21:12.482  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.week on 0.0006 to 131.1018
                2023-06-25 20:21:12.490  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.month on 0.0006 to 581.5877
                2023-06-25 20:21:12.495  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.quarter on 0.0006 to 1564.6761
                2023-06-25 20:21:12.501  - debug: statistics.0 (6379) [STATE CHANGE] Increase temp.sumDelta.smartmeter.0.1-0:2_8_0__255.value.year on 0.0006 to 1712.8164
                2023-06-25 20:21:12.506  - debug: statistics.0 (6379) [EXECUTING] minmax smartmeter.0.1-0:2_8_0__255.value
                2023-06-25 20:21:12.507  - debug: statistics.0 (6379) [STATE CHANGE] new last for "temp.minmax.smartmeter.0.1-0:2_8_0__255.value.last: 3778.228
                2023-06-25 20:21:12.517  - debug: statistics.0 (6379) [STATE CHANGE] new abs max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                2023-06-25 20:21:12.524  - debug: statistics.0 (6379) [STATE CHANGE] new day max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                2023-06-25 20:21:12.529  - debug: statistics.0 (6379) [STATE CHANGE] new week max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                2023-06-25 20:21:12.535  - debug: statistics.0 (6379) [STATE CHANGE] new month max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                2023-06-25 20:21:12.541  - debug: statistics.0 (6379) [STATE CHANGE] new quarter max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                2023-06-25 20:21:12.546  - debug: statistics.0 (6379) [STATE CHANGE] new year max for "smartmeter.0.1-0:2_8_0__255.value: 3778.228
                • GlasfaserG Glasfaser
                  N Offline
                  N Offline
                  novregen
                  @glasfaser - leider habe ich nicht mehr, danach Kreisverkehr und keine Rückmeldung mehr. hier noch ein Screenshot vom Anfang von einem vorherigen Versuch, dort lag das Backup noch nicht lokal.
                  • N novregen
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        10
                    Codename:       buster
                    VERSION_ID="10"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=62.3'C
                    volt=0.8500V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           99M         13M         86M
                             7897 M total memory
                             2849 M used memory
                              911 M active memory
                             1226 M free memory
                              204 M buffer memory
                             3616 M swap cache
                               99 M total swap
                               13 M used swap
                               86 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    707M    /var/
                    329M    /var/cache
                    317M    /var/cache/apt
                    221M    /var/lib
                    /usr/bin/npm            8.19.4
                    /usr/bin/npx            8.19.4
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.4.3
                    javascript:     7.0.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        32959
                    States:         27495
                    Pending Updates: 83
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Ahh ..
                    Bei der Neuinstallation solltest du
                    erstmal updaten
                    dann dein Restore !
                    • N novregen
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @novregen
                      Lese mal ;)
                        @novregen
                        Lese mal ;)
                        @glasfaser das war die gesuchte Meldung
                        @homoran sagte in VIS Iobroker Anzeige/Ladefehler - Vis + iobroker langsam:
                          N Offline
                          N Offline
                          novregen
                          ist jetzt aktuell und das Restore sieht schon etwas anders aus, allerdings steht in den meisten Zeilen cannot restore.
                          Mal sehen ob da noch was vernünftiges bei rum kommt.
                          • N novregen
                            N Offline
                            N Offline
                            novregen
                            Jetzt habe ich wieder Kreisverkehr und iobroker ist wieder nicht erreichbar....
                            • N novregen
                              N Offline
                              N Offline
                              novregen
                              Ich mache morgen weiter, das macht mir zu viel schlechte Laune.
                              • N novregen
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Immer langsam .. das bekommen wir schon hin.
                                Was mich nur Wundert , das dein System Uralt war und du nicht regelmäßich ein Update auch bei den Adaptern gemacht hast
                                und dann auch noch mit BETA gespielt hast !?
                                  N Offline
                                  N Offline
                                  novregen
                                  @glasfaser
                                  ja gebe ich dir recht, das ich das nur sehr amateurhaft gemacht habe.
                                  Was ist denn jetzt das bessere - hier noch wieder versuchen auf dem Raspb4 - 8gb es zum laufen zu bringen.
                                  (habe zwei SSDs - stecke gleich die alte wieder dran somit ist erstmal nichts verloren)
                                  oder auf dem Beelink N5095 - 8 GB weiter zu machen. Proxmox läuft da und Homeassisten (testweise) - iobroker Maschine läuft dort auch, dann muss ich da auch mal gucken wegen dem js-controller und wie ich das Backup dort rauf kriege. Und wie man dann den Smartmeter USB tty dort durch bekommt.
                                  • N novregen
                                    @glasfaser
                                    N Offline
                                    N Offline
                                    novregen
                                    Ich bin jetzt nochmal in ruhe dabei gegangen und die Backitup Sicherung ist mit ok durchgelaufen, jetzt scheint es einige Zeit zu dauern, bis alle Adapter wieder drauf sind.
                                    Wie muss ich denn bzgl. Grafana und influxdb vorgehen ? Gesichert habe ich die auch über Backitup aber generell muss ich die ja bestimmt auch einmal neu installieren über putty/Konsole ? Oder
